BXRE-35G2000-C-73
BXRE-35G2000-C-73
    BRIDGELUX(普瑞)
    LED Lighting COBs, Engines, Modules Chip On Board (COB) Gen 7 V13 Array White, Warm Square
BXRE-35G2000-C-73 数据手册
Bridgelux Gen 7 V13 Array Series ® Product Data Sheet DS101 1 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These chip on board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V13 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, replacement lamps, and task, accent, spot, track, wide area, security, wall pack and down lights. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and H Series™. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen lamps. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features Benefits • Efficacy of 170 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform high quality illumination • High quality true color reproduction • Minimum 65, 70, 80, 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 2, 3 and 4 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 8 Electrical Characteristics 14 Eye Safety 15 Absolute Maximum Ratings 16 Performance Curves 17 Typical Radiation Pattern 20 Typical Color Spectrum 21 Mechanical Dimensions 22 Color Binning Information 23 Packaging and Labeling 24 Design Resources 26 Precautions 26 Disclaimers 26 About Bridgelux 27 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Designed to comply with global safety standards for creepage and clearance distances Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 200 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 20 = 2,000K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen. 7 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI B = 63 CRI typ. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 200x = 2000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E2000-C-74 1750 80 630 2014 1813 34.8 21.9 92 BXRE-20B2001-B-73 2000 65 450 2455 1992 34.8 15.6 157 157 BXRE-20B2001-C-73 2000 65 630 3437 2853 34.8 21.9 BXRE-25E2000-C-74 2500 80 630 3350 3015 34.8 21.9 153 BXRE-27E2000-B-7x 2700 80 450 2502 2090 34.8 15.6 160 BXRE-27E2000-C-7x 2700 80 630 3503 2926 34.8 21.9 160 BXRE-27G20H0-B-7x 2700 90 450 2142 1928 34.8 15.6 137 BXRE-27G20H0-C-7x 2700 90 630 2999 2699 34.8 21.9 137 BXRE-27G2000-B-7x 2700 90 450 2064 1858 34.8 15.6 132 BXRE-27G2000-C-7x 2700 90 630 2890 2601 34.8 21.9 132 BXRE-27H2000-B-7x 2700 97 450 1830 1647 34.8 15.6 117 BXRE-30C2001-B-74 3000 70 450 2783 2505 34.8 15.6 178 BXRE-30C2001-C-74 3000 70 630 3897 3507 34.8 21.9 178 BXRE-30E2000-B-7x 3000 80 450 2658 2392 34.8 15.6 170 BXRE-30E2000-C-7x 3000 80 630 3722 3350 34.8 21.9 170 BXRE-30G20H0-B-7x 3000 90 450 2252 2027 34.8 15.6 144 BXRE-30G20H0-C-7x 3000 90 630 3153 2837 34.8 21.9 144 BXRE-30G2000-B-7x 3000 90 450 2158 1942 34.8 15.6 138 BXRE-30G2000-C-7x 3000 90 630 3021 2719 34.8 21.9 138 BXRE-30G200C-B-73 3000 90 450 2080 1872 34.8 15.6 133 BXRE-30G200C-C-73 3000 90 630 2912 2621 34.8 21.9 133 BXRE-30A2001-B-738,9 3000 93 450 1939 1745 34.8 15.6 124 BXRE-30A2001-C-738,9 3000 93 630 2715 2443 34.8 21.9 124 BXRE-30H2000-B-7x 3000 97 450 1955 1759 34.8 15.6 125 BXRE-35E2000-B-7x 3500 80 450 2721 2449 34.8 15.6 174 BXRE-35E2000-C-7x 3500 80 630 3809 3428 34.8 21.9 174 BXRE-35G2000-B-7x 3500 90 450 2236 2013 34.8 15.6 143 BXRE-35G2000-C-7x 3500 90 630 3131 2818 34.8 21.9 143 BXRE-35A2001-B-738,9 3500 93 450 2064 1858 34.8 15.6 132 BXRE-35A2001-C-738,9 3500 93 630 2890 2601 34.8 21.9 132 BXRE-40C2001-B-74 4000 70 450 2862 2575 34.8 15.6 183 BXRE-40C2001-C-74 4000 70 630 4006 3606 34.8 21.9 183 BXRE-40E2000-B-7x 4000 80 450 2737 2463 34.8 15.6 175 BXRE-40E2000-C-7x 4000 80 630 3831 3170 34.8 21.9 175 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-40G2000-B-7x 4000 90 450 2283 1938 34.8 15.6 146 BXRE-40G2000-C-7x 4000 90 630 3196 2713 34.8 21.9 146 BXRE-50C2001-B-7x 5000 70 450 2877 2482 34.8 15.6 184 BXRE-50C2001-C-7x 5000 70 630 4028 3475 34.8 21.9 184 177 BXRE-50E2001-B-7x 5000 80 450 2768 2491 34.8 15.6 BXRE-50E2001-C-7x 5000 80 630 3875 3266 34.8 21.9 177 BXRE-50G2001-B-7x 5000 90 450 2393 1986 34.8 15.6 153 BXRE-50G2001-C-7x 5000 90 630 3350 2780 34.8 21.9 153 BXRE-57C2001-B-7x 5700 70 450 2799 2395 34.8 15.6 179 BXRE-57C2001-C-7x 5700 70 630 3919 3353 34.8 21.9 179 BXRE-57E2001-B-7x 5700 80 450 2658 2374 34.8 15.6 170 BXRE-57E2001-C-7x 5700 80 630 3722 3322 34.8 21.9 170 BXRE-65C2001-B-7x 6500 70 450 2799 2439 34.8 15.6 179 BXRE-65C2001-C-7x 6500 70 630 3919 3414 34.8 21.9 179 BXRE-65E2001-B-7x 6500 80 450 2690 2417 34.8 15.6 172 BXRE-65E2001-C-7x 6500 80 630 3766 3383 34.8 21.9 172 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-30A2001-B-73 3000 80 93 450 1751 1576 34.4 15.5 113 BXRE-30A2001-C-73 3000 80 93 630 2452 2207 34.4 21.7 113 BXRE-35A2001-B-73 3500 80 93 450 1876 1688 34.4 15.5 121 BXRE-35A2001-C-73 3500 80 93 630 2622 2360 34.4 21.7 121 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. All CRI values are measured at Tj = Tc = 25°C. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 5 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E2000-C-74 1750 80 630 1813 1631 33.9 21.4 85 BXRE-20B2001-B-73 2000 65 450 2210 1989 33.9 15.3 145 BXRE-20B2001-C-73 2000 65 630 3093 2784 33.9 21.4 145 BXRE-25E2000-C-74 2500 80 630 3015 2713 33.9 21.4 141 BXRE-27E2000-B-7x 2700 80 450 2252 2027 33.9 15.3 148 BXRE-27E2000-C-7x 2700 80 630 3153 2837 33.9 21.4 148 BXRE-27G20H0-B-7x 2700 90 450 1928 1735 33.9 15.3 126 BXRE-27G20H0-C-7x 2700 90 630 2699 2429 33.9 21.4 126 BXRE-27G2000-B-7x 2700 90 450 1858 1672 33.9 15.3 122 BXRE-27G2000-C-7x 2700 90 630 2601 2341 33.9 21.4 122 BXRE-27H2000-B-7x 2700 97 450 1647 1482 33.9 15.3 108 BXRE-30C2001-B-74 3000 70 450 2505 2255 33.9 15.3 164 BXRE-30C2001-C-74 3000 70 630 3507 3156 33.9 21.4 164 BXRE-30E2000-B-7x 3000 80 450 2393 2153 33.9 15.3 157 BXRE-30E2000-C-7x 3000 80 630 3350 3015 33.9 21.4 157 BXRE-30G20H0-B-7x 3000 90 450 2027 1824 33.9 15.3 133 BXRE-30G20H0-C-7x 3000 90 630 2837 2554 33.9 21.4 133 BXRE-30G2000-B-7x 3000 90 450 1942 1748 33.9 15.3 127 BXRE-30G2000-C-7x 3000 90 630 2719 2447 33.9 21.4 127 BXRE-30G200C-B-73 3000 90 450 1872 1685 33.9 15.3 123 BXRE-30G200C-C-73 3000 90 630 2621 2358 33.9 21.4 123 BXRE-30A2001-B-738,9 3000 93 450 1745 1571 33.9 15.3 114 BXRE-30A2001-C-738,9 3000 93 630 2443 2199 33.9 21.4 114 BXRE-30H2000-B-7x 3000 97 450 1759 1583 33.9 15.3 115 BXRE-35E2000-B-7x 3500 80 450 2449 2204 33.9 15.3 161 BXRE-35E2000-C-7x 3500 80 630 3428 3086 33.9 21.4 161 BXRE-35G2000-B-7x 3500 90 450 2013 1811 33.9 15.3 132 BXRE-35G2000-C-7x 3500 90 630 2818 2536 33.9 21.4 132 BXRE-35A2001-B-738,9 3500 93 450 1858 1672 33.9 15.3 122 BXRE-35A2001-C-73 3500 93 630 2601 2341 33.9 21.4 122 BXRE-40C2001-B-74 4000 70 450 2575 2318 33.9 15.3 169 BXRE-40C2001-C-74 4000 70 630 3606 3245 33.9 21.4 169 BXRE-40E2000-B-7x 4000 80 450 2463 2217 33.9 15.3 161 8,9 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary 6 depending on fixture design and performance. Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) BXRE-40E2000-C-7x 4000 80 630 BXRE-40G2000-B-7x 4000 90 450 BXRE-40G2000-C-7x 4000 90 630 BXRE-50C2001-B-7x 5000 70 450 BXRE-50C2001-C-7x 5000 70 630 BXRE-50E2001-B-7x 5000 80 450 BXRE-50E2001-C-7x 5000 80 630 Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) 3448 3103 33.9 21.4 161 2055 1849 33.9 15.3 135 2877 2589 33.9 21.4 135 2590 2331 33.9 15.3 170 3625 3263 33.9 21.4 170 2491 2242 33.9 15.3 163 3487 3139 33.9 21.4 163 141 Typical Power (W) Typical Efficacy (lm/W) BXRE-50G2001-B-7x 5000 90 450 2153 1938 33.9 15.3 BXRE-50G2001-C-7x 5000 90 630 3015 2713 33.9 21.4 141 BXRE-57C2001-B-7x 5700 70 450 2519 2267 33.9 15.3 165 BXRE-57C2001-C-7x 5700 70 630 3527 3174 33.9 21.4 165 BXRE-57E2001-B-7x 5700 80 450 2393 2153 33.9 15.3 157 BXRE-57E2001-C-7x 5700 80 630 3350 3015 33.9 21.4 157 BXRE-65C2001-B-7x 6500 70 450 2519 2267 33.9 15.3 165 BXRE-65C2001-C-7x 6500 70 630 3527 3174 33.9 21.4 165 BXRE-65E2001-B-7x 6500 80 450 2421 2179 33.9 15.3 159 BXRE-65E2001-C-7x 6500 80 630 3389 3050 33.9 21.4 159 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRE-17E2000-C-74 80 BXRE-20B2001-B-7x 65 BXRE-20B2001-C-73 65 BXRE-25E2000-C-74 80 BXRE-27E2000-B-7x 80 BXRE-27E2000-C-7x 80 BXRE-27G20H0-B-7x 90 BXRE-27G20H0-C-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 548 1057 2014 2894 3693 673 1298 2455 3552 4530 935 1804 3437 4939 6302 911 1758 3350 4813 6142 686 1323 2502 3620 4616 952 1838 3503 5034 6423 587 1133 2142 3100 3953 815 1574 2999 4310 5499 519 996 1813 2707 3442 621 1191 1992 3224 4091 885 1700 2853 4619 5874 863 1657 3015 4501 5724 633 1214 2252 3286 4170 902 1733 3153 4707 5986 542 1040 1928 2813 3570 772 1484 2699 4031 5126 108 101 92 85 79 185 174 157 146 135 184 173 157 145 134 179 168 153 141 131 189 177 160 149 138 187 176 160 148 137 161 152 137 127 118 160 151 137 126 117 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-27G2000-B-7x 90 BXRE-27G2000-C-7x 90 BXRE-27H2000-B-7x 97 BXRE-30C2001-B-74 70 BXRE-30C2001-C-74 70 BXRE-30E2000-B-7x 80 BXRE-30E2000-C-7x 80 BXRE-30G20H0-B-7x 90 BXRE-30G20H0-C-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 566 1092 2064 2987 3809 786 1516 2890 4153 5299 501 968 1830 2647 3376 757 1461 2783 4000 5104 1068 2061 3897 5638 7190 728 1406 2658 3846 4905 1012 1953 3722 5348 6824 617 1191 2252 3258 4155 857 1654 3153 4530 5780 522 1002 1858 2711 3440 744 1429 2601 3884 4939 463 888 1647 2403 3049 717 1377 2505 3741 4757 986 1891 3507 5118 6494 672 1290 2393 3491 4430 958 1841 3350 5002 6360 570 1093 2027 2957 3753 812 1559 2837 4237 5388 156 146 132 123 114 154 145 132 122 113 138 130 117 109 101 208 196 178 164 152 210 197 178 165 153 200 188 170 158 147 199 187 170 157 145 170 160 144 134 124 168 158 144 133 123 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30G2000-B-7x 90 BXRE-30G2000-C-7x 90 BXRE-30G200C-B-73 90 BXRE-30G200C-C-73 90 BXRE-30A2001-B-73 93 BXRE-30A2001-C-73 93 BXRE-30H2000-B-7x 97 BXRE-35E2000-B-7x 80 BXRE-35E2000-C-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 113 225 450 675 900 158 315 630 945 1260 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 591 1141 2158 3122 3982 821 1585 3021 4341 5540 570 1100 2080 3009 3837 798 1540 2912 4213 5372 531 1025 1939 2806 3578 744 1436 2715 3928 5009 536 1034 1955 2828 3607 746 1439 2721 3937 5020 1036 1999 3809 5474 6985 546 1047 1942 2834 3596 778 1494 2719 4060 5163 526 1009 1872 2731 3466 736 1413 2621 3824 4852 490 941 1745 2546 3231 687 1317 2443 3565 4524 494 949 1759 2567 3257 688 1320 2449 3573 4534 981 1884 3428 5119 6510 163 153 138 128 119 161 152 138 127 118 157 147 133 124 115 157 147 133 123 114 146 137 124 115 107 146 137 124 115 107 147 139 125 116 108 205 193 174 162 150 203 191 174 160 149 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-35G2000-B-7x 90 BXRE-35G2000-C-7x 90 BXRE-35A2001-B-73 93 BXRE-35A2001-C-73 93 BXRE-40C2001-B-74 70 BXRE-40C2001-C-74 70 BXRE-40E2000-B-7x 80 BXRE-40E2000-C-7x 80 BXRE-40G2000-B-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 613 1183 2236 3235 4126 851 1643 3131 4499 5740 566 1092 2064 2987 3809 786 1516 2890 4153 5299 784 1513 2862 4140 5280 1089 2102 4006 5757 7346 750 1447 2737 3959 5049 1042 2010 3831 5505 7025 626 1207 2283 3303 4213 566 1085 2013 2937 3727 806 1549 2818 4207 5350 522 1002 1858 2711 3440 744 1429 2601 3884 4939 724 1389 2575 3758 4769 1032 1982 3606 5384 6847 692 1328 2463 3594 4560 987 1895 3448 5149 6547 577 1108 2055 2998 3805 169 158 143 133 123 167 157 143 132 122 156 146 132 123 114 154 145 132 122 113 216 203 183 170 158 214 201 183 169 156 206 194 175 163 151 205 192 175 161 149 172 162 146 136 126 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-40G2000-C-7x 90 BXRE-50C2001-B-7x 70 BXRE-50C2001-C-7x 70 BXRE-50E2001-B-7x 80 BXRE-50E2001-C-7x 80 BXRE-50G2001-B-7x 90 BXRE-50G2001-C-7x 90 BXRE-57C2001-B-7x 70 BXRE-57C2001-C-7x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 869 1677 3196 4593 5861 788 1522 2877 4163 5309 1095 2114 4028 5789 7386 758 1464 2768 4005 5107 1054 2033 3875 5568 7105 656 1265 2393 3462 4414 911 1758 3350 4813 6142 767 1480 2799 4050 5165 1065 2056 3919 5631 7185 823 1581 2877 4295 5462 728 1396 2590 3779 4795 1037 1993 3625 5414 6884 700 1343 2491 3635 4613 998 1917 3487 5208 6622 605 1161 2153 3142 3987 863 1657 3015 4501 5724 708 1358 2519 3676 4665 1009 1938 3527 5266 6697 171 161 146 135 125 217 204 184 171 159 215 202 184 170 157 209 196 177 165 153 207 195 177 163 151 180 170 153 142 132 179 168 153 141 131 211 198 179 166 154 209 197 179 165 153 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-57E2001-B-7x 80 BXRE-57E2001-C-7x 80 BXRE-65C2001-B-7x 70 BXRE-65C2001-C-7x 70 BXRE-65E2001-B-7x 80 BXRE-65E2001-C-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 113 225 450 675 900 158 315 630 945 1260 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 32.3 33.2 34.8 36.0 37.2 32.3 33.2 34.8 36.1 37.3 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 3.6 7.5 15.6 24.3 33.5 5.1 10.4 21.9 34.1 47.0 728 1406 2658 3846 4905 1012 1953 3722 5348 6824 767 1480 2799 4050 5165 1065 2056 3919 5631 7185 737 1422 2690 3892 4963 1024 1976 3766 5411 6904 672 1290 2393 3491 4430 958 1841 3350 5002 6360 708 1358 2519 3676 4665 1009 1938 3527 5266 6697 680 1305 2421 3532 4482 970 1863 3389 5060 6435 200 188 170 158 147 199 187 170 157 145 211 198 179 166 154 209 197 179 165 153 203 191 172 160 148 201 189 172 159 147 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.28 31.0 38.3 -14.1 0.34 33.3 40.9 37.4 -14.1 0.20 31.0 38.3 40.1 -14.1 0.24 33.4 41.0 Minimum Typical Maximum 450 32.1 34.8 37.4 -14.1 900 34.4 37.2 40.0 630 32.1 34.8 1260 34.5 37.3 BXRE-xxx200x-B-7x BXRE-xxx200x-C-7x Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 14 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx200x-B-7x BXRE-xxx200x-C-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 450 RG1 RG1 RG1 RG1 675 RG1 RG1 RG1 RG2 900 RG1 RG1 RG2 RG2 630 RG1 RG1 RG1 RG1 945 RG1 RG1 RG2 RG2 1260 RG1 RG2 RG2 RG2 6500K4 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 15 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx200x-B-7x BXRE-xxx200x-C-7x Maximum Drive Current3 900mA 1260mA Maximum Peak Pulsed Drive Current4 1290mA 1800mA Maximum Reverse Voltage5 -60V -60V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 16 Performance Curves Figure 1: V13B Drive Current vs. Voltage Figure 2: V13C Drive Current vs. Voltage 1000 1300 900 1150 700 Forward Current (mA) Forward Current (mA) 800 600 500 400 300 200 100 0 1000 850 700 550 400 250 32 33 34 35 36 37 100 38 32 33 34 Forward Voltage (V) 36 37 38 Figure 4: V13C Typical Relative Flux vs. Current Figure 3: V13B Drive Current vs. Voltage 200% 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 35 Forward Voltage (V) 120% 100% 80% 60% 120% 100% 80% 60% 40% 40% 20% 20% 0% 0% 0 100 200 300 400 500 600 Forward Current (mA) 700 800 900 1000 100 250 400 550 700 850 1000 1150 1300 Forward Current (mA) Notes for Figures 1-4: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 17 Performance Curves Figure 5: Typical DC Flux vs. Case Temperature Figure 6: Typical DC ccy Shift vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 125 Case Temperature (°C) Neutral White Cool White 25°C Pulsed Case Temperature (°C) Figure 7: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 5-7: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. Characteristics shown for warm white includes Decor Series Class A 5. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 18 Performance Curves Figure 8: 2000K, 65 CRI Color Shift vs. Case Temperature Figure 9: 3000K, 90 CRI Color Shift vs. Case Temperature1,3 0.403 0.4101 0.41 0.4099 0.4098 15°C 25°C 0.4097 45°C 0.4 45°C ccy ccy Pulsed Center Point Tc=25°C 25°C 0.401 0.4096 0.4095 65°C 0.399 65°C 0.398 0.4094 85°C 0.4093 0.397 85°C 0.4092 0.526 0.527 0.528 0.529 0.53 0.531 105°C 0.396 105°C 0.4091 0.409 0.525 15°C 0.402 Pulsed Center Point Tc=25°C 0.395 0.444 0.532 0.4445 0.445 0.4455 0.446 0.4465 0.447 ccx ccx Figure 10: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 11: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.3950 0.4323 0.4572 0.4574 0.4576 0.4578 0.4328 0.4333 0.4343 0.4348 0.4353 ccx Figure 12: 3000K Class A Color Shift vs. Case Temperature1 Figure 13: 3500K Class A Color Shift vs. Case Temperature1 0.37 0.369 15°C 0.368 25°C 0.367 0.366 15°C Pulsed Center Point Tc=25°C 0.368 25°C 0.366 45°C Pulsed Center Point Tc=25°C 45°C 0.365 ccy ccy 0.4338 0.458 ccx 0.364 0.364 70°C 0.363 70°C 0.362 85°C 85°C 0.362 0.361 0.36 0.416 0.36 105°C 0.4165 105°C 0.417 ccx 0.4175 0.418 0.4185 0.358 0.392 0.393 0.394 0.395 0.396 0.397 ccx Note for Figures 8-12: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRE-30G200C-x-73 19 Typical Radiation Pattern Figure 13: Typical Spatial Radiation Pattern Note for Figure 13: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 14: Typical Polar Radiation Pattern 20 Typical Color Spectrum Figure 15: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 15: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 16: Typical Color Spectrum for Décor Series 1 17E 25E 0.9 20B 27H 30H 0.8 Relative Spectral Power Distribution 30G (Décor Series Showcase) 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 16: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 21 Mechanical Dimensions Figure 17: Drawing for V13 LED Array Notes for Figure 17: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 22 Color Binning Information Figure 18: Warm and Neutral White Test Bins in xy Color Figure 19: Cool White Test Bins in xy Color Space Space 0.44 0.39 2500K 4SDCM 3 SDCM 4 SDCM 2700K 0.42 4 SDCM 2000K 3SDCM 0.37 3000K 5700K 4000K 0.35 1750K 4SDCM Y Y 5000K 0.36 3500K 0.4 3 SDCM 0.38 0.34 0.38 6500K 0.33 0.36 0.32 0.31 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.3 0.54 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2000K 2500K ANSI Bin (for reference only) - - - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - - - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - - - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5167, 0.336) (0.5280, 0.4100) (0.4765, 0.4137) 2700K 3000K1 (0.4578, 0.4101) 3500K1 (0.4338, 0.403) (0.4073, 0.3917) (0.4465, 0.4024)2 4000K1 (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Décor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (4590K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 23 Packaging and Labeling Figure 20: Drawing for V13 Packaging Tray Notes for Figure 20: 1. Each tube holds 25 V13 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 21.3 (W) x 9.5(H) x 505 (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm. 24 Packaging and Labeling Figure 21: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 25 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 26 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 V13 Array Series Product Data Sheet DS101 Rev. N (07/2019) 27
BXRE-35G2000-C-73 价格&库存
很抱歉,暂时无法提供与“BXRE-35G2000-C-73”相匹配的价格&库存,您可以联系我们找货
