H175CBWD
H175CBWD
    BIVAR
    发光二极管/LED 蓝色 15mcd
H175CBWD 数据手册
PART NUMBER REV. ITEM Q'TY PART DESCRIPTION 1 1 H-175C-2 T-1¾ (5mm) LED Holder, 90° Mount, Interlocking 2 1 5XX T-1¾ (5mm) Non-Flange LED, See Page 2 1 A B C D 2 DESCRIPTION Engineering Update w/o Changes Corrected LED Protrusion and Holder PN# Updated LED Protrusion Engineering Update w/o Changes DATE APPROVED 03/05/04 01/18/07 08/05/09 06/20/16 M. C. M. C. T. Y. J. C. 0.209 [5.3mm] 0.350 [8.9mm] 0.250 [6.4mm] 0.190 [4.8mm] Ø.197 [Ø5.0mm] 0.240 [6.1mm] 0.120 [3.0mm] 0.157 [4.0mm] 0.100 [2.5mm] 0.020 [0.5mm] SQ. TYP. 0.200 [5.1mm] Holder Faces 0.200 [5.1mm] 0.100 [2.5mm] LED Lead Ø.032+.003 -.002 TYP. 0.254 [6.5mm] Holder Pitch Recommended Mounting Holes ABSOLUTE MAXIMUM RATINGS (Ta=25° C) REVERSE VOLTAGE REVERSE CURRENT OPERATING TEMPERATURE RANGE STANDARD TOLERANCE DECIMALS .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: STORAGE TEMPERATURE LEAD SOLDERING TEMPERATURE(1/16" FROM BODY) ® ( UNLESS OTHERWISE SPECIFIED ) T. Yin CHECKED: D. Green ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DATE: 03/05/04 DATE: 03/05/04 T-1¾ (5MM) INTERLOCKING 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: H175CXX CAGE CODE : 32559 D SHEET # 1 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING. REV. DATE DESCRIPTION APPROVED SEE SHEET #1 LED Assy. No. Peak Wave Length λ p(nm ) Electro-Optical Data Em itted Color Lens Appearance MAX TYP If (m A) TYP STANDARD TYP View ing Angle 2 ½ (Deg) Iv (m cd) Vf (V) LED P/N Data @ 20m A H175CBWD 430 BLUE DIFFUSED 20 4.0 4.5 15 45 5BWD H175CGD 568 GREEN DIFFUSED 20 2.1 2.8 25 45 5GD H175CPGD 555 PURE GREEN DIFFUSED 20 2.2 2.8 10 45 5PGD H175CYD 590 YELLOW DIFFUSED 20 2.0 2.8 25 45 5YD H175CHD 625 HE RED DIFFUSED 20 2.0 2.8 25 45 5HD H175CRD 700 RED DIFFUSED 20 2.1 2.8 2 45 5RD H175CSRD 645 SUPER RED DIFFUSED 20 1.7 2.4 40 45 5SRD LOW CURRENT Data @ 2m A H175CGDL 568 GREEN DIFFUSED 2 2.1 2.6 5 45 5GDL H175CYDL 590 YELLOW DIFFUSED 2 2.0 2.6 4 45 5YDL H175CHDL 625 HE RED DIFFUSED 2 2.0 2.6 5 45 5HDL 5 VOLT Data @ 5V H175CGD5V 568 GREEN DIFFUSED 10 - 5.0 25 45 5GD5V H175CYD5V 590 YELLOW DIFFUSED 10 - 5.0 20 45 5YD5V H175CHD5V 625 HE RED DIFFUSED 10 - 5.0 25 45 5HD5V STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) ±10% ALL VALUES ANGULAR 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: DESIGNED: T. Yin CHECKED: M. Chen DATE: 03/05/04 DATE: 03/05/04 T-1¾ (5MM) INTERLOCKING 90° SINGLE-LEVEL LED ASSY REVISION: PART NO: H175CXX CAGE CODE : 32559 D SHEET # 2 OF 2 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H175CBWD 价格&库存
很抱歉,暂时无法提供与“H175CBWD”相匹配的价格&库存,您可以联系我们找货
H175CBWD
  • 1+29.303781+3.80810
  • 10+24.4343110+3.17530
  • 100+19.56484100+2.54250
  • 250+17.56488250+2.28260
  • 500+16.60837500+2.15830
  • 1000+15.130141000+1.96620
  • 2000+13.651912000+1.77410
  • 4000+12.695414000+1.64980
H175CBWD
  • 1+27.24995
  • 10+22.72227
  • 100+18.19458
  • 250+16.33799
  • 500+15.43964
  • 1000+14.07415
  • 2000+12.69668
  • 4000+11.81031
