H131CBC-120
H131CBC-120
    BIVAR
    H131CBC-120
H131CBC-120 数据手册
ITEM Q'TY 1 1 H-131C-1-XXX T-1 (3mm) LED Holder, 90° Mount, Var. C/L 2 1 3BC-X T-1 (3mm) N-Flange Shouldered Bi-Color LED, See Page 2 PART NUMBER REV. PART DESCRIPTION DATE APPROVED 01/11/11 06/20/16 T. Y. J. C. DESCRIPTION A Engineering Release B Engineering Update w/o Changes 2 1 0.084 [2.1mm] 0.240 [6.1mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] L C/L POLARITY I.D. 0.157 [4.0mm] 0.100 [2.5mm] 0.020 [0.5mm] SQ. TYP. 0.210 [5.3mm] LED P/N (1) CATHODE 3BC GREEN 3BC-A/G GREEN 3BC-R/Y YELLOW 3BC-Y/G GREEN (2) CATHODE RED AMBER RED YELLOW Available Centerlines XXX C/L L 120 .120 (3.0) .250 (6.4) 140 .140 (3.6) .270 (6.9) 160 .160 (4.1) .290 (7.4) 180 .180 (4.6) .310 (7.9) Holder Face 0.210 [5.3mm] Ø.032+.003 -.002 0.100 [2.5mm] LED Lead Recommended Mounting Holes STANDARD TOLERANCE ABSOLUTE MAXIMUM RATINGS (Ta=25° C) ( UNLESS OTHERWISE SPECIFIED ) REVERSE VOLTAGE .X .XX .XXX REVERSE CURRENT DECIMALS ± .1 ± .02 ± .010 ANGULAR X° ± 1° ® 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: OPERATING TEMPERATURE RANGE DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) M. Myers CHECKED: T. Yin DATE: 01/11/11 DATE: 01/11/11 FAX: (949) 951-3974 T-1 (3MM) 90° SINGLE-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H131CBC-XX-XXX CAGE CODE : 32559 B SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. H131CBC-XXX H131CBC-A/G-XXX H131CBC-R/Y-XXX H131CBC-Y/G-XXX Peak Wave Length λ p(nm ) Electro-Optical Data @ 20m A Em itted Color 625 RED 568 GREEN 605 AMBER 568 GREEN 625 RED 590 YELLOW 590 YELLOW 568 GREEN Lens Appearance WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED WHITE DIFFUSED TYP TYP MAX TYP View ing Angle 2 ½ (Deg) 20 2.0 2.8 6 45 20 2.1 2.8 6 45 20 2.0 2.8 6 45 20 2.1 2.8 6 45 20 2.0 2.8 6 45 20 2.0 2.8 4 45 20 2.0 2.8 4 45 20 2.1 2.8 6 45 Vf (V) If (m A) Iv (m cd) LED P/N 3BC 3BC-A/G 3BC-R/Y 3BC-Y/G STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: M. Myers CHECKED: T. Yin DATE: 01/11/11 DATE: 01/11/11 FAX: (949) 951-3974 T-1 (3MM) 90° SINGLE-LEVEL VAR. C/L LED ASSY REVISION: PART NO: H131CBC-XX-XXX CAGE CODE : 32559 B SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H131CBC-120 价格&库存
很抱歉,暂时无法提供与“H131CBC-120”相匹配的价格&库存,您可以联系我们找货
