H101CSGC
H101CSGC
    BIVAR
    插件
    发光二极管/LED 翠绿色 插件 50mcd
H101CSGC 数据手册
REV. PART DESCRIPTION ITEM Q'TY 1 1 H-101C T-1 (3mm) LED Holder 90° Mount, Single-Station 2 1 3SGC-S T-1 (3mm) Shouldered LED PART NUMBER 1 DESCRIPTION A Engineering Release B Updated Shouldered LED C Engineering Update w/o Changes DATE APPROVED 08/08/06 04/13/09 06/20/16 M. C. T. Y. J. C. 2 0.091 [2.3mm] 0.250 [6.4mm] 0.170 [4.3mm] Ø.118 [Ø3.0mm] Holder Face 0.100 [2.5mm] LED Lead Ø.032+.003 -.002 TYP. 0.185 [4.7mm] 0.285 [7.2mm] 0.200 [5.1mm] Cathode I.D. Mark 0.100 [2.5mm] Recommended Mounting Holes 0.157 [4.0mm] 0.020 [0.5mm] SQ. TYP. 0.185 [4.7mm] Chip LED P/N 3SGC-S Absolute Max. Ratings Em itted Color Peak Wavelength λp (nm ) SUPER GREEN 568 Lens Appearance ∆λ (nm ) Pd (m W) If (m A) Peak If (m A) - 80 30 150 WATER CLEAR ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) Electro-Optical Data @ 20m A Vf (V) Iv (m cd) TYP MAX TYP 2.1 2.8 50 View ing Angle (Deg) 30 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: S. Dam CHECKED: T. Yin ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 08/08/06 DATE: 08/08/06 T-1 (3MM) 90° SINGLE-LEVEL LED ASSEMBLY REVISION: PART NO: H101CSGC CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H101CSGC 价格&库存
很抱歉,暂时无法提供与“H101CSGC”相匹配的价格&库存,您可以联系我们找货
H101CSGC
  • 1+9.435281+1.22040
  • 10+7.8540010+1.01587
  • 100+6.28145100+0.81247
  • 250+5.65244250+0.73111
  • 500+5.33793500+0.69043
  • 1000+4.866161000+0.62941
  • 2000+4.394402000+0.56839
  • 4000+4.079894000+0.52771
H101CSGC
  • 1+8.75352
  • 10+7.28622
  • 100+5.82730
  • 250+5.24397
  • 500+4.95171
  • 1000+4.51451
  • 2000+4.07731
  • 4000+3.78505
