PART NUMBER
REV.
ITEM
Q'TY
PART DESCRIPTION
1
1
H-485C
Quad-Level Sub-Miniature (1.8mm) LED 90° Holder
2
3
1.8RD
Small Footprint, Radial Lead Orientation (1.8mm)
3
1
1.8GD
DESCRIPTION
A Engineering Release
B Engineering Update w/o Changes
DATE
APPROVED
06/01/06
08/05/16
M. C.
J. C.
1
0.043 [1.1mm]
0.200 [5.1mm]
Ø0.071 [Ø1.8mm] TYP.
0.173 [4.4mm]
0.073 [1.8mm]
2
2
2
3
0.445 [11.3mm]
0.200 [5.1mm]
Holder
Face
0.373 [9.5mm]
0.273 [6.9mm]
0.535 [13.6mm]
0.157 [4.0mm]
Ø.032+.003
-.002
TYP.
Cathode
0.150 [3.8mm]
0.100 [2.5mm]
0.300 [7.6mm]
0.200 [5.1mm]
0.100 [2.5mm]
0.020 [0.5mm] SQ. TYP.
0.500 [12.7mm]
0.100 [2.5mm]
Recommended Mounting Holes
0.400 [10.2mm]
0.300 [7.6mm]
0.200 [5.1mm]
Absolute Max. Ratings
Chip
LED Part No.
Material
Peak Wave
Length
λp (nm )
Em itted Color
Lens
Appearance
∆λ
(nm )
Pd
(m W)
If
(m A)
Electro-Optical Data @ 20m A
Vf
(V)
Peak If
(m A)
Iv
(m cd)
TYP
MAX
TYP
View ing
Angle
(Deg)
1.8RD
GaAsP/GaP
655
RED
DIFFUSED
100
40
15
150
2.3
2.6
1.0
70
1.8GD
GaP/GaP
565
GREEN
DIFFUSED
30
80
30
150
2.2
2.6
5.0
70
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
STANDARD TOLERANCE
DECIMALS
REVERSE VOLTAGE
5V
REVERSE CURRENT ( VR=5V)
100µA
OPERATING TEMPERATURE RANGE
-25°C ~ 85°C
STORAGE TEMPERATURE
-30°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
( UNLESS OTHERWISE SPECIFIED )
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
S. Dam
CHECKED:
D. Beckman
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DATE:
01/26/07
DATE:
01/26/07
Sub-Miniature (1.8mm) RP
90° Quad-Level LED Assembly
REVISION:
PART NO:
H485CRRRGD-RP
CAGE CODE : 32559
B
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H485CRRRGD-RP”相匹配的价格&库存,您可以联系我们找货
