ITEM
Q'TY
PART NUMBER
1
1
H-455C
2
4
3XX-S
REV.
PART DESCRIPTION
D
E
F
T-1 (3mm) Quad-Level LED Holder, 90° Mount and Bottom Piece
T-1 (3mm) N-Flange Shouldered LED, See Page 2.
Reference P/N Designation Note.
G
1
0.170 [4.3mm]
DATE
APPROVED
08/17/07
12/14/07
06/19/08
M. C.
M. C.
M. C.
08/04/16
J. C.
DESCRIPTION
Changed Bottom Piece Part Number to BH-340
LED Package Change to 3XX-S LEDs
Added P/N Designation Note and Removed
Bottom Piece Callout
Engineering Update w/o Changes
2TYP.
0.555 [14.1mm]
Holder Face
Ø.118 [Ø3.0mm]
TYP.
0.250 [6.4mm]
0.550 [14.0mm]
Ø.032+.003
-.002
0.660 [16.8mm]
0.400 [10.2mm]
TYP.
0.075 [1.9mm]
0.150 [3.8mm]
0.225 [5.7mm]
0.250 [6.3mm]
0.100 [2.5mm] LED Lead
0.100 [2.5mm]
Recommended Mounting Holes
0.157 [4.0mm]
0.400 [10.2mm]
0.325 [8.3mm]
0.250 [6.4mm]
0.020 [0.5mm] SQ. TYP.
0.100 [2.5mm]
0.475 [12.1mm]
NOTE: P/N DESIGNATION
H455CGHYGDL
- " " Standard LED
- "L" Low Current LED
-""5V" 5V LED
H-455 Holder
Series
Color of top LED
- Use "X" if blank
Diffused Lens
Color of LED, 2nd from top
- Use "X" if blank
Color of bottom LED
Color of LED, 3rd from top
- Use "X" if blank
-If LEDs are the same,
use e.g. H455CGD
All Green LEDs
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE: T-1 (3mm) SINGLE STATION
90° QUAD-LEVEL ASSEMBLY
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H455CXX
CAGE CODE : 32559
G
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
STANDARD
H455CBWD
H455CGD
H455CYD
H455CHD
H455CRD
H455CSRD
LOW CURRENT
H455CGDL
H455CYDL
H455CHDL
5 VOLT
H455CGD5V
H455CYD5V
H455CHD5V
Electro-Optical Data
Peak Wave
Length
λ p (nm )
Em itted
Color
Lens
Appearance
430
565
585
635
655
660
BLUE
GREEN
YELLOW
HE RED
RED
SUPER RED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
565
585
635
GREEN
YELLOW
HE RED
DIFFUSED
DIFFUSED
DIFFUSED
Vf
If
(V)
(m A)
TYP
TYP
MAX
Data @ 20m A
4.5
2.6
2.6
2.6
2.0
2.6
Data @ 2m A
2
1.9
2.2
2
1.9
2.2
2
1.8
2.2
Data @ 5V
10
5.0
10
5.0
10
5.0
View ing
Angle
2 ½
(Deg)
LED P/N
6
90
45
45
45
45
45
45
3BWD-S
3GD-S
3YD-S
3HD-S
3RD-S
3SRD-S
6
4
6
45
45
45
3GDL-S
3YDL-S
3HDL-S
30
45
45
45
3GD5V-S
3YD5V-S
3HD5V-S
Iv
(m cd)
TYP
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H455CXX
CAGE CODE : 32559
G
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H455CGDL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+7.1697510+0.89910
- 30+6.9484630+0.87135
- 100+6.77143100+0.84915
- 200+6.63866200+0.83250
- 500+6.32885500+0.79365
- 国内价格
- 1+17.47440
- 200+6.97680
- 500+6.75000
- 1000+6.63120
- 国内价格 香港价格
- 1+18.292391+2.29390
- 10+15.2286410+1.90970
- 100+12.16489100+1.52550
- 250+10.99346250+1.37860
- 500+10.36268500+1.29950
- 1000+9.461581000+1.18650
- 2000+8.560482000+1.07350
- 4000+7.929714000+0.99440
