PART NUMBER
REV.
PART DESCRIPTION
ITEM
Q'TY
1
1
H-280C
T-1 (3mm) Bi-Level Tri-Lead LED Holder, 90° Mount
2
2
3BC-3-XXXX-F
T-1 (3mm) Bi-Color/Tri-Color Flanged LED, See Page 2
1
DATE
APPROVED
03/05/04
04/05/05
06/22/16
M. C.
M. C.
J. C.
DESCRIPTION
A Engineering Update w/o Changes
B Removed Fig. 3
C Engineering Update w/o Changes
2
0.095 [2.4mm] TYP.
0.283 [7.2mm]
0.394 [10.0mm]
Ø.118 [Ø3.0mm]
TYP.
Holder Face
Ø.032+.003
-.002
TYP.
0.215 [5.5mm]
0.291 [7.4mm]
0.100 [2.5mm]
0.386 [9.8mm]
0.094 [2.4mm]
0.100 [2.5mm]
0.157 [4.0mm]
TYP.
(1) (2) (3)
Recommended Mounting Holes
0.215 [5.5mm]
0.315 [8.0mm]
0.020 [0.5mm]
0.100 [2.5mm]
TYP.
SQ. TYP.
Fig. 1
Fig. 2
(2) Common Cathode
(2) Common Anode
(1) Anode
Red
Yellow
Red
(3) Anode
(1) Cathode
Red
Yellow
Red
Green
Green
Yellow
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
5V
REVERSE CURRENT
100uA
OPERATING TEMPERATURE RANGE
-25° C - 85° C
STORAGE TEMPERATURE
-30° C - 100° C
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
260° C FOR 5 SECONDS
(3) Cathode
Green
Green
Yellow
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
D. Green
CHECKED:
M. Chen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
DATE:
03/05/04
DATE:
03/05/04
FAX: (949) 951-3974
T-1 (3MM) BI-COLOR 3 LEAD
90° BI-LEVEL LED ASSY
TITLE:
REVISION:
PART NO:
H280CBCXXXX
CAGE CODE : 32559
C
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED As s y. No.
H280CBC
(Fig. 1)
H280CBC-Y /G
(Fig. 1)
H280CBC-CA
(Fig. 2)
H280CBC-Y /G-CA
(Fig. 2)
Pe ak Wave
Le ngth
λ p(nm )
Em itte d Color
635
568
585
568
635
568
585
568
HE RED
GREEN
Y ELLOW
GREEN
HE RED
GREEN
Y ELLOW
GREEN
Le ns
Appe arance
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
WHITE DIFFUSED
A bs .
M a x.
R a t in g
If
(m A)
30
30
30
30
30
30
30
30
Ele ctr o-Optical
Data @ 20m A
V ie w ing
Angle
Vf
2
½
Iv
(V )
(De g)
(m cd)
TYP M AX TYP
2.0
2.6
35.0
40
2.2
2.6
35.0
2.1
2.6
30.0
40
2.2
2.6
35.0
2.0
2.6
35.0
40
2.2
2.6
35.0
2.1
2.6
30.0
40
2.2
2.6
35.0
LED P/N
3BC-3-F
3BC-3-Y /G-F
3BC-3-CA -F
3BC-3-Y /G-CA -F
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/05/04
DATE:
03/05/04
FAX: (949) 951-3974
REVISION:
PART NO:
H280CBCXXXX
CAGE CODE : 32559
C
SHEET # 2 OF 2
很抱歉,暂时无法提供与“H280CBC-CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+9.71830100+1.25886
