H200CYGDL
H200CYGDL
    BIVAR
    发光二极管/LED 黄色,翠绿色 4mcd,6mcd
H200CYGDL 数据手册
REV. ITEM Q'TY 1 1 H-200C T-1 (3mm) Bi-Level LED Holder, 90° Mount, Interlocking 2 2 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Page 2 PART NUMBER PART DESCRIPTION 1 DESCRIPTION B Added H200CRDL & H200CSRDL C Added H200BWC D Corrected Recommended Hole Pattern E LED Package Change to 3XX-S LEDs F Added P/N Designation G Engineering Update w/o Changes 2 DATE APPROVED 03/25/05 02/14/07 03/28/07 12/14/07 04/02/12 06/21/16 M. C. M. C. M. C. M. C. T. Y. J. C. 0.069 [1.8mm] TYP. 0.320 [8.1mm] 0.180 [4.6mm] Ø.118 [Ø3.0mm] 0.285 [7.2mm] 0.300 [7.6mm] 0.380 [9.7mm] 0.100 [2.5mm] 0.100 [2.5mm] Cathode I.D. Mark 0.157 [4.0mm] 0.020 [0.5mm] SQ. TYP. 0.195 [5.0mm] 0.295 [7.5mm] NOTE: P/N DESIGNATION H200CXXDX Holder Face 0.195 [5.0mm] Ø.032+.003 -.002TYP. 0.100 [2.5mm] H-400 Holder Series - " " Standard LED - "L" Low Current LED - "5V" 5V LED Color of top LED - Use "X" if blank 0.100 [2.5mm] LED Lead Recommended Mounting Holes Color of Bottom LED - Use "X" if blank Lens Appearance -If LEDs are the same, use e.g. H200CGD All Green Diffused LEDs ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 03/05/04 DATE: 03/05/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) INTERLOCKING 90° BI-LEVEL LED ASSY REVISION: H200CXX CAGE CODE : 32559 G SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. STANDARD H200CBWD H200CBWC H200CGD H200CYD H200CHD H200CRD H200CSRD LOW CURRENT H200CGDL H200CYDL H200CHDL H200CRDL H200CSRDL 5 VOLT H200CGD5V H200CYD5V H200CHD5V Electro-Optical Data Peak Wave Length λ p(nm ) Em itted Color 430 430 565 585 635 655 660 BLUE BLUE GREEN YELLOW HE RED RED SUPER RED 565 585 635 655 660 GREEN YELLOW HE RED RED SUPER RED 565 585 635 GREEN YELLOW HE RED View ing Angle Lens Vf 2 ½ Appearance If Iv (V) (m A) (m cd) (Deg) TYP TYP MAX TYP Data @ 20m A DIFFUSED 20 4.0 4.5 20 45 WATER CLEAR 20 4.0 4.5 50 30 DIFFUSED 20 2.2 2.6 30 45 DIFFUSED 20 2.1 2.6 20 45 DIFFUSED 20 2.0 2.6 30 45 DIFFUSED 20 1.7 2.0 6 45 DIFFUSED 20 1.7 2.6 90 45 Data @ 2m A DIFFUSED 2 1.9 2.2 6 45 DIFFUSED 2 1.9 2.2 4 45 DIFFUSED 2 1.8 2.2 6 45 DIFFUSED 2 1.9 2.2 1 45 DIFFUSED 2 1.6 2.0 14 45 Data @ 5V DIFFUSED 10 5.0 30 45 DIFFUSED 10 5.0 20 45 DIFFUSED 10 5.0 30 45 LED P/N 3BWD-S 3BWC-S 3GD-S 3YD-S 3HD-S 3RD-S 3SRD-S 3GDL-S 3YDL-S 3HDL-S 3RDL-S 3SRDL-S 3GD5V-S 3YD5V-S 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/05/04 DATE: 03/05/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) INTERLOCKING 90° BI-LEVEL LED ASSY REVISION: H200CXX CAGE CODE : 32559 G SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H200CYGDL 价格&库存
很抱歉,暂时无法提供与“H200CYGDL”相匹配的价格&库存,您可以联系我们找货
H200CYGDL
    • 1+9.16920
    • 200+3.66120
    • 500+3.54240
    • 1000+3.47760
    H200CYGDL
