BXRE-27E6500-B-73
BXRE-27E6500-B-73
    BRIDGELUX(普瑞)
    LED Lighting COBs, Engines, Modules Chip On Board (COB) Gen 7 V22 Array White, Warm Square
BXRE-27E6500-B-73 数据手册
Bridgelux Gen 7 V22 Array Series ® Product Data Sheet DS103 1 V Series Introduction The V Series™ LED Array products deliver high quality light in a compact and cost-effective solid-state lighting package. These chip on board (CoB) arrays can be efficiently driven at twice the nominal drive current, enabling design flexibility not previously possible. This high flux density light source is designed to support a wide range of high quality, low cost directional luminaires and replacement lamps for commercial and residential applications. The V22 LED Array is available in a variety of electrical, CCT and CRI combinations providing substantial design flexibility and energy efficiencies. Lighting system designs incorporating these LED arrays deliver increased system level efficacy and longer service life. Typical applications include, replacement lamps, and task, accent, spot, track, wide area, security, wall pack and down lights. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and H Series™. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is designed as a replacement for halogen lamps. Décor Series™ Food products offer color points developed to address the unique requirements of the food, grocery, and restaurant industries. Highlighting the distinctive colors and nuanced patterns found in meats and breads, the Décor Series Food products are a must have for any butcher counter or bakery. Décor Series ™ Entertainment products provide color points developed specifically for the healthcare and entertainment industries. The 5600K cool white color point combined with a CRI of 90 or 97 provides the bright white required by these industries. Décor Series™ Street and Landmark is designed to be a direct replacement for high pressure sodium lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features Benefits • Efficacy of 170 lm/W typical • Enhanced optical control • Compact high flux density light source • Clean white light without pixilation • Uniform high quality illumination • High quality true color reproduction • Minimum 65, 70, 80, 90 and 95 CRI options • Significantly reduced thermal resistance and increased operating temperatures • Streamlined thermal path • ENERGY STAR® / ANSI compliant color binning structure with 2, 3 and 4 SDCM options • Uniform consistent white light • Lower operating costs • More energy efficient than incandescent, halogen and fluorescent lamps • Easy to use with daylight and motion detectors to enable increased energy savings • Low voltage DC operation • Reduced maintenance costs • Instant light with unlimited dimming • Environmentally friendly, no disposal issue • Vf bin code backside marking Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 9 Electrical Characteristics 17 Eye Safety 18 Absolute Maximum Ratings 19 Performance Curves 20 Typical Radiation Pattern 24 Typical Color Spectrum 25 Mechanical Dimensions 26 Color Binning Information 27 Packaging and Labeling 28 Design Resources 30 Precautions 30 Disclaimers 30 About Bridgelux 31 1 Product Feature Map Bridgelux arrays are fully engineered devices that provide consistent thermal and optical performance on an engineered mechanical platform. The V Series arrays are the most compact chip-on-board devices across all of Bridgelux’s LED Array products. The arrays incorporate several features to simplify design integration and assembly. Please visit www.bridgelux.com for more information on the V Series family of products. Polarity symbols Designed to comply with global safety standards for creepage and clearance distances Fully engineered substrate for consistent thermal, mechanical and optical properties White ring around LES Yellow phosphor Light Emitting Surface (LES) Case Temperature (Tc) Measurement Point Solder Pads Note: Part number and lot codes are scribed on back of array Product Nomenclature The part number designation for Bridgelux V Series LED arrays is explained as follows: 1 2 3 4 5 6 7 8 9 10 11 – 12 – 13 14 BXRE – 30 E 650 0 – C – 7 3 CCT Bin Options Product Family Nominal CCT 17 = 1,750K 20 = 2,000K 25 = 2,500K 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 56 = 5,600K 57 = 5,700K 65 = 6,500K Gen. 7 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Array Configuration CRI B = 63 CRI typ. C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Décor Series Showcase Target Flux Indicator 650x = 6500 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E6500-D-74 1750 80 1400 4508 4057 35.0 49.0 92 BXRE-20B6501-C-73 2000 65 1440 11756 10581 52.0 74.9 157 157 BXRE-20B6501-D-73 2000 65 1400 7693 6924 35.0 49.0 BXRE-25E6500-D-74 2500 80 1400 7497 6747 35.0 49.0 153 BXRE-27E6500-B-7x 2700 80 1170 9734 8761 52.0 60.8 160 BXRE-27E6500-C-7x 2700 80 1440 11981 10783 52.0 74.9 160 BXRE-27E6500-D-7x 2700 80 1400 7840 7056 35.0 49.0 160 BXRE-27G65H0-B-7x 2700 90 1170 8335 7502 52.0 60.8 137 BXRE-27G65H0-C-7x 2700 90 1440 10259 9233 52.0 74.9 137 BXRE-27G65H0-D-7x 2700 90 1400 6713 6042 35.0 49.0 137 BXRE-27G6500-B-7x 2700 90 1170 8031 7228 52.0 60.8 132 BXRE-27G6500-C-7x 2700 90 1440 9884 8896 52.0 74.9 132 BXRE-27G6500-D-7x 2700 90 1400 6468 5821 35.0 49.0 132 BXRE-27H6500-D-7x 2700 97 1400 5733 5160 35.0 49.0 117 BXRE-30C6501-B-74 3000 70 1170 10830 9747 52.0 60.8 178 178 BXRE-30C6501-C-74 3000 70 1440 13329 11996 52.0 74.9 BXRE-30C6501-D-74 3000 70 1400 8722 7850 35.0 49.0 178 BXRE-30E6500-B-7x10 3000 80 1170 10343 9309 52.0 60.8 170 BXRE-30E6500-C-7x10 3000 80 1440 12730 11457 52.0 74.9 170 BXRE-30E6500-D-7x10 3000 80 1400 8330 7497 35.0 49.0 170 BXRE-30G65H0-B-7x 3000 90 1170 8761 7885 52.0 60.8 144 BXRE-30G65H0-C-7x 3000 90 1440 10783 9704 52.0 74.9 144 BXRE-30G65H0-D-7x 3000 90 1400 7056 6350 35.0 49.0 144 BXRE-30G6500-B-7x 3000 90 1170 8396 7556 52.0 60.8 138 BXRE-30G6500-C-7x 3000 90 1440 10333 9300 52.0 74.9 138 BXRE-30G6500-D-7x 3000 90 1400 6762 6086 35.0 49.0 138 BXRE-30G650C-D-73 3000 90 1400 6517 5865 35.0 49.0 133 BXRE-30H6500-D-7x 3000 97 1400 6125 5513 35.0 49.0 125 BXRE-35E6500-B-7x10 3500 80 1170 10586 9528 52.0 60.8 174 BXRE-35E6500-C-7x10 3500 80 1440 13029 11726 52.0 74.9 174 BXRE-35E6500-D-7x10 3500 80 1400 8526 7673 35.0 49.0 174 BXRE-35G6500-B-7x 3500 90 1170 8700 7830 52.0 60.8 143 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 3 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) 90 1440 10708 9637 90 1400 7007 6306 Part Number Nominal CCT1 (K) CRI BXRE-35G6500-C-7x 3500 BXRE-35G6500-D-7x 3500 BXRE-35A6501-D-73 2 Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Power (W) Typical Efficacy (lm/W) 52.0 74.9 143 35.0 49.0 143 Typical Vf (V) 3500 93 1400 6468 5821 35.0 49.0 132 BXRE-40C6501-B-74 4000 70 1170 11134 10020 52.0 60.8 183 8,9 BXRE-40C6501-C-74 4000 70 1440 13703 12333 52.0 74.9 183 BXRE-40C6501-D-74 4000 70 1400 8967 8070 35.0 49.0 183 BXRE-40E6500-B-7X10 4000 80 1170 10647 9582 52.0 60.8 175 BXRE-40E6500-C-7x 10 4000 80 1440 13104 11794 52.0 74.9 175 BXRE-40E6500-D-7x10 4000 80 1400 8575 7718 35.0 49.0 175 BXRE-40G6500-B-7x 4000 90 1170 8883 7994 52.0 60.8 146 BXRE-40G6500-C-7x 4000 90 1440 10932 9839 52.0 74.9 146 BXRE-40G6500-D-7x 4000 90 1400 7154 6439 35.0 49.0 146 BXRE-40H6500-D-73 4000 97 1400 6468 5821 35.0 49.0 132 BXRE-50C6501-B-7x10 5000 70 1170 11195 10075 52.0 60.8 184 BXRE-50C6501-C-7x10 5000 70 1440 13778 12400 52.0 74.9 184 BXRE-50C6501-D-7x10 5000 70 1400 9016 8114 35.0 49.0 184 BXRE-50E6501-B-7x10 5000 80 1170 10769 9692 52.0 60.8 177 BXRE-50E6501-C-7x 10 5000 80 1440 13254 11928 52.0 74.9 177 BXRE-50E6501-D-7x10 5000 80 1400 8673 7806 35.0 49.0 177 BXRE-50G6501-B-7x 5000 90 1170 9309 8378 52.0 60.8 153 BXRE-50G6501-C-7x 5000 90 1440 11457 10311 52.0 74.9 153 BXRE-50G6501-D-7x 5700 90 1400 7497 6747 35.0 49.0 153 BXRE-56G6501-D-7x 5600 90 1400 7546 6791 35.0 49.0 154 BXRE-57C6501-B-7x10 5700 70 1170 10890 9801 52.0 60.8 179 BXRE-57C6501-C-7x10 5700 70 1440 13404 12063 52.0 74.9 179 BXRE-57C6501-D-7x10 5700 70 1400 8771 7894 35.0 49.0 179 BXRE-57E6501-B-7x10 5700 80 1170 10343 9309 52.0 60.8 170 BXRE-57E6501-C-7x10 5700 80 1440 12730 11457 52.0 74.9 170 BXRE-57E6501-D-7x10 6500 80 1400 8330 7497 35.0 49.0 170 BXRE-65C6501-B-7x10 6500 70 1170 10890 9801 52.0 60.8 179 BXRE-65C6501-C-7x10 6500 70 1440 13404 12063 52.0 74.9 179 BXRE-65C6501-D-7x10 6500 70 1400 8771 7894 35.0 49.0 179 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 4 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-65E6501-B-7x10 6500 80 1170 10464 9418 52.0 60.8 172 BXRE-65E6501-C-7x10 6500 80 1440 12879 11591 52.0 74.9 172 BXRE-65E6501-D-7x 6500 80 1400 8428 7585 35.0 49.0 172 10 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 10. SKUs meet DLC premium (Outdoor Mid Output) requirements under certain system level conditions. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-35A6501-D-73 3500 80 93 1400 6015 5414 33.4 46.8 129 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. All CRI values are measured at Tj = Tc = 25°C. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRE-17E6500-D-74 1750 80 1400 4057 3651 33.4 46.8 87 BXRE-20B6501-C-73 2000 65 1440 10581 9522 50.7 73.0 145 148 BXRE-20B6501-D-73 2000 65 1400 6924 6231 33.4 46.8 BXRE-25E6500-D-74 2500 80 1400 6747 6073 33.4 46.8 144 BXRE-27E6500-B-7x 2700 80 1170 8761 7885 50.7 59.3 148 BXRE-27E6500-C-7x 2700 80 1440 10783 9704 50.7 73.0 148 BXRE-27E6500-D-7x 2700 80 1400 7056 6350 33.4 46.8 151 127 BXRE-27G65H0-B-7x 2700 90 1170 7502 6751 50.7 59.3 BXRE-27G65H0-C-7x 2700 90 1440 9233 8309 50.7 73.0 127 BXRE-27G65H0-D-7x 2700 90 1400 6042 5438 33.4 46.8 129 122 BXRE-27G6500-B-7x 2700 90 1170 7228 6505 50.7 59.3 BXRE-27G6500-C-7x 2700 90 1440 8896 8006 50.7 73.0 122 BXRE-27G6500-D-7x 2700 90 1400 5821 5239 33.4 46.8 124 BXRE-27H6500-D-7x 2700 97 1400 5160 4644 33.4 46.8 110 164 BXRE-30C6501-B-74 3000 70 1170 9747 8772 50.7 59.3 BXRE-30C6501-C-74 3000 70 1440 11996 10796 50.7 73.0 164 BXRE-30C6501-D-74 3000 70 1400 7850 7065 33.4 46.8 168 157 BXRE-30E6500-B-7x 3000 80 1170 9309 8378 50.7 59.3 BXRE-30E6500-C-7x 3000 80 1440 11457 10311 50.7 73.0 157 BXRE-30E6500-D-7x 3000 80 1400 7497 6747 33.4 46.8 160 133 BXRE-30G65H0-B-7x 3000 90 1170 7885 7096 50.7 59.3 BXRE-30G65H0-C-7x 3000 90 1440 9704 8734 50.7 73.0 133 BXRE-30G65H0-D-7x 3000 90 1400 6350 5715 33.4 46.8 136 127 BXRE-30G6500-B-7x 3000 90 1170 7556 6801 50.7 59.3 BXRE-30G6500-C-7x 3000 90 1440 9300 8370 50.7 73.0 127 BXRE-30G6500-D-7x 3000 90 1400 6086 5477 33.4 46.8 130 BXRE-30G650C-D-73 3000 90 1400 5865 5279 33.4 46.8 125 BXRE-30H6500-D-7x 3000 97 1400 5513 4961 33.4 46.8 118 BXRE-35E6500-B-7x 3500 80 1170 9528 8575 50.7 59.3 161 BXRE-35E6500-C-7x 3500 80 1440 11726 10554 50.7 73.0 161 BXRE-35E6500-D-7x 3500 80 1400 7673 6906 33.4 46.8 164 BXRE-35G6500-B-7x 3500 90 1170 7830 7047 50.7 59.3 132 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Nominal Drive Current3 (mA) Part Number Nominal CCT1 (K) CRI2 BXRE-35G6500-C-7x 3500 90 1440 BXRE-35G6500-D-7x 3500 90 1400 Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) 9637 8673 50.7 73.0 132 6306 5676 33.4 46.8 135 Typical Power (W) Typical Efficacy (lm/W) BXRE-35A6501-D-737,8 3500 93 1400 5821 5239 33.4 46.8 124 BXRE-40C6501-B-74 4000 70 1170 10020 9018 50.7 59.3 169 BXRE-40C6501-C-74 4000 70 1440 12333 11099 50.7 73.0 169 BXRE-40C6501-D-74 4000 70 1400 8070 7263 33.4 46.8 173 BXRE-40E6500-B-7x 4000 80 1170 9582 8624 50.7 59.3 162 BXRE-40E6500-C-7x 4000 80 1440 11794 10614 50.7 73.0 162 BXRE-40E6500-D-7x 4000 80 1400 7718 6946 33.4 46.8 165 135 BXRE-40G6500-B-7x 4000 90 1170 7994 7195 50.7 59.3 BXRE-40G6500-C-7x 4000 90 1440 9839 8855 50.7 73.0 135 BXRE-40G6500-D-7x 4000 90 1400 6439 5795 33.4 46.8 138 BXRE-40H6500-D-73 4000 97 1400 5821 5239 33.4 46.8 124 BXRE-50C6501-B-7x 5000 70 1170 10075 9068 50.7 59.3 170 170 BXRE-50C6501-C-7x 5000 70 1440 12400 11160 50.7 73.0 BXRE-50C6501-D-7x 5000 70 1400 8114 7303 33.4 46.8 174 BXRE-50E6501-B-7x 5000 80 1170 9692 8723 50.7 59.3 163 BXRE-50E6501-C-7x 5000 80 1440 11928 10736 50.7 73.0 163 BXRE-50E6501-D-7x 5000 80 1400 7806 7025 33.4 46.8 167 141 BXRE-50G6501-B-7x 5000 90 1170 8378 7540 50.7 59.3 BXRE-50G6501-C-7x 5000 90 1440 10311 9280 50.7 73.0 141 BXRE-50G6501-D-7x 5700 90 1400 6747 6073 33.4 46.8 144 BXRE-56G6501-D-7x 5600 90 1400 6791 6112 33.4 46.8 145 BXRE-57C6501-B-7x 5700 70 1170 9801 8821 50.7 59.3 165 BXRE-57C6501-C-7x 5700 70 1440 12063 10857 50.7 73.0 165 BXRE-57C6501-D-7x 5700 70 1400 7894 7105 33.4 46.8 169 BXRE-57E6501-B-7x 5700 80 1170 9309 8378 50.7 59.3 157 BXRE-57E6501-C-7x 5700 80 1440 11457 10311 50.7 73.0 157 BXRE-57E6501-D-7x 6500 80 1400 7497 6747 33.4 46.8 160 165 BXRE-65C6501-B-7x 6500 70 1170 9801 8821 50.7 59.3 BXRE-65C6501-C-7x 6500 70 1440 12063 10857 50.7 73.0 165 BXRE-65C6501-D-7x 6500 70 1400 7894 7105 33.4 46.8 169 BXRE-65E6501-B-7x 6500 80 1170 9418 8476 50.7 59.3 159 BXRE-65E6501-C-7x 6500 80 1440 11591 10432 50.7 73.0 159 BXRE-65E6501-D-7x 6500 80 1400 7585 6827 33.4 46.8 162 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Décor Series Ultra, Décor Series Street and Landmark and Décor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 values for 90 CRI products is 50, the minimum R9 values for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Performance at Commonly Used Drive Currents V Series LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. V Series may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRE-17E6500-D-74 80 BXRE-20B6501-C-73 65 BXRE-20B6501-D-73 65 BXRE-25E6500-D-74 80 BXRE-27E6500-B-7X 80 BXRE-27E6500-C-7x 80 BXRE-27E6500-D-7x 80 BXRE-27G65H0-B-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 720 960 1440 2160 2880 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 23.3 35.9 49.0 76.5 105.6 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 2327 3429 4508 6518 8394 6562 8348 11756 16462 20681 3972 5851 7693 11123 14324 3870 5702 7497 10839 13959 5209 6762 9734 13860 17586 6688 8507 11981 16777 21076 4047 5963 7840 11335 14598 4460 5790 8335 11868 15058 2145 3145 4057 5855 7462 5573 7302 10581 15134 19184 3660 5366 6924 9992 12734 3567 5229 6747 9737 12410 4819 6182 8761 12331 15488 5679 7441 10783 15423 19550 3730 5469 7056 10183 12977 4126 5293 7502 10559 13261 100 95 92 85 79 184 172 157 141 128 171 163 157 145 136 166 159 153 142 132 179 172 160 145 134 187 176 160 143 131 174 166 160 148 138 154 147 137 125 115 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 9 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-27G65H0-C-7x 90 BXRE-27G65H0-D-7x 90 BXRE-27G6500-B-7x 90 BXRE-27G6500-C-7x 90 BXRE-27G6500-D-7x 90 BXRE-27H6500-D-7x 97 BXRE-30C6501-B-74 70 BXRE-30C6501-C-74 70 BXRE-30C6501-D-74 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 5726 7284 10259 14365 18046 3466 5106 6713 9706 12499 4297 5578 8031 11435 14509 5517 7019 9884 13841 17388 3339 4920 6468 9352 12043 2960 4361 5733 8289 10675 6045 7690 10830 15165 19051 6881 10138 13329 19271 24818 4503 6634 8722 12611 16240 4863 6372 9233 13206 16740 3194 4683 6042 8719 11112 3975 5100 7228 10173 12777 4685 6139 8896 12724 16129 3077 4512 5821 8401 10706 2727 3999 5160 7446 9490 5134 6726 9747 13941 17672 6341 9297 11996 17311 22063 4149 6084 7850 11328 14437 160 150 137 123 112 149 142 137 127 118 148 142 132 120 110 154 145 132 118 108 144 137 132 122 114 127 121 117 108 101 208 195 178 159 145 193 209 178 165 154 194 185 178 165 154 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30E6500-B-7x 80 BXRE-30E6500-C-7x 80 BXRE-30E6500-D-7x 80 BXRE-30G65H0-B-7x 90 BXRE-30G65H0-C-7x 90 BXRE-30G65H0-D-7x 90 BXRE-30G6500-B-7x 90 BXRE-30G6500-C-7x 90 BXRE-30G6500-D-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 5534 7184 10343 14726 18685 7106 9039 12730 17825 22393 4300 6336 8330 12044 15510 4688 6086 8761 12474 15827 6019 7657 10783 15099 18969 3643 5367 7056 10202 13138 4493 5832 8396 11954 15168 5768 7338 10333 14470 18178 3491 5143 6762 9777 12591 5120 6568 9309 13102 16456 6034 7906 11457 16387 20772 3963 5811 7497 10819 13789 4337 5564 7885 11098 13939 5111 6697 9704 13881 17595 3357 4922 6350 9164 11680 4156 5332 7556 10636 13358 4898 6418 9300 13303 16862 3217 4717 6086 8783 11193 191 182 170 155 142 199 187 170 152 139 185 176 170 157 147 161 155 144 131 120 168 158 144 129 118 157 149 144 133 124 155 148 138 125 115 161 151 138 124 113 150 143 138 128 119 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-30G650C-D-73 90 BXRE-30H6500-D-7x 97 BXRE-35E6500-B-7x 80 BXRE-35E6500-C-7x 80 BXRE-35E6500-D-7x 80 BXRE-35G6500-B-7x 90 BXRE-35G6500-C-7x 90 BXRE-35G6500-D-7x 90 BXRE-35A6501-D-73 93 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 700 1050 1400 2100 2800 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 3364 4957 6517 9422 12134 3162 4659 6125 8856 11405 5665 7353 10586 15073 19125 7273 9252 13029 18245 22920 4402 6485 8526 12327 15875 4655 6043 8700 12387 15718 5977 7603 10708 14994 18837 3617 5330 7007 10131 13047 3339 4920 6468 9352 12043 3100 4546 5865 8464 10787 2914 4272 5513 7955 10139 5240 6723 9528 13410 16843 6176 8092 11726 16773 21261 4056 5947 7673 11074 14113 4307 5525 7830 11021 13842 5076 6651 9637 13785 17473 3333 4888 6306 9101 11599 3077 4512 5821 8401 10706 145 138 133 123 115 136 130 125 116 108 195 187 174 158 145 204 191 174 156 142 189 180 174 161 150 160 153 143 130 120 167 157 143 128 117 155 148 143 132 124 144 137 132 122 114 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-40C6501-B-74 70 BXRE-40C6501-C-74 70 BXRE-40C6501-D-74 70 BXRE-40E6500-B-7x 80 BXRE-40E6500-C-7x 80 BXRE-40E6500-D-7x 80 BXRE-40G6500-B-7x 90 BXRE-40G6500-C-7x 90 BXRE-40G6500-D-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 6215 7906 11134 15591 19586 7074 10423 13703 19812 25515 4629 6820 8967 12965 16696 5697 7396 10647 15160 19235 7315 9305 13104 18350 23052 4427 6522 8575 12398 15966 4753 6170 8883 12647 16047 6103 7763 10932 15309 19232 3693 5441 7154 10343 13321 5278 6915 10020 14333 18168 6519 9558 12333 17798 22682 4266 6255 8070 11647 14843 5271 6761 9582 13487 16940 6212 8139 11794 16869 21383 4079 5981 7718 11137 14194 4397 5641 7994 11252 14132 5182 6790 9839 14074 17840 3403 4990 6439 9292 11842 214 201 183 164 149 198 215 183 169 158 199 190 183 169 158 196 188 175 159 146 205 192 175 157 143 190 181 175 162 151 164 157 146 133 122 171 160 146 131 119 159 151 146 135 126 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-40H6500-D-73 97 BXRE-50C6501-B-7x 70 BXRE-50C6501-C-7x 70 BXRE-50C6501-D-7x 70 BXRE-50E6501-B-7x 80 BXRE-50E6501-C-7x 80 BXRE-50E6501-D-7x 80 BXRE-50G6501-B-7x 90 BXRE-50G6501-C-7x 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 3339 4920 6468 9352 12043 5990 7776 11195 15939 20224 7691 9783 13778 19293 24238 4655 6858 9016 13036 16788 5762 7480 10769 15333 19455 7398 9411 13254 18559 23316 4477 6597 8673 12540 16149 4981 6466 9309 13254 16817 6395 8135 11457 16043 20154 3077 4512 5821 8401 10706 5542 7109 10075 14181 17811 6531 8558 12400 17737 22483 4289 6289 8114 11710 14924 5331 6839 9692 13641 17133 6283 8232 11928 17062 21627 4126 6050 7806 11265 14356 4608 5911 8378 11792 14810 5431 7116 10311 14749 18695 144 137 132 122 114 206 197 184 167 154 215 202 184 165 150 200 191 184 170 159 198 190 177 161 148 207 194 177 159 145 192 184 177 164 153 172 164 153 139 128 179 168 153 137 125 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-50G6501-D-7x 90 BXRE-56G6501-D-7x 90 BXRE-57C6501-B-7x 70 BXRE-57C6501-C-7x 70 BXRE-57C6501-D-74 70 BXRE-57E6501-B-7x 80 BXRE-57E6501-C-7x 80 BXRE-57E6501-D-74 80 BXRE-65C6501-B-7x 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 700 1050 1400 2100 2800 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 33.2 34.2 35.0 36.4 37.7 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 23.3 35.9 49.0 76.5 105.6 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 3870 5702 7497 10839 13959 3896 5740 7546 10910 14050 5827 7565 10890 15506 19674 7482 9518 13404 18769 23579 4528 6671 8771 12681 16331 5534 7184 10343 14726 18685 7106 9039 12730 17825 22393 4300 6336 8330 12044 15510 5827 7565 10890 15506 19674 3567 5229 6747 9737 12410 3590 5264 6791 9801 12491 5391 6916 9801 13795 17327 6354 8325 12063 17255 21872 4173 6118 7894 11392 14519 5120 6568 9309 13102 16456 6034 7906 11457 16387 20772 3963 5811 7497 10819 13789 5391 6916 9801 13795 17327 166 159 153 142 132 167 160 154 143 133 201 192 179 163 150 209 196 179 160 146 195 186 179 166 155 191 182 170 155 142 199 187 170 152 139 185 176 170 157 147 201 192 179 163 150 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRE-65C6501-C-7x 70 BXRE-65C6501-D-7x 70 BXRE-65E6501-B-7x 80 BXRE-65E6501-C-7x 80 BXRE-65E6501-D-7x 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 720 960 1440 2160 2880 700 1050 1400 2100 2800 585 780 1170 1755 2340 720 960 1440 2160 2880 700 1050 1400 2100 2800 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 49.6 50.5 52.0 54.3 56.2 49.6 50.5 52.0 54.2 55.9 33.2 34.2 35.0 36.4 37.7 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 29.0 39.4 60.8 95.3 131.5 35.7 48.5 74.9 117.0 161.1 23.3 35.9 49.0 76.5 105.6 7482 9518 13404 18769 23579 4528 6671 8771 12681 16331 5600 7269 10464 14900 18905 7189 9145 12879 18035 22657 4351 6410 8428 12185 15693 6354 8325 12063 17255 21872 4173 6118 7894 11392 14519 5180 6646 9418 13256 16649 6105 7999 11591 16580 21016 4010 5879 7585 10946 13951 209 196 179 160 146 195 186 179 166 155 193 185 172 156 144 201 189 172 154 141 187 178 172 159 149 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRE-xxx650x-B-7x BXRE-xxx650x-C-7x BXRE-xxx650x-D-7x Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.07 46.3 57.3 -22.1 0.09 50.2 61.8 55.9 -22.1 0.06 46.3 57.3 55.9 60.1 -22.1 0.08 50.0 61.6 32.4 35.0 37.6 -22.1 0.07 30.6 39.1 35.0 37.7 40.4 -22.1 0.08 33.2 41.8 Minimum Typical Maximum 1170 48.1 52.0 55.9 -22.1 2340 52.0 56.2 60.4 1440 48.1 52.0 2880 51.7 1400 2800 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 17 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRE-xxx650x-B-7x BXRE-xxx650x-C-7x BXRE-xxx650x-D-7x CCT1,5 Drive Current 5 (mA) 2700K/3000K 4000K2 5000K3 6500K4 1170 RG1 RG1 RG1 RG1 1755 RG1 RG1 RG2 RG2 2340 RG1 RG2 RG2 RG2 1440 RG1 RG1 RG1 RG2 2160 RG1 RG1 RG2 RG2 2880 RG1 RG2 RG2 RG2 1400 RG1 RG1 RG1 RG1 2100 RG1 RG1 RG1 RG2 2800 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux V Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 18 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C Soldering Temperature2 300°C or lower for a maximum of 6 seconds BXRE-xxx650x-B-7x BXRE-xxx650x-C-7x BXRE-xxx650x-D-7x Maximum Drive Current3 2340mA 2880mA 2800mA Maximum Peak Pulsed Drive Current4 3340mA 4110mA 4000mA Maximum Reverse Voltage5 -90V -90V -60V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN101: Handling and Assembly of Bridgelux V Series LED Arrays 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 19 Performance Curves Figure 2: V22C Drive Current vs. Voltage 2500 3000 2000 2500 Forward Current (mA) Forward Current (mA) Figure 1: V22B Drive Current vs. Voltage 1500 1000 500 0 2000 1500 1000 500 47 48 49 50 51 52 53 54 55 56 0 57 47 48 49 50 Forward Voltage (V) 51 52 53 54 55 56 57 Forward Voltage (V) Figure 4: V22B Typical Relative Flux vs. Current Figure 3: V22D Drive Current vs. Voltage 200% 3000 180% 160% Relative Luminous Flux Forward Current (mA) 2500 2000 1500 1000 140% 120% 100% 80% 60% 40% 500 20% 0 30 31 32 33 34 35 36 37 38 0% 100 400 700 1000 1300 1600 1900 2200 2500 Forward Voltage (V) Forward Current (mA) Figure 6: V22D Typical Relative Flux vs. Current Figure 5: V22C Typical Relative Flux vs. Current 200% 180% 180% 160% 160% 140% 140% 120% Relative Luminous Flux Relative Luminous Flux 200% 100% 80% 60% 40% 120% 100% 80% 60% 40% 20% 20% 0% 0% 100 400 700 1000 1300 1600 1900 2200 2500 2800 0 500 1000 1500 2000 2500 3000 Forward Current (mA) Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 20 Performance Curves Figure 7: Typical DC Flux vs. Case Temperature Figure 8: Typical DC ccy Shift vs. Case Temperature 0 50 75 100 125 Warm White Neutral White 100% 0.000 Cool White 25°C Pulsed 97% -0.003 ccy Shift Relative Luminous Flux 25 0.003 103% 94% -0.006 91% -0.009 88% Warm White -0.012 85% -0.015 82% 0 25 50 75 100 125 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Case Temperature (°C) Figure 9: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 7-9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 21 Performance Curves Figure 10: 1750K Color Shift vs. Case Temperature1 Figure 11: 2500K Color Shift vs. Case Temperature1 0.3705 0.37 0.4145 Pulsed Center Point Tc = 25°C 15°C 15°C 0.414 25°C 0.4135 25°C 0.413 0.3695 0.369 ccy ccy 45°C 0.411 0.52 85°C 0.4115 105°C 0.5198 70°C 0.412 0.3685 0.368 0.5196 45°C 0.4125 70°C 85°C 0.5202 0.5204 0.5206 105°C 0.4105 0.468 0.47 0.472 15°C Pulsed Center Point Tc=25°C 25°C 0.401 25°C 45°C 0.4 45°C 0.4096 ccy ccy 15°C 0.402 Pulsed Center Point Tc=25°C 0.4097 0.4095 65°C 0.399 65°C 0.398 0.4094 85°C 0.4093 0.397 85°C 0.4092 0.396 105°C 0.4091 0.409 0.525 0.478 0.403 0.41 0.4098 0.476 Figure 13: 3000K, 90 CRI Color Shift vs. Case Temperature3 0.4101 0.4099 0.474 ccx ccx Figure 12: 2000K, 65 CRI Color Shift vs. Case Temperature Pulsed Center Point Tc = 25°C 0.526 0.527 0.528 0.529 0.53 0.531 0.532 ccx 0.395 0.444 105°C 0.4445 0.445 0.4455 0.446 0.4465 0.447 ccx Note for Figures 10-13: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRE-30G650C-x-73 22 Performance Curves Figure 14: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 15: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4090 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.4572 0.4574 0.4576 0.4578 0.3950 0.4323 0.458 0.4328 0.4333 ccx 0.4338 0.4343 Figure 16: 5600K Color Shift vs. Case Temperature1,3 0.37 15°C 0.342 Pulsed Center Point Tc = 25°C 15°C 0.34 25°C 0.338 0.368 25°C 0.366 0.336 Pulsed Center Point Tc=25°C 45°C 45°C 0.334 ccy ccy 0.4353 Figure 17: 3500K Class A Color Shift vs. Case Temperature1 0.344 0.332 0.364 70°C 70°C 0.33 0.362 85°C 85°C 0.328 0.326 0.4348 ccx 0.36 105°C 105°C 0.324 0.322 0.32 0.322 0.324 0.326 0.328 0.33 ccx 0.358 0.392 0.393 0.394 0.395 0.396 0.397 ccx Note for Figures 14-17: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Color shift shown for product hot targeted at Tc=85°C 23 Typical Radiation Pattern Figure 18: Typical Spatial Radiation Pattern Note for Figure 18: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 19: Typical Polar Radiation Pattern 24 Typical Color Spectrum Figure 20: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 20: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 21: Typical Color Spectrum for Décor Series 1 17E 20B 0.9 25E 27H 0.8 30G (Décor Series Showcase) Relative Spectral Power Distribution 30H 56G 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 21: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 25 Mechanical Dimensions Figure 22: Drawing for V22 LED Array Notes for Figure 22: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Solder pad labeled “+” denotes positive contact. 5. Refer to Application Notes AN101 for product handling, mounting and heat sink recommendations. 6. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 7. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 26 Color Binning Information Figure 23: Graph of Warm and Neutral White Test Bins in xy Color Space 0.44 2500K 4SDCM 3 SDCM 4 SDCM 2000K 3SDCM 2700K 0.42 3000K 3500K 0.4 Y 4000K 1750K 4SDCM 0.38 0.36 0.34 0.36 0.39 0.42 0.45 X 0.48 0.51 0.54 Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2000K 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) - (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) - (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) - (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.5280, 0.4100) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Figure 24: Graph of Cool White Test Bins in xy Color Space 0.39 4 SDCM 3 SDCM 0.38 0.37 5000K 0.36 5700K Y 0.35 0.34 6500K 0.33 0.32 0.31 0.3 0.3 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5600K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5310K - 6020K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5475K - 5830K) (5481K - 5829K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3293, 0.3423) (0.3287, 0.3417) (0.3123, 0.3282) Note for Table 9: 1. Select configurations with a CCT of 5600K are available with center point targets at Tc = 85°C or Tc = 25°C. 27 Packaging and Labeling Figure 25: Drawing for V22 Packaging Tube Notes for Figure 25: 1. Each tube holds 15 V22 COB arrays. 2. One tube is sealed in an anti-static bag. Four bags are placed in a shipping box and shipped. Depending on quantities ordered, a bigger shipping box, containing four boxes may be used to ship products. 3. Each bag and box is to be labeled as shown above. 4. Dimensions for each tube are 30.7 (W) x 9.65(H) x 460(L). Dimensions for the anti-static bag are 75 (W) x 615 (L) x 3.1 (T) mm. Dimensions for the shipping box are 58.7 x 13.3 x 7.9 cm. 28 Packaging and Labeling Figure 26: Gen. 7 Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E4000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 29 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the V Series product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux V Series LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN101 for additional information. CAUTION: RISK OF BURN Do not touch the V Series LED array during operation. Allow the array to cool for a sufficient period of time before handling. The V Series LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 30 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2018-2019 Bridgelux, Inc. All rights reserved. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design and Vero are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Gen 7 V22 Array Series Product Data Sheet DS103 Rev. P (03/2019) 31
BXRE-27E6500-B-73 价格&库存
很抱歉,暂时无法提供与“BXRE-27E6500-B-73”相匹配的价格&库存,您可以联系我们找货
BXRE-27E6500-B-73
  • 1+108.848851+13.96206
