CVM-18-31-95-36-AA00-F2-2 数据手册
CVM Product Datasheet
CVM Studio COB Arrays
LED Entertainment Lighting
Features:
Table of Contents
• High lumen output
• Over 25,000 lm @ 3150K, 25ºC
Technology Overview. . . . . . 2
• Over 27,000 lm @ 5600K, 25ºC
Test Specifications . . . . . . . . . 2
• 3150K and 5600K CCT
Chromaticity Bins. . . . . . . . . . 3
• 95 CRI minimum
Product Ordering & Shipping
Part Numbers. . . . . . . . . . . . . . 4
Product Typical Flux Range. 5
Operating Characteristics . . 5
Optical and Electrical Characteristics. . . . . . . . . . . . . . . . . . . . . . . 7
Spectra. . . . . . . . . . . . . . . . . . . 11
• 90 TLCI minimum
• 2 SDCM color binning accuracy
• Excellent optical emission uniformity and color over angle consistency
• Exceptional long term color stability
• Superior thermal conductivity for uniform heat spreading
• Environmentally friendly: RoHS and REACH compliant
• UL certified, file # E465703
Mechanical Dimensions. . . 12
Packaging Information. . . . 12
Handling Notes. . . . . . . . . . . 17
Applications
• TV Studio
• Stage/Set Lights
• Film Production
• Architectural/Hospitality
• Still Photography
1
PDS-002321 Rev 11
© 2019 Luminus Devices, Inc. - All Rights Reserved
Technology Overview
Luminus Chip-on-Board (COB) LED series offers a complete lighting class solution designed for high performance illumination
applications. The selection covers a wide lumen range from less than 400lm to over 10,000lm, all major color temperatures and can
deliver color rendering greater than 97 at 2700K and 3000K and R9 equal to 95. These breakthroughs allow illumination engineers and
designers to develop lighting solutions with maximum efficacy, brightness and overall quality.
Reliability
UL Recognized Compliance
Designed from the ground up, the Luminus COB LED is one of
the most reliable light sources in the world today. Having
passed a rigorous suite of environmental and mechanical stress
tests, including mechanical shock, vibration, temperature
cycling and humidity. Only then are the devices qualified for
use in a wide range of lighting application including some of the
most demanding commercial applications.
Luminus COB arrays are tested in accordance with ANSI/UL 8750
to ensure safe operation for their intended applications.
REACH & RoHS Compliance
All LED products manufactured by Luminus are REACH and
RoHS compliant and free of hazardous materials, including lead
and mercury.
Understanding Luminus COB LED Test Specifications
Every Luminus LED is fully tested to ensure it meets the high quality standards customers have come to expect from Luminus’ products.
Traceability
Chromaticity Bin Range
Each Luminus COB LED is marked with a 2D bar code that
contains a unique serial number. With this serial number,
Luminus has the ability to provide customers with actual test
data measurements for a specific LED. In addition, the 2D bar
code is linked to manufacturing date codes that enables
traceability of production processes and materials.
Chromaticity binning delivers color consistency for every order.
Studio products are delivered with a 2-step MacAdam ellipse.
This ensures color performance matching in the application.
These tightly controlled, small distribution bins provide
customers predictable, repeatable colors.
Testing Temperature
Luminus Studio products are measured at temperatures typical
for the LED operating in the fixture. Each device is tested at 85ºC
junction temperature eliminating the need to scale datasheet
specifications to real world situations.
2
PDS-002321 Rev 11
Chromaticity Bin Structure
Chromaticity Bins: 1931 CIE Curve
0.4600
ANSI C78.377-2008
2-step Ellipse
3-step Ellipse
0.4400
3150K
Black Body
0.4200
CIE y
0.4000
0.3800
5600K
0.3600
0.3400
0.3200
0.3000
0.3000
0.3200
0.3400
0.3600
0.3800
0.4000
0.4200
0.4400
0.4600
0.4800
0.5000
CIE x
CVM White Chromaticity Bins
The following tables describe the ANSI bin center points, the orientation angle for the MacAdam ellipse (θ °), and the maximum radii for
the ellipses. The ANSI Bin is provided for reference.
CCT
Center Point
Angle
2-step Bin
3-step Bin
CIEx
CIEy
θ (°)
a
b
a
b
3150K
0.4263
0.4003
53.2
0.00556
0.00272
0.00834
0.00408
5600K
0.3287
0.3417
59.1
0.00497
0.00213
0.00746
0.0032
*Note:
Luminus maintains a +/- 0.005 tolerance on chromaticity (CIEx and CIEy) measurements.
3
PDS-002321 Rev 11
Product Ordering and Shipping Part Number Nomenclature
All CVM products are packaged and labeled with part numbers as outlined in the table on page 5. When shipped, each package will
contain only a single flux and chromaticity bin. The part number designation is as follows:
CVM
XX
Product Family
Light Emitting
Surface Diameter
Color
Temperature
CVM: Chip on
Board, Studio
Approx. LES
Diameter (mm)
Color
See Note 1
below
NN
Color Render- Voltage
ing Index (CRI) (typical)
CRI See Note 2
below
Volts
95VVQQPPFGW
Package
Configurator
Flux Bin
Chromaticity
Bin
See Note 3
below
Lumens
See page 3 for
bins
Note 1: NN nomenclature corresponds to the following:
31 = 3150K
56 = 5600K
Note 2: XX CRI is specified as minimum value
95 CRI is 95 minimum
Note 3: AA00 /AC00 / AB00 - Package Configurator for 3-step
FA00 / FB00 / FC00 - Package Configurator for 2-step
Example 1:
The ordered part number CVM-27-56-95-36-FA00-F2-2 which refers to a 26.5 millimeter diameter emitter, at color temperature 5600K, a minimum CRI
of 95, a typical voltage of 36V, a standard package, a typical flux of 10,500 lumens and a 2-step MacAdam ellipse chromaticity range.
Note:
Luminus part numbers may be accompanied by prefixes or suffixes. The most common is the “Rev01” suffix indicating a part is fully released
and carries a full warranty. These additional characters may appear on shipping labels, packing slips and invoices. In all cases the basic part
number described above will always be included.
4
PDS-002321 Rev 11
CVM Part Numbers
The following tables describe products with typical flux and minimum flux measured at the maximum rated current and specified at
junction temperature, Tj = 85ºC. The values at 25ºC are calculated and shown for reference only.
CCT
3150K
5600K
Output Flux (lm) Reference
LES
(mm)
Test
Currant
(A)
13.5
1.0
2,575
2,395
17.5
1.8
5,140
26.5
4.2
26.5
Typ.
Min.
(calculated)
(85ºC)
(25ºC)
2-step MacAdam Ellipse
3-step MacAdam Ellipse
3,085
CVM-14-31-95-36-FC00-F2-2
CVM-14-31-95-36-AC00-F2-3
4,880
5,655
CVM-18-31-95-36-FA00-F2-2
CVM-18-31-95-36-AA00-F2-3
11,500
10,750
13,800
CVM-27-31-95-36-FA00-F2-2
CVM-27-31-95-36-AA00-F2-3
4.2
11,500
10,750
13,800
CVM-27-31-95-36-FB00-F2-2
CVM-27-31-95-36-AB00-F2-3
32
5.0
22,800
21,250
25,150
CVM-32-31-95-54-FC00-F2-2
CVM-32-31-95-54-AC00-F2-3
13.5
1.0
2,800
2,600
3,350
CVM-14-56-95-36-FC00-F2-2
CVM-14-56-95-36-AC00-F2-3
17.5
1.8
5,625
5,345
6,190
CVM-18-56-95-36-FA00-F2-2
CVM-18-56-95-36-AA00-F2-3
26.5
4.2
12,500
11,500
15,000
CVM-27-56-95-36-AA00-F2-3
26.5
4.2
12,500
11,500
15,000
CVM-27-56-95-36-FB00-F2-2
CVM-27-56-95-36-AB00-F2-3
32
5.0
24,800
23,110
27,350
CVM-32-56-95-54-FC00-F2-2
CVM-32-56-95-54-AC00-F2-3
Typ.
(85ºC)
CVM Operating Characteristics1
CVM-14
Parameter
Symbol
Typical
Maximum
Unit
Forward Current2
If
1
1
A
Forward Voltage
Vf
36
40
V
36
40
W
100
ºC
Power
Operating Case Temperature3
Tc
Light Emitting Surface Diameter
LES
13.5
mm
Thermal Resisitance (junction-to-case)
Qjc
0.46
ºC/W
120
Degree
Viewing Angle
*Note:
Luminus maintains a +/- 6% tolerance on flux measurements.
Luminus maintains a +/- 2% tolerance on CRI measurements.
5
PDS-002321 Rev 11
(Part #)
CVM
Product
Product
Datasheet
Datasheet
CVM-18
Parameter
Forward Current
Symbol
Typical
Maximum
Unit
If
1.8
1.8
A
Vf
36
40
V
65
72
W
100
ºC
2
Forward Voltage
Power
Tc
LES
17.5
mm
Qjc
0.30
ºC/W
120
Degree
Viewing Angle
CVM-27
Parameter
Symbol
Typical
Maximum
Unit
Forward Current2
If
4.2
4.2
A
Forward Voltage
Vf
36
40
V
150
168
W
100
ºC
Power
Tc
LES
26.5
mm
Qjc
0.16
ºC/W
120
Degree
3
Viewing Angle
CVM-32
Parameter
Symbol
Typical
Maximum
Unit
Forward Current2
If
5.0
5.0
A
Forward Voltage
Vf
54.5
58
V
272.5
290
W
100
ºC
3
Power
Operating Case Temperature4
Tc
LES
32
mm
Qjc
0.10 (est.)
ºC/W
120
Degree
Viewing Angle
Note 1: Ratings are based on operation at a constant junction temperature of Tj = 85ºC.
Note 2:
Although products are specified at Maximum Current, they are all capable to be driven down to currents as low as 20% of the typical value. Operation
below these current levels may result in uneven light distribution across the LES surface.
Note 3: Voltage is rated at typical forward current. For voltage at lower drive current, refer to performance graphs
Note 3: Maximum operating case temperature combined with maximum drive current defines the total maximum operating condition for the device. To
prevent damage, please follow derating curves for all operating conditions.
Note 4: All product specifications are subject to change without prior notice.
Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye.
6
PDS-002321 Rev 11
CVM-14 Optical & Electrical Characteristics
Relative Output Flux vs. Forward Current @ 85ºC
Forward Current vs. Forward Voltage @ 85ºC
100%
1000
90%
900
800
Forward Current (mA)
Relative Luminous Flux
80%
70%
60%
50%
40%
700
600
500
400
30%
20%
300
400
500
600
700
800
900
300
1000
31
31.5
32
32.5
33
33.5
34
34.5
35
Forward Voltage (V)
Relative Output Flux vs. Junction Temperature
Change in Voltage vs. Junction Temperature
120%
38
Forward Voltage (V)
37
100%
80%
36
35
34
60%
33
40%
5
15
25
35
45
55
65
75
85
95
105
32
5
15
25
35
Junction Temperature (ºC)
55
65
75
85
95
105
Change in CIEy vs. Junction Temperature (3100K)
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
Change in CIEx vs. Jucntion Temperature (3100K)
-0.01
-0.02
45
5
15
25
35
45
55
65
75
7
PDS-002321 Rev 11
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
CVM-18 Optical & Electrical Characteristics
100%
1600
1800
120%
80%
60%
40%
1400
1200
1000
20%
0%
800
600
800
1000
1200
1400
1600
600
1800
31
31.5
32
32.5
Forward Voltage (V)
34.5
35
35.5
38
80%
60%
40%
36
34
32
20%
5
15
25
35
45
55
65
75
85
95
105
30
5
15
25
35
45
55
65
75
85
95
105
Change in CIEx vs. Junction Temperature (3100K)
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
34
40
100%
-0.01
-0.02
33.5
120%
0%
33
Forward Voltage (V)
5
15
25
35
45
55
65
75
8
PDS-002321 Rev 11
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
(PartCVM
#) Product
ProductDatasheet
Datasheet
CVM-27 Optical & Electrical Characteristics
120.0%
4200
100.0%
3700
80.0%
60.0%
40.0%
20.0%
0.0%
3200
2700
2200
1700
700
1200
1700
2200
2700
3200
3700
1200
4200
31
31.5
32
32.5
34.5
35
38
Forward Voltage (V)
34
40
100.0%
80.0%
60.0%
40.0%
36
34
32
20.0%
0.0%
5
15
25
35
45
55
65
75
85
95
105
30
5
15
25
35
45
55
65
75
85
95
105
0.02
0.02
0.01
0.01
Δ CIEy
Δ CIEx
33.5
120.0%
-0.01
-0.02
33
Forward Voltage (V)
5
15
25
35
45
55
65
75
9
PDS-002321 Rev 11
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
CVM-32 Optical & Electrical Characteristics
120%
5000
4500
100%
80%
60%
40%
20%
4000
3500
3000
2500
2000
0%
1000
1500
1500
2000
2500
3000
3500
4000
4500
5000
50
50.5
51
51.5
53
53.5
54
54.5
55
58
57
100%
56
Forward Voltage (V)
52.5
120%
80%
60%
40%
55
54
53
52
20%
0%
51
25
35
45
55
65
75
85
95
50
105
5
15
25
35
55
65
75
85
95
105
0.02
0.01
0.01
Δ CIEy
0.02
-0.01
-0.02
45
Δ CIEx
52
Forward Voltage (V)
5
15
25
35
45
55
65
75
10
PDS-002321 Rev 11
85
95
105
-0.02
5
15
25
35
45
55
65
75
85
95
105
CVM Optical & Electrical Characteristics
Typical Spectrum (5600K)
1
1
0.8
0.8
Relative Output
Relative Output
Typical Spectum (3150K)
0.6
0.4
0.2
0.4
0.2
400
500
600
700
400
500
Wavelength (nm)
600
700
800
Wavelength (nm)
Typical Polar Radiation Pattern
Typical Angular Radiation Pattern
120%
100%
Relative Intensity (%)
80%
60%
40%
20%
0%
-80
-60
-40
-20
Anglular Displacement (Degrees)
11
PDS-002321 Rev 11
40
60
80
CVM
Product
Datasheet
(Part #)
Product
Datasheet
Mechanical Dimensions (CVM-14-AC00)
Shipping Container (CVM-14-AC00)
225 pcs per box
Each bag is boxed for
easier storage/ stacking
45 pcs per tray
5 trays are stacked together
with separate cover
Trays are sealed in
an anti-static bag
Label
Luminus Label Model:
Bar code
Rev XX
Bar code
XXX-XX-XX-XX-XX-XXXX-XX-X (Customer Part Number)
XXXXXXXXXXXXXX (Box ID)
Bar code
12
PDS-002321 Rev 11
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
XXXXXX-XX-XX (Manufacturer Part Number & Bin Kits)
(PartCVM
#) Product
ProductDatasheet
Datasheet
Mechanical Dimensions (CVM-18-AA00)
Shipping Container (CVM-18-AA00)
180 pcs per box
36 pcs per tray
with separate cover
Trays are sealed in
an anti-static bag
Label
Bar code
Rev XX
Bar code
Bar code
13
PDS-002321 Rev 11
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
Mechanical Dimensions (CVM-27-AA00)
Mechanical Dimensions (CVM-27-AB00)
14
PDS-002321 Rev 11
Shipping Container (CVM-27)
100 pcs per box
20 pcs per tray
with separate cover
Trays are sealed in
an anti-static bag
Label
Bar code
Rev XX
Bar code
Bar code
15
PDS-002321 Rev 11
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
Mechanical Dimensions (CVM-32-AC00)
Shipping Container (CVM-32-AC00)
60 pcs per box
20 pcs per tray
3 trays are stacked together
with separate cover
Trays are sealed in
an anti-static bag
Label
Bar code
Rev XX
Bar code
Bar code
16
PDS-002321 Rev 11
Qty: XX
Bar code
RoHS Compliant
Luminus Devices Inc
Product
Datasheet
(PartCVM
#) Product
Datasheet
Handling Notes for Luminus COBs
Luminus products are designed for robust performance in general lighting application. However, care must be taken when handling and
assembling the LEDs into their fixtures. To avoid damaging Luminus COBs please follow these guidelines.
The following is an overview of the application notes detailing some of the practices to follow when working with these devices. More
detailed information is available on the Luminus web site at www.luminus.com.
General Handling
Electrical Contact
Devices are made to be lifted or carried with tweezers on two
adjacent corners opposite the contact pads. At no time should
the devices be handled by or should anything come in contact
with the light emitting surface (LES) area. This area includes the
yellow colored circular area and the ring surrounding it. There
are electrical connections under the LES which if damaged will
cause the device to fail.
Luminus COBs are designed with contact pads on their top
surface. These pads are clearly marked with + and – polarity.
Wires can be soldered to the contact pads for electrical
connections or other solderless connector products are
available.
In addition, the ring frame itself should not be used for moving,
lifting or carrying the device. Also do not attach any optics or
mechanical holders to the ring as it is not capable to handle the
mechanical stress.
If wires are being soldered to the COB product, we recommend
attaching these wires prior to mounting the devices to a heat
sink. Please contact Luminus for specific recommendations on
how to solder wires if not familiar with the standard practice.
Luminus can also offer design recommendations for jigs to
allow easily soldering multiple products in rapid succession.
Static Electricity
Chemical Compatibility
Luminus COBs are electronic devices which can be damaged by
electrostatic discharge (ESD). Please use appropriate measures
to assure the devices do not experience ESD during their
handling and or storage. ESD protection guidelines should be
used at all times when working with Luminus COBs.
The resin material used to form the LES can getter hydrocarbons
from the surrounding environment. As a results, certain
chemical compounds are not recommended for use with the
Luminus products. Use of these compounds can cause damage
to the light output of the device and may permanently damage
the device. Please refer to www.luminus.com for a list of the
compounds not recommended for use with the Luminus COB
products.
Storage: Luminus products are delivered in ESD shielded bags
and should be stored in these bags until used.
Assembly: Individuals handling Luminus COBs during assembly
should be trained in ESD protection practices. Assemblers
should maintain constant conductive contact with a path to
ground by means of a wrist strap, ankle straps, mat or other ESD
protection system.
Transporting: When transporting the devices from one
assembly area to another, ESD shielded carts and carriers should
be used.
17
PDS-002321 Rev 11
Thermal Interface Material (TIM)
Proper thermal management is critical for successful operation
of any LED system. Excess operating temperature can reduce
the light output of the device. And excessive heating can cause
permanent damage to the device. Proper TIM material is a
crucial component for effective heat transfer away from the LED
during normal operation. Please refer to www.luminus.com for
specific recommendations for TIM solutions.
