H485CAD
H485CAD
    BIVAR
    发光二极管/LED 琥珀色 20mcd
H485CAD 数据手册
PART NUMBER REV. PART DESCRIPTION ITEM Q'TY 1 1 H-485C Quad-Level Sub-Miniature (1.8mm) LED 90° Holder 2 4 1.8XXX Sub-Miniature (1.8mm) Radial LED, See Page 2 1 DESCRIPTION A Engineering Update w/o Changes B Added P/N Configuration and LED Specs C Added H485CBC & H485CBC-Y/G Specs DATE APPROVED 03/08/04 09/17/09 08/04/16 M. C. T. Y. J. C. 2 0.043 [1.1mm] TYP. 0.535 [13.6mm] 0.200 [5.1mm] Ø.071 [Ø1.8mm] TYP. 0.373 [9.5mm] 0.445 [11.3mm] 0.273 [6.9mm] 0.173 [4.4mm] 0.073 [1.8mm] 0.157 [4.0mm] 0.150 [3.8mm] 0.100 [2.5mm] 0.200 [5.1mm] 1 LED P/N Single Color BI-COLOR POLARITY (1) CATHODE (2) CATHODE HE RED YELLOW GREEN GREEN 1.8BC 1.8BC-Y/G 1 Bi-Color 1 2 0.300 [7.6mm] 0.400 [10.2mm] 0.500 [12.7mm] 2 2 NOTE: P/N CONFIGURATION H485CXXXXDX H-485C Holder Series Holder Face 0.200 [5.1mm] Ø.032+.003 -.002 TYP. - " " Standard LED - "L" Low Current LED Color of top LED - "X" if blank 0.100 [2.5mm] Lens Appearance Color of 2nd from top LED - "X" if blank Color of bottom LED - Use "X" if blank Color of 3rd from top LED - "X" if blank 0.100 [2.5mm] 0.200 [5.1mm] 0.300 [7.6mm] e.g. H485CRYGXD Series Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE -If LEDs are the same, use e.g. H485CGD LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) All Green LEDs Diffused Lens Appearance No LED Green, 3rd from top Yellow, 2nd from top Red, top LED STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE 0.020 [0.5mm] SQ. TYP. T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 SUB-MINIATURE (1.8MM) 90° QUAD-LEVEL LED ASSEMBLY TITLE: DATE: 03/08/04 DATE: 03/08/04 PART NO: REVISION: H485CXX CAGE CODE : 32559 C SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λ p(nm ) Electro-Optical Data Em itted Color Lens Appearance MAX TYP If (m A) TYP STANDARD TYP View ing Angle 2 ½ (Deg) Iv (m cd) Vf (V) LED P/N Data @ 20m A H485CAD 605 AMBER DIFFUSED 20 2.0 2.8 20 50 1.8AD H485CBWD 430 BLUE DIFFUSED 20 4.0 4.5 10 50 1.8BWD H485CGD 568 GREEN DIFFUSED 20 2.1 2.8 20 50 1.8GD H485CHD 625 HE RED DIFFUSED 20 2.0 2.8 20 50 1.8HD H485CRD 700 RED DIFFUSED 20 2.1 2.8 2 50 1.8RD H485CYD 590 YELLOW DIFFUSED 20 2.0 2.8 10 50 1.8YD 635 HE RED 20 2.0 2.6 4.2 50 1.8BC 568 GREEN WHITE DIFFUSED 20 2.2 2.6 6.5 590 YELLOW 20 2.0 2.8 3.5 50 1.8BC-Y/G 568 GREEN WHITE DIFFUSED 20 2.1 2.8 4.5 H485CBC H485CBC-Y/G LOW CURRENT Data @ 2m A H485CADL 605 AMBER DIFFUSED 2 2.0 2.6 2 50 1.8ADL H485CBWDL 430 BLUE DIFFUSED 2 3.8 4.2 1 50 1.8BWDL H485CGDL 568 GREEN DIFFUSED 2 2.1 2.6 2 50 1.8GDL H485CHDL 625 HE RED DIFFUSED 2 2.0 2.6 2 50 1.8HDL H485CYDL 590 YELLOW DIFFUSED 2 2.0 2.6 1 50 1.8YDL STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 SUB-MINIATURE (1.8MM) 90° QUAD-LEVEL LED ASSEMBLY TITLE: DESIGNED: T. Yin CHECKED: D. Green DATE: 03/08/04 DATE: 03/08/04 PART NO: REVISION: H485CXX CAGE CODE : 32559 C SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H485CAD 价格&库存
很抱歉,暂时无法提供与“H485CAD”相匹配的价格&库存,您可以联系我们找货
