ITEM
Q'TY
1
1
H-401C
PART NUMBER
Quad-Level T-1 (3mm) LED Holder
2
3
3BC
T-1 (3mm) Bi-Color LED
3
1
3BC-LL
T-1 (3mm) Bi-Color LED, Long Lead
REV.
PART DESCRIPTION
DATE
APPROVED
06/19/09
08/04/16
T. Y.
J. C.
DESCRIPTION
A Engineering Release
B Engineering Update w/o Changes
0.04 [1.0mm] MAX.
Ø0.120 [Ø3.0mm]
1
0.560 [14.2mm]
0.170 [4.3mm]
3
0.740 [18.8mm]
2
Cathode ID
0.840 [21.3mm]
2
0.540 [13.7mm]
0.340 [8.6mm]
2
Holder Face
0.140 [3.6mm]
0.157 [4.0mm] REF. 2
0.215 [5.5mm]
1
0.020 [0.5mm] SQ. TYP.
0.440 [11.2mm]
0.365 [9.3mm]
0.100 [2.5mm]
0.290 [7.4mm]
Ø.032+.003
-.002
TYP.
0.075 [1.9mm]
0.150 [3.8mm]
0.225 [5.7mm]
0.215 [5.5mm]
LEAD-2
CATHODE
LEAD-1
CATHODE
RED
GREEN
Chip
LED Part No.
3BC (-LL)
Recommended Mounting Holes
Absolute Max. Ratings
Material
Peak Wave
Length
λp (nm )
Em itted Color
GaAsP/GaP
625
HE RED
GaP/GaP
568
GREEN
Lens
Appearance
0.100 [2.5mm] LED Lead
Electro-Optical Data @ 20m A
Vf
(V)
Iv
(m cd)
∆λ
(nm )
Pd
(m W)
If
(m A)
Peak If
(m A)
TYP
MAX
TYP
80
30
150
2.0
2.8
6
80
30
150
2.1
2.8
6
WHITE DIFFUSED
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
REVERSE VOLTAGE
5V
100µA
OPERATING TEMPERATURE RANGE
-25°C ~ 85°C
STORAGE TEMPERATURE
-30°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
45
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
REVERSE CURRENT ( VR=5V)
View ing
Angle
(Deg)
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
R. Paje
CHECKED:
F. Jensen
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
T-1 (3mm) SINGLE STATION
QUAD-LEVEL ASSY, REVERSE POLARITY
DATE:
06/19/09
DATE:
06/19/09
PART NO:
REVISION:
H401CBC-RP
CAGE CODE : 32559
B
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H401CBC-RP”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+28.99874
- 10+24.12369
- 100+19.33249
- 250+17.38008
- 500+16.40986
- 1000+14.94854
- 2000+13.48723
- 4000+12.50503
- 国内价格 香港价格
- 1+31.270101+4.03410
- 10+26.0146210+3.35610
- 100+20.84673100+2.68940
- 250+18.74454250+2.41820
- 500+17.69345500+2.28260
- 1000+16.116801000+2.07920
- 2000+14.540162000+1.87580
- 4000+13.489064000+1.74020
