PART NUMBER
REV.
PART DESCRIPTION
ITEM
Q'TY
1
1
H-201C
T-1 (3mm) Bi-Level LED Holder, 90° Mount
2
2
3BCXX
T-1 (3mm) N-Flange Bi-Color LED, See Page 2
DESCRIPTION
A Engineering Update w/o Changes
B Added Note for Blank LED
C Engineering Update w/o Changes
1
DATE
APPROVED
03/05/04
02/26/08
06/21/16
M. C.
M. C.
J. C.
2
0.069 [1.8mm] TYP.
0.320 [8.1mm]
0.285 [7.2mm]
0.180 [4.6mm]
Ø.118 [Ø3.0mm]
TYP.
0.300 [7.6mm]
0.380 [9.7mm]
0.100 [2.5mm]
Cathode I.D.
Mark
Note: If blank, use
H201CBCX
0.157 [4.0mm]
0.100 [2.5mm]
GREEN
CATHODE
0.020 [0.5mm]
SQ. TYP.
RED,YELLOW
CATHODE
0.195 [5.0mm]
0.295 [7.5mm]
Holder Face
0.195 [5.0mm]
Ø.032+.003
-.002
TYP.
0.100 [2.5mm]
0.100 [2.5mm] LED Lead
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1 (3MM) BI-COLOR
90° BI-LEVEL LED ASSY
REVISION:
H201CBCXX
CAGE CODE : 32559
C
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy No.
H201CBC
H201CBC-Y/G
Peak Wave
Length
λp (nm )
Em itted Color
635
HE RED
568
GREEN
585
YELLOW
568
GREEN
Lens
Appearance
WHITE DIFFUSED
WHITE DIFFUSED
Absolute
Max.
Rating
Electro-Optical Data @ 20m A
Vf
(V)
Iv
(m cd)
If (m A)
TYP
MAX
TYP
30
2.0
2.6
30
30
2.2
2.6
30
30
2.1
2.6
15
30
2.2
2.6
30
View ing
Angle
2 ϴ½
(Deg)
LED P/N
45
3BC
45
3BC-Y/G
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
TITLE:
DESIGNED:
S. Irving
CHECKED:
M. Chen
DATE:
03/05/04
DATE:
03/05/04
PART NO:
FAX: (949) 951-3974
T-1 (3MM) BI-COLOR
REVISION:
H201CBCXX
CAGE CODE : 32559
C
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H201CBC-Y/G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+14.851831+1.92100
- 10+12.4056510+1.60460
- 100+9.87210100+1.27690
- 250+8.91110250+1.15260
- 500+8.38692500+1.08480
- 1000+7.688011000+0.99440
- 2000+6.901742000+0.89270
- 4000+6.464924000+0.83620
- 国内价格
- 1+13.77470
- 10+11.51086
- 100+9.16317
- 250+8.26482
- 500+7.78570
- 1000+7.12691
- 2000+6.40823
- 4000+6.00098
- 国内价格 香港价格
- 1+15.650761+2.02434
- 10+11.1650610+1.44414
- 100+8.45772100+1.09396
- 500+7.26037500+0.93909
- 1000+6.869361000+0.88852
- 2000+6.538022000+0.84566
- 5000+6.176585000+0.79891
- 10000+5.9516210000+0.76981
