PART NUMBER
REV.
PART DESCRIPTION
ITEM
Q'TY
1
1
H-485C
Quad-Level Sub-Miniature (1.8mm) LED 90° Holder
2
4
1.8XXX
Sub-Miniature (1.8mm) Radial LED, See Page 2
1
DESCRIPTION
A Engineering Update w/o Changes
B Added P/N Configuration and LED Specs
C Added H485CBC & H485CBC-Y/G Specs
DATE
APPROVED
03/08/04
09/17/09
08/04/16
M. C.
T. Y.
J. C.
2
0.043 [1.1mm] TYP.
0.535 [13.6mm]
0.200 [5.1mm]
Ø.071 [Ø1.8mm]
TYP.
0.373 [9.5mm]
0.445 [11.3mm]
0.273 [6.9mm]
0.173 [4.4mm]
0.073 [1.8mm]
0.157 [4.0mm]
0.150 [3.8mm]
0.100 [2.5mm]
0.200 [5.1mm]
1
LED P/N
Single Color
BI-COLOR POLARITY
(1) CATHODE (2) CATHODE
HE RED
YELLOW
GREEN
GREEN
1.8BC
1.8BC-Y/G
1
Bi-Color 1
2
0.300 [7.6mm]
0.400 [10.2mm]
0.500 [12.7mm]
2
2
NOTE: P/N CONFIGURATION
H485CXXXXDX
H-485C
Holder Series
Holder
Face
0.200 [5.1mm]
Ø.032+.003
-.002
TYP.
- " " Standard LED
- "L" Low Current LED
Color of top LED
- "X" if blank
0.100 [2.5mm]
Lens Appearance
Color of 2nd from top LED
- "X" if blank
Color of bottom LED
- Use "X" if blank
Color of 3rd from top LED
- "X" if blank
0.100 [2.5mm]
0.200 [5.1mm]
0.300 [7.6mm]
e.g. H485CRYGXD
Series
Recommended Mounting Holes
ABSOLUTE MAXIMUM RATINGS (Ta=25° C)
REVERSE VOLTAGE
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
-If LEDs are the same,
use e.g. H485CGD
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
All Green LEDs
Diffused Lens Appearance
No LED
Green, 3rd from top
Yellow, 2nd from top
Red, top LED
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
STORAGE TEMPERATURE
0.020 [0.5mm] SQ. TYP.
T. Yin
CHECKED:
D. Green
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
FAX: (949) 951-3974
SUB-MINIATURE (1.8MM)
90° QUAD-LEVEL LED ASSEMBLY
TITLE:
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H485CXX
CAGE CODE : 32559
C
SHEET # 1 OF 2
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
LED Assy. No.
Peak Wave
Length
λ p(nm )
Electro-Optical Data
Em itted
Color
Lens
Appearance
MAX
TYP
If
(m A)
TYP
STANDARD
TYP
View ing
Angle
2 ½
(Deg)
Iv
(m cd)
Vf
(V)
LED P/N
Data @ 20m A
H485CAD
605
AMBER
DIFFUSED
2.8
1.8AD
H485CBWD
430
BLUE
DIFFUSED
4.5
10
50
1.8BWD
H485CGD
568
GREEN
DIFFUSED
2.8
1.8GD
H485CHD
625
HE RED
DIFFUSED
2.8
1.8HD
H485CRD
700
RED
DIFFUSED
2.8
2
50
1.8RD
H485CYD
590
YELLOW
DIFFUSED
2.8
10
50
1.8YD
635
HE RED
2.6
4.2
50
1.8BC
568
GREEN
WHITE
DIFFUSED
2.6
6.5
590
YELLOW
2.8
3.5
50
1.8BC-Y/G
568
GREEN
WHITE
DIFFUSED
2.8
4.5
H485CBC
H485CBC-Y/G
LOW CURRENT
Data @ 2m A
H485CADL
605
AMBER
DIFFUSED
2
2.0
2.6
2
50
1.8ADL
H485CBWDL
430
BLUE
DIFFUSED
2
3.8
4.2
1
50
1.8BWDL
H485CGDL
568
GREEN
DIFFUSED
2
2.1
2.6
2
50
1.8GDL
H485CHDL
625
HE RED
DIFFUSED
2
2.0
2.6
2
50
1.8HDL
H485CYDL
590
YELLOW
DIFFUSED
2
2.0
2.6
1
50
1.8YDL
STANDARD TOLERANCE
±10% ALL VALUES
ANGULAR
TEL: (949) 951-8808
FAX: (949) 951-3974
TITLE:
DESIGNED:
T. Yin
CHECKED:
D. Green
DATE:
03/08/04
DATE:
03/08/04
PART NO:
REVISION:
H485CXX
CAGE CODE : 32559
C
SHEET # 2 OF 2
