H301CYDL-100
H301CYDL-100
    BIVAR
    发光二极管/LED 黄色 2mcd
H301CYDL-100 数据手册
REV. ITEM Q'TY 1 1 H-301C-1-XXX T-1 (3mm) Bi-Level LED Holder, 90° Mount, Var. C/L 2 2 3XX-S T-1 (3mm) N-Flange Shouldered LED, See Page 2 PART NUMBER PART DESCRIPTION 1 DESCRIPTION A Engineering Update w/o Changes B LED Package Change to 3XX-S LEDs C Added H301CSRC-XXX Spec D Added P/N Designation Note E Engineering Update w/o Changes DATE APPROVED 03/10/04 12/14/07 03/04/08 08/19/09 06/24/16 M. C. M. C. M. C. T. Y. J. C. 2 0.094 [2.4mm] TYP. 0.170 [4.3mm] 0.320 [8.1mm] Ø.118 [Ø3.0mm] TYP. PART NUMBER DESIGNATION C/L 2 L H301CRGD-160* * XXX = Centerline "C/L" Centerline "C/L1" LED Lens Appearance Color of Bottom LED -Use "X" if blank Color of Top LED -Use "X" if blank Series C/L 1 0.100 [2.5mm] Cathode I.D. Mark 0.157 [4.0mm] 0.285 [7.2mm] 0.185 [4.7mm] 0.020 [0.5mm] SQ. TYP. -If all LEDs are the same, use e.g. H301CRD-100 All Red LEDs Holder Face 0.185 [4.7mm] Ø.032+.003 -.002 TYP. 0.100 [2.5mm] TYP. 0.100 [2.5mm] LED Lead Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE XXX 100 120 140 160 180 Available Centerlines C/L 1 C/L 2 L .100 (2.5) .300 (7.6) .415 (10.6) .120 (3.0) .320 (8.1) .435 (11.0) .140 (3.6) .340 (8.6) .455 (11.6) .160 (4.1) .360 (9.1) .475 (12.1) .180 (4.6) .380 (9.7) .495 (12.6) STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DATE: 03/10/04 DATE: 03/10/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) 90° BI-LEVEL VAR. C/L LED ASSY REVISION: H301CXX-XXX CAGE CODE : 32559 E SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λ p(nm ) Electro-Optical Data Em itted Color Lens Appearance MAX TYP If (m A) TYP STANDARD TYP View ing Angle 2 ½ (Deg) Iv (m cd) Vf (V) LED P/N Data @ 20m A H301CBWD-XXX 430 BLUE DIFFUSED 20 4.0 4.5 10 40 3BWD-S H301CGD-XXX 568 GREEN DIFFUSED 20 2..1 2.8 25 40 3GD-S H301CSGC-XXX 568 SUPER GREEN WATER CLEAR 20 2.1 2.8 50 30 3SGC-S H301CSGD-XXX 568 SUPER GREEN DIFFUSED 20 2.1 2.8 30 40 3SGD-S H301CSGT-XXX 568 SUPER GREEN TINTED 20 2.1 2.8 50 30 3SGT-S H301CYD-XXX 590 YELLOW DIFFUSED 20 2.0 2.8 20 40 3YD-S H301CHD-XXX 625 HE RED DIFFUSED 20 2.0 2.8 30 40 3HD-S H301CRD-XXX 700 RED DIFFUSED 20 2.1 2.8 2 40 3RD-S H301CSRD-XXX 645 SUPER RED DIFFUSED 20 1.7 2.4 40 40 3SRD-S H301CSRC-XXX 645 SUPER RED WATER CLEAR 20 1.7 2.4 60 30 3SRC-S LOW CURRENT Data @ 2m A H301CGDL-XXX 568 GREEN DIFFUSED 2 2.1 2.6 2 40 3GDL-S H301CYDL-XXX 590 YELLOW DIFFUSED 2 2.0 2.6 2 40 3YDL-S H301CHDL-XXX 625 HE RED DIFFUSED 2 2.0 2.6 3 40 3HDL-S 5 VOLT Data @ 5V H301CGD5V-XXX 568 GREEN DIFFUSED 8 - 5.0 25 40 3GD5V-S H301CYD5V-XXX 590 YELLOW DIFFUSED 8 - 5.0 20 40 3YD5V-S H301CHD5V-XXX 625 HE RED DIFFUSED 8 - 5.0 30 40 3HD5V-S STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/10/04 DATE: 03/10/04 PART NO: FAX: (949) 951-3974 T-1 (3MM) 90° BI-LEVEL VAR. C/L LED ASSY REVISION: H301CXX-XXX CAGE CODE : 32559 E SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H301CYDL-100 价格&库存
很抱歉,暂时无法提供与“H301CYDL-100”相匹配的价格&库存,您可以联系我们找货
