REV.
ITEM
Q'TY
1
1
H-301C-1-XXX
T-1 (3mm) Bi-Level LED Holder, 90° Mount, Var. C/L
2
2
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Page 2
PART NUMBER
PART DESCRIPTION
1
DESCRIPTION
A Engineering Update w/o Changes
B LED Package Change to 3XX-S LEDs
C Added H301CSRC-XXX Spec
D Added P/N Designation Note
E Engineering Update w/o Changes
DATE
APPROVED
03/10/04
12/14/07
03/04/08
08/19/09
06/24/16
M. C.
M. C.
M. C.
T. Y.
J. C.
2
0.094 [2.4mm] TYP.
0.170 [4.3mm]
0.320 [8.1mm]
Ø.118 [Ø3.0mm]
TYP.
PART NUMBER DESIGNATION
C/L 2
L
H301CRGD-160*
* XXX = Centerline "C/L"
Centerline "C/L1"
LED Lens Appearance
Color of Bottom LED
-Use "X" if blank
Color of Top LED
-Use "X" if blank
Series
C/L 1
0.100 [2.5mm]
Cathode I.D.
Mark
0.157 [4.0mm]
0.285 [7.2mm]
0.185 [4.7mm]
0.020 [0.5mm]
SQ. TYP.
-If all LEDs are the same,
use e.g. H301CRD-100
All Red LEDs
Holder Face
0.185 [4.7mm]
Ø.032+.003
-.002
TYP.
0.100 [2.5mm]
TYP.
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
XXX
100
120
140
160
180
Available Centerlines
C/L 1
C/L 2
L
.100 (2.5) .300 (7.6) .415 (10.6)
.120 (3.0) .320 (8.1) .435 (11.0)
.140 (3.6) .340 (8.6) .455 (11.6)
.160 (4.1) .360 (9.1) .475 (12.1)
.180 (4.6) .380 (9.7) .495 (12.6)
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
03/10/04
DATE:
03/10/04
PART NO:
FAX: (949) 951-3974
T-1 (3MM) 90° BI-LEVEL
VAR. C/L LED ASSY
REVISION:
H301CXX-XXX
CAGE CODE : 32559
E
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
Peak Wave
Length
λ p(nm )
Electro-Optical Data
Em itted Color
Lens
Appearance
MAX
TYP
If
(m A)
TYP
STANDARD
TYP
View ing
Angle
2 ½
(Deg)
Iv
(m cd)
Vf
(V)
LED P/N
Data @ 20m A
H301CBWD-XXX
430
BLUE
DIFFUSED
4.5
10
40
3BWD-S
H301CGD-XXX
568
GREEN
DIFFUSED
2.8
25
40
3GD-S
H301CSGC-XXX
568
SUPER GREEN
WATER CLEAR
2.8
50
30
3SGC-S
H301CSGD-XXX
568
SUPER GREEN
DIFFUSED
2.8
30
40
3SGD-S
H301CSGT-XXX
568
SUPER GREEN
TINTED
2.8
50
30
3SGT-S
H301CYD-XXX
590
YELLOW
DIFFUSED
2.8
3YD-S
H301CHD-XXX
625
HE RED
DIFFUSED
2.8
30
40
3HD-S
H301CRD-XXX
700
RED
DIFFUSED
2.8
2
40
3RD-S
H301CSRD-XXX
645
SUPER RED
DIFFUSED
2.4
40
40
3SRD-S
H301CSRC-XXX
645
SUPER RED
WATER CLEAR
2.4
60
30
3SRC-S
LOW CURRENT
Data @ 2m A
H301CGDL-XXX
568
GREEN
DIFFUSED
2
2.1
2.6
2
40
3GDL-S
H301CYDL-XXX
590
YELLOW
DIFFUSED
2
2.0
2.6
2
40
3YDL-S
H301CHDL-XXX
625
HE RED
DIFFUSED
2
2.0
2.6
3
40
3HDL-S
5 VOLT
Data @ 5V
H301CGD5V-XXX
568
GREEN
DIFFUSED
8
5.0
25
40
3GD5V-S
H301CYD5V-XXX
590
YELLOW
DIFFUSED
8
5.0
3YD5V-S
H301CHD5V-XXX
625
HE RED
DIFFUSED
8
5.0
30
40
3HD5V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/10/04
DATE:
03/10/04
PART NO:
FAX: (949) 951-3974
VAR. C/L LED ASSY
REVISION:
H301CXX-XXX
CAGE CODE : 32559
E
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H301CHDL-120”相匹配的价格&库存,您可以联系我们找货
