REV.
ITEM
Q'TY
1
1
H-201C
T-1 (3mm) Bi-Level LED Holder, 90° Mount
2
2
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Page 2
PART NUMBER
PART DESCRIPTION
1
E
F
G
H
J
2
DESCRIPTION
Removed H201CBCXX Specifications
Updated Note and H201CAD Specs
Updated Note and H201CRD5V Specs
Added H201CGC Specs
Engineering Update w/o Changes
DATE
APPROVED
01/25/08
04/28/08
05/20/08
11/18/08
06/21/16
M. C.
M. C.
M. C.
T. Y.
J. C.
0.069 [1.8mm] TYP.
0.320 [8.1mm]
0.285 [7.2mm]
0.180 [4.6mm]
Ø.118 [Ø3.0mm]
TYP.
0.300 [7.6mm]
0.380 [9.7mm]
0.100 [2.5mm]
Cathode I.D.
Mark
0.157 [4.0mm]
0.020 [0.5mm]
0.100 [2.5mm]
SQ. TYP.
0.195 [5.0mm]
Note: P/N Designation
0.295 [7.5mm]
H201CY X D X X
Color of top LED
-Use "X" if blank
- "L" Low Current LED
- "5V" 5V LED
- " " if Standard LED
Color of bottom LED
-Use "X" if blank
- If top and bottom are same
LED, i.e. H201CYD
Holder Face
0.195 [5.0mm]
Ø.032+.003
-.002
TYP.
0.100 [2.5mm]
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1 (3MM)
90° BI-LEVEL LED ASSY
REVISION:
H201CXX
CAGE CODE : 32559
J
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
STANDARD
H201CBWD
H201CGD
H201CGC
H201CYD
H201CHD
H201CRD
H201CSRD
H201CAD
LOW CURRENT
H201CGDL
H201CYDL
H201CHDL
H201CRDL
5 VOLT
H201CGD5V
H201CYD5V
H201CHD5V
H201CRD5V
Electro-Optical Data
Peak Wave
Length
λ p(nm )
Em itted Color
430
568
568
590
625
700
645
605
BLUE
GREEN
GREEN
YELLOW
HE RED
RED
SUPER RED
AMBER
568
590
625
700
GREEN
YELLOW
HE RED
RED
568
590
625
700
GREEN
YELLOW
HE RED
RED
View ing
Lens
Angle
Vf
If
Iv
2 ½
Appearance
(V)
(m A)
(m cd) (Deg)
TYP TYP MAX TYP
Data @ 20m A
DIFFUSED
4.5
10
40
DIFFUSED
2.8
25
40
WATER CLEAR
2.8
40
30
DIFFUSED
2.8
DIFFUSED
2.8
30
40
DIFFUSED
2.8
2
40
DIFFUSED
2.4
40
40
DIFFUSED
2.8
25
40
Data @ 2m A
DIFFUSED
2
2.1
2.6
2
40
DIFFUSED
2
2.0
2.6
2
40
DIFFUSED
2
2.0
2.6
3
40
DIFFUSED
2
2.1
2.6
1
40
Data @ 5V
DIFFUSED
5.0
25
40
DIFFUSED
5.0
DIFFUSED
5.0
30
40
DIFFUSED
5.0
2
40
LED P/N
3BWD-S
3GD-S
3GC-S
3YD-S
3HD-S
3RD-S
3SRD-S
3AD-S
3GDL-S
3YDL-S
3HDL-S
3RDL-S
3GD5V-S
3YD5V-S
3HD5V-S
3RD5V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1 (3MM)
REVISION:
H201CXX
CAGE CODE : 32559
J
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H201CHGD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+14.18040
- 200+5.65920
- 500+5.47560
- 1000+5.37840
