ELM5480R5BC
ELM5480R5BC
    BIVAR
    发光二极管/LED 红色,翠绿色 4mcd,3mcd
ELM5480R5BC 数据手册
PART NUMBER REV. ITEM Q'TY 1 1 R5BC 2 x 5mm Rectangular LED 2 1 ELM 5-480 Extruded, Self-Retaining Narrow LED Spacer PART DESCRIPTION DESCRIPTION A B C Engineering Release LED Lens Appearance Update Engineering Update w/o Changes DATE APPROVED 04/02/10 04/14/10 05/25/16 T. Y. T. Y. J. C. 0.480 [12.2mm] 0.274 [7.0mm] Ø.032+.003 TYP.-.002 0.520 [13.2mm] REF. 0.075 [1.9mm] 0.020 [0.5mm]SQ. TYP. 2 0.100 [2.5mm] 2 0.100 [2.5mm] Ø.155 [Ø3.9mm] 1 1 0.197 [5.0mm] 1 Recommended Mounting Holes LONG LEAD 2 (1) Cathode (2) Cathode Green Emitted Color Chip Peak Wave Length Absolute Max. Ratings RED λ p (nm) 625 GaAsP/GaP GREEN 568 GaP/GaP Material Lens Appearance WHITE DIFFUSED ABSOLUTE MAXIMUM RATINGS (Ta=25 C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE Electro-Optical Data @ 20mA Viewing Iv Vf Angle (mcd) (V) 2 ½ (Deg) TYP MAX TYP Pd If Peak (mW) (mA) If(mA) 80 30 150 2.0 2.8 4 80 30 150 2.1 2.8 3 LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) 120 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE Red R. Paje CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 EXTRUDED VERTICAL RCT 2X5 LED NARROW SPACER PROFILE ASSY TITLE: DATE: 04/02/10 DATE: 04/02/10 REVISION: PART NO: ELM5480R5BC CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
ELM5480R5BC 价格&库存
很抱歉,暂时无法提供与“ELM5480R5BC”相匹配的价格&库存,您可以联系我们找货
