CXA3590-0000-000N00CD0E3
    WOLFSPEED
    LED Lighting COBs, Engines, Modules Chip On Board (COB) XLamp® CXA3590 White, Cool Square
CXA3590-0000-000N00CD0E3 数据手册
® ® Cree XLamp CXA3590 LED Product Description features The XLamp® CXA3590 LED array • Available in 4-step and 2-step Characteristics................................ 2 expands Cree’s family of high‑flux, EasyWhite bins at 2700 K, Operating Limits.............................. 3 multi‑die 3000 K, 3500 K, 4000 K and Flux Characteristics, EasyWhite® 5000 K CCT Order Codes and Bins - 36 V............. 4 integrated arrays, offering high performance in an easy-to-use platform. With XLamp Table of Contents ® • Available in ANSI white bins as Flux Characteristics, ANSI White well as 4-step EasyWhite bins Order Codes and Bins - 36 V............. 6 the CXA3590’s uniform emitting at 4000 K, 5000 K, 5700 K and Flux Characteristics, EasyWhite® surface enables both directional 6500 K CCT Order Codes and Bins - 72 V............. 8 LED and lighting‑class reliability, non‑directional applications and lighting luminaire and lamp designs. Available in 2‑step • Available in 70-, 80-, 90- and 93‑minimum CRI options • Forward voltage options: 36‑V Flux Characteristics, ANSI White Order Codes and Bins - 72 V........... 10 Relative Spectral Power and 4‑step color consistency, and class & 72‑V class Distribution.................................. 12 featuring a 30‑mm optical source, • 85 °C binning and Electrical Characteristics................. 13 characterization Relative Luminous Flux................... 14 the CXA3590 brings new levels of flux and efficacy to this form factor. The CX Family LED Design Guide provides basic information on the requirements to use the CXA3590 LED successfully designs. in luminaire • Maximum drive current: Typical Spatial Distribution.............. 16 3600 mA (36 V), 1800 mA Performance Groups - Brightness..... 16 (72 V) Performance Groups - Chromaticity.. 17 • 115° viewing angle, uniform chromaticity profile Cree EasyWhite® Bins Plotted on the CIE 1931 Color Space............... 19 • Top-side solder connections Cree ANSI White Bins Plotted on • Thermocouple attach point the CIE 1931 Color Space............... 20 • NEMA SSL-3 2011 standard flux bins www.cree.com/Xlamp CLD-DS81 Rev 4 Product family data sheet Bin and Order Code Formats........... 21 Mechanical Dimensions.................. 21 • RoHS-compliant Thermal Design............................. 22 • UL recognized component Notes........................................... 24 ® (E349212) Packaging..................................... 25 Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 1 XLamp ® CXA3590 LED Characteristics Characteristics Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Unit degrees Minimum Typical Maximum 115 V 8000 DC forward current (36 V) mA 3600* DC forward current (72 V) mA 1800* Reverse current (36 V, 72 V ) mA Forward voltage (36 V, @ 2400 mA, Tj = 85 °C) V Forward voltage (36 V, @ 2400 mA, Tj = 25 °C) V Forward voltage (72 V, @ 1200 mA, Tj = 85 °C) V Forward voltage (72 V, @ 1200 mA, Tj = 25 °C) V * 0.1 38.5 42 77 84 Refer to the Operating Limits section. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 2 XLamp ® CXA3590 LED Operating Limits The maximum current rating of the CXA3590 is dependent on the case temperature (Tc) when the LED has reached thermal equilibrium under steady-state operation. The graphs shown below assume that the system design employs good thermal management (thermal interface material and heat sink) and may vary when poor thermal management is CXA3590 employed. Please refer to the Mechanical Dimensions section on page 21 for the location of the Tc measurement point. 4000 3600 3200 If (mA) 2800 2400 36 V 2000 1600 1200 800 400 0 0 25 50 75 100 125 150 Case Temperature (°C) 2000 1800 1600 If (mA) 1400 1200 72 V 1000 800 600 400 200 0 0 25 50 75 100 125 150 Case Temperature (°C) Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 3 XLamp ® CXA3590 LED Flux Characteristics, EasyWhite® Order Codes and Bins - 36 V (If = 2400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). CRI CCT Range Min 70 6500 K 80 90 70 5700 K 80 90 70 5000 K 80 90 Typ 75 --- 95 75 --- 95 75 --- 95 Base Order Codes Min. Luminous Flux @ 2400 mA Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BD 10,000 11,100 CB 11,000 12,210 CD 12,000 13,320 2-Step Chromaticity Region Order Code 4-Step Chromaticity Region Order Code CXA3590-0000-000N00BD65F 65F CXA3590-0000-000N00CB65F CXA3590-0000-000N00CD65F BB 9,500 10,545 BD 10,000 11,100 CXA3590-0000-000N0HBB65F CB 11,000 12,210 CXA3590-0000-000N0HCB65F Z4 7,945 8,819 CXA3590-0000-000N0UZ465F AB 8,500 9,435 AD 9,000 9,990 CXA3590-0000-000N0UAD65F BD 10,000 11,100 CXA3590-0000-000N00BD57F CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000N00CD57F BB 9,500 10,545 CXA3590-0000-000N0HBB57F BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000N0HCB57F Z4 7,945 8,819 CXA3590-0000-000N0UZ457F AB 8,500 9,435 AD 9,000 9,990 BD 10,000 11,100 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000N00CD50H CXA3590-0000-000N00CD50F BB 9,500 10,545 CXA3590-0000-000N0HBB50H CXA3590-0000-000N0HBB50F BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000N0HCB50H AB 8,500 9,435 CXA3590-0000-000N0UAB50H AD 9,000 9,990 65F 65F 57F 57F 57F CXA3590-0000-000N0HBD65F CXA3590-0000-000N0UAB65F CXA3590-0000-000N00CB57F CXA3590-0000-000N0HBD57F CXA3590-0000-000N0UAB57F CXA3590-0000-000N0UAD57F CXA3590-0000-000N00BD50H 50H 50H 50H CXA3590-0000-000N00CB50H CXA3590-0000-000N0HBD50H CXA3590-0000-000N0UAD50H CXA3590-0000-000N00BD50F 50F 50F CXA3590-0000-000N00CB50F CXA3590-0000-000N0HBD50F CXA3590-0000-000N0HCB50F 50F CXA3590-0000-000N0UAB50F CXA3590-0000-000N0UAD50F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 4 XLamp ® CXA3590 LED Flux Characteristics, EasyWhite® Order Codes and Bins - 36 V (If = 2400 mA, TJ = 85 °C) - Continued CRI CCT Range Min 70 4000 K 80 90 80 Typ 75 --- 95 --- 3500 K 93 80 95 --- 3000 K 93 80 95 --- 2700 K 93 95 Base Order Codes Min. Luminous Flux @ 2400 mA 2-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BB 9,500 10,545 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000N00CB40H CXA3590-0000-000N00CB40F AD 9,000 9,435 CXA3590-0000-000N0HAD40H CXA3590-0000-000N0HAD40F BB 9,500 10,545 BD 10,000 11,100 Z4 7,945 8,819 AB 8,500 9,435 AD 9,000 9,990 BB 9,500 10,545 BD 10,000 11,100 CXA3590-0000-000N00BD35H Z2 7,390 8,203 CXA3590-0000-000N0YZ235H Z4 7,945 8,819 AD 9,000 9,990 BB 9,500 10,545 BD 10,000 11,100 Z2 7,390 8,203 Z4 7,945 8,819 AB 8,500 9,435 AD 9,000 9,990 BB 9,500 10,545 Y4 6,910 7,670 Z2 7,390 8,203 Chromaticity Region Order Code Chromaticity Region CXA3590-0000-000N00BB40H 40H 40H CXA3590-0000-000N00BD40H CXA3590-0000-000N0HBB40H CXA3590-0000-000N00BB40F 40F 40F CXA3590-0000-000N0HBD40H 40H CXA3590-0000-000N0UZ440H CXA3590-0000-000N0UAB40H 35H CXA3590-0000-000N00BB35H CXA3590-0000-000N0YZ435H 40F CXA3590-0000-000N00BB30H 35F CXA3590-0000-000N0YZ230H CXA3590-0000-000N0YZ430H 35F CXA3590-0000-000N00AD27H 30F CXA3590-0000-000N0YY427H CXA3590-0000-000N0YZ227H CXA3590-0000-000N00BB35F CXA3590-0000-000N0YZ235F CXA3590-0000-000N0YZ435F CXA3590-0000-000N00BB30F CXA3590-0000-000N00BD30F 30F CXA3590-0000-000N0YZ230F CXA3590-0000-000N0YZ430F CXA3590-0000-000N00AB27F 27F CXA3590-0000-000N00BB27H 27H CXA3590-0000-000N0UAB40F CXA3590-0000-000N00AD30F CXA3590-0000-000N00AB27H 27H CXA3590-0000-000N0UZ440F CXA3590-0000-000N00BD35F CXA3590-0000-000N00BD30H 30H CXA3590-0000-000N0HBB40F CXA3590-0000-000N00AD35F CXA3590-0000-000N00AD30H 30H CXA3590-0000-000N00BD40F CXA3590-0000-000N0HBD40F CXA3590-0000-000N00AD35H 35H Order Code CXA3590-0000-000N00AD27F CXA3590-0000-000N00BB27F 27F CXA3590-0000-000N0YY427F CXA3590-0000-000N0YZ227F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 5 XLamp ® CXA3590 LED Flux Characteristics, ANSI White Order Codes and Bins - 36 V (If = 2400 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). CCT Range Min 70 6500 K 80 90 70 5700 K 80 90 70 5000 K Base Order Codes Min Luminous Flux @ 2400 mA CRI 80 90 Typ 75 --- 95 75 --- 95 75 --- 95 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BD 10,000 11,100 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000N00CD0E1 BB 9,500 10,545 CXA3590-0000-000N0HBB0E1 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000N0HCB0E1 Z4 7,945 8,819 CXA3590-0000-000N0UZ40E1 AB 8,500 9,435 CXA3590-0000-000N00BD0E1 1A0, 1B0, 1C0, 1D0 1A0, 1B0, 1C0, 1D0 1A0, 1B0, 1C0, 1D0 CXA3590-0000-000N00CB0E1 CXA3590-0000-000N0HBD0E1 CXA3590-0000-000N0UAB0E1 AD 9,000 9,990 CXA3590-0000-000N0UAD0E1 BD 10,000 11,100 CXA3590-0000-000N00BD0E2 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000N00CD0E2 BB 9,500 10,545 CXA3590-0000-000N0HBB0E2 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000N0HCB0E2 Z4 7,945 8,819 CXA3590-0000-000N0UZ40E2 AB 8,500 9,435 AD 9,000 9,990 CXA3590-0000-000N0UAD0E2 BD 10,000 11,100 CXA3590-0000-000N00BD0E3 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000N00CD0E3 BB 9,500 10,545 CXA3590-0000-000N0HBB0E3 BD 10,000 11,100 CB 11,000 12,210 AB 8,500 9,435 AD 9,000 9,990 2A0, 2B0, 2C0, 2D0 2A0, 2B0, 2C0, 2D0 2A0, 2B0, 2C0, 2D0 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 CXA3590-0000-000N00CB0E2 CXA3590-0000-000N0HBD0E2 CXA3590-0000-000N0UAB0E2 CXA3590-0000-000N00CB0E3 CXA3590-0000-000N0HBD0E3 CXA3590-0000-000N0HCB0E3 3A0, 3B0, 3C0, 3D0 CXA3590-0000-000N0UAB0E3 CXA3590-0000-000N0UAD0E3 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 6 XLamp ® CXA3590 LED Flux Characteristics, ANSI White Order Codes and Bins - 36 V (If = 2400 mA, TJ = 85 °C) - Continued CCT Range Min 70 4000 K Base Order Codes Min Luminous Flux @ 2400 mA CRI 80 90 Typ 75 --- 95 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BB 9,500 10,545 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000N00CB0E5 AD 9,000 9,435 CXA3590-0000-000N0HAD0E5 BB 9,500 10,545 BD 10,000 11,100 Z4 7,945 8,819 AB 8,500 9,435 CXA3590-0000-000N00BB0E5 5A0, 5B0, 5C0, 5D0 5A0, 5B0, 5C0, 5D0 CXA3590-0000-000N00BD0E5 CXA3590-0000-000N0HBB0E5 CXA3590-0000-000N0HBD0E5 5A0, 5B0, 5C0, 5D0 CXA3590-0000-000N0UZ40E5 CXA3590-0000-000N0UAB0E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 7 XLamp ® CXA3590 LED Flux Characteristics, EasyWhite® Order Codes and Bins - 72 V (If = 1200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). CRI CCT Range Min 70 6500 K 80 90 70 5700 K 80 90 70 5000 K 80 90 Typ 75 --- 95 75 --- 95 75 --- 95 Base Order Codes Min. Luminous Flux @ 1200 mA Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BD 10,000 11,100 CB 11,000 12,210 CD 12,000 13,320 2-Step Chromaticity Region Order Code 4-Step Chromaticity Region Order Code CXA3590-0000-000R00BD65F 65F CXA3590-0000-000R00CB65F CXA3590-0000-000R00CD65F BB 9,500 10,545 BD 10,000 11,100 CXA3590-0000-000R0HBB65F CB 11,000 12,210 CXA3590-0000-000R0HCB65F Z4 7,945 8,819 CXA3590-0000-000R0UZ465F AB 8,500 9,435 AD 9,000 9,990 CXA3590-0000-000R0UAD65F BD 10,000 11,100 CXA3590-0000-000R00BD57F CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000R00CD57F BB 9,500 10,545 CXA3590-0000-000R0HBB57F 65F 65F 57F 57F CXA3590-0000-000R0HBD65F CXA3590-0000-000R0UAB65F CXA3590-0000-000R00CB57F BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000R0HCB57F Z4 7,945 8,819 CXA3590-0000-000R0UZ457F AB 8,500 9,435 AD 9,000 9,990 BD 10,000 11,100 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000R00CD50H CXA3590-0000-000R00CD50F BB 9,500 10,545 CXA3590-0000-000R0HBB50H CXA3590-0000-000R0HBB50F BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000R0HCB50H AB 8,500 9,435 CXA3590-0000-000R0UAB50H AD 9,000 9,990 57F CXA3590-0000-000R0HBD57F CXA3590-0000-000R0UAB57F CXA3590-0000-000R0UAD57F CXA3590-0000-000R00BD50H 50H 50H 50H CXA3590-0000-000R00CB50H CXA3590-0000-000R0HBD50H CXA3590-0000-000R0UAD50H CXA3590-0000-000R00BD50F 50F 50F CXA3590-0000-000R00CB50F CXA3590-0000-000R0HBD50F CXA3590-0000-000R0HCB50F 50F CXA3590-0000-000R0UAB50F CXA3590-0000-000R0UAD50F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 8 XLamp ® CXA3590 LED Flux Characteristics, EasyWhite® Order Codes and Bins - 72 V (If = 1200 mA, TJ = 85 °C) - Continued CRI CCT Range Min 70 4000 K 80 90 80 Typ 75 --- 95 --- 3500 K 93 80 95 --- 3000 K 93 80 95 --- 2700 K 93 95 Base Order Codes Min. Luminous Flux @ 1200 mA 2-Step 4-Step Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BB 9,500 10,545 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000R00CB40H CXA3590-0000-000R00CB40F AD 9,000 9,435 CXA3590-0000-000R0HAD40H CXA3590-0000-000R0HAD40F BB 9,500 10,545 BD 10,000 11,100 Z4 7,945 8,819 AB 8,500 9,435 AD 9,000 9,990 BB 9,500 10,545 BD 10,000 11,100 Z2 7,390 8,203 Z4 7,945 8,819 AD 9,000 9,990 BB 9,500 10,545 BD 10,000 11,100 Z2 7,390 8,203 Z4 7,945 8,819 AB 8,500 9,435 AD 9,000 9,990 BB 9,500 10,545 Y4 6,910 7,670 Z2 7,390 8,203 Chromaticity Region Order Code Chromaticity Region CXA3590-0000-000R00BB40H 40H 40H CXA3590-0000-000R00BD40H CXA3590-0000-000R0HBB40H CXA3590-0000-000R00BB40F 40F 40F CXA3590-0000-000R0HBD40H 40H CXA3590-0000-000R0UZ440H CXA3590-0000-000R0UAB40H CXA3590-0000-000R00BB35H 40F CXA3590-0000-000R0YZ235H CXA3590-0000-000R0YZ435H 35F CXA3590-0000-000R00BB30H 35F CXA3590-0000-000R0YZ230H CXA3590-0000-000R0YZ430H 30F CXA3590-0000-000R00AD27H 30F CXA3590-0000-000R0YY427H CXA3590-0000-000R0YZ227H CXA3590-0000-000R0YZ235F CXA3590-0000-000R0YZ435F CXA3590-0000-000R00BB30F CXA3590-0000-000R0YZ230F CXA3590-0000-000R0YZ430F CXA3590-0000-000R00AB27F 27F CXA3590-0000-000R00BB27H 27H CXA3590-0000-000R00BB35F CXA3590-0000-000R00BD30F CXA3590-0000-000R00AB27H 27H CXA3590-0000-000R0UAB40F CXA3590-0000-000R00AD30F CXA3590-0000-000R00BD30H 30H CXA3590-0000-000R0UZ440F CXA3590-0000-000R00BD35F CXA3590-0000-000R00AD30H 30H CXA3590-0000-000R0HBB40F CXA3590-0000-000R00AD35F CXA3590-0000-000R00BD35H 35H CXA3590-0000-000R00BD40F CXA3590-0000-000R0HBD40F CXA3590-0000-000R00AD35H 35H Order Code CXA3590-0000-000R00AD27F CXA3590-0000-000R00BB27F 27F CXA3590-0000-000R0YY427F CXA3590-0000-000R0YZ227F Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 9 XLamp ® CXA3590 LED Flux Characteristics, ANSI White Order Codes and Bins - 72 V (If = 1200 mA, TJ = 85 °C) The following table provides order codes for XLamp CXA3590 LEDs. For a complete description of the order code nomenclature, please see the Bin and Order Code Formats section (page 21). CCT Range Min 70 6500 K 80 90 70 5700 K 80 90 70 5000 K Base Order Codes Min Luminous Flux @ 1200 mA CRI 80 90 Typ 75 --- 95 75 --- 95 75 --- 95 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BD 10,000 11,100 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000R00CD0E1 BB 9,500 10,545 CXA3590-0000-000R0HBB0E1 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000R0HCB0E1 Z4 7,945 8,819 CXA3590-0000-000R0UZ40E1 AB 8,500 9,435 CXA3590-0000-000R00BD0E1 1A0, 1B0, 1C0, 1D0 1A0, 1B0, 1C0, 1D0 1A0, 1B0, 1C0, 1D0 CXA3590-0000-000R00CB0E1 CXA3590-0000-000R0HBD0E1 CXA3590-0000-000R0UAB0E1 AD 9,000 9,990 CXA3590-0000-000R0UAD0E1 BD 10,000 11,100 CXA3590-0000-000R00BD0E2 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000R00CD0E2 BB 9,500 10,545 CXA3590-0000-000R0HBB0E2 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000R0HCB0E2 Z4 7,945 8,819 CXA3590-0000-000R0UZ40E2 AB 8,500 9,435 AD 9,000 9,990 CXA3590-0000-000R0UAD0E2 BD 10,000 11,100 CXA3590-0000-000R00BD0E3 CB 11,000 12,210 CD 12,000 13,320 CXA3590-0000-000R00CD0E3 BB 9,500 10,545 CXA3590-0000-000R0HBB0E3 BD 10,000 11,100 CB 11,000 12,210 AB 8,500 9,435 AD 9,000 9,990 2A0, 2B0, 2C0, 2D0 2A0, 2B0, 2C0, 2D0 2A0, 2B0, 2C0, 2D0 3A0, 3B0, 3C0, 3D0 3A0, 3B0, 3C0, 3D0 CXA3590-0000-000R00CB0E2 CXA3590-0000-000R0HBD0E2 CXA3590-0000-000R0UAB0E2 CXA3590-0000-000R00CB0E3 CXA3590-0000-000R0HBD0E3 CXA3590-0000-000R0HCB0E3 3A0, 3B0, 3C0, 3D0 CXA3590-0000-000R0UAB0E3 CXA3590-0000-000R0UAD0E3 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 10 XLamp ® CXA3590 LED Flux Characteristics, ANSI White Order Codes and Bins - 72 V (If = 1200 mA, TJ = 85 °C) - Continued CCT Range Min 70 4000 K Base Order Codes Min Luminous Flux @ 1200 mA CRI 80 90 Typ 75 --- 95 Chromaticity Regions Order Code Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* BB 9,500 10,545 BD 10,000 11,100 CB 11,000 12,210 CXA3590-0000-000R00CB0E5 AD 9,000 9,435 CXA3590-0000-000R0HAD0E5 BB 9,500 10,545 BD 10,000 11,100 Z4 7,945 8,819 AB 8,500 9,435 CXA3590-0000-000R00BB0E5 5A0, 5B0, 5C0, 5D0 5A0, 5B0, 5C0, 5D0 CXA3590-0000-000R00BD0E5 CXA3590-0000-000R0HBB0E5 CXA3590-0000-000R0HBD0E5 5A0, 5B0, 5C0, 5D0 CXA3590-0000-000R0UZ40E5 CXA3590-0000-000R0UAB0E5 Notes • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. See the Measurements section (page 24). • Cree XLamp CXA3590 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code * Flux values @ 25 °C are calculated and for reference only. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 11 XLamp ® CXA3590 LED Relative Spectral Power Distribution Relative Spectral Power Distribution The following graph is the result of a series of pulsed measurements at 2400 mA for the 36-V CXA3590 and 1200 mA for the 72‑V CXA3590 and TJ = 85 °C. 100% Relative Spectral Power 90% 80% 70% 60% 5000K, 70 CRI 50% 4000K, 70 CRI 40% 3000K, 80 CRI 30% 3000K, 93 CRI 20% 10% 0% 380 430 480 530 580 630 680 730 780 Wavelength (nm) Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 12 Electrical Characteristics (Tj = 85ºC) XLamp ® CXA3590 LED Electrical Characteristics The following graph is the result of a series of steady-state measurements. 42 41 36 V 40 Voltage (V) 39 Tc = 25 °C 38 Tc = 55 °C 37 Tc = 85 °C 36 Tc = 105 °C 35 34 33 32 400 800 1200 1600 2000 2400 2800 3200 3600 Current(mA) 84 82 72 V 80 Voltage (V) 78 Tc = 25 °C 76 Tc = 55 °C 74 Tc = 85 °C 72 Tc = 105 °C 70 68 66 64 200 400 600 800 1000 1200 1400 1600 1800 Current(mA) Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 13 XLamp ® CXA3590 LED Relative Luminous Flux The relative luminous flux values provided below are the ratio of: • Measurements of CXA3590 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 2400 mA at TJ = 85 °C for the 36‑V CXA3590. Using the 36-V CXA3590 LED as an example, at steady-state operation of Tc = 25 °C, IF = 1200 mA, the relative luminous flux ratio is 60% in the chart below. A CXA3590 LED that measures 11,000  lm during binning will deliver 6,600 lm (11,000 * 0.6) at steady-state operation of Tc = 25 °C, IF = 1200 mA. Relative Luminous Flux 150% 36 V 120% Tc = 25 °C Tc = 55 °C 90% Tc = 85 °C Tc = 105 °C 60% 30% 0% 400 800 1200 1600 2000 2400 2800 3200 3600 Current (mA) Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 14 XLamp ® CXA3590 LED Relative Luminous Flux - Continued The relative luminous flux values provided below are the ratio of: • Measurements of CXA3590 at steady-state operation at the given conditions, divided by • Flux measured during binning, which is a pulsed measurement at 1200 mA at TJ = 85 °C for the 72‑V CXA3590. Using the 72-V CXA3590 LED as an example, at steady-state operation of Tc = 105 °C, IF = 1200 mA, the relative luminous flux ratio is 90% in the chart below. A CXA3590 LED that measures 11,000  lm during binning will deliver 9,900 lm (11,000 * 0.9) at steady-state operation of Tc = 105 °C, IF = 1200 mA. Relative Luminous Flux 150% 72 V 120% Tc = 25 °C Tc = 55 °C 90% Tc = 85 °C Tc = 105 °C 60% 30% 0% 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 15 XLamp ® CXA3590 LED Far Field Typical Spatial Distribution Relative Luminous Intensity 100% 80% 60% 40% 20% -90 -70 -50 -30 0% -10 10 30 50 70 90 Angle (º) Performance Groups - Brightness (36 V, If = 2400 mA; 72 V If = 1200 mA, Tj = 85 °C) XLamp CXA3590 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Min. Luminous Flux @ 1200 mA Max. Luminous Flux @ 1200 mA Y4 6,910 7,390 Z2 7,390 7,945 Z4 7,945 8,500 AB 8,500 9,000 AD 9,000 9,500 BB 9,500 10,000 BD 10,000 11,000 CB 11,000 12,000 CD 12,000 13,000 DB 13,000 14,000 Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 16 XLamp ® CXA3590 LED Performance Groups - Chromaticity (Tj = 85 °C) XLamp CXA3590 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 4-Step Code 65F 57F 50F 40F 35F 30F 27F CCT 6500 K 5700 K 5000 K 4000 K 3500 K 3000 K 2700 K x y 0.3097 0.3196 0.3079 0.3297 0.3164 0.3382 0.3176 0.3275 0.3253 0.3325 0.3249 0.3439 0.3331 0.3514 EasyWhite Color Temperatures – 2-Step 0.3330 0.3393 Code x y 0.3407 0.3459 0.3429 0.3507 0.3415 0.3586 0.3434 0.3571 0.3499 0.3654 0.3475 0.3604 0.3484 0.3521 0.3469 0.3539 0.3744 0.3685 0.3784 0.3741 0.3782 0.3837 0.3804 0.3818 0.3912 0.3917 0.3867 0.3857 0.3863 0.3758 0.3844 0.3778 0.3981 0.3800 0.4030 0.3857 0.4040 0.3966 0.4061 0.3941 0.4186 0.4037 0.4132 0.3976 0.4116 0.3865 0.4099 0.3890 0.4242 0.3919 0.4291 0.3973 0.4322 0.4096 0.4333 0.4062 0.4449 0.4141 0.4395 0.4084 0.4359 0.3960 0.4351 0.3994 0.4475 0.3994 0.4528 0.4046 0.4573 0.4178 0.4578 0.4138 0.4695 0.4207 0.4638 0.4152 0.4589 0.4021 0.4586 0.4060 50H 40H 35H 30H 27H CCT 5000 K 4000 K 3500 K 3000 K 2700 K Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 17 XLamp ® CXA3590 LED Performance Groups - Chromaticity (Tj = 85 °C) - Continued ANSI White Bins Code CCT Bin Code 1A0 1B0 0E1 6500 K 1C0 1D0 ANSI White Bins x y 0.3048 0.3207 0.3130 0.3290 0.3144 0.3186 0.3068 Code Code CCT 3A0 3B0 0E3 5000 K 3C0 3D0 Bin Code x y 0.3215 0.3350 0.3290 0.3417 0.3290 0.3300 0.3113 0.3222 0.3243 2A0 0.3028 0.3304 0.3207 0.3462 0.3115 0.3391 0.3290 0.3538 0.3130 0.3290 0.3290 0.3417 0.3048 0.3207 0.3115 0.3391 0.3205 0.3481 0.3213 0.3373 0.3130 2B0 0.3215 0.3350 0.3290 0.3538 0.3376 0.3616 0.3371 0.3490 0.3290 0.3290 0.3417 0E2 5700 K 2C0 0.3130 0.3290 0.3290 0.3417 0.3213 0.3373 0.3371 0.3490 0.3221 0.3261 0.3366 0.3369 0.3144 0.3186 0.3290 0.3300 2D0 ANSI White Bins Bin Code CCT ANSI White Bins x y .3371 .3451 .3440 .3427 .3366 .3376 .3463 .3687 .3451 .3554 .3371 .3490 .3463 .3687 .3551 .3760 .3533 .3620 .3451 .3451 .3533 .3620 .3515 .3487 .3440 .3427 Code CCT Bin Code x y .3490 .3670 .3578 .3554 .3702 .3722 .3825 .3798 .3369 .3783 .3646 .3616 .3702 .3722 .3736 .3874 .3869 .3958 .3825 .3798 .3825 .3798 .3869 .3958 .4006 .4044 .3554 .3950 .3875 .3554 .3783 .3646 .3825 .3798 .3950 .3875 .3898 .3716 5A0 5B0 0E5 4000 K 5C0 5D0 Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 18 XLamp ® CXA3590 LED Cree EasyWhite® Bins Plotted on the CIE 1931 Color Space (Tj = 85 °C) 0.44 2700K ANSI C78.377 Quadrangle EasyWhite 4 -step EasyWhite 2 -step 0.43 3000K 0.42 3500K 0.41 4000K 0.40 4500K 0.39 5000K CCy 0.38 0.37 5700K 0.36 6500K 0.35 0.34 0.33 0.32 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.31 CCx Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 19 XLamp ® CXA3590 LED Cree ANSI White Bins Plotted on the CIE 1931 Color Space (Tj = 85 °C) 0.42 ANSI C78.377 Quadrangle 0.41 4000K 0.40 4500K 5C 0.39 CCy 5B 5000K 0.38 5D 0.37 5700K 0.36 5A 3C 3B 6500K 0.35 2B 0.34 1C 0.33 1B 0.32 3D 2C 1D 3A 2D 2A 1A 0.31 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.31 0.30 0.29 0.28 0.30 CCx Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 20 XLamp ® CXA3590 LED Bin and Order Code Formats Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA35 Series = CXA35 Internal code Chromaticity bin CRI Specification 0 = Standard CRI H = 80 min CRI U = 90 min CRI Y = 93 min CRI Vf class: N0 = 36-V class R0 = 72-V class Internal code SSSSSCC-WWW-FF-GGR-AAAAA CRI Specification B = 70 min CRI H = 803 min CRI U = 90 min CRI Y = 93 min CRI SSSSSCC-HHHH-HHHGGRNNNNN 6 Kit code 5 4 NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT OF CREE INC. Vf class: N0 = 36-V class R0 = 72-V class Flux bin Performance class D REV Performance class Mechanical Dimensions Dimensions are in mm. 34.85 ±0.2 Tolerances unless otherwise specified: +.13 15.764 4.0 C Tc 1.300 12.16 1.15 ± 0.15 x° +1° 4.0 15.902 14.25 34.85 ±0.2 B 30.00 ±0.2 15.902 32.00 ±0.2 4.0 0.55 ± 0.1 4.0 15.764 UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .01 .XXX ± .005 X° ± .5 ° A TOLERANCE UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN MM THIRD ANGLE PROJECTION .X ± .10 FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 ® .XX ± are .03 Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to± change without notice. Cree®, the Cree logo, XLamp® and EasyWhite .XXX .010 .XXX ± .010 registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. X ° X° ± .5 ° ± 1° SURFACE FINISH: 6 5 4 3 63 21 DRAWN BY D. CRONIN CHECK APPROVED MATERIAL FINAL PROTECTIVE FIN XLamp ® CXA3590 LED Thermal Design The CXA family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to ensure the CXA LED is being operated within its designed limits. Please refer to page 22 for the Operating Limit specification. There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from solder point (TSP) to ambient (Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to the Thermal Management application note. For CXA soldering recommendations and more information on thermal interface materials (TIM) and connection methods, please refer to the Cree XLamp CX Family LEDs soldering and handling document. The CX Family LED Design Guide provides basic information on the requirements to use Cree XLamp CXA LEDs successfully in luminaire designs. To keep the CXA3590 LED at or below the maximum rated Tc, the case to ambient temperature thermal resistance (R_c-a) must be at or below the maximum R_c-a R_j-c R_j-c Tc Tc value shown on the following graph, depending on the operating environment. The y‑axis in each graph is a base 10 logarithmic scale. As the figure at right shows, the R_c-a value is the sum of the thermal resistance of R_tim R_c-a the TIM (R_tim) plus the thermal resistance of the heat sink (R_hs). R_hs CXA3590 Ta Ta Maximum R_c-a 100.00 36 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 400 800 1200 1600 2000 2400 2800 3200 3600 Current (mA) Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 22 XLamp ® CXA3590 LED Thermal Design - Continued Maximum R_c-a 100.00 72 V 10.00 Ta = 25 °C Ta = 55 °C 1.00 Ta = 85 °C Ta = 105 °C 0.10 0.01 200 400 600 800 1000 1200 1400 1600 1800 Current (mA) Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 23 XLamp ® CXA3590 LED Notes Measurements The luminous flux, radiant power, chromaticity and CRI measurements in this document are binning specifications only and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated values are provided for informational purposes only and are not intended as specifications. Lumen Maintenance Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document. Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting. Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Documentation sections of www.cree.com. UL® Recognized Component Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please refer to the LED Eye Safety application note. Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo, XLamp® and EasyWhite® are registered trademarks of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC. 24 XLamp ® CXA3590 LED Packaging Cree CXA3590 LEDs are packaged in trays of 10. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 50 LEDs per carton. Each carton contains 50 LEDs from the same performance bin. Dimensions are in inches. Tolerances: +.13 x° +1° 6 5 4 3 2 1 REVISONS TICE HIS PLOT AND THE INFORMATION E THE PROPRIETARY AND ATION OF CREE, INC. THIS PLOT EPRODUCED OR DISCLOSED TO ANY ON WITHOUTTHE WRITTEN CONSENT REV 5 4 7.500 BY DESCRIPTION 3 DATE 2 APP'D 1 R.375 E INFORMATION RY AND NC. THIS PLOT DISCLOSED TO ANY WRITTEN CONSENT 7.53 R.375 1.59 8.125 1.313 LABEL WITH CREE BIN CODE, QTY, LOT # 1.59 PATENT LABEL TED ON UNDERSIDE OF COVER .38 LABEL WITH CREE CODE, QTY, LOT# BAG BAG 1.313 PATENT LABEL D ON UNDERSIDE OF CARTON 6 LABEL WITH CREE BIN CODE, QTY, LOT # LABEL WITH CREE BIN CODE, QTY, LOT# THIRD ANGLE PROJECTION LABEL WITH CREE BIN CODE, QTY, LOT # UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN INCHES AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .01 .XXX ± .005 X° ± .5 ° FOR SHEET METAL PARTS ONLY .X ± .06 .XX ± .03 .XXX ± .010 X° ± .5 ° SURFACE FINISH: 5 4 DATE DRAWN BY D. CRONIN 4600 Silicon Drive Durham, N.C 27703 7/30/13 CHECK DATE APPROVED DATE Phone (919) 313-5300 Fax (919) 313-5558 TITLE LE3501 MARKETING SPEC MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE 63 3 UNLESS OTHERWISE SPECIFIED DRAWN BY DATE 2 CHECK DATE .X ± .XX ± .XXX ± X° ± APPROVED DATE C DRAWING NO. REV. LE3501 A SHEET 3.000 OF 1 Copyright © 2013-2015 Cree, Inc. All rights reserved. The information in this document is subject to change withoutARE notice. Cree , the Cree logo, XLamp and EasyWhite are DIMENSIONS IN LABEL WITH CREE ® MILLIMETERS & BEFORE FINISH. registered Phone (919) 361-4770 BIN CODE, QTY, LOT#trademarks of Cree, Inc. UL and the UR logo are registered trademarks of UL LLC. TOLERANCE UNLESS SPECIFIED: THIRD ANGLE PROJECTION 0.1 .05 .005 1° FOR SHEET METAL PARTS ONLY ® ® ® 4600 Silicon Drive Durham, N.C 27703 Fax (919) 313-5303 TITLE MATERIAL 25 CXA30XX_DATASHEET 2
CXA3590-0000-000N00CD0E3 价格&库存
很抱歉,暂时无法提供与“CXA3590-0000-000N00CD0E3”相匹配的价格&库存,您可以联系我们找货
