ITEM
Q'TY
1
1
FLPR-XX
PART NUMBER
2
1
LC-XX.X
PART DESCRIPTION
REV.
Flexible Light-Pipe Lens Cap Assembly
NOTE: FLPR ADAPTER SHIPPED NON-ASSEMBLED
SEE TABLE 1
0.320 [8.1mm]
L
D
E
F
G
H
J
K
L
M
RP note added
Added the 3HC-F LED to page 2
Updated Table For Length "L"
Updated LED Tables
Updated LED Tables
0.025 [0.6mm]
0.145 [3.7mm]
DATE
APPROVED
04/17/06
02/12/07
08/27/08
11/18/11
02/09/12
02/09/12
11/15/12
08/15/18
11/13/18
M. C.
M. C.
M. C.
T. Y.
T. Y.
T. Y.
T. Y.
M. C.
M. C.
DESCRIPTION
Added Shipping Note and Tolerance Table
Changed Length From 2.5 to 0.5 at "L" Table
Updated FLPC Hidden View and BOM
LED Data Update
0.240 [6.1mm]
0.210 [5.3mm]
2
0.475 [12.1mm]
1
0.100 [2.5mm]
TABLE 1
" L "*
BI-COLOR LED'S
Tolerance
1.0" ~ 16.0"
16.1" ~ 40.0"
40.1" ~ 80.0"
80.1" ~ 3,940.0"
* Available in 0.1" increments only
SINGLE COLOR LED
SHORT LEAD CATHODE
Add -RP suffix for Reverse Polarity
SHOULDER OF HOLDER
+.003
-.002
+.003
-.002
Recommended
Mounting Holes
SHORT
LEAD
CATHODE
RED
YELLOW
LED
PART NO.
3xBCC-F
3BC-Y/G-F
LONG
LEAD
CATHODE
GREEN
GREEN
0.300 [7.6mm]
0.100 [2.5mm]
RECOMMENDED FOOTPRINT
STANDARD TOLERANCE
(UNLESS OTHERWISE SPECIFIED)
DECIMALS
ANGULAR
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
REVERSE VOLTAGE
DESIGNED:
REVERSE CURRENT
OPERATING TEMPERATURE RANGE
STORAGE TEMPERATURE
S. IRVING
REVISED:
K. BARON
CHECKED:
LEAD SOLDERING TEMPERATURE(1/16" FROM BODY)
TD. NGUYEN
DATE:
FLPRX.X-XX
02/09/99
DATE:
11/13/18
M
CAGE CODE:
11/13/18
DATE:
FAX: (949) 951-3974
TITLE:
FLEXIBLE LIGHT-PIPE ASSY
RIGHT ANGLE, 3mm LENS CAP W/LED
REVISION:
PART NO:
32559
SCALE:
NONE
SHEET # 1 OF
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING
3
REV.
DESCRIPTION
DATE
APPROVED
See Sheet 1
VISIT WWW.BIVAR.COM FOR CURRENT LED DATASHEETS
LED DETAILS ON DATASHEETS TAKE PRECEDENCE OVER DETAILS SHOWN HERE
FLEXIBLE LIGHT
PIPE SERIES
Emitted Colors
"L" LENGTH, inches
available in 0.1" increments only
e.g. 6.0, 11.5
PART NO:
SCALE:
REVISION:
FLPRX.X-XX
M
SHEET # 2 OF 3
REV.
DESCRIPTION
DATE
APPROVED
See Sheet 1
FLEXIBLE LIGHT
PIPE SERIES
Emitted Colors
"L" LENGTH, inches
e.g. 6.0, 11.5
PART NO:
SCALE:
REVISION:
FLPRX.X-XX
M
SHEET # 3 OF 3
很抱歉,暂时无法提供与“FLPR18.0-SG”相匹配的价格&库存,您可以联系我们找货
