ITEM
Q'TY
PART NUMBER
REV.
PART DESCRIPTION
1
1
H-278C-2
T-1¾ (5mm) Bi-Level LED Holder, 90° Mount
2
2
5XX
T-1¾ (5mm) Non-Flange LED, See Following Pages
1
2
0.170 [4.3mm]
TYP.
0.240 [6.1mm]
C
D
E
F
G
H
J
DATE
APPROVED
02/28/05
02/14/07
02/27/07
03/04/09
05/29/12
06/19/12
09/15/15
M. C.
M. C.
M. C.
T. Y.
T. Y.
T. Y.
J. C.
DESCRIPTION
Corrected Holder from H-278C to H-278C-1.
Changed Holder from H-278C-1 to H-278C-2.
Changed LED Protrusion from .180 to .170
Added P/N Designation Note
Added H278CGAD
Updated LED Offering List
Updated LED Optical Characteristics
0.433 [11.0mm]
Ø.197 [Ø5.0mm]
TYP.
0.380 [9.7mm]
0.500 [12.7mm]
0.130 [3.3mm]
0.157 [4.0mm]
0.100 [2.5mm]
1
2
Standard
1
2
5 & 12 V
1
2
Bi-Color
1
2
0.310 [7.9mm]
0.220 [5.6mm]
0.020 [0.5mm] SQ. TYP.
BI-COLOR POLARITY
LED P/N (1) Cathode (2) Cathode
Red
5BC
Green
Yellow
5BC-Y/G
Green
Red
5BC-R/Y
Yellow
Amber
5BC-A/G
Green
NOTE: P/N CONFIGURATION
H278CYGDL
H278 Holder
Series
Color of top LED
- Use "X" if blank
Color of bottom LED
- Use "X" if blank
- " " Standard LED
- "L" Low Current LED
- "5V" 5V LED
- "12V" 12V LED
0.220 [5.6mm]
0.090 [2.3mm]
Lens Appearance
0.100 [2.5mm] LED Lead
-If LEDs are the same,
use e.g. H278CGD
Recommended Mounting Holes
All Green LEDs
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
Holder Face
Ø.032+.003
-.002
TYP.
5V
REVERSE CURRENT
100uA
OPERATING TEMPERATURE RANGE
-25° C - 85° C
STORAGE TEMPERATURE
-30° C - 100° C
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
260° C FOR 5 SECONDS
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1¾ (5MM)
90° BI-LEVEL LED ASSY
REVISION:
H278CXX
CAGE CODE : 32559
J
SHEET # 1 OF 4
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET#1.
LED Assy. No.
H278CBWC
H278CBWD
H278CBWT
H278CGC
H278CGD
H278CGT
H278CUGC
H278CPGC
H278CPGD
H278CPGT
H278CYC
H278CYD
H278CYT
H278CAC
H278CAD
H278CAT
H278CHC
H278CHD
H278CHT
H278CRC
H278CRD
H278CRT
H278CBC‐A/G
H278CBC
H278CBC‐R/Y
H278CBC‐Y/G
Material
GaN/SiC
GaN/SiC
GaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
AlGaInP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaP/GaP
Chip
Peak
Wave
Length
430
430
430
568
568
568
570
555
555
555
590
590
590
605
605
605
625
625
625
700
700
700
605
568
625
568
625
590
590
568
Emitted Color
BLUE
BLUE
BLUE
GREEN
GREEN
GREEN
GREEN
PURE GREEN
PURE GREEN
PURE GREEN
YELLOW
YELLOW
YELLOW
AMBER
AMBER
AMBER
HE RED
HE RED
HE RED
RED
RED
RED
AMBER
GREEN
RED
GREEN
RED
YELLOW
YELLOW
GREEN
Lens
Appearance
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
Electro‐Optical Data @ 20mA
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
25
4.0
4.5
25
25
4.0
4.5
15
25
4.0
4.5
30
30
2.1
2.8
40
30
2.1
2.8
25
30
2.1
2.8
40
30
2.1
2.4
600
30
2.2
2.8
10
30
2.2
2.8
10
30
2.2
2.8
10
30
2.0
2.8
40
30
2.0
2.8
25
30
2.0
2.8
40
30
2.0
2.8
40
30
2.0
2.8
25
30
2.0
2.8
40
30
2.0
2.8
40
30
2.0
2.8
25
30
2.0
2.8
40
2.8
2
2.8
2
2.8
2
30
2.0
2.8
6
30
2.1
2.8
6
30
2.0
2.8
6
30
2.1
2.8
8
30
2.0
2.8
6
30
2.0
2.8
5
30
2.0
2.8
5
30
2.1
2.8
8
Viewing
Angle
2 θ ½
(Deg)
45
35
35
35
45
35
35
45
35
35
45
35
35
45
35
35
45
35
LED P/N
5BWC
5BWD
5BWT
5GC
5GD
5GT
5UGC
5PGC
5PGD
5PGT
5YC
5YD
5YT
5AC
5AD
5AT
5HC
5HD
5HT
5RC
5RD
5RT
45
5BC‐A/G
45
5BC
45
5BC‐R/Y
45
5BC‐Y/G
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1¾ (5MM)
REVISION:
H278CXX
CAGE CODE : 32559
J
SHEET # 2 OF 4
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET#1.
LED Assy. No.
H278CUBWC
H278CSGC
H278CSGD
H278CSGT
H278CSYC
H278CSYD
H278CSYT
H278CSRC
H278CSRD
H278CSRT
H278CUGC
H278CSUGC
H278CUYC
H278CSUYC
H278CUUYC
H278CUOC
H278CUOC
H278CURC
H278CSURC
H278CUWC
Material
InGaN/SiC
GaP/GaP
GaP/GaP
GaP/GaP
GaAsP/GaP
GaAsP/GaP
GaAsP/GaP
GaAlAs/GaAs
GaAlAs/GaAs
GaAlAs/GaAs
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
AlGaInP
GaAlAs/GaAs
AlGaInP
InGaN/SiC
Chip
Peak
Wave
Length
468
568
568
568
590
590
590
645
645
645
570
570
590
590
590
625
625
645
640
6500K
Emitted
Color
BLUE
GREEN
GREEN
GREEN
YELLOW
YELLOW
YELLOW
SUPER RED
SUPER RED
SUPER RED
GREEN
GREEN
YELLOW
YELLOW
YELLOW
ORANGE
ORANGE
RED
RED
WHITE
Lens
Appearance
WATER CLEAR
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
DIFFUSED
TINTED
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
WATER CLEAR
If
Iv
Vf
(mA)
(mcd)
(V)
MAX
TYP
MAX
TYP
50
3.2
3.6
5000
30
2.1
2.8
60
30
2.1
2.8
50
30
2.1
2.8
60
30
2.0
2.8
600
30
2.0
2.8
150
30
2.0
2.8
600
30
1.7
2.4
60
30
1.7
2.4
40
30
1.7
2.4
60
30
2.1
2.4
400
30
2.1
2.4
300
30
2.0
2.4
1000
30
2.0
2.4
700
30
2.0
2.4
500
30
1.8
2.4
1400
30
1.8
2.4
1300
30
1.7
2.4
400
30
1.8
2.4
500
100
3.5
4.2
2700
Viewing
Angle
LED P/N
2 θ ½
(Deg)
15
5BWC2.515
35
5SGC
45
5SGD
35
5SGT
35
5SYC
45
5SYD
35
5SYT
35
5SRC
45
5SRD
35
5SRT
35
5UGC
35
5SUGC
30
5UYC
35
5SUYC
35
5UUYC
35
5UOC
35
5SUOC
30
5URC
35
5SURC
30
5WC2.730
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1¾ (5MM)
REVISION:
H278CXX
CAGE CODE : 32559
J
SHEET # 3 OF 4
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET#1.
Max. Rating
Electro-Optical Data @ 2m A
MAX
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
DIFFUSED
7
3.8
4.2
4
45
5BWDL
PURE GREEN
DIFFUSED
7
2.1
2.6
1
45
5PGDL
568
GREEN
DIFFUSED
7
2.1
2.6
4
45
5GDL
H278CYDL
590
YELLOW
DIFFUSED
7
2.0
2.6
4
45
5YDL
H278CADL
605
AMBER
DIFFUSED
7
2.0
2.6
4
45
5ADL
H278CHDL
625
HE RED
DIFFUSED
7
2.0
2.6
5
45
5HDL
H278CSRDL
645
SUPER RED
DIFFUSED
7
1.7
2.3
6
45
5SRDL
Viewing
Angle
2 θ½
(Deg)
LED P/N
45
35
45
35
45
45
45
45
5BWD5V
5GC5V
5GD5V
5GT5V
5AD5V
5HD5V
5RD5V
5YD5V
35
45
35
45
35
45
35
45
5GC12V
5GD12V
5HC12V
5HD12V
5RC12V
5RD12V
5YC12V
5YD12V
Peak Wave
Length
λp(nm )
Em itted
Color
H278CBWDL
430
BLUE
H278CPGDL
555
H278CGDL
LED Assy. No.
LED Assy. No.
5 Volt
H278CBWD5V
H278CGC5V
H278CGD5V
H278CGT5V
H278CAD5V
H278CHD5V
H278CRD5V
H278CYD5V
12 Volt
H278CGC12V
H278CGD12V
H278CHC12V
H278CHD12V
H278CRC12V
H278CRD12V
H278CYC12V
H278CYD12V
Lens
Appearance
If
(m A)
Peak Wave
Length
λp(nm)
Emitted
Color
Lens
Appearance
BLUE
GREEN
GREEN
GREEN
AMBER
HE RED
RED
YELLOW
430
568
568
568
605
625
700
590
DIFFUSED
WATER CLEAR
DIFFUSED
TINTED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
GREEN
GREEN
HE RED
HE RED
RED
RED
YELLOW
YELLOW
568
568
625
625
700
700
590
590
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
WATER CLEAR
DIFFUSED
Iv
(m cd)
Vf
(V)
Vf
If
Iv
(V)
(mA)
(mcd)
MAX
TYP
MAX
TYP
Data @ 5V
5
15
5
40
5
25
5
40
5
25
5
30
5
1.5
5
25
Data @ 12V
12
40
12
25
12
50
12
30
12
2
12
1.5
12
25
12
LED P/N
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
X°
± 5°
TEL: (949) 951-8808
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1¾ (5MM)
REVISION:
H278CXX
CAGE CODE : 32559
J
SHEET # 4 OF 4
很抱歉,暂时无法提供与“H278CYD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.13920
- 200+4.84920
- 500+4.68720
- 1000+4.60080
