BXRE-35E4000-C-73
BXRE-35E4000-C-73
    BRIDGELUX(普瑞)
    LEDCOBV183500KSQUARE
BXRE-35E4000-C-73 数据手册
Bridgelux Gen 7 V18 Array Series ® Product Data Sheet DS102 1 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These chip on board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V18 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, replacement lamps, and task, accent, spot, track, wide area, security, wall pack and down lights. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and H Series™. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen lamps. Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features Benefits • Efficacy of 170 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform high quality illumination • High quality true color reproduction • Minimum 65, 70, 80, 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 2, 3 and 4 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 7 Electrical Characteristics 13 Eye Safety 14 Absolute Maximum Ratings 15 Performance Curves 16 Typical Radiation Pattern 19 Typical Color Spectrum 20 Mechanical Dimensions 21 Color Binning Information 22 Packaging and Labeling 23 Design Resources 25 Precautions 25 Disclaimers 25 About Bridgelux 26 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Designed to comply with global safety standards for creepage and clearance distances Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 400 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Gen. 7 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI B = 63 CRI typ. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 400x = 4000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E4000-B-74 1750 80 900 2881 2593 34.8 31.3 92 BXRE-20B4001-C-73 2000 65 1170 6392 5753 34.8 40.7 157 BXRE-25E4000-B-74 2500 80 900 4792 4313 34.8 31.3 153 BXRE-27E4000-B-7x 2700 80 900 5011 4510 34.8 31.3 160 BXRE-27E4000-C-7x 2700 80 1170 6515 5863 34.8 40.7 160 BXRE-27G40H0-B-7x 2700 90 900 4291 3862 34.8 31.3 137 BXRE-27G40H0-C-7x 2700 90 1170 5578 5020 34.8 40.7 137 BXRE-27G4000-B-7x 2700 90 900 4134 3721 34.8 31.3 132 BXRE-27G4000-C-7x 2700 90 1170 5375 4837 34.8 40.7 132 BXRE-27H4000-B-7x 2700 97 900 3664 3298 34.8 31.3 117 BXRE-30C4001-B-74 3000 70 900 5575 5017 34.8 31.3 178 BXRE-30C4001-C-74 3000 70 1170 7247 6523 34.8 40.7 178 BXRE-30E4000-B-7x 3000 80 900 5324 4792 34.8 31.3 170 BXRE-30E4000-C-7x 3000 80 1170 6922 6230 34.8 40.7 170 144 BXRE-30G40H0-B-7x 3000 90 900 4510 4059 34.8 31.3 BXRE-30G40H0-C-7x 3000 90 1170 5863 5277 34.8 40.7 144 BXRE-30G4000-B-7x 3000 90 900 4322 3890 34.8 31.3 138 138 BXRE-30G4000-C-7x 3000 90 1170 5619 5057 34.8 40.7 BXRE-30G400C-B-73 3000 90 900 4176 3759 34.8 31.4 133 BXRE-30H4000-B-7x 3000 97 900 3915 3524 34.8 31.3 125 BXRE-35E4000-B-7x 3500 80 900 5450 4905 34.8 31.3 174 BXRE-35E4000-C-7x 3500 80 1170 7085 6376 34.8 40.7 174 BXRE-35G4000-B-7x 3500 90 900 4479 4031 34.8 31.3 143 143 BXRE-35G4000-C-7x 3500 90 1170 5822 5240 34.8 40.7 BXRE-35A4001-B-738,9 3500 93 900 4134 3721 34.8 31.3 132 BXRE-40C4001-B-74 4000 70 900 5732 5158 34.8 31.3 183 BXRE-40C4001-C-74 4000 70 1170 7451 6706 34.8 40.7 183 BXRE-40E4000-B-7x 4000 80 900 5481 4933 34.8 31.3 175 BXRE-40E4000-C-7x 4000 80 1170 7125 6413 34.8 40.7 175 BXRE-40G4000-B-7x 4000 90 900 4573 4115 34.8 31.3 146 BXRE-40G4000-C-7x 4000 90 1170 5945 5350 34.8 40.7 146 BXRE-50C4001-B-7x 5000 70 900 5763 5187 34.8 31.3 184 BXRE-50C4001-C-7x 5000 70 1170 7492 6743 34.8 40.7 184 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 177 BXRE-50E4001-B-7x 5000 80 900 5544 4989 34.8 31.3 BXRE-50E4001-C-7x 5000 80 1170 7207 6486 34.8 40.7 177 BXRE-50G4001-B-7x 5000 90 900 4792 4313 34.8 31.3 153 BXRE-50G4001-C-7x 5000 90 1170 6230 5607 34.8 40.7 153 BXRE-57C4001-B-7x 5700 70 900 5606 5046 34.8 31.3 179 BXRE-57C4001-C-7x 5700 70 1170 7288 6559 34.8 40.7 179 BXRE-57E4001-B-7x 5700 80 900 5324 4792 34.8 31.3 170 BXRE-57E4001-C-7x 5700 80 1170 6922 6230 34.8 40.7 170 BXRE-65C4001-B-7x 6500 70 900 5606 5046 34.8 31.3 179 BXRE-65C4001-C-7x 6500 70 1170 7288 6559 34.8 40.7 179 BXRE-65E4001-B-7x 6500 80 900 5387 4848 34.8 31.3 172 BXRE-65E4001-C-7x 6500 80 1170 7003 6303 34.8 40.7 172 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI BXRE-35A4001-B-73 3500 80 2 CRI Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 93 900 3845 3460 34.3 30.9 121 3 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. All CRI values are measured at Tj = Tc = 25°C. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 4 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E4000-B-74 1750 80 900 2593 2334 33.9 30.6 85 BXRE-20B4001-C-73 2000 65 1170 5753 5178 34.0 39.8 145 BXRE-25E4000-B-74 2500 80 900 4313 3881 33.9 30.6 141 BXRE-27E4000-B-7x 2700 80 900 4510 4059 33.9 30.6 148 BXRE-27E4000-C-7x 2700 80 1170 5863 5277 33.9 39.7 148 BXRE-27G40H0-B-7x 2700 90 900 3862 3476 33.9 30.6 126 BXRE-27G40H0-C-7x 2700 90 1170 5020 4518 33.9 39.7 126 BXRE-27G4000-B-7x 2700 90 900 3721 3349 33.9 30.6 122 BXRE-27G4000-C-7x 2700 90 1170 4837 4353 33.9 39.7 122 BXRE-27H4000-B-7x 2700 97 900 3298 2968 33.9 30.6 108 BXRE-30C4001-B-74 3000 70 900 5017 4516 33.9 30.6 164 BXRE-30C4001-C-74 3000 70 1170 6523 5870 33.9 39.7 164 BXRE-30E4000-B-7x 3000 80 900 4792 4313 33.9 30.6 157 BXRE-30E4000-C-7x 3000 80 1170 6230 5607 33.9 39.7 157 BXRE-30G40H0-B-7x 3000 90 900 4059 3653 33.9 30.6 133 BXRE-30G40H0-C-7x 3000 90 1170 5277 4749 33.9 39.7 133 BXRE-30G4000-B-7x 3000 90 900 3890 3501 33.9 30.6 127 BXRE-30G4000-C-7x 3000 90 1170 5057 4551 33.9 39.7 127 BXRE-30G400C-B-73 3000 90 900 3759 3383 34.0 30.6 123 BXRE-30H4000-B-7x 3000 97 900 3524 3171 33.9 30.6 115 BXRE-35E4000-B-7x 3500 80 900 4905 4414 33.9 30.6 161 BXRE-35E4000-C-7x 3500 80 1170 6376 5739 33.9 39.7 161 BXRE-35G4000-B-7x 3500 90 900 4031 3628 33.9 30.6 132 132 BXRE-35G4000-C-7x 3500 90 1170 5240 4716 33.9 39.7 BXRE-35A4001-B-738,9 3500 93 900 3721 3349 33.9 30.6 122 BXRE-40C4001-B-74 4000 70 900 5158 4643 33.9 30.6 169 BXRE-40C4001-C-74 4000 70 1170 6706 6035 33.9 39.7 169 BXRE-40E4000-B-7x 4000 80 900 4933 4440 33.9 30.6 161 BXRE-40E4000-C-7x 4000 80 1170 6413 5771 33.9 39.7 161 BXRE-40G4000-B-7x 4000 90 900 4115 3704 33.9 30.6 135 BXRE-40G4000-C-7x 4000 90 1170 5350 4815 33.9 39.7 135 BXRE-50C4001-B-7x 5000 70 900 5187 4668 33.9 30.6 170 BXRE-50C4001-C-7x 5000 70 1170 6743 6068 33.9 39.7 170 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 5 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-50E4001-B-7x 5000 80 900 4989 4490 33.9 30.6 163 BXRE-50E4001-C-7x 5000 80 1170 6486 5837 33.9 39.7 163 BXRE-50G4001-B-7x 5000 90 900 4313 3881 33.9 30.6 141 BXRE-50G4001-C-7x 5000 90 1170 5607 5046 33.9 39.7 141 BXRE-57C4001-B-7x 5700 70 900 5046 4541 33.9 30.6 165 BXRE-57C4001-C-7x 5700 70 1170 6559 5903 33.9 39.7 165 BXRE-57E4001-B-7x 5700 80 900 4792 4313 33.9 30.6 157 BXRE-57E4001-C-7x 5700 80 1170 6230 5607 33.9 39.7 157 BXRE-65C4001-B-7x 6500 70 900 5046 4541 33.9 30.6 165 BXRE-65C4001-C-7x 6500 70 1170 6559 5903 33.9 39.7 165 BXRE-65E4001-B-7x 6500 80 900 4848 4364 33.9 30.6 159 BXRE-65E4001-C-7x 6500 80 1170 6303 5673 33.9 39.7 159 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Décor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. 4. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 6 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1 & 2 and the flux vs. current characteristics shown in Figures 3 & 4. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRE-17E4000-B-74 80 BXRE-20B4001-C-73 65 BXRE-25E4000-B-74 80 BXRE-27E4000-B-7x 80 BXRE-27E4000-C-7x 80 BXRE-27G40H0-B-7x 90 BXRE-27G40H0-C-7x 90 BXRE-27G4000-B-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 1524 1997 2881 4169 5317 3293 4312 6392 8974 11420 2534 3321 4792 6933 8842 2650 3473 5011 7250 9246 3355 4395 6515 9145 11639 2269 2974 4291 6208 7917 2873 3763 5578 7831 9966 2186 2865 4134 5982 7628 1396 1826 2593 3782 4800 2901 3779 5753 7659 9578 2321 3037 4313 6289 7982 2428 3176 4510 6577 8347 2956 3851 5863 7805 9761 2079 2719 3862 5632 7147 2531 3297 5020 6683 8358 2003 2620 3721 5426 6886 102 99 92 85 79 170 164 157 141 130 170 164 153 142 131 177 171 160 148 137 173 167 160 144 133 152 147 137 127 117 148 143 137 123 114 146 141 132 122 113 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 7 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-27G4000-C-7x 90 BXRE-27H4000-B-7x 97 BXRE-30C4001-B-74 70 BXRE-30C4001-C-74 70 BXRE-30E4000-B-7x 80 BXRE-30E4000-C-7x 80 BXRE-30G40H0-B-7x 90 BXRE-30G40H0-C-7x 90 BXRE-30G4000-B-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 450 600 900 1350 1800 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 2768 3626 5375 7545 9602 1938 2540 3664 5302 6761 2871 3761 5575 7826 9960 3833 5023 7247 10486 13372 2816 3690 5324 7704 9824 3565 4669 6922 9717 12366 2385 3126 4510 6525 8322 3020 3955 5863 8231 10475 2286 2996 4322 6254 7975 2439 3177 4837 6439 8053 1775 2322 3298 4809 6104 2530 3295 5017 6679 8354 3511 4593 6523 9512 12072 2579 3374 4792 6988 8869 3141 4092 6230 8293 10372 2185 2858 4059 5919 7512 2660 3466 5277 7025 8785 2094 2739 3890 5673 7199 143 138 132 119 110 130 125 117 108 100 192 186 178 160 148 197 191 178 165 153 188 182 170 157 146 184 177 170 153 141 160 154 144 133 123 155 150 144 129 120 153 148 138 128 118 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30G4000-C-7x 90 BXRE-30G400C-B-73 90 BXRE-30H4000-B-7x 97 BXRE-35E4000-B-7x 80 BXRE-35E4000-C-7x 80 BXRE-35G4000-B-7x 90 BXRE-35G4000-C-7x 90 BXRE-35A4001-B-73 93 BXRE-40C4001-B-74 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 450 600 900 1350 1800 450 600 900 1350 1800 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 450 600 900 1350 1800 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.3 37.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 14.9 20.3 31.4 49.0 67.5 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 14.9 20.3 31.4 49.0 67.5 2894 3790 5619 7888 10038 2209 2895 4176 6042 7706 2070 2713 3915 5664 7224 2882 3777 5450 7885 10055 3649 4779 7085 9945 12657 2369 3104 4479 6480 8264 2999 3928 5822 8173 10402 2186 2865 4134 5982 7628 2952 3866 5732 8046 10240 2550 3321 5057 6732 8419 2023 2646 3759 5481 6956 1897 2481 3524 5138 6521 2640 3453 4905 7152 9078 3215 4188 6376 8488 10616 2170 2838 4031 5878 7460 2642 3442 5240 6976 8724 2003 2620 3721 5426 6886 2601 3388 5158 6867 8588 149 144 138 124 115 148 143 133 123 114 139 134 125 116 107 193 186 174 161 149 188 181 174 156 144 159 153 143 132 122 154 149 143 129 119 146 141 132 122 113 198 191 183 164 152 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-40C4001-C-74 70 BXRE-40E4000-B-7x 80 BXRE-40E4000-C-7x 80 BXRE-40G4000-B-7x 90 BXRE-40G4000-C-7x 90 BXRE-50C4001-B-7x 70 BXRE-50C4001-C-7x 70 BXRE-50E4001-B-7x 80 BXRE-50E4001-C-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 3940 5164 7451 10781 13748 2899 3799 5481 7930 10113 3670 4807 7125 10002 12730 2418 3169 4573 6616 8437 3062 4010 5945 8345 10620 3048 3994 5763 8338 10633 3859 5054 7492 10517 13384 2932 3842 5544 8021 10229 3712 4862 7207 10117 12875 3610 4722 6706 9779 12411 2655 3473 4933 7194 9130 3233 4212 6413 8537 10677 2215 2898 4115 6001 7617 2697 3514 5350 7122 8907 2792 3652 5187 7563 9599 3399 4428 6743 8976 11226 2686 3513 4989 7276 9234 3270 4260 6486 8634 10799 203 196 183 169 157 194 187 175 162 150 189 183 175 157 145 162 156 146 135 125 158 152 146 131 121 204 197 184 170 158 199 192 184 165 153 196 190 177 164 152 191 185 177 159 147 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-50G4001-B-7x 90 BXRE-50G4001-C-7x 90 BXRE-57C4001-B-7x 70 BXRE-57C4001-C-7x 70 BXRE-57E4001-B-7x 80 BXRE-57E4001-C-7x 80 BXRE-65C4001-B-7x 70 BXRE-65C4001-C-7x 70 BXRE-65E4001-C-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 585 780 1170 1755 2340 450 600 900 1350 1800 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 33.2 33.8 34.8 36.2 37.5 33.2 33.8 34.8 36.3 37.5 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 19.4 26.3 40.8 63.6 87.6 14.9 20.3 31.4 49.0 67.5 2534 3321 4792 6933 8842 3209 4202 6230 8745 11129 2965 3886 5606 8111 10344 3754 4917 7288 10231 13021 2816 3690 5324 7704 9824 3565 4669 6922 9717 12366 2965 3886 5606 8111 10344 3754 4917 7288 10231 13021 2849 3734 5387 7794 9940 2321 3037 4313 6289 7982 2827 3682 5607 7464 9334 2716 3553 5046 7358 9338 3307 4308 6559 8732 10921 2579 3374 4792 6988 8869 3141 4092 6230 8293 10372 2716 3553 5046 7358 9338 3307 4308 6559 8732 10921 2610 3414 4848 7070 8973 170 164 153 142 131 165 160 153 137 127 198 192 179 166 153 193 187 179 161 149 188 182 170 157 146 184 177 170 153 141 198 192 179 166 153 193 187 179 161 149 191 184 172 159 147 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number BXRE-65E4001-C-7x CRI Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 80 585 780 1170 1755 2340 33.2 33.8 34.8 36.2 37.5 19.4 26.3 40.8 63.6 87.6 3607 4724 7003 9831 12512 3178 4140 6303 8390 10494 186 179 172 155 143 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRE-xxx400x-B-7x BXRE-xxx400x-C-7x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.15 31.1 38.4 -14.5 0.18 33.5 41.2 37.5 -14.5 0.11 31.1 38.4 40.3 -14.5 0.13 33.5 41.2 Minimum Typical Maximum 900 32.2 34.8 37.5 -14.5 1800 34.7 37.5 40.3 1170 32.2 34.8 2340 34.6 37.5 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 13 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx400x-B-7x BXRE-xxx400x-C-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 900 RG1 RG1 RG1 RG1 1350 RG1 RG1 RG1 RG2 1800 RG1 RG1 RG2 RG2 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 14 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx400x-B-7x BXRE-xxx400x-C-7x Maximum Drive Current3 1800mA 2340mA Maximum Peak Pulsed Drive Current4 2570mA 3340mA Maximum Reverse Voltage5 -60V -60V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 15 Performance Curves Figure 2: V18C Drive Current vs. Voltage 2000 2500 1800 2250 1600 2000 1400 1750 Forward Current (mA) Forward Current (mA) Figure 1: V18B Drive Current vs. Voltage 1200 1000 800 600 1500 1250 1000 750 400 500 200 250 0 32 33 34 35 36 37 0 38 32 33 34 200% 180% 180% 160% 160% 140% 140% Relative Luminous Flux Relative Luminous Flux 200% 120% 100% 80% 60% 80% 60% 40% 20% 0% 600 800 1000 1200 Forward Current (mA) 38 100% 20% 400 37 120% 40% 200 36 Figure 4: V18C Typical Relative Flux vs. Current Figure 3: V18B Typical Relative Flux vs. Current 0 35 Forward Voltage (V) Forward Voltage (V) 1400 1600 1800 2000 0% 0 250 500 750 1000 1250 1500 1750 2000 2250 2500 Forward Current (mA) Notes for Figures 1-4: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 16 Performance Curves Figure 5: Typical DC Flux vs. Case Temperature Figure 6: Typical DC ccy Shift vs. Case Temperature 0 103% Neutral White 50 75 100 125 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 100% 25 0.003 Warm White 94% 91% -0.006 -0.009 88% Warm White Neutral White -0.012 85% Cool White 25°C Pulsed -0.015 82% 0 25 50 75 100 125 Case Temperature (°C) Case Temperature (°C) Figure 8: 1750K Color Shift vs. Case Temperature1 Figure 7: Typical DC ccx Shift vs. Case Temperature 0.3705 0 25 50 75 100 125 0.37 0.000 Pulsed Center Point Tc = 25°C 15°C 25°C -0.002 0.3695 45°C ccy ccx Shift -0.004 -0.006 0.369 70°C -0.008 85°C Warm White -0.010 -0.012 Neutral White 0.3685 Cool White 105°C 25°C Pulsed Case Temperature (°C) 0.368 0.5196 0.5198 0.52 0.5202 0.5204 0.5206 ccx Notes for Figures 5-7: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 17 Performance Curves Figure 9: 2000K, 65 CRI Color Shift vs. Case Temperature Figure 10: 2500K Color Shift vs. Case Temperature1 0.4145 0.4101 0.41 15°C 0.413 45°C 0.4096 0.4095 65°C 0.4093 45°C 0.4125 70°C 0.412 0.4094 85°C 0.4115 85°C 0.4092 0.526 0.527 0.528 0.529 0.53 0.531 105°C 0.411 105°C 0.4091 0.409 0.525 0.4105 0.468 0.532 0.47 0.472 0.474 ccx 0.476 0.478 ccx Figure 11: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 12: 3000K, 90 CRI Color Shift vs. Case Temperature3 0.4110 0.403 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 15°C 0.402 Pulsed Center Point Tc=25°C 25°C 0.401 0.4090 0.4080 45°C 0.4 45°C ccy ccy Pulsed Center Point Tc = 25°C 0.4135 25°C 0.4097 ccy 25°C ccy 0.4099 0.4098 15°C 0.414 Pulsed Center Point Tc=25°C 0.4070 0.399 65°C 65°C 0.398 0.4060 85°C 0.397 85°C 0.4050 105°C 0.396 0.4040 105°C 0.4030 0.457 0.4572 0.4574 0.4576 0.4578 0.395 0.444 0.458 0.4445 0.445 0.4455 0.446 0.4465 0.447 ccx ccx Figure 13: 3000K, 97 CRI Color Shift vs. Case Temperature1 Figure 14: 3500K Class A Color Shift vs. Case Temperature1 0.4050 0.37 15°C Pulsed Center Point Tc = 25°C 15°C 0.4030 25°C 0.368 25°C 0.366 0.4010 45°C ccy ccy 45°C 70°C 0.3990 0.364 70°C 0.362 85°C 0.3970 Pulsed Center Point Tc=25°C 105°C 85°C 0.36 105°C 0.3950 0.4323 0.4328 0.4333 0.4338 0.4343 0.4348 0.4353 ccx 0.358 0.392 0.393 0.394 0.395 0.396 0.397 ccx Note for Figures 8-14: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRE-30G400C-x-73 18 Typical Radiation Pattern Figure 15: Typical Spatial Radiation Pattern Note for Figure 15: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 16: Typical Polar Radiation Pattern 19 Typical Color Spectrum Figure 17: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 17: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 18: Typical Color Spectrum for Décor Series 1 17E 20B 0.9 25E 27H 0.8 30G (Décor Series Showcase) Relative Spectral Power Distribution 30H 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 18: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 20 Mechanical Dimensions Figure 19: Drawing for V18 LED Array Notes for Figure 19; 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 21 Color Binning Information Figure 20: Warm and Neutral White Test Bins in xy Color Space 0.44 2500K 4SDCM 3 SDCM 4 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 1750K 2000K 2500K ANSI Bin (for reference only) - - - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - - - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - - - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5167, 0.336) (0.5280, 0.4100) (0.4765, 0.4137) 2700K 3000K1 (0.4578, 0.4101) 3500K1 4000K1 (0.4338, 0.403) (0.4073, 0.3917) (0.3818, 0.3797) (0.4465, 0.4024)2 Note for Table 8: 1. Color Binning information excludes Décor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Figure 21: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 22 Packaging and Labeling Figure 22: Drawing for V18 Packaging Tube Notes for Figure 22: 1. Each tube holds 20 V18 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 26.3 (W) x 9.5(H) x 510 (L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm 23 Packaging and Labeling Figure 23: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 24 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 25 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2018-2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 V18 Array Series Product Data Sheet DS102 Rev. N (03/2019) 26
BXRE-35E4000-C-73 价格&库存
很抱歉,暂时无法提供与“BXRE-35E4000-C-73”相匹配的价格&库存,您可以联系我们找货
BXRE-35E4000-C-73
  • 600+76.32368600+9.79005
