REV.
PART DESCRIPTION
PART NUMBER
ITEM
Q'TY
1
1
H-400C
T-1 (3mm) Quad-Level LED Holder, 90° Mount, Interlocking
2
1
3XX-LL
T-1 (3mm) N-Flange LED, Long Leads
3
3
3XX-S
T-1 (3mm) N-Flange Shouldered LED, See Page 2
DATE
DESCRIPTION
E Updated to Previous Protrusion
F Added P/N Designation
G Added H400CAD Specs
H Updated LED Protrusion Dimension
J Engineering Update w/o Changes
APPROVED
M. C.
M. C.
T. Y.
T. Y.
J. C.
04/10/08
09/30/08
04/13/09
08/11/11
08/04/16
Holder Faces
0.215 [5.5mm]
Ø.032+.003
TYP. -.002
0.075 [1.9mm]
0.150 [3.8mm]
1
0.170 [4.3mm]
Ø.118 [Ø3.0mm]
2
3
0.175 [4.4mm] Holder Pitch
0.100 [2.5mm] LED Lead
0.225 [5.7mm]
Recommended Mounting Holes
0.04 [1.0mm] MAX.
0.560 [14.2mm]
TYP.
NOTE: P/N DESIGNATION
0.740 [18.8mm]
H400CXXXXDX
0.540 [13.7mm]
Cathode I.D.
Mark
H-400 Holder
Series
0.840 [21.3mm]
Color of top LED
- Use "X" if blank
0.157 [4.0mm]
-If LEDs are the same,
use e.g. H400CGD
0.100 [2.5mm]
0.440 [11.2mm]
0.365 [9.3mm]
0.290 [7.4mm]
0.215 [5.5mm] SQ. TYP.
0.020 [0.5mm]
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
Color of bottom LED
- Use "X" if blank
Color of 3rd from top LED
- Use "X" if blank
0.140 [3.6mm]
REVERSE VOLTAGE
Lens Appearance
Color of 2nd from top LED
- Use "X" if blank
0.340 [8.6mm]
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
- " " Standard LED
- "L" Low Current LED
- "5V" 5V LED
All Green Diffused LEDs
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
03/08/04
DATE:
03/08/04
PART NO:
FAX: (949) 951-3974
T-1 (3MM) INTERLOCKING
90° QUAD-LEVEL LED ASSY
REVISION:
H400CXX
CAGE CODE : 32559
J
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
Peak Wave
LED Assy. No.
Length
λ p(nm )
Electro-Optical Data
Em itted
Color
Lens
Appearance
If
(m A)
TYP
STANDARD
Iv
(m cd)
Vf
(V)
TYP
MAX
TYP
View ing
Angle
2 ½
(Deg)
LED P/N
Data @ 20m A
H400CAD
605
AMBER
DIFFUSED
2.8
25
40
3AD-S
H400CBWD
430
BLUE
DIFFUSED
4.5
10
40
3BWD-S
H400CGD
568
GREEN
DIFFUSED
2.8
25
40
3GD-S
H400CYD
590
YELLOW
DIFFUSED
2.8
3YD-S
H400CHD
625
HE RED
DIFFUSED
2.8
30
40
3HD-S
H400CRD
700
RED
DIFFUSED
2.8
2
40
3RD-S
H400CSRD
645
SUPER RED
DIFFUSED
2.4
40
40
3SRD-S
LOW CURRENT
Data @ 2m A
H400CGDL
568
GREEN
DIFFUSED
2
2.1
2.6
2
40
3GDL-S
H400CYDL
590
YELLOW
DIFFUSED
2
2.0
2.6
2
40
3YDL-S
H400CHDL
625
HE RED
DIFFUSED
2
2.0
2.6
3
40
3HDL-S
5 VOLT
Data @ 5V
H400CGD5V
568
GREEN
DIFFUSED
8
5.0
25
40
3GD5V-S
H400CYD5V
590
YELLOW
DIFFUSED
8
5.0
3YD5V-S
H400CHD5V
625
HE RED
DIFFUSED
8
5.0
30
40
3HD5V-S
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/08/04
DATE:
03/08/04
PART NO:
FAX: (949) 951-3974
REVISION:
H400CXX
CAGE CODE : 32559
J
SHEET # 2 OF 2
