ITEM
1
Q'TY
1
PART NUMBER
H-402C
REV.
PART DESCRIPTION
B
C
D
E
F
T-1 (3mm) LED Holder, 90° Mount, Quad-Level, Left-End
2
2
H-400C
T-1 (3mm) LED Holder, 90° Mount, Quad-Level, Interlocking
3
1
H-403C
T-1 (3mm) LED Holder, 90° Mount, Quad-Level, Right-End
4
4
3GDL-LL
5
12
3GDL-S
T-1 (3mm) Non-Flange LED, Low Current, Long Leads
T-1 (3mm) Non-Flange Shouldered LED, Low Current
DATE
APPROVED
06/25/07
03/13/08
03/24/08
04/10/08
08/04/16
M. C.
M. C.
M. C.
M. C.
J. C.
DESCRIPTION
Changed Top Row LEDs to 3GDL-LL
Updated Protrusion and LEDs to Shouldered
Added Cut Lead Dimension
Updated to Previous Protrusion
Engineering Update w/o Changes
0.170 [4.3mm] TYP.
1
0.04 [1.0mm] MAX.
2
3
Ø.120 [Ø3.0mm] TYP.
0.560 [14.2mm]
0.740 [18.8mm]
4
4
4
4
5
5
5
5
5
5
5
5
5
5
5
5
0.840 [21.3mm]
0.540 [13.7mm]
0.340 [8.6mm]
Holder Face
Ø.032+.003
-.002 TYP.
Cathode ID
0.157 [4.0mm]
0.140 [3.6mm]
0.020 [0.5mm] SQ. TYP.
0.100 [2.5mm] TYP.
0.440 [11.2mm]
0.365 [9.3mm]
0.290 [7.4mm]
0.215 [5.5mm]
Chip
LED Part No.
3GDL-S(-LL)
Material
GaP/GaP
0.215 [5.5mm]
0.075 [1.9mm]
0.150 [3.8mm]
0.225 [5.7mm]
Em itted Color
565
GREEN
Lens
Appearance
DIFFUSED
∆λ
(nm )
30
ABSOLUTE MAXIMUM RATINGS (Ta = 25°C)
Pd
(m W)
10
If
(m A)
5
Electro-Optical Data @ 2m A
5V
REVERSE CURRENT ( VR=5V)
100µA
OPERATING TEMPERATURE RANGE
-25°C ~ 85°C
STORAGE TEMPERATURE
-30°C ~ 100°C
LEAD SOLDERING TEMPERATURE (1/16" FROM BODY)
260°C for 5 Seconds
Vf
(V)
Peak If
(m A)
Iv
(m cd)
TYP
MAX
TYP
1.9
2.2
6
View ing
Angle
(Deg)
45
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
REVERSE VOLTAGE
0.175 [4.4mm] Holder Pitch
Recommended Mounting Holes
Absolute Max. Ratings
Peak Wave
Length
λp (nm )
0.100 [2.5mm] LED Lead
.X
.XX
.XXX
± .1
± .02
± .010
DESIGNED:
S. Dam
CHECKED:
T. Yin
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
08/11/06
DATE:
08/11/06
PART NO:
FAX: (949) 951-3974
T-1 (3mm), 90° MOUNT
QUAD-LEVEL ASSEMBLY
REVISION:
H404CGDL
CAGE CODE : 32559
F
SHEET # 1 OF 1
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
很抱歉,暂时无法提供与“H404CGDL”相匹配的价格&库存,您可以联系我们找货
