BXRC-50C10K0-L-24
BXRC-50C10K0-L-24
    BRIDGELUX(普瑞)
    BXRC-50C10K0-L-24
BXRC-50C10K0-L-24 数据手册
Bridgelux Vero 29 Array Series ® ® Product Data Sheet DS33 BXRC-27x10K0 | 30x10K0 | 35x10K0 | 40x10K0 | 50x10K0 Vero Introduction Vero represents a revolutionary advancement in chip on board (COB) light source technology and innovation. Vero LED light sources simplify luminaire design and manufacturing processes, improve light quality, and define a platform for future functionality integration. Vero is available in four different light emitting surface (LES) configurations and has been engineered to reliably operate over a broad current range, enabling new degrees of flexibility in luminaire design optimization. Vero arrays deliver increased lumen density to enable improved beam control and precision lighting with 2 and 3 SDCM color control standard for clean and consistent uniform lighting. Vero includes an on board connector port to enable solder free electrical interconnect and simple easy to use mounting features to enable plug-and-play installation. Features • Efficacy of 130 lm/W typical • Vero 29 lumen output performance ranges from 2,200 to 20,500 lumens • Broad range of CCT options from 2700K to 5000K • CRI options include minimum 70, 80, and 90 • 2 and 3 SDCM color control for 2700K-4000K CCT • Reliable operation at up to 2X nominal drive current • Radial die pattern and improved lumen density • Thermally isolated solder pads • Onboard connector port • Top side part number markings Benefits • Broad application coverage for interior and exterior lighting • Flexibility for application driven lighting design requirements • High quality true color reproduction • Uniform consistent white light • Flexibility in design optimization • Improved optical control • Enhanced ease of use and manufacturability • Solderless connectivity enables plug & play installation and field upgradability • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 4 Electrical Characteristics 6 Absolute Maximum Ratings 7 Performance Curves 8 Typical Radiation Pattern 12 Typical Color Spectrum 13 Mechanical Dimensions 14 Color Binning Information 15 Packaging and Labeling 16 Design Resources 18 Precautions 18 Disclaimers 18 About Bridgelux 19 1 Product Feature Map Vero 29 is the largest form factor in the Vero family of next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please consult the Bridgelux Vero Array Series Product Brief for more information on the Vero family of products. Thermally isolated solder pads reduce manufacturing cycle time and complexity Mounting holes Polarity indication marks simplify manufacturing operator instructions Tc Measurement point Top side part number marking improves inventory management and outgoing quality control 2D Bar code provides full manufacturing traceability Radial die configuration improves lumen density and beam control Solderless connector port enables simplified manufacturing processes, reduced inventory carrying costs and can enable field upgradability Optional Molex Pico-EZmate™ connector harness (sold separately) Product Nomenclature The part number designation for Bridgelux Vero LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRC – 30 E 10K0 – L – 23 Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K CCT Bin Options 22 = 2 SDCM 23 = 3 SDCM 24 = 4 SDCM Array Configuration Minimum CRI C = 70 CRI E = 80 CRI G = 90 CRI Flux Indicator 10K0 = 10,000lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number BXRC-27E10K0-L-2x Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 2700 80 2100 10113 9864 38.0 79.8 127 BXRC-27G10K0-L-2x 2700 90 2100 8666 8277 38.0 79.8 109 BXRC-30E10K0-L-2x 3000 80 2100 10943 10388 38.0 79.8 137 BXRC-30G10K0-L-2x 3000 90 2100 9060 8351 38.0 79.8 114 BXRC-35E10K0-L-2x 3500 80 2100 11399 10299 38.0 79.8 143 BXRC-35G10K0-L-2x 3500 90 2100 9705 8979 38.0 79.8 122 BXRC-40E10K0-L-2x 4000 80 2100 11597 10769 38.0 79.8 145 BXRC-40G10K0-L-2x 4000 90 2100 9720 9385 38.0 79.8 122 BXRC-50C10K0-L-24 5000 70 2100 12034 11177 38.0 79.8 151 BXRC-50E10K0-L-24 5000 80 2100 11397 10636 38.0 79.8 143 BXRC-50G10K0-L-24 5000 90 2100 10173 9951 38.0 79.8 127 Minimum DC Flux10 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) Table 2: Selection Guide, Stabilized DC Performance (Tc = 85°C) 8,9 Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) BXRC-27E10K0-L-2x 2700 80 2100 9156 8931 36.8 77.3 118 BXRC-27G10K0-L-2x 2700 90 2100 7626 7284 36.8 77.3 99 BXRC-30E10K0-L-2x 3000 80 2100 9933 9430 36.8 77.3 129 BXRC-30G10K0-L-2x 3000 90 2100 7973 7349 36.8 77.3 103 BXRC-35E10K0-L-2x 3500 80 2100 10231 9243 36.8 77.3 132 BXRC-35G10K0-L-2x 3500 90 2100 8540 7902 36.8 77.3 111 BXRC-40E10K0-L-2x 4000 80 2100 10416 9672 36.8 77.3 135 BXRC-40G10K0-L-2x 4000 90 2100 8554 8259 36.8 77.3 111 BXRC-50C10K0-L-24 5000 70 2100 10590 9836 36.8 77.3 137 BXRC-50E10K0-L-24 5000 80 2100 10029 9360 36.8 77.3 130 BXRC-50G10K0-L-24 5000 90 2100 8952 8757 36.8 77.3 116 Part Number Typical DC Flux Tc = 85ºC (lm) Notes for Tables 1 & 2: 1. Nominal CCT as defined by ANSI C78.377-2011. 2. CRI Values are minimums. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 10. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 3 Performance at Commonly Used Drive Currents Vero LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figure 2 and the flux vs. current characteristics shown in Figure 3. The performance at commonly used drive currents is summarized in Table 3. Table 3: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E10K0-L-2x 80 BXRC-27G10K0-L-2x 90 BXRC-30E10K0-L-2x 80 BXRC-30G10K0-L-2x 90 BXRC-35E10K0-L-2x 80 BXRC-35G10K0-L-2x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Watt Tj = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tj = 25ºC (lm/W) 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 2753 3791 5536 10113 12923 14133 17227 2359 3248 4744 8666 11074 12111 14762 2979 4102 5990 10943 13984 15293 18641 2467 3396 4959 9060 11578 12662 15434 3103 4273 6240 11399 14567 15930 19418 2642 3638 5312 9705 12402 13563 16532 2461 3384 4941 9156 11584 12685 15533 2049 2819 4115 7626 9648 10565 12937 2669 3671 5360 9933 12568 13762 16851 2143 2947 4302 7973 10087 11046 13525 2749 3781 5520 10231 12944 14174 17355 2295 3156 4608 8540 10805 11832 14488 157 152 145 127 118 114 102 134 130 124 109 101 97 87 170 165 157 137 128 123 110 141 136 130 114 106 102 91 177 171 163 143 133 128 114 151 146 139 122 114 109 97 Notes for Table 3 can be found on page 5. 4 Performance at Commonly Used Drive Currents Table 3: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E10K0-L-2x 80 BXRC-40G10K0-L-2x 90 BXRC-50C10K0-L-24 70 BXRC-50E10K0-L-24 80 BXRC-50G10K0-L-24 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Watt Tj = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tj = 25ºC (lm/W) 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 500 700 1050 2100 2800 3150 4200 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 35.1 35.6 36.4 38.0 39.0 39.5 40.4 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 17.6 24.9 38.2 79.8 109.2 124.4 169.7 3157 4347 6348 11597 14820 16207 19755 2646 3643 5321 9720 12421 13584 16558 3276 4511 6587 12034 15378 16818 20500 3103 4272 6239 11397 14564 15928 19415 2770 3813 5569 10173 13000 14217 17330 2799 3850 5621 10416 13178 14431 17670 2299 3161 4615 8554 10822 11850 14510 2846 3914 5714 10590 13398 14672 17965 2695 3707 5412 10029 12689 13895 17014 2406 3309 4831 8952 11326 12403 15186 180 174 166 145 136 130 116 151 146 139 122 114 109 98 187 181 172 151 141 135 121 177 171 163 143 133 128 114 158 153 146 127 119 114 102 Notes for Table 3: 1. Alternate drive currents in Table 3 are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5 Electrical Characteristics Table 4: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆TC (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Minimum Typical Maximum 2100 35.2 38.0 40.9 -20 4200 37.3 40.4 44.0 -20 Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.06 33.6 42.2 0.07 35.7 45.3 BXRC-xxx10K0-L-2x Notes for Table 4: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± O.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± O.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 6 Absolute Maximum Ratings Table 5: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 350°C or lower for a maximum of 10 seconds Maximum Drive Current3 4200mA Maximum Peak Pulsed Drive Current4 6000mA Maximum Reverse Voltage5 -65V Notes for Table 5: 1. Please refer to Figure 1 for drive current derating. For IEC 62717 requirement, please contact Bridgelux Sales Support. 2. See Bridgelux Application Note AN31, Assembly Considerations for Vero LED arrays, for more information. 3. Please refer to Figure 1 for drive current derating curve. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20ms when operating LED Arrays at the maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where the LED array can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 7 Performance Curves The maximum allowable drive current for the Vero 29 family of products is dependent on the operating case temperature. Please refer to the Product Feature Map (page 2) for the location of the Tc Point. Figure 1: Vero 29 Drive Current Derating Curve Notes for Figure 1: 1. LM-80 Max Drive Current must not be exceeded in order to meet LM-80 lifetime projections. 2. Lumen maintenance (L70) and lifetime predictions are valid for drive current and case temperature conditions used for LM-80 testing as included in the applicable LM-80 test report for these products. Contact your Bridgelux sales representative for LM-80 report. 8 Performance Curves Figure 2: Drive Current vs. Forward Voltage (Tj = Tc = 25°C) Figure 3: Typical Relative Luminous Flux vs. Drive Current (Tj = Tc = 25°C) 9 Performance Curves Figure 4: Typical DC Flux vs. Case Temperature Figure 5: Typical DC ccy Shift vs. Case Temperature Notes for Figures 4-5: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 10 Performance Curves Figure 6: Typical DC ccx Shift vs. Case Temperature Notes for Figure 6: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 11 Typical Radiation Pattern Figure 7: Typical Spatial Radiation Pattern Notes for Figure 7: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 8: Typical Polar Radiation Pattern 12 Typical Color Spectrum Figure 9: Typical Color Spectrum Notes for Figure 9: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 13 Mechanical Dimensions Figure 10: Drawing for Vero 29 LED Array Notes for Figure 10: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ± 0.10mm. 4. Mounting holes (4X) are for M3 screws. 5. Bridgelux recommends four tapped holes for mounting screws with 43.0 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. Solder pads and connector port are labeled “+” and “-“ to denote positive and negative, respectively. 8. It is not necessary to provide electrical connections to both the solder pads and the connector port. Either set may be used depending on application specific design requirements. 9. Refer to Application Notes AN30 and AN31 for product handling, mounting and heat sink recommendations. 10. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 11. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 14 Color Binning Information Figure 11: Graph of Warm and Neutral White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 6: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K 3500K 4000K ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 23 (3SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 22 (2SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) Figure 12: Graph of Cool White Test Bins in xy Color Space Note: Pulsed Test Conditions, Tc = 25°C Table 7: Cool White xy Bin Coordinates and Associated Typical CCT Bin Code 5000K 5600K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) 24 (4SDCM) (4801K - 5282K) (5475K - 5830K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) 15 Packaging and Labeling Figure 13: Drawing for Vero 29 Packaging Tray Notes for Figure 13: 1. Dimensions are in millimeters. 2. Drawing is not to scale. 15 Packaging and Labeling Figure 14: Vero Series Packaging and Labeling Notes for Figure 14: 1. Each tray holds 50 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 15: Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number Internal Bridgelux use only. 16 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN31 for additional information. CAUTION: EYE SAFETY Eye safety classification for the use of Bridgelux Vero LED arrays is in accordance with IEC specification EN62471: Photobiological Safety of Lamps and Lamp Systems. Vero LED arrays are classified as Risk Group 1 (Low Risk) when operated at or below the maximum drive current. Please use appropriate precautions. It is important that employees working with LEDs are trained to use them safely. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 18 About Bridgelux: We Build Light That Transforms At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux WeChat ID: BridgeluxInChina 101 Portola Avenue Livermore, CA 94551 Tel (925) 583-8400 Fax (925) 583-8410 www.bridgelux.com © 2016 Bridgelux, Inc. All rights reserved 2016. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vero 29 Array Series Product Data Sheet DS33 Rev. L (06/2016) 19
BXRC-50C10K0-L-24 价格&库存
很抱歉,暂时无法提供与“BXRC-50C10K0-L-24”相匹配的价格&库存,您可以联系我们找货
