H380CGDL
H380CGDL
    BIVAR
    发光二极管/LED 翠绿色 2mcd
H380CGDL 数据手册
REV. ITEM Q'TY PART DESCRIPTION 1 1 H-381C Tri-Level Sub-Miniature (1.8mm) LED 90° Holder 2 3 1.8XXX 1.8 Sub-Miniature Radial LED, See Page 2 3 1 BCH-1020 Backplate PART NUMBER 1 DATE APPROVED 10/15/07 01/04/08 08/28/08 09/12/08 06/24/16 M. C. M. C. M. C. M. C. J. C. DESCRIPTION C Added Backplate Feature D Updated Item Number on Model E Updated Part Number Designation F Added 1.8BWD Specs G Engineering Update w/o Changes 2 0.200 [5.1mm] Ø.071 [Ø1.8mm] TYP. 0.05 [1.3mm] TYP. 3 0.495 [12.6mm] 0.400 [10.2mm] 0.130 [3.3mm] TYP. 0.070 [1.8mm] 0.135 [3.4mm] 0.100 [2.5mm] 0.100 [2.5mm] TYP. 0.270 [6.9mm] 0.020 [0.5mm] SQ TYP. ANODE Ø.032+.003 -.002 Holder Face TYP. DIN 41494 COMPATIBLE REVERSE POLARITY 0.100 [2.5mm] 0.200 [5.1mm] 0.100 [2.5mm] 0.270 [6.9mm] NOTE: P/N DESIGNATION H380CXXXDX H380 Holder Series Color of top LED - Use "X" if blank - " " Standard LED - "L" Low Current LED Color of middle LED - Use "X" if blank Diffused Lens Color of bottom LED - Use "X" if blank -If LEDs are the same, use e.g. H380CGD Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE All Green LEDs STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 SUB-MINIATURE (1.8MM) 90° TRI-LEVEL LED ASSEMBLY TITLE: DATE: 03/08/04 DATE: 03/08/04 PART NO: REVISION: H380CXX CAGE CODE : 32559 G SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. H380CBWD H380CGD H380CYD H380CHD H380CAD LOW CURRENT H380CGDL H380CYDL H380CHDL Peak Wave Length λ p(nm ) Em itted Color Lens Appearance 430 568 590 625 605 BLUE GREEN YELLOW HE RED AMBER DIFFUSED DIFFUSED DIFFUSED DIFFUSED DIFFUSED 568 590 625 GREEN YELLOW HE RED DIFFUSED DIFFUSED DIFFUSED Electro-Optical Data @ 20 m A View ing Angle Vf If Iv 2 ½ (V) (m A) (m cd) (Deg) TYP TYP MAX TYP 20 4.0 4.5 10 50 20 2.1 2.8 20 50 20 2.0 2.8 10 50 20 2.0 2.8 20 50 20 2.0 2.8 20 50 Data @ 2 mA 2 2.1 2.6 2.0 50 2 2.0 2.6 2.0 50 2 2.0 2.6 2.0 50 LED P/N 1.8BWD 1.8GD 1.8YD 1.8HD 1.8AD 1.8GDL 1.8YDL 1.8HDL STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 SUB-MINIATURE (1.8MM) 90° TRI-LEVEL LED ASSEMBLY REVISION: PART NO: H380CXX CAGE CODE : 32559 G SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H380CGDL 价格&库存
很抱歉,暂时无法提供与“H380CGDL”相匹配的价格&库存,您可以联系我们找货
H380CGDL
  • 1+15.76305
  • 10+11.21141
  • 100+8.52834
  • 250+7.71383
  • 500+7.30658
  • 1000+7.06702
  • 2000+6.82746
H380CGDL
  • 1+16.959541+2.19220
  • 10+12.0640010+1.55940
  • 100+9.17913100+1.18650
  • 250+8.30493250+1.07350
  • 500+7.86783500+1.01700
  • 1000+7.605571000+0.98310
  • 2000+7.343312000+0.94920
