H485CBC-RP
H485CBC-RP
    BIVAR
    发光二极管/LED 红色,翠绿色 6.5mcd,4.2mcd
H485CBC-RP 数据手册
ITEM Q'TY PART NUMBER 1 1 H-485C Quad-Level 90° LED Holder 2 4 1.8BC 1.8 Sub-Miniature Radial LED REV. PART DESCRIPTION APPROVED M. C. M. C. J. C. 1 0.043 [1.1mm] 0.535 [13.6mm] 0.200 [5.1mm] DATE 12/03/07 01/31/08 08/05/16 DESCRIPTION A Engineering Release B Updated LEDs Orientation C Engineering Update w/o Changes Ø.071 [Ø1.8mm] TYP. 0.373 [9.5mm] 0.445 [11.3mm] 4X 2 0.273 [6.9mm] 0.173 [4.4mm] 0.200 [5.1mm] Holder Face 0.073 [1.8mm] 0.157 [4.0mm] 0.150 [3.8mm] 0.100 [2.5mm] HE Red Cathode Green Cathode Chip LED Part No. 1.8BC Em itted Color GaAsP/GaP 635 HE RED GaP/GaP 568 GREEN Lens Appearance WHITE DIFFUSED 0.100 [2.5mm] 0.200 [5.1mm] 0.300 [7.6mm] 0.020 [0.5mm] SQ. TYP. Recommended Mounting Holes Absolute Max. Ratings Peak Wave Length λp (nm ) Material Ø.032+.003 -.002 TYP. 0.200 [5.1mm] 0.300 [7.6mm] 0.400 [10.2mm] 0.500 [12.7mm] 0.100 [2.5mm] ∆λ (nm ) Pd (m W) If (m A) Electro-Optical Data @ 20m A Vf (V) Peak If (m A) Iv (m cd) TYP MAX TYP 45 80 30 150 2.0 2.6 4.2 30 80 30 150 2.2 2.6 6.5 ABSOLUTE MAXIMUM RATINGS (Ta = 25°C) REVERSE VOLTAGE 5V 100µA OPERATING TEMPERATURE RANGE -25°C ~ 85°C STORAGE TEMPERATURE -30°C ~ 100°C LEAD SOLDERING TEMPERATURE (1/16" FROM BODY) 260°C for 5 Seconds 45 STANDARD TOLERANCE ® ( UNLESS OTHERWISE SPECIFIED ) DECIMALS REVERSE CURRENT ( VR=5V) View ing Angle 2 ϴ½ (Deg) .X .XX .XXX ± .1 ± .02 ± .010 DESIGNED: T. Yin CHECKED: M. Chen ANGULAR X° ± 1° 4 THOMAS, IRVINE, CA. 92618 TEL: (949) 951-8808 FAX: (949) 951-3974 TITLE: 1.8mm QUAD-LEVEL 90° LED ASSY, REVERSE POLARITY DATE: 12/03/07 DATE: 12/03/07 PART NO: REVISION: H485CBC-RP CAGE CODE : 32559 C SHEET # 1 OF 1 CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
H485CBC-RP 价格&库存
很抱歉,暂时无法提供与“H485CBC-RP”相匹配的价格&库存,您可以联系我们找货
H485CBC-RP
  • 1+18.61381
  • 1000+16.99678
  • 25000+14.72096
H485CBC-RP
  • 1+20.058411+2.58770
  • 1000+18.306591000+2.36170
  • 25000+15.8540325000+2.04530
