Cree® XLamp® CXB1820 LED
Product Description
features
Table of Contents
The XLamp® CXB1820 LED Array is a
• 12‑mm optical source
Characteristics.............................................2
member of the second generation of
• Mechanical and optical design
Operating Limits...........................................2
the CXA family that delivers up to 30%
consistent with other CXA18 and
Flux Characteristics, EasyWhite® Order
higher efficacy and up to 20% higher
CXB18 LEDs with a 12‑mm optical
Codes and Bins............................................3
lumens than the first generation in the
source
Flux Characteristics, Premium Color
same LES. The higher performance
• Available in 70-, 80-, 90- and
second generation CXA LED Arrays
95-minimum CRI options
provide a drop-in performance upgrade
to existing CXA LED designs to shorten
• Cree EasyWhite 2-, 3‑ and 5-step
binning
Order Codes and Bins..................................6
Relative Spectral Power Distribution,
EasyWhite® ..................................................7
product development time. In addition,
• Premium Color 2- and 3-step binning
Premium Color.............................................7
the CXB LEDs also allow lighting
• Forward voltage option: 36‑V class
Electrical Characteristics.............................8
manufacturers to achieve the same
• 85 °C binning and characterization
Relative Luminous Flux................................9
or better performance with a smaller
• Extremely uniform color over viewing
Typical Spatial Distribution....................... 10
LES, enabling a smaller, more impactful
angle
Performance Groups - Brightness........... 10
luminaire. Available in 2‑step, 3‑step
• Top-side solder connections
EasyWhite® Performance Groups -
and 5‑step EasyWhite® bins and 2‑step
• Thermocouple attach point
Chromaticity.............................................. 11
and 3‑step Premium Color bins, the
• NEMA SSL-3 2011 standard flux bins
Premium Color Performance Groups -
CXB1820 LED delivers high lumen
• RoHS and REACh compliant
Chromaticity.............................................. 12
output and high efficacy in a single,
• UL recognized component
Cree EasyWhite® Bins Plotted on the
easy‑to‑use package that eliminates the
need for reflow soldering.
(E349212)
CLD-DS120 Rev 4A
Product family data sheet
1931 CIE Color Space............................... 13
Cree Premium Color Bins Plotted on the
1931 CIE Color Space............................... 14
www.cree.com/Xlamp
The CX Family LED Design Guide
Bin and Order Code Formats.................... 16
provides basic information on the
Mechanical Dimensions........................... 16
requirements to use the CXB1820 LED
Thermal Design......................................... 17
successfully in luminaire designs.
Notes......................................................... 18
Packaging.................................................. 19
Copyright © 2015-2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and
EasyWhite® are registered trademarks and the Cree logo is a trademark of Cree, Inc. UL® and the UR logo are registered trademarks of UL LLC.
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
XLamp ® CXB1820 LED
Characteristics
Characteristics
Unit
Viewing angle (FWHM)
Minimum
Typical
degrees
ESD withstand voltage (HBM per Mil-Std-883D)
Maximum
115
V
8000
DC forward current
mA
1050*
Reverse current
mA
0.1
Forward voltage (@ 550 mA, 85 °C)
V
35
38
Refer to the Operating Limits section.
Operating Limits
The maximum current rating of the CXB1820 depends on the case temperature (Tc) when the LED has reached thermal equilibrium under
steady-state operation. The graph shown below assumes that the system design employs good thermal management (thermal interface
material and heat sink) and may vary when poor thermal management is employed. Please refer to the Mechanical Dimensions section
on page 16 for the location of the Tc measurement point.
Another important factor in good thermal management is the temperature of the Light Emitting Surface (LES). Cree recommends a
maximum LES temperature of 135 °C to ensure optimal LED lifetime. Please refer to the Thermal Design section on page 17 for more
information on CXB1820
LES temperature measurement.
1200
1000
If (mA)
800
600
400
200
50
75
100
125
150
Case Temperature (°C)
Copyright © 2015-2017 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, XLamp® and EasyWhite® are registered trademarks and the Cree logo is a
2
XLamp ® CXB1820 LED
Flux Characteristics, EasyWhite® Order Codes and Bins (If = 550 mA, TJ = 85 °C)
The following table provides order codes for XLamp CXB1820 LEDs. For a complete description of the order code nomenclature, please
see the Bin and Order Code Formats section (page 16).
Nominal
CCT
CRI*
Min
70
Minimum Luminous Flux
Typ
6500 K
80
70
70
90
Order Code
Group
Order Code
5-Step
Group
Order Code
CXB1820-0000000N0BS265E
S2
2780
3050
S4
2990
3280
T2
3200
3510
CXB1820-0000000N0BT265E
S2
2780
3050
CXB1820-0000000N0HS265E
S4
2990
3280
CXB1820-0000000N0HS465E
S2
2780
3050
CXB1820-0000000N0BS257E
S4
2990
3280
T2
3200
3510
S2
2780
3050
65E
65E
57E
CXB1820-0000000N0BS465E
CXB1820-0000000N0BS457E
CXB1820-0000000N0BT257E
5000 K
80
Flux (lm) Flux (lm)
Group
@ 85 °C @ 25 °C**
3-Step
5700 K
80
Group
2-Step
57E
CXB1820-0000000N0HS257E
S4
2990
3280
CXB1820-0000000N0HS457E
S2
2780
3050
CXB1820-0000000N0BS250E
S4
2990
3280
T2
3200
3510
S2
2780
3050
S4
2990
3280
R2
2420
2655
50E
CXB1820-0000000N0BT250E
50G
92
50G
R4
2600
2852
CXB1820-0000000N0BS450E
CXB1820-0000000N0HS250G
CXB1820-0000000N0HS450G
50E
CXB1820-0000000N0HS250E
CXB1820-0000000N0HS450E
CXB1820-0000000N0UR250G
CXB1820-0000000N0UR450G
Notes
Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI
measurements. See the Measurements section (page 18).
Cree XLamp CXB1820 LED order codes specify only a minimum flux bin and not a maximum. Cree may ship reels in flux bins higher than the minimum
specified by the order code without advance notice. Shipments will always adhere to the chromaticity bin restrictions specified by the order code.
For 80 CRI minimum LEDs, CRI R9 minimum is 0 with a ±2 tolerance. For 90 CRI minimum LEDs, CRI R9 typical is 60.
** Flux values @ 25 °C are calculated and for reference only.
3
XLamp ® CXB1820 LED
Flux Characteristics, EasyWhite® Order Codes and Bins (If = 550 mA, TJ = 85 °C) - Continued
Nominal
CCT
CRI*
Min
70
4000 K
80
90
80
Typ
92
Group
2-Step
Flux (lm) Flux (lm)
Group
@ 85 °C @ 25 °C**
80
S4
2990
3280
T2
3200
3510
R4
2600
2852
S2
2780
3050
S4
2990
3280
CXB1820-0000000N0HS440H
CXB1820-0000000N0HS440G
Q4
2260
2479
CXB1820-0000000N0UQ440H
CXB1820-0000000N0UQ440G
R2
2420
2655
R4
2600
2852
CXB1820-0000000N0UR440H
CXB1820-0000000N0UR440G
R4
2600
2852
CXB1820-0000000N0HR435H
CXB1820-0000000N0HR435G
S2
2780
3050
92
Group
CXB1820-0000000N0HS235H
Q4
2260
2479
CXB1820-0000000N0UQ435H
R2
2420
2655
CXB1820-0000000N0UR235H
R2
2420
2655
CXB1820-0000000N0HR230H
R4
2600
2852
S2
2780
3050
CXB1820-0000000N0HS230H
CXB1820-0000000N0HS230G
Q2
2100
2304
CXB1820-0000000N0UQ230H
CXB1820-0000000N0UQ230G
Q4
2260
2479
R2
2420
2655
40E
Order Code
CXB1820-0000000N0BS440E
CXB1820-0000000N0BT240E
CXB1820-0000000N0HR440H
40H
40H
35H
92
5-Step
CXB1820-0000000N0BS240E
3050
35H
30H
3000 K
90
Order Code
2780
Group
S2
3500 K
90
Order Code
3-Step
30H
CXB1820-0000000N0HS240H
CXB1820-0000000N0UR240H
CXB1820-0000000N0HR430H
CXB1820-0000000N0UQ430H
CXB1820-0000000N0UR230H
CXB1820-0000000N0HR440G
40G
40G
35G
35G
CXB1820-0000000N0HS240G
CXB1820-0000000N0UR240G
CXB1820-0000000N0HS235G
CXB1820-0000000N0UQ435G
CXB1820-0000000N0UR235G
CXB1820-0000000N0HR230G
30G
30G
CXB1820-0000000N0HR430G
CXB1820-0000000N0UQ430G
CXB1820-0000000N0UR230G
Notes
4
XLamp ® CXB1820 LED
Nominal
CCT
CRI*
Min
Typ
80
Group
R2
2700 K
90
92
2-Step
Flux (lm) Flux (lm)
Group
@ 85 °C @ 25 °C**
2420
2655
27H
Order Code
CXB1820-0000000N0HR227H
R4
2600
2852
CXB1820-0000000N0HR427H
P4
1965
2156
CXB1820-0000000N0UP427H
Q2
2100
2304
Q4
2260
2479
27H
CXB1820-0000000N0UQ227H
CXB1820-0000000N0UQ427H
3-Step
Group
27G
Order Code
5-Step
Group
Order Code
CXB1820-0000000N0HR227G
CXB1820-0000000N0HR427G
CXB1820-0000000N0UP427G
27G
CXB1820-0000000N0UQ227G
CXB1820-0000000N0UQ427G
Notes
5
XLamp ® CXB1820 LED
Flux Characteristics, Premium Color Order Codes and Bins (If = 550 mA, TJ = 85 °C)
Fidelity
Nominal
CCT
CRI*
Typical
Luminous
Flux (lm) Flux (lm) Flux (lm)
@ 85 °C @ 25 °C** @ 85 °C
Min
Typ
Group
4000 K
95
98
Q2
2100
2304
3500 K
95
98
Q2
2100
3000 K
95
98
P4
2700 K
95
98
P2
2-Step
Group
Order Code
2297
L5A
CXB1820-0000-000N0ZQ2L5A
2304
2212
35H
CXB1820-0000-000N0ZQ235H
1965
2156
2127
30H
CXB1820-0000-000N0ZP430H
1830
2007
2006
27H
CXB1820-0000-000N0ZP227H
Specialty
Nominal
CCT
3100 K
CRI
Min
90
80
3000 K
90
95
Typical
Luminous
Typ
Group
N4
1710
1876
Q2
2100
2304
R2
2420
2655
P4
1965
2156
Q2
2100
2304
Q4
2260
2479
P2
1830
2007
92
92
98
2-Step
Group
Order Code
2451
2850
3-Step
Group
31Q
L7B
Order Code
Group
Order Code
CXB1820-0000000N0UN431Q
CXB1820-0000000N0UQ231Q
CXB1820-0000000N0HR2L7B
CXB1820-0000000N0UP430U
2451
30Q
CXB1820-0000000N0UQ230Q
CXB1820-0000000N0UQ430Q
2127
L7C
30U
CXB1820-0000000N0UQ230U
CXB1820-0000000N0UQ430U
CXB1820-0000000N0ZP2L7C
Notes
6
XLamp ® CXB1820 LED
Relative Spectral Power Distribution, EasyWhite®
The following graph is the result of a series of pulsed measurements at 550 mA and TJ = 85 °C.
100%
90%
80%
70%
60%
5000 K, 70 CRI
50%
4000 K, 70 CRI
40%
3000 K, 80 CRI
30%
3000 K, 90 CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
Relative Spectral Power Distribution, Premium Color
The following graphs are the result of a series of pulsed measurements at 550 mA and TJ = 85 °C.
Fidelity
100%
90%
80%
70%
60%
4000 K, Z CRI
50%
3500 K, Z CRI
3000 K, Z CRI
40%
2700 K, Z CRI
30%
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
7
XLamp ® CXB1820 LED
Relative
Spectral
Power Distribution, Premium color - Continued
Relative Spectral
Power Distribution
Specialty
100%
90%
80%
70%
31Q, 3100 K, 90 CRI
60%
30Q, 3000 K, 90 CRI
50%
30U, 3000 K, 90 CRI
40%
L7B, 3000 K 80 CRI
30%
L7C, 3000 K, Z CRI
20%
10%
0%
380
430
480
530
580
630
680
730
780
Wavelength (nm)
The following graph is the result of a series of steady-state measurements.
39
Voltage (V)
38
37
Tc = 25 °C
Tc = 55 °C
36
Tc = 85 °C
Tc = 105 °C
35
34
33
350
450
550
650
750
850
950
1050
Current (mA)
8
XLamp ® CXB1820 LED
The relative luminous flux values provided below are the ratio of measurements of the CXB1820 LED at steady-state operation at the given
conditions, divided by the flux measured during binning, which is a pulsed measurement at 550 mA at TJ = 85 °C.
For example, at steady-state operation of Tc = 55 °C, IF = 650 mA, the relative luminous flux ratio is 120% in the chart below. A CXB1820
LED that measures 2100 lm during binning will deliver 2520 lm (2100 * 1.2) at steady-state operation of Tc = 55 °C, IF = 650 mA.
200%
180%
160%
140%
Tc = 25 °C
120%
Tc = 55 °C
100%
Tc = 85 °C
80%
Tc = 105 °C
60%
40%
20%
0%
350
450
550
650
750
850
950
1050
Current (mA)
9
XLamp ® CXB1820 LED
Far Field
100%
Relative Luminous Intensity
80%
60%
40%
20%
-90
-70
-50
-30
-10
0%
10
30
50
70
90
Angle (º)
Performance Groups - Brightness (If = 550 mA, Tj = 85 °C)
XLamp CXB1820 LEDs are tested for luminous flux and placed into one of the following bins.
Group Code
Maximum Luminous Flux
N4
1710
1830
P2
1830
1965
P4
1965
2100
Q2
2100
2260
Q4
2260
2420
R2
2420
2600
R4
2600
2780
S2
2780
2990
S4
2990
3200
T2
3200
3440
T4
3440
3680
10
XLamp ® CXB1820 LED
EasyWhite® Performance Groups - Chromaticity (Tj = 85 °C)
XLamp CXB1820 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates.
EasyWhite Color Temperatures – 2-Step
Code
40H
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3777
0.3739
0.3797
0.3816
0.3861
0.3855
0.3838
0.3777
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
EasyWhite Color Temperatures – 3-Step Ellipse
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
5000 K
0.3447
0.3553
0.00840
0.00312
65.0
4000 K
0.3818
0.3797
0.00939
0.00402
53.7
35G
3500 K
0.4073
0.3917
0.00927
0.00414
54.0
30G
3000 K
0.4338
0.4030
0.00834
0.00408
53.2
27G
2700 K
0.4577
0.4099
0.00834
0.00420
48.5
Major Axis
Minor Axis
y
a
b
Rotation Angle
Bin Code
CCT
50G
40G
EasyWhite Color Temperatures – 5-Step Ellipse
Bin Code
CCT
Center Point
x
65E
6500 K
0.3123
0.3282
0.01110
0.00550
61.0
57E
5700 K
0.3287
0.3417
0.01230
0.00600
72.0
50E
5000 K
0.3447
0.3553
0.01400
0.00520
65.0
40E
4000 K
0.3818
0.3797
0.01565
0.00670
53.7
11
XLamp ® CXB1820 LED
Premium Color Performance Groups - Chromaticity (Tj = 85 °C)
Fidelity
Code
L5A
35H
30H
27H
CCT
4000 K
3500 K
3000 K
2700 K
x
y
0.3764
0.3711
0.3784
0.3787
0.3847
0.3826
0.3825
0.3748
0.4022
0.3858
0.4053
0.3942
0.4125
0.3977
0.4091
0.3891
0.4287
0.3975
0.4328
0.4064
0.4390
0.4086
0.4347
0.3996
0.4524
0.4048
0.4574
0.4140
0.4633
0.4154
0.4581
0.4062
Specialty
Code
L7B
L7C
CCT
3000 K
3000 K
x
y
0.4263
0.3848
0.4296
0.3916
0.4361
0.3938
0.4326
0.3868
0.4192
0.3754
0.4224
0.3823
0.4291
0.3847
0.4257
0.3777
Center Point
Major Axis
Minor Axis
x
y
a
b
Rotation Angle
3100 K
0.4236
0.3888
0.00848
0.00455
50.3
30Q
3000 K
0.4305
0.3935
0.00834
0.00408
53.2
30U
3000 K
0.4274
0.3837
0.00834
0.00408
53.2
Bin Code
CCT
31Q
12
XLamp ® CXB1820 LED
Cree EasyWhite® Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
0.44
2700 K
ANSI C78.377 Quadrangle
0.43
3000 K
EasyWhite 5-step
EasyWhite 3-step
0.42
3500 K
EasyWhite 2-step
0.41
4000 K
0.40
4500 K
CCy
0.39
5000 K
0.38
0.37
5700 K
0.36
6500 K
0.35
0.34
0.33
0.32
0.48
0.47
0.46
0.45
0.44
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
0.33
0.32
0.31
0.30
0.29
0.31
CCx
13
XLamp ® CXB1820 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C)
Fidelity (2-step)
0.44
2700K
0.43
3000K
0.42
3500K
0.41
27H
4000K
CCy
0.40
30H
4500K
35H
0.39
0.38
L5A
0.37
0.36
0.35
0.48
0.47
0.46
0.45
0.44
CCx
0.43
0.42
0.41
0.40
0.39
0.38
0.37
0.36
0.35
0.34
14
XLamp ® CXB1820 LED
Cree Premium Color Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) - Continued
Speciality (2-step)
0.44
3000 K
0.43
0.42
3500 K
CCy
0.41
0.40
0.39
L7B
L7C
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
Speciality (3-step)
0.44
3000K
0.43
0.42
3500K
CCy
0.41
0.40
30Q
0.39
31Q
30U
0.38
0.46
0.45
CCx
0.44
0.43
0.42
0.41
0.37
15
XLamp ® CXB1820 LED
Bin codes and order codes are configured as follows:
Order Code
Bin Code
Series = CXB18
Series = CXB18
Internal code
Chromaticity bin
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Vf class
N0 = 36-V class
SSSSSCC-HHHH-HHHGGRNNNNN
Internal code
SSSSSCC-WWW-FF-GGR-AAAAA
Vf class
N0 = 36-V class
CRI Specification
B = 70 CRI minimum
H = 80 CRI minimum
U = 90 CRI minimum
Z = 95 CRI minimum
Performance class
Flux bin
Kit code
Performance class
Dimensions are in mm.
Tolerances unless otherwise
specified: ±.13
x° ±1°
B1820N = 36‑V CXB1820
B1820N
Meaning of B1820N
16
XLamp ® CXB1820 LED
Thermal Design
The CXB family of LED arrays can include over a hundred different LED die inside one package, and thus over a hundred different junction
temperatures (TJ). Cree has intentionally removed junction-temperature-based operating limits and replaced the commonplace maximum
TJ calculations with maximum ratings based on forward current (IF) and case temperature (Tc). No additional calculations are required to
ensure that the CXB LED is being operated within its designed limits. LES temperature measurement provides additional verification of
good thermal design. Please refer to page 2 for the Operating Limit specifications.
There is no need to calculate for TJ inside the package, as the thermal management design process, specifically from TSP to ambient
(Ta), remains identical to any other LED component. For more information on thermal management of Cree XLamp LEDs, please refer to
the Thermal Management application note. For CXB soldering recommendations and more information on thermal interface materials
(TIM), LES temperature measurement, and connection methods, please refer to the Cree XLamp CX Family LEDs soldering and handling
document. The CX Family LED Design Guide provides basic information on the requirements to use Cree XLamp CXB LEDs successfully
To keep the CXB1820 LED at or below the maximum rated Tc, the case to ambient temperature
thermal resistance (R_c-a) must be at or below the maximum R_c-a value shown on the following
graph, depending on the operating environment. The y‑axis in the graph is a base 10 logarithmic
scale.
As the figure at right shows, the R_c-a value is the sum of the thermal resistance of the TIM (R_tim)
R_j-c
R_j-c
Tc
Tc
R_tim
R_c-a
plus the thermal resistance of the heat sink (R_hs).
R_hs
CXB1820
Ta
Ta
100.00
Maximum R_c-a
10.00
Ta = 25 °C
Ta = 55 °C
1.00
Ta = 85 °C
Ta = 105 °C
0.10
0.01
350
450
550
650
750
850
950
1050
Current (mA)
17
XLamp ® CXB1820 LED
Notes
Measurements
The luminous flux, radiant power, chromaticity, forward voltage and CRI measurements in this document are binning specifications only
and solely represent product measurements as of the date of shipment. These measurements will change over time based on a number
of factors that are not within Cree’s control and are not intended or provided as operational specifications for the products. Calculated
values are provided for informational purposes only and are not intended or provided as specifications.
Pre‑Release Qualification Testing
Please read the LED Reliability Overview for details of the qualification process Cree applies to ensure long-term reliability for XLamp
LEDs and details of Cree’s pre-release qualification testing for XLamp LEDs.
Lumen Maintenance
Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance.
For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document.
Please read the Long-Term Lumen Maintenance application note for more details on Cree’s lumen maintenance testing and forecasting.
Please read the Thermal Management application note for details on how thermal design, ambient temperature, and drive current affect
the LED junction temperature.
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold
limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as
implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product
Ecology section of the Cree website.
REACh Compliance
REACh substances of very high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative
to insure you get the most up-to-date REACh Declaration. REACh banned substance information (REACh Article 67) is also available upon
request.
UL® Recognized Component
This product meets the requirements to be considered a UL Recognized Component with Level 4 enclosure consideration. The LED
package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750.
Vision Advisory
WARNING: Do not look at an exposed lamp in operation. Eye injury can result. For more information about LEDs and eye safety, please
refer to the LED Eye Safety application note.
18
XLamp ® CXB1820 LED
Packaging
Cree CXB1820 LEDs are packaged in trays of 20. Five trays are sealed in an anti-static bag and placed inside a carton, for a total of 100
LEDs per carton. Each carton contains 100 LEDs from the same performance bin.
Dimensions are in inches.
REV
DATE
BY
Tolerances:
+.13CHK.
DESC.
x° +1°
5
7.875
6
4
3
2
1
R.375
5
4
3
NOTICE
2
1
.75
IDENTIAL. THIS PLOT AND THE INFORMATION
NSENT
WITHIN ARE THE PROPRIETARY AND
IAL INFORMATION OF CREE, INC. THIS PLOT
E COPIED, REPRODUCED OR DISCLOSED TO ANY
IZED PERSON WITHOUTTHE WRITTEN CONSENT
C.
5.875
R .375
5.875
1.125
R.375
7.125
.875
.875
5.875
.38
1.125
.38
.75
PATENT LABEL IS LOCATED
ON UNDERSIDE OF CARTON
LABEL WITH CREE
SECTION C-C
.19
.38
.875
BIN CODE, QTY, LOT#
ITH CREE BIN
ANTITY, LOT #
.875
PATENT LABEL
IS LOCATED ON UNDERSIDE OF
CARTON
.38
THIS DRAWING CONTAINS PROPRIETARY DESIGN INFORMATION
AND REMAINS ALONG WITH THE PRODUCT OR PRODUCTS
REPRESENTED HEREIN THE PROPERTY OF TEK PAK, INCORPORATED.
THIS DOCUMENT AND THE INFORMATION IT CONTAINS
DWG.TITLE
MAY NOT BE COPIED, TRANSMITTED, OR USED BY ANY
THIRD PARTY WITHOUT THE EXPRESS WRITTEN APPROVAL
PART DRAWING
BAG
DO NOT
SCALE DWG.
UNLESS OTHERWISE NOTED ALL
TOLERANCES ARE AS FOLLOWS:
FRACT ±1/64 X.X" ±.030 X.0mm ±.75mm
ANGLES ±0°-30' X.XX" ±.015 X.Xmm ±.30mm
DRAFT ±1°
X.XXX" ±.005 X.XXmm ±.10mm
BAG
DATE:
DR. BY:
CHK. BY:
4-3-13
KJS
SCALE: 0.750
SIZE
B
DWG. NO.
022489-00
SHEET 2 OF 2
EL IS LOCATED
IDE OF COVER
LABEL WITH CREE
BIN CODE, QTY, LOT#
LABEL WITH CREE BIN
CODE, QUANTITY, LOT #
LABEL WITH CREE BIN
UNLESS OTHERWISE SPECIFIED
DIMENSIONS ARE IN
MILLIMETERS & BEFORE FINISH.
TOLERANCE UNLESS SPECIFIED:
LABEL WITH CREE
BIN CODE, QTY, LOT#
.X
.XX ±
.XXX ±
X°
THIRD ANGLE PROJECTION
L WITH CREE BIN
QUANTITY,
LOT #
6
5 reserved. The information in this document
4
0.1
.05
.005
1°
.X
.XX
.XXX ±
X°
0.1
.05
.005
1 °
FOR SHEET METAL PARTS ONLY
.X
.06
DATE
DATE
APPROVED
DATE
4600 Silicon Driv
Durham, N.C 27
Phone (919) 361
Fax (919) 313-5
TITLE
CXA15XX_DATASHEET
MATERIAL
.X
± DRAWN
.06BY
.03
UNLESS OTHERWISE SPECIFIED .XX ±
.XXX ±
.010
DIMENSIONS ARE IN
X°
± CHECK
2°
3 UNLESS
notice.
Cree
, XLamp
TOLERANCE
SPECIFIED:and
DRAWN BY
CHECK
SIZE
FINALDATE
PROTECTIVE FINISH
SCALE
DATE
C
DRAWING NO.
CXA15XX_DATASHEET_BAG2013
0.500
2 trademarks and the Cree logo is a
EasyWhite are registered
APPROVED
4600 Silicon Drive
SHEET
OF
Durham,
N.C 27703
Phone (919) 361-4770
1
Fax (919) 313-5303
DATE
TITLE
CXA15XX_DATASHEET
19
MATERIAL
SIZE
FINAL PROTECTIVE FINISH
DRAWING NO.
