FLPR2.5-UR
FLPR2.5-UR
    BIVAR
    插件
    发光二极管/LED 红色 插件 200mcd
FLPR2.5-UR 数据手册
ITEM Q'TY 1 1 FLPR-XX PART NUMBER 2 1 LC-XX.X PART DESCRIPTION REV. Flexible Light-Pipe Lens Cap Assembly NOTE: FLPR ADAPTER SHIPPED NON-ASSEMBLED SEE TABLE 1 0.320 [8.1mm] L D E F G H J K L M RP note added Added the 3HC-F LED to page 2 Updated Table For Length "L" Updated LED Tables Updated LED Tables 0.025 [0.6mm] 0.145 [3.7mm] DATE APPROVED 04/17/06 02/12/07 08/27/08 11/18/11 02/09/12 02/09/12 11/15/12 08/15/18 11/13/18 M. C. M. C. M. C. T. Y. T. Y. T. Y. T. Y. M. C. M. C. DESCRIPTION Added Shipping Note and Tolerance Table Changed Length From 2.5 to 0.5 at "L" Table Updated FLPC Hidden View and BOM LED Data Update 0.240 [6.1mm] 0.210 [5.3mm] 2 0.475 [12.1mm] 1 0.100 [2.5mm] TABLE 1 " L "* BI-COLOR LED'S Tolerance 1.0" ~ 16.0" 16.1" ~ 40.0" 40.1" ~ 80.0" 80.1" ~ 3,940.0" * Available in 0.1" increments only SINGLE COLOR LED SHORT LEAD CATHODE Add -RP suffix for Reverse Polarity SHOULDER OF HOLDER +.003 -.002 +.003 -.002 Recommended Mounting Holes SHORT LEAD CATHODE RED YELLOW LED PART NO. 3xBCC-F 3BC-Y/G-F LONG LEAD CATHODE GREEN GREEN 0.300 [7.6mm] 0.100 [2.5mm] RECOMMENDED FOOTPRINT STANDARD TOLERANCE (UNLESS OTHERWISE SPECIFIED) DECIMALS ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 REVERSE VOLTAGE DESIGNED: REVERSE CURRENT OPERATING TEMPERATURE RANGE STORAGE TEMPERATURE S. IRVING REVISED: K. BARON CHECKED: LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) TD. NGUYEN DATE: FLPRX.X-XX 02/09/99 DATE: 11/13/18 M CAGE CODE: 11/13/18 DATE: FAX: (949) 951-3974 TITLE: FLEXIBLE LIGHT-PIPE ASSY RIGHT ANGLE, 3mm LENS CAP W/LED REVISION: PART NO: 32559 SCALE: NONE SHEET # 1 OF CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING 3 REV. DESCRIPTION DATE APPROVED See Sheet 1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 PART NO: SCALE: REVISION: FLPRX.X-XX M SHEET # 2 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING REV. DESCRIPTION DATE APPROVED See Sheet 1 VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE FLEXIBLE LIGHT PIPE SERIES Emitted Colors "L" LENGTH, inches available in 0.1" increments only e.g. 6.0, 11.5 PART NO: SCALE: REVISION: FLPRX.X-XX M SHEET # 3 OF 3 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
FLPR2.5-UR 价格&库存
很抱歉,暂时无法提供与“FLPR2.5-UR”相匹配的价格&库存,您可以联系我们找货
