REV.
ITEM
Q'TY
PART DESCRIPTION
1
1
H-381C
Tri-Level Sub-Miniature (1.8mm) LED 90° Holder
2
3
1.8XXX
1.8 Sub-Miniature Radial LED, See Page 2
3
1
BCH-1020
Backplate
PART NUMBER
1
DATE
APPROVED
10/15/07
01/04/08
08/28/08
09/12/08
06/24/16
M. C.
M. C.
M. C.
M. C.
J. C.
DESCRIPTION
C Added Backplate Feature
D Updated Item Number on Model
E Updated Part Number Designation
F Added 1.8BWD Specs
G Engineering Update w/o Changes
2
0.200 [5.1mm]
Ø.071 [Ø1.8mm]
TYP.
0.05 [1.3mm] TYP.
3
0.495 [12.6mm]
0.400 [10.2mm]
0.130 [3.3mm] TYP.
0.070 [1.8mm]
0.135 [3.4mm]
0.100 [2.5mm]
0.100 [2.5mm] TYP.
0.270 [6.9mm]
0.020 [0.5mm] SQ TYP.
ANODE
Ø.032+.003
-.002
Holder Face
TYP.
DIN 41494 COMPATIBLE
REVERSE POLARITY
0.100 [2.5mm]
0.200 [5.1mm]
0.100 [2.5mm]
0.270 [6.9mm]
NOTE: P/N DESIGNATION
H380CXXXDX
H380 Holder
Series
Color of top LED
- Use "X" if blank
- " " Standard LED
- "L" Low Current LED
Color of middle LED
- Use "X" if blank
Diffused Lens
Color of bottom LED
- Use "X" if blank
-If LEDs are the same,
use e.g. H380CGD
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
All Green LEDs
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
( UNLESS OTHERWISE SPECIFIED )
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
SUB-MINIATURE (1.8MM)
90° TRI-LEVEL LED ASSEMBLY
TITLE:
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H380CXX
CAGE CODE : 32559
G
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
H380CBWD
H380CGD
H380CYD
H380CHD
H380CAD
LOW CURRENT
H380CGDL
H380CYDL
H380CHDL
Peak Wave
Length
λ p(nm )
Em itted Color
Lens
Appearance
430
568
590
625
605
BLUE
GREEN
YELLOW
HE RED
AMBER
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
568
590
625
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
Electro-Optical
Data @ 20 m A
View ing
Angle
Vf
If
Iv
2 ½
(V)
(m A)
(m cd) (Deg)
TYP TYP MAX TYP
4.5
10
50
2.8
2.8
10
50
2.8
2.8
Data @ 2 mA
2
2.1
2.6
2.0
50
2
2.0
2.6
2.0
50
2
2.0
2.6
2.0
50
LED P/N
1.8BWD
1.8GD
1.8YD
1.8HD
1.8AD
1.8GDL
1.8YDL
1.8HDL
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/08/04
DATE:
03/08/04
REVISION:
PART NO:
H380CXX
CAGE CODE : 32559
G
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H380CGGHDL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+16.40986
- 10+13.64294
- 100+10.95987
- 250+9.83394
- 500+9.25899
- 1000+8.44449
- 2000+7.62999
- 4000+7.15087
- 国内价格 香港价格
- 1+17.693451+2.28260
- 10+14.7153410+1.89840
- 100+11.82483100+1.52550
- 250+10.59855250+1.36730
- 500+9.98541500+1.28820
- 1000+9.109501000+1.17520
- 2000+8.233592000+1.06220
- 4000+7.708044000+0.99440
