Cree® XLamp® CXB1830 LED
Product Description
features
Table of Contents
The XLamp® CXB1830 LED Array is a
• 14‑mm optical source
Characteristics.............................................2
member of the second generation of
• Optical design consistent with
Operating Limits...........................................2
the CXA family that delivers up to 30%
Flux Characteristics, EasyWhite® Order
CXA1830 LEDs
higher efficacy and up to 20% higher
• Available in 70-, 80-, 90- and
lumens than the first generation in the
95-minimum CRI options
same LES. The higher performance
second generation CXA LED Arrays
• Cree EasyWhite 2‑, 3‑ and 5-step
binning
Codes and Bins............................................3
Flux Characteristics, Premium Color
Order Codes and Bins..................................6
Relative Spectral Power Distribution,
provide a drop-in performance upgrade
• Premium Color 2- and 3-step binning
EasyWhite® ..................................................7
to existing CXA LED designs to shorten
• Forward voltage option: 36‑V class
product development time. In addition,
• 85 °C binning and characterization
Premium Color.............................................7
the CXB LEDs also allow lighting
• Extremely uniform color over viewing
Electrical Characteristics.............................8
manufacturers to achieve the same
angle
Relative Luminous Flux................................9
or better performance with a smaller
• Top-side solder connections
Typical Spatial Distribution....................... 10
LES, enabling a smaller, more impactful
• Thermocouple attach point
Performance Groups - Brightness........... 10
luminaire. Available in 2‑step, 3‑step
• NEMA SSL-3 2011 standard flux bins
EasyWhite® Performance Groups -
and 5‑step EasyWhite® bins and 2‑step
• RoHS and REACh compliant
Chromaticity.............................................. 11
and 3‑step Premium Color bins, the
• UL® recognized component
Premium Color Performance Groups -
CXB1830 LED delivers high lumen
(E349212)
CLD-DS121 Rev 4B
Product family data sheet
Chromaticity.............................................. 12
output and high efficacy in a single,
Cree EasyWhite® Bins Plotted on the
easy‑to‑use package that eliminates the
1931 CIE Color Space............................... 13
need for reflow soldering.
Cree Premium Color Bins Plotted on the
1931 CIE Color Space............................... 14
www.cree.com/Xlamp
The CX Family LED Design Guide
Bin and Order Code Formats.................... 16
provides basic information on the
Mechanical Dimensions........................... 16
requirements to use the CXB1830 LED
Thermal Design......................................... 17
successfully in luminaire designs.
Notes......................................................... 18
Packaging.................................................. 19
Copyright © 2015-2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and
EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
XLamp ® CXB1830 LED
Characteristics
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
115
V
8000
DC forward current
mA
1400*
Reverse current
mA
0.1
Forward voltage (@ 800 mA, 85 °C)
V
35
38
Refer to the Operating Limits section.
Operating Limits
The maximum current rating of the CXB1830 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 16 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 17 for more
CXB1830
information on LES
temperature measurement.
1500
1200
If (mA)
900
600
300
50
75
100
125
150
Case Temperature (°C)
Copyright © 2015-2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a
2
XLamp ® CXB1830 LED
Flux Characteristics, EasyWhite® Order Codes and Bins (If = 800 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXB1830 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 16).
Nominal
CCT
CRI*
Min
70
Minimum Luminous Flux
Typ
6500 K
80
70
70
5000 K
80
90
Flux (lm) Flux (lm)
Group
@ 85 °C @ 25 °C**
Order Code
3-Step
Group
Order Code
Order Code
CXB1830-0000000N0BU465E
4332
V2
4230
4633
V4
4545
4978
CXB1830-0000000N0BV465E
U4
3955
4332
CXB1830-0000000N0HU465E
V2
4230
4633
CXB1830-0000000N0HV265E
U4
3955
4332
CXB1830-0000000N0BU457E
V2
4230
4633
V4
4545
4978
U4
3955
4332
65E
65E
57E
CXB1830-0000000N0BV265E
CXB1830-0000000N0BV257E
CXB1830-0000000N0BV457E
57E
CXB1830-0000000N0HU457E
V2
4230
4633
CXB1830-0000000N0HV257E
U4
3955
4332
CXB1830-0000000N0BU450E
V2
4230
4633
V4
4545
4978
U4
3955
4332
V2
4230
4633
CXB1830-0000000N0HV250G
T4
3440
3768
CXB1830-0000000N0UT450G
U2
3680
4031
U4
3955
4332
92
Group
3955
5-Step
U4
5700 K
80
Group
2-Step
50E
CXB1830-0000000N0BV250E
CXB1830-0000000N0BV450E
50G
50G
CXB1830-0000000N0HU450G
50E
CXB1830-0000000N0HU450E
CXB1830-0000000N0HV250E
CXB1830-0000000N0UU250G
CXB1830-0000000N0UU450G
Notes
Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI
measurements. See the Measurements section (page 18).
Cree XLamp CXB1830 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60.
** Flux values @ 25 °C are calculated and for reference only.
3
XLamp ® CXB1830 LED
Flux Characteristics, EasyWhite® Order Codes and Bins (If = 800 mA, TJ = 85 °C) - Continued
Nominal
CCT
CRI*
Min
70
4000 K
80
90
80
Typ
92
3500 K
90
80
Group
Order Code
5-Step
Group
Order Code
CXB1830-0000000N0BU440E
3955
4332
V2
4230
4633
V4
4545
4978
U2
3680
4031
U4
3955
4332
V2
4230
4633
CXB1830-0000000N0HV240H
CXB1830-0000000N0HV240G
T2
3200
3505
CXB1830-0000000N0UT240H
CXB1830-0000000N0UT240G
T4
3440
3768
U2
3680
4031
CXB1830-0000000N0UU240H
CXB1830-0000000N0UU240G
U2
3680
4031
CXB1830-0000000N0HU235H
CXB1830-0000000N0HU235G
U4
3955
4332
V2
4230
4633
CXB1830-0000000N0HV235H
CXB1830-0000000N0HV235G
S4
2990
3275
CXB1830-0000000N0US435H
CXB1830-0000000N0US435G
T2
3200
3505
40E
CXB1830-0000000N0BV240E
CXB1830-0000000N0BV440E
CXB1830-0000000N0HU240H
40H
40H
35H
35H
CXB1830-0000000N0HU440H
CXB1830-0000000N0UT440H
CXB1830-0000000N0HU435H
CXB1830-0000000N0UT235H
T4
3440
3768
CXB1830-0000000N0UT435H
U2
3680
4031
CXB1830-0000000N0UU235H
U2
3680
4031
92
Order Code
3-Step
U4
92
3000 K
90
Group
2-Step
Flux (lm) Flux (lm)
Group
@ 85 °C @ 25 °C**
30H
CXB1830-0000000N0HU230H
U4
3955
4332
CXB1830-0000000N0HU430H
S4
2990
3275
CXB1830-0000000N0US430H
T2
3200
3505
T4
3440
3768
30H
CXB1830-0000000N0UT230H
CXB1830-0000000N0UT430H
CXB1830-0000000N0HU240G
40G
40G
35G
35G
CXB1830-0000000N0HU440G
CXB1830-0000000N0UT440G
CXB1830-0000000N0HU435G
CXB1830-0000000N0UT235G
CXB1830-0000000N0UT435G
CXB1830-0000000N0UU235G
30G
CXB1830-0000000N0HU230G
CXB1830-0000000N0HU430G
CXB1830-0000000N0US430G
30G
CXB1830-0000000N0UT230G
CXB1830-0000000N0UT430G
Notes
4
XLamp ® CXB1830 LED
Nominal
CCT
CRI*
Min
80
Typ
Group
2-Step
Flux (lm) Flux (lm)
Group
@ 85 °C @ 25 °C**
92
Group
CXB1830-0000000N0HT427H
Order Code
3440
3768
U2
3680
4031
U4
3955
4332
CXB1830-0000000N0HU427H
CXB1830-0000000N0HU427G
S2
2780
3045
CXB1830-0000000N0US227H
CXB1830-0000000N0US227G
S4
2990
3275
T2
3200
3505
27H
27H
CXB1830-0000000N0HU227H
CXB1830-0000000N0US427H
CXB1830-0000000N0UT227H
5-Step
Group
Order Code
CXB1830-0000000N0HT427G
T4
2700 K
90
Order Code
3-Step
27G
27G
CXB1830-0000000N0HU227G
CXB1830-0000000N0US427G
CXB1830-0000000N0UT227G
Notes
5
XLamp ® CXB1830 LED
Flux Characteristics, Premium Color Order Codes and Bins (If = 800 mA, TJ = 85 °C)
Fidelity
Nominal
CCT
CRI*
Typical
Luminous
Flux (lm) Flux (lm) Flux (lm)
@ 85 °C @ 25 °C** @ 85 °C
Min
Typ
Group
4000 K
95
98
S4
2990
3275
3500 K
95
98
S4
2990
3000 K
95
98
S2
2700 K
95
98
S2
2-Step
Group
Order Code
3346
L5A
CXB1830-0000-000N0ZS4L5A
3275
3222
35H
CXB1830-0000-000N0ZS435H
2780
3045
3098
30H
CXB1830-0000-000N0ZS230H
2780
3045
2923
27H
CXB1830-0000-000N0ZS227H
Specialty
Nominal
CCT
3100 K
CRI
Min
90
80
3000 K
90
95
Typical
Luminous
Typ
Group
S4
2990
3275
T2
3200
3505
U2
3680
4031
S2
2780
3030
S4
2990
3275
T2
3200
3505
R4
2600
2848
92
92
98
2-Step
Group
Order Code
3571
4152
3-Step
Group
31Q
L7B
Order Code
Group
Order Code
CXB1830-0000000N0US431Q
CXB1830-0000000N0UT231Q
CXB1830-0000000N0HU2L7B
CXB1830-0000000N0US230U
3571
30Q
CXB1830-0000000N0US430Q
CXB1830-0000000N0UT230Q
3098
L7C
30Q
CXB1830-0000000N0US430U
CXB1830-0000000N0UT230U
CXB1830-0000000N0ZR4L7C
Notes
6
XLamp ® CXB1830 LED
Relative Spectral Power Distribution, EasyWhite®
The following graph is the result of a series of pulsed measurements at 800 mA and TJ = 85 °C.
100%
90%
80%
70%
60%
5000 K, 70 CRI
50%
4000 K, 70 CRI
40%
3000 K, 80 CRI
30%
3000 K, 90 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
Relative Spectral Power Distribution, Premium Color
The following graphs are the result of a series of pulsed measurements at 800 mA and TJ = 85 °C.
Fidelity
100%
90%
80%
70%
60%
4000 K, Z CRI
50%
3500 K, Z CRI
3000 K, Z CRI
40%
2700 K, Z CRI
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
7
XLamp ® CXB1830 LED
Relative
Spectral
Power Distribution, Premium color - Continued
Relative Spectral
Power Distribution
Specialty
100%
90%
80%
70%
31Q, 3100 K, 90 CRI
60%
30Q, 3000 K, 90 CRI
50%
30U, 3000 K, 90 CRI
40%
L7B, 3000 K 80 CRI
30%
L7C, 3000 K, Z CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
The following graph is the result of a series of steady-state measurements.
39
38
Voltage (V)
37
Tc = 25 °C
36
Tc = 55 °C
Tc = 85 °C
35
Tc = 105 °C
34
33
32
400
500
600
700
800
900
1000
1100
1200
1300
1400
Current (mA)
8
XLamp ® CXB1830 LED
The relative luminous flux values provided below are the ratio of measurements of the CXB1830 LED at steady-state operation at the given
conditions, divided by the flux measured during binning, which is a pulsed measurement at 800 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 25 °C, IF = 900 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1830
LED that measures 3200 lm during binning will deliver 3840 lm (3200 * 1.2) at steady-state operation of Tc = 25 °C, IF = 900 mA.
180%
160%
140%
120%
Tc = 25 °C
100%
Tc = 55 °C
Tc = 85 °C
80%
Tc = 105 °C
60%
40%
20%
0%
400
600
800
1000
1200
1400
Current (mA)
9
XLamp ® CXB1830 LED
Far Field
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
Performance Groups - Brightness (If = 800 mA, Tj = 85 °C)
XLamp CXB1830 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
R4
2600
2780
S2
2780
2990
S4
2990
3200
T2
3200
3440
T4
3440
3680
U2
3680
3955
U4
3955
4230
V2
4230
4545
V4
4545
4860
W2
4860
5225
10
XLamp ® CXB1830 LED
EasyWhite® Performance Groups - Chromaticity (Tj = 85 °C)
XLamp CXB1830 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
40H
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3777
0.3739
0.3797
0.3816
0.3861
0.3855
0.3838
0.3777
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
EasyWhite Color Temperatures – 3-Step Ellipse
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
Major Axis
Minor Axis
y
a
b
Rotation Angle
Bin Code
CCT
50G
40G
EasyWhite Color Temperatures – 5-Step Ellipse
Bin Code
CCT
Center Point
x
65E
6500 K
0.3123
0.3282
0.01110
0.00550
61.0
57E
5700 K
0.3287
0.3417
0.01230
0.00600
72.0
50E
5000 K
0.3447
0.3553
0.01400
0.00520
65.0
40E
4000 K
0.3818
0.3797
0.01565
0.00670
53.7
11
XLamp ® CXB1830 LED
Premium Color Performance Groups - Chromaticity (Tj = 85 °C)
XLamp CXB2530 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
Fidelity
Code
L5A
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3764
0.3711
0.3784
0.3787
0.3847
0.3826
0.3825
0.3748
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
Specialty
Code
L7B
L7C
CCT
3000 K
3000 K
x
y
0.4263
0.3848
0.4296
0.3916
0.4361
0.3938
0.4326
0.3868
0.4192
0.3754
0.4224
0.3823
0.4291
0.3847
0.4257
0.3777
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
3100 K
0.4236
0.3888
0.00848
0.00455
50.3
30Q
3000 K
0.4305
0.3935
0.00834
0.00408
53.2
30U
3000 K
0.4274
0.3837
0.00834
0.00408
53.2
Bin Code
CCT
31Q
12
XLamp ® CXB1830 LED
Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
0.44
2700 K
ANSI C78.377 Quadrangle
0.43
3000 K
EasyWhite 5-step
EasyWhite 3-step
0.42
3500 K
EasyWhite 2-step
0.41
4000 K
0.40
4500 K
CCy
0.39
5000 K
0.38
0.37
5700 K
0.36
6500 K
0.35
0.34
0.33
0.32
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.31
CCx
13
XLamp ® CXB1830 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
Fidelity (2-step)
0.44
2700K
0.43
3000K
0.42
3500K
0.41
27H
4000K
CCy
0.40
30H
4500K
35H
0.39
0.38
L5A
0.37
0.36
0.35
0.48
0.47
0.46
0.45
0.44
CCx
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
14
XLamp ® CXB1830 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) - Continued
Speciality (2-step)
0.44
3000 K
0.43
0.42
3500 K
CCy
0.41
0.40
0.39
L7B
L7C
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
Speciality (3-step)
0.44
3000K
0.43
0.42
3500K
CCy
0.41
0.40
30Q
0.39
31Q
30U
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
15
XLamp ® CXB1830 LED
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXB18
Series = CXB18
Internal code
Chromaticity bin
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Vf class
N0 = 36-V class
SSSSSCC-HHHH-HHHGGRNNNNN
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
Vf class
N0 = 36-V class
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Performance class
Flux bin
Kit code
Performance class
Dimensions are in mm.
Tolerances unless otherwise
specified: +.13
x° +1°
B1830N = 36‑V CXB1830
B1830N
Meaning of B1830N
16
XLamp ® CXB1830 LED
Thermal Design
The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum
TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to
ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of
good thermal design. Please refer to page 2 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient
(Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to
the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials
(TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CX Family LEDs soldering and handling
document. The CX Family LED Design Guide provides basic information on the requirements to use Cree XLamp CXB LEDs successfully
To keep the CXB1830 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
scale.
R_j-c
R_j-c
Tc
Tc
R_tim
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXB1830
Ta
Ta
100.00
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
400
500
600
700
800
900
1000
1100
1200
1300
1400
Current (mA)
17
XLamp ® CXB1830 LED
Notes
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp
LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance.
For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting.
Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect
the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product
Ecology section of the Cree website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
18
XLamp ® CXB1830 LED
Packaging
Cree CXB1830 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100
LEDs per carton. Each carton contains 100 LEDs from the same performance bin.
Dimensions are in inches.
REV
DESC.
DATE
BY
CHK.
REV
DATE
BY
Tolerances:
+.13CHK.
DESC.
x° +1°
5
7.875
R.375
6
4
3
2
1
R.375
5
4
3
NOTICE
FIDENTIAL.
THIS PLOT AND THE INFORMATION
NSENT
D WITHIN ARE THE PROPRIETARY AND
TIAL INFORMATION OF CREE, INC. THIS PLOT
E COPIED, REPRODUCED OR DISCLOSED TO ANY
IZED PERSON WITHOUTTHE WRITTEN CONSENT
C.
2
1
.75
.75
5.875
1.125
5.875
R .375
1.125
R.375
7.125
.875
.875
5.875
.38
1.125
.19
.75
PATENT LABELTHIS
ISDRAWING
LOCATED
CONTAINS PROPRIETARY DESIGN INFORMATION
REMAINS ALONG WITH THE PRODUCT OR PRODUCTS
ON UNDERSIDEAND
OF
CARTON
REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED.
.875
THIS DOCUMENT AND THE INFORMATION IT CONTAINS
LABEL WITH CREE
SECTION
C-C OR USED BY ANY
MAY
NOT BE COPIED, TRANSMITTED,
.38
.38
BIN CODE, QTY, LOT#
THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL
ITH CREE BIN
ANTITY, LOT #
.875
UNLESS OTHERWISE NOTED ALL
TOLERANCES ARE AS FOLLOWS:
DO NOT PATENT LABEL
SCALE ON
DWG.
IS LOCATED
UNDERSIDE OF
FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm
ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm
DRAFT ±1°
X.XXX" ±.005 X.XXmm ±.10mm
CARTON
THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION
AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS
DWG.TITLE
MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY
.38
DWG.TITLE
PART DRAWING
.38DATE:
4-3-13
DOKJS
NOT
DR. BY:
SCALE
CHK. BY:
SIZE
B
DWG.
DWG.TOLERANCES
NO.
PART DRAWING
BAG
UNLESS0.750
OTHERWISE NOTED ALL
SCALE:
ARE AS FOLLOWS:
022489-00
DRAFT ±1°
SHEET 2 OF 2
BAG
DATE:
DR. BY:
CHK. BY:
4-3-13
KJS
SCALE: 0.750
SIZE
B
DWG. NO.
022489-00
SHEET 2 OF 2
EL IS LOCATED
IDE OF COVER
LABEL WITH CREE
BIN CODE, QTY, LOT#
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE
BIN CODE, QTY, LOT#
.X
.XX ±
.XXX ±
X°
THIRD ANGLE PROJECTION
L WITH CREE BIN
QUANTITY,
LOT #
6
5 reserved. The information in this document
4
0.1
.05
.005
1°
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
FOR SHEET METAL PARTS ONLY
.X
.06
DATE
DATE
APPROVED
DATE
4600 Silicon Dri
Durham, N.C 27
Phone (919) 361
Fax (919) 313-5
TITLE
CXA15XX_DATASHEET
MATERIAL
.X
± DRAWN
.06BY
.03
UNLESS OTHERWISE SPECIFIED .XX ±
.XXX ±
.010
DIMENSIONS ARE IN
X°
± CHECK
2°
3 UNLESS
notice.
Cree
, XLamp
TOLERANCE
SPECIFIED:and
DRAWN BY
CHECK
SIZE
FINALDATE
PROTECTIVE FINISH
SCALE
DATE
C
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
0.500
2 trademarks and the Cree logo is a
EasyWhite are registered
APPROVED
4600 Silicon Drive
SHEET
OF
Durham,
N.C 27703
Phone (919) 361-4770
1
Fax (919) 313-5303
DATE
TITLE
CXA15XX_DATASHEET
19
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
DRAWING NO.
