BXRC-27E2000-C-73-SE
    BRIDGELUX(普瑞)
BXRC-27E2000-C-73-SE 数据手册
Bridgelux Vero SE 13 Array ® ® Product Data Sheet DS121 1 Vero SE Introduction Vero® SE Series is a revolutionary light source system that integrates Bridgelux’s seventh generation COB technology with poke-in connectivity enabling solder-free installation. Vero SE LED light sources streamline assembly processes, lower manufacturing cost, simplify luminaire design, improve light quality and increase design flexibility. Vero SE is available in four different light emitting surface (LES) configurations that operate reliably over a broad current range. With Vero SE, secondary connector and holder components are not required, allowing for rapid integration of arrays into fixtures and an efficient field replaceable solution. Vero SE arrays deliver increased lumen density for improved beam control and precision lighting with 2 and 3 SDCM color control standards for clean and consistent uniform lighting. Bridgelux Décor Series is our state of the art color line designed specifically for premium applications, producing unmatched LED light quality with brilliant color-rendering options and offer pleasing and inspiring lighting palettes. Bridgelux Décor Series color points are available on Vero® SE Series, Vero® Series, V Series™ and V Series™ HD. Décor Series Class A is based on human response testing, providing color points with a combined GAI and CRI metric. Décor Series™ Ultra products provide a high CRI of 97 and a minimum R9 value of 93, which emphasizes the reds and color tones to which the human eye is most receptive - perfect for the most luxurious retail shops and world renowned museums. Décor Series Ultra is also a good replacement for halogen lamps. Décor Series™ Showcase is the optimal solution for replacing ceramic metal halide lamps, incorporating the same pure white light with enhanced spectrum coverage and higher efficacy. Features • Poke-in connectivity • Efficacy of 157 lm/W typical • Lumen output performance ranges from 511 to 6,931 lumens Benefits • Poke-in connectivity enables solderless, connector free installation • Broad application coverage for interior and exterior lighting • Broad range of CCT options from 2700K to 6500K • Flexibility for application driven lighting design requirements • CRI options; minimum 70, 80, and 90 • High quality, true color reproduction • Color control: 2 and 3 SDCM for 2700K-4000K CCT • Uniform consistent white light • Reliable operation at up to 2X nominal drive current • Flexibility in design optimization • Radial die pattern and improved lumen density • Enhanced ease of use and assembly • Top side part number markings • Ability to configure multiple Vero SE arrays in series and parallel reduces customer driver cost • No exposed solder pads or electrical connections • Vf bin code backside marking • Improved inventory management and quality control Contents Product Feature Map 2 Product Nomenclature 2 Product Selection Guide 3 Performance at Commonly Used Drive Currents 10 Electrical Characteristics 19 Eye Safety 20 Absolute Maximum Ratings 21 Performance Curves 22 Typical Radiation Pattern 25 Typical Color Spectrum 26 Mechanical Dimensions 27 Color Binning Information 28 Packaging and Labeling 29 Design Resources 31 Precautions 31 Disclaimers 31 About Bridgelux 32 1 Product Feature Map Vero SE 13 is the second smallest form factor in the product family of the next generation solid state light sources. In addition to delivering the performance and light quality required for many lighting applications, Vero SE incorporates several features to simplify the design integration and manufacturing process, accelerate time to market and reduce system costs. Please visit www. bridgelux.com for more information on the Vero SE family of products. 2D Bar code provides full manufacturing traceability Polarity indication marks simplify manufacturing operator instructions Wire release mechanisms x4 Tc Measurement point Optic mounting holes Radial die configuration improves lumen density and beam control Mounting holes Top side part number marking improves inventory management and outgoing quality control Zhaga Book 3 compatible mounting locations Test ports for probing Dual poke-in connectivity Product Nomenclature The part number designation for Bridgelux Vero SE LED arrays is explained as follows: 1 2 3 4 – 5 6 7 8 9 10 11 – 12 – 13 14 – 15 16 BXRC – 30 E 200 0 – C – 7 3 – SE Product Family Nominal CCT 27 = 2,700K 30 = 3,000K 35 = 3,500K 40 = 4,000K 50 = 5,000K 57 = 5,700K 65 = 6,500K Special Edition CCT Bin Options Gen. 7 Array Configuration CRI C = 70 CRI min. E = 80 CRI min. G = 90 CRI min. H = 97 CRI typ. A = Class A 2 = 2 SDCM 3 = 3 SDCM 4 = 4 SDCM Color Targeting Designator 0 = Cold Targeted 1 = Hot Targeted C = Decor Series Showcase Flux Indicator 200x = 2000 lm 2 Product Selection Guide The following product configurations are available: Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-27E2000-B-7X-SE 2700 80 450 2365 2128 34.8 15.7 151 BXRC-27E2000-C-7X-SE 2700 80 630 3311 2979 34.8 21.9 151 BXRC-27E2000-D-7X-SE 2700 80 500 2401 2161 31.8 15.9 151 BXRC-27G20H0-B-7X-SE 2700 90 450 2036 1832 34.8 15.7 130 BXRC-27G20H0-C-7X-SE 2700 90 630 2850 2565 34.8 21.9 130 BXRC-27G20H0-D-7X-SE 2700 90 500 2067 1860 31.8 15.9 130 BXRC-27G2000-B-7X-SE 2700 90 450 1973 1776 34.8 15.7 126 BXRC-27G2000-C-7X-SE 2700 90 630 2762 2486 34.8 21.9 126 BXRC-27G2000-D-7X-SE 2700 90 500 2003 1803 31.8 15.9 126 BXRC-27H2000-B-7x-SE 2700 97 450 1707 1536 34.8 15.7 109 BXRC-27H2000-C-7x-SE 2700 97 630 2390 2151 34.8 21.9 109 BXRC-27H2000-D-7x-SE 2700 97 500 1733 1560 31.8 15.9 109 BXRC-30C2001-B-7X-SE 3000 70 450 2694 2424 34.8 15.7 172 BXRC-30C2001-C-7X-SE 3000 70 630 3771 3394 34.8 21.9 172 BXRC-30C2001-D-7X-SE 3000 70 500 2735 2461 31.8 15.9 172 BXRC-30E2000-B-7X-SE 3000 80 450 2459 2213 34.8 15.7 157 BXRC-30E2000-C-7X-SE 3000 80 630 3442 3098 34.8 21.9 157 BXRC-30E2000-D-7X-SE 3000 80 500 2496 2247 31.8 15.9 157 BXRC-30G20H0-B-7X-SE 3000 90 450 2145 1931 34.8 15.7 137 BXRC-30G20H0-C-7X-SE 3000 90 630 3004 2703 34.8 21.9 137 BXRC-30G20H0-C-7X-SE 3000 90 500 2178 1960 31.8 15.9 137 BXRC-30G2000-B-7X-SE 3000 90 450 2051 1846 34.8 15.7 131 BXRC-30G2000-C-7X-SE 3000 90 630 2872 2585 34.8 21.9 131 BXRC-30G2000-D-7X-SE 3000 90 500 2083 1875 31.8 15.9 131 BXRC-30G200C-B-73-SE 3000 90 450 1906 34.8 15.8 121 BXRC-30G200C-D-73-SE 3000 90 500 1924 1732 31.8 15.9 121 BXRC-30H2000-B-7x-SE 3000 97 450 1832 1649 34.8 15.7 117 117 BXRC-30H2000-C-7x-SE 3000 97 630 2565 2309 34.8 21.9 BXRC-30H2000-D-7x-SE 3000 97 500 1860 1674 31.8 15.9 117 BXRC-30A2001-B-73-SE8,9 3000 93 450 1848 1663 34.8 15.7 118 BXRC-30A2001-C-73-SE8,9 3000 93 630 2587 2328 34.8 21.9 118 BXRC-30A2001-D-73-SE 3000 93 500 1876 1689 31.8 15.9 118 8,9 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E2000-B-7X-SE 3500 80 450 2537 2283 34.8 15.7 162 BXRC-35E2000-C-7X-SE 3500 80 630 3552 3197 34.8 21.9 162 BXRC-35E2000-D-7X-SE 3500 80 500 2576 2318 31.8 15.9 162 BXRC-35G2000-B-7X-SE 3500 90 450 2114 1903 34.8 15.7 135 BXRC-35G2000-C-7X-SE 3500 90 630 2960 2664 34.8 21.9 135 BXRC-35G2000-D-7X-SE 3500 90 500 2147 1932 31.8 15.9 135 BXRC-35A2001-B-73-SE8,9 3500 93 450 1989 1790 34.8 15.7 127 BXRC-35A2001-C-73-SE8,9 3500 93 630 2784 2506 34.8 21.9 127 BXRC-35A2001-D-73-SE8,9 3500 93 500 2019 1817 31.8 15.9 127 BXRC-40C2001-B-7X-SE 4000 70 450 2772 2495 34.8 15.7 177 177 BXRC-40C2001-C-7X-SE 4000 70 630 3881 3492 34.8 21.9 BXRC-40C2001-D-7X-SE 4000 70 500 2814 2533 31.8 15.9 177 BXRC-40E2000-B-7X-SE 4000 80 450 2553 2297 34.8 15.7 163 163 BXRC-40E2000-C-7X-SE 4000 80 630 3574 3216 34.8 21.9 BXRC-40E2000-D-7X-SE 4000 80 500 2592 2333 31.8 15.9 163 BXRC-40G2000-B-7X-SE 4000 90 450 2192 1973 34.8 15.7 140 BXRC-40G2000-C-7X-SE 4000 90 630 3069 2762 34.8 21.9 140 BXRC-40G2000-D-7X-SE 4000 90 500 2226 2003 31.8 15.9 140 BXRC-40H2000-B-7X-SE 4000 97 450 1864 1677 34.8 15.7 119 BXRC-40H2000-C-7X-SE 4000 97 630 2609 2348 34.8 21.9 119 BXRC-40H2000-D-7X-SE 4000 97 500 1892 1703 31.8 15.9 119 BXRC-40A2001-B-73-SE8,9 4000 93 450 2130 1917 34.8 15.7 136 BXRC-40A2001-C-73-SE8,9 4000 93 630 2982 2683 34.8 21.9 136 BXRC-40A2001-D-73-SE8,9 4000 93 500 2162 1946 31.8 15.9 136 BXRC-50C2001-B-74-SE 5000 70 450 2803 2523 34.8 15.7 179 BXRC-50C2001-C-74-SE 5000 70 630 3924 3532 34.8 21.9 179 BXRC-50C2001-D-74-SE 5000 70 500 2846 2561 31.8 15.9 179 BXRC-50E2001-B-74-SE 5000 80 450 2631 2368 34.8 15.7 168 BXRC-50E2001-C-74-SE 5000 80 630 3683 3315 34.8 21.9 168 BXRC-50E2001-D-74-SE 5000 80 500 2671 2404 31.8 15.9 168 BXRC-50G2001-B-74-SE 5000 90 450 2239 2015 34.8 15.7 143 BXRC-50G2001-C-74-SE 5000 90 630 3135 2822 34.8 21.9 143 BXRC-50G2001-D-74-SE 5000 90 500 2274 2046 31.8 15.9 143 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 4 Product Selection Guide Table 1: Selection Guide, Pulsed Measurement Data (Tj = Tc = 25°C) (continued) Part Number Nominal CCT1 (K) CRI 2 Nominal Drive Current3 (mA) Typical Pulsed Flux4,5,6 Tc = 25ºC (lm) Minimum Pulsed Flux6,7 Tc = 25ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-57C2001-B-74-SE 5700 70 450 2709 2438 34.8 15.7 173 BXRC-57C2001-C-74-SE 5700 70 630 3793 3414 34.8 21.9 173 BXRC-57C2001-D-74-SE 5700 70 500 2751 2476 31.8 15.9 173 BXRC-57E2001-B-74-SE 5700 80 450 2600 2340 34.8 15.7 166 BXRC-57E2001-C-74-SE 5700 80 630 3639 3275 34.8 21.9 166 BXRC-57E2001-D-74-SE 5700 80 500 2639 2375 31.8 15.9 166 BXRC-65C2001-B-74-SE 6500 70 450 2756 2481 34.8 15.7 176 BXRC-65C2001-C-74-SE 6500 70 630 3859 3473 34.8 21.9 176 BXRC-65C2001-D-74-SE 6500 70 500 2798 2519 31.8 15.9 176 BXRC-65E2001-B-74-SE 6500 80 450 2647 2382 34.8 15.7 169 BXRC-65E2001-C-74-SE 6500 80 630 3705 3335 34.8 21.9 169 BXRC-65E2001-D-74-SE 6500 80 500 2687 2418 31.8 15.9 169 Notes for Table 1: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Minimum flux values at the nominal test current are guaranteed by 100% test. 8. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 9. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 5 Product Selection Guide Table 2: Selection Guide, Stabilized DC Performance (Tc = 70°C) 7,8 Part Number Nominal CCT1 (K) GAI2 CRI3 Nominal Drive Current4 (mA) Typical DC Flux5,6 Tc = 70ºC (lm) Minimum DC Flux6,9 Tc = 70ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-30A2001-B-73 3000 80 93 450 1719 1512 34.4 15.5 111 BXRC-30A2001-C-73 3000 80 93 630 2406 2117 34.4 21.6 111 BXRC-30A2001-D-73 3000 80 93 500 1745 1535 31.2 15.6 112 BXRC-35A2001-B-73 3500 80 93 450 1850 1628 34.4 15.5 120 BXRC-35A2001-C-73 3500 80 93 630 2589 2279 34.4 21.6 120 BXRC-35A2001-D-73 3500 80 93 500 1878 1653 31.2 15.6 120 BXRC-40A2001-B-73 4000 80 93 450 1981 1743 34.4 15.5 128 BXRC-40A2001-C-73 4000 80 93 630 2773 2440 34.4 21.6 128 BXRC-40A2001-D-73 4000 80 93 500 2011 1770 31.2 15.6 129 Notes for Table 2: 1. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 2. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C.  GAI may vary depending on fixture design and performance. 3. CRI Values are specified as typical. 4. Drive current is referred to as nominal drive current. 5. Typical performance values are provided as a reference only and are not a guarantee of performance. 6. Bridgelux maintains a ±7% tolerance on flux measurements. 7. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 8. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at specified temperature. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 9. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected 6 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) 139 BXRC-27E2000-B-7X-SE 2700 80 450 2128 1915 33.9 15.3 BXRC-27E2000-C-7X-SE 2700 80 630 2979 2682 33.9 21.4 139 BXRC-27E2000-D-7X-SE 2700 80 500 2161 1945 30.9 15.5 140 BXRC-27G20H0-B-7X-SE 2700 90 450 1832 1649 33.9 15.3 120 BXRC-27G20H0-C-7X-SE 2700 90 630 2565 2309 33.9 21.4 120 BXRC-27G20H0-D-7X-SE 2700 90 500 1860 1674 30.9 15.5 120 BXRC-27G2000-B-7X-SE 2700 90 450 1776 1598 33.9 15.3 116 BXRC-27G2000-C-7X-SE 2700 90 630 2486 2238 33.9 21.4 116 BXRC-27G2000-D-7X-SE 2700 90 500 1803 1623 30.9 15.5 117 BXRC-27H2000-B-7x-SE 2700 97 450 1536 1383 33.9 15.3 101 BXRC-27H2000-C-7x-SE 2700 97 630 2151 1936 33.9 21.4 101 BXRC-27H2000-D-7x-SE 2700 97 500 1560 1404 30.9 15.5 101 BXRC-30C2001-B-7X-SE 3000 70 450 2424 2182 33.9 15.3 159 BXRC-30C2001-C-7X-SE 3000 70 630 3394 3054 33.9 21.4 159 BXRC-30C2001-D-7X-SE 3000 70 500 2461 2215 30.9 15.5 159 BXRC-30E2000-B-7X-SE 3000 80 450 2213 1991 33.9 15.3 145 BXRC-30E2000-C-7X-SE 3000 80 630 3098 2788 33.9 21.4 145 BXRC-30E2000-D-7X-SE 3000 80 500 2247 2022 30.9 15.5 145 BXRC-30G20H0-B-7X-SE 3000 90 450 1931 1738 33.9 15.3 127 BXRC-30G20H0-C-7X-SE 3000 90 630 2703 2433 33.9 21.4 127 BXRC-30G20H0-D-7X-SE 3000 90 500 1960 1764 30.9 15.5 127 BXRC-30G2000-B-7X-SE 3000 90 450 1846 1662 33.9 15.3 121 BXRC-30G2000-C-7X-SE 3000 90 630 2585 2326 33.9 21.4 121 BXRC-30G2000-D-7X-SE 3000 90 500 1875 1687 30.9 15.5 121 BXRC-30G200C-B-73-SE 3000 90 450 1715 1544 33.9 15.3 112 BXRC-30G200C-D-73-SE 3000 90 500 1732 1558 30.9 15.5 112 BXRC-30H2000-B-7x-SE 3000 97 450 1649 1484 33.9 15.3 108 BXRC-30H2000-C-7x-SE 3000 97 630 2309 2078 33.9 21.4 108 BXRC-30H2000-D-7x-SE 3000 97 500 1674 1507 30.9 15.5 108 BXRC-30A2001-B-73-SE7,8 3000 93 450 1663 1497 33.9 15.3 109 BXRC-30A2001-C-73-SE7,8 3000 93 630 2328 2095 33.9 21.4 109 BXRC-30A2001-D-73-SE 3000 93 500 1689 1520 30.9 15.5 109 7,8 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 7 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-35E2000-B-7X-SE 3500 80 450 2283 2055 33.9 15.3 150 BXRC-35E2000-C-7X-SE 3500 80 630 3197 2877 33.9 21.4 150 BXRC-35E2000-D-7X-SE 3500 80 500 2318 2086 30.9 15.5 150 BXRC-35G2000-B-7X-SE 3500 90 450 1903 1712 33.9 15.3 125 BXRC-35G2000-C-7X-SE 3500 90 630 2664 2397 33.9 21.4 125 BXRC-35G2000-D-7X-SE 3500 90 500 1932 1739 30.9 15.5 125 BXRC-35A2001-B-73-SE7,8 3500 93 450 1790 1611 33.9 15.3 117 BXRC-35A2001-C-73-SE7,8 3500 93 630 2506 2255 33.9 21.4 117 BXRC-35A2001-D-73-SE7,8 3500 93 500 1817 1636 30.9 15.5 118 BXRC-40C2001-B-7X-SE 4000 70 450 2495 2245 33.9 15.3 164 BXRC-40C2001-C-7X-SE 4000 70 630 3492 3143 33.9 21.4 164 BXRC-40C2001-D-7X-SE 4000 70 500 2533 2280 30.9 15.5 164 BXRC-40E2000-B-7X-SE 4000 80 450 2297 2068 33.9 15.3 151 BXRC-40E2000-C-7X-SE 4000 80 630 3216 2895 33.9 21.4 151 BXRC-40E2000-D-7X-SE 4000 80 500 2333 2099 30.9 15.5 151 BXRC-40G2000-B-7X-SE 4000 90 450 1973 1776 33.9 15.3 129 BXRC-40G2000-C-7X-SE 4000 90 630 2762 2486 33.9 21.4 129 BXRC-40G2000-D-7X-SE 4000 90 500 2003 1803 30.9 15.5 130 BXRC-40H2000-B-7X-SE 4000 97 450 1677 1509 33.9 15.3 110 110 BXRC-40H2000-C-7X-SE 4000 97 630 2348 2113 33.9 21.4 BXRC-40H2000-D-7X-SE 4000 97 500 1703 1533 30.9 15.5 110 BXRC-40A2001-B-73-SE7,8 4000 93 450 1917 1725 33.9 15.3 126 126 BXRC-40A2001-C-73-SE7,8 4000 93 630 2683 2415 33.9 21.4 BXRC-40A2001-D-73-SE7,8 4000 93 500 1946 1752 30.9 15.5 126 BXRC-50C2001-B-74-SE 5000 70 450 2523 2271 33.9 15.3 165 BXRC-50C2001-C-74-SE 5000 70 630 3532 3179 33.9 21.4 165 BXRC-50C2001-D-74-SE 5000 70 500 2561 2305 30.9 15.5 166 BXRC-50E2001-B-74-SE 5000 80 450 2368 2131 33.9 15.3 155 BXRC-50E2001-C-74-SE 5000 80 630 3315 2983 33.9 21.4 155 BXRC-50E2001-D-74-SE 5000 80 500 2404 2164 30.9 15.5 155 BXRC-50G2001-B-74-SE 5000 90 450 2015 1814 33.9 15.3 132 BXRC-50G2001-C-74-SE 5000 90 630 2822 2539 33.9 21.4 132 BXRC-50G2001-D-74-SE 5000 90 500 2046 1842 30.9 15.5 132 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 8 Product Selection Guide Table 3: Selection Guide, Stabilized DC Performance (Tc = 85°C) 4,5 (continued) Part Number Nominal CCT1 (K) CRI2 Nominal Drive Current3 (mA) Typical DC Flux4,5 Tc = 85ºC (lm) Minimum DC Flux6 Tc = 85ºC (lm) Typical Vf (V) Typical Power (W) Typical Efficacy (lm/W) BXRC-57C2001-B-74-SE 5700 70 450 2438 2194 33.9 15.3 160 BXRC-57C2001-C-74-SE 5700 70 630 3414 3072 33.9 21.4 160 BXRC-57C2001-D-74-SE 5700 70 500 2476 2228 30.9 15.5 160 BXRC-57E2001-B-74-SE 5700 80 450 2340 2106 33.9 15.3 153 BXRC-57E2001-C-74-SE 5700 80 630 3275 2948 33.9 21.4 153 BXRC-57E2001-D-74-SE 5700 80 500 2375 2138 30.9 15.5 154 BXRC-65C2001-B-74-SE 6500 70 450 2481 2232 33.9 15.3 163 163 BXRC-65C2001-C-74-SE 6500 70 630 3473 3125 33.9 21.4 BXRC-65C2001-D-74-SE 6500 70 500 2519 2267 30.9 15.5 163 BXRC-65E2001-B-74-SE 6500 80 450 2382 2144 33.9 15.3 156 BXRC-65E2001-C-74-SE 6500 80 630 3335 3001 33.9 21.4 156 BXRC-65E2001-D-74-SE 6500 80 500 2418 2177 30.9 15.5 156 Notes for Table 3: 1. Nominal CCT as defined by ANSI C78.377-2011. Products with a CCT of 5000K-6500K are hot targeted to Tc = 85°C. 2. All CRI values are measured at Tj = Tc = 25°C. CRI values are typical for Decor Series Ultra, Decor Series Street and Landmark and Decor Series Class A products. CRI values are minimums for all other products. Minimum R9 value for 80 CRI products is 0, the minimum R9 value for 90 CRI products is 50, the minimum R9 value for 97 CRI products is 93. Bridgelux maintains a ± 3 tolerance on CRI and R9 values. 3. Drive current is referred to as nominal drive current. 4. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 5. Typical performance is estimated based on operation under DC (direct current) with LED array mounted onto a heat sink with thermal interface material and the case temperature maintained at 85°C. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 6. Minimum flux values at elevated temperatures are provided for reference only and are not guaranteed by 100% production testing. Based on Bridgelux test setup, values may vary depending on the thermal design of the luminaire and/or the exposed environment to which the product is subjected. 7. Nominal CCT is defined by the Lighting Research Center’s Class A definition. The center of the Class A color bin is on the corresponding isothermal line. 8. GAI value is 80. To help ensure optimal fixture level performance, GAI is measured at the fixture level, on axis, at a case temperature of 70°C. GAI may vary depending on fixture design and performance. 9 Performance at Commonly Used Drive Currents Vero SE LED arrays are tested to the specifications shown using the nominal drive currents in Table 1. Vero SE may also be driven at other drive currents dependent on specific application design requirements. The performance at any drive current can be derived from the current vs. voltage characteristics shown in Figures 1, 2 & 3 and the flux vs. current characteristics shown in Figures 4, 5 & 6. The performance at commonly used drive currents is summarized in Table 4. Table 4: Product Performance at Commonly Used Drive Currents Part Number CRI BXRC-27E2000-B-7X 80 BXRC-27E2000-C-7X 80 BXRC-27E2000-D-7X 80 BXRC-27G20H0-B-7X 90 BXRC-27G20H0-C-7X 90 BXRC-27G20H0-D-7X 90 BXRC-27G2000-B-7X 90 BXRC-27G2000-C-7X 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 644 1247 2365 3417 4359 894 1732 3311 4752 6064 636 1232 2401 3393 4338 554 1073 2036 2942 3753 770 1491 2850 4091 5221 547 1061 2067 2921 3735 537 1040 1973 2852 3637 746 1445 2762 3965 5060 590 1131 2128 2993 3744 846 1631 2979 4442 5651 607 1173 2161 3214 4100 508 973 1832 2576 3223 728 1404 2565 3824 4865 523 1010 1860 2767 3529 492 943 1776 2497 3124 706 1361 2486 3707 4715 178 168 151 140 130 177 166 151 139 129 172 162 151 136 126 153 144 130 121 112 152 143 130 120 111 148 140 130 117 108 149 140 126 117 108 147 139 126 116 108 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 10 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-27G2000-D-7X 90 BXRC-27H2000-B-7X-SE 80 BXRC-27H2000-C-7X-SE 80 BXRC-27H2000-D-7X-SE 80 BXRC-30C2001-B-74-SE 70 BXRC-30C2001-C-74-SE 70 BXRC-30C2001-D-74-SE 70 BXRC-30E2000-B-7X-SE 80 BXRC-30E2000-C-7X-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 530 1028 2003 2831 3620 465 900 1707 2467 3147 646 1250 2390 3430 4378 459 889 1733 2449 3132 734 1420 2694 3893 4965 1019 1972 3771 5412 6908 724 1403 2735 3865 4942 670 1296 2459 3553 4532 930 1800 3442 4940 6305 506 979 1803 2682 3421 426 816 1536 2160 2703 610 1177 2151 3207 4079 438 847 1560 2320 2959 672 1288 2424 3409 4265 963 1857 3394 5060 6437 691 1337 2461 3661 4670 614 1175 2213 3112 3893 879 1695 3098 4619 5875 144 136 126 114 105 129 121 109 101 94 128 120 109 101 93 124 117 109 98 91 203 191 172 160 148 201 190 172 159 147 196 185 172 155 144 185 174 157 146 135 184 173 157 145 134 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 11 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30E2000-D-7X-SE 80 BXRC-30G20H0-B-7X 90 BXRC-30G20H0-C-7X 90 BXRC-30G20H0-D-7X 90 BXRC-30G2000-B-7X-SE 90 BXRC-30G2000-C-7X-SE 90 BXRC-30G2000-D-7X-SE 90 BXRC-30G200C-B-73-SE 90 BXRC-30G200C-D-73-SE 90 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 125 250 500 750 1000 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 3.7 7.6 15.9 24.9 34.4 661 1281 2496 3528 4511 584 1131 2145 3100 3955 812 1571 3004 4311 5502 577 1118 2178 3078 3936 559 1081 2051 2965 3782 776 1502 2872 4122 5261 551 1069 2083 2943 3764 519 1005 1906 2754 3513 509 987 1924 2719 3476 631 1220 2247 3342 4262 535 1026 1931 2715 3397 767 1479 2703 4030 5127 551 1065 1960 2916 3719 512 981 1846 2596 3248 734 1415 2585 3854 4902 527 1018 1875 2788 3557 476 911 1715 2412 3018 486 940 1732 2576 3285 179 169 157 142 131 162 152 137 127 118 160 151 137 126 117 156 147 137 124 114 155 146 131 122 113 153 144 131 121 112 149 141 131 118 109 144 135 122 113 105 138 130 121 109 101 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 12 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-30H2000-B-7X-SE 80 BXRC-30H2000-C-7X-SE 80 BXRC-30H2000-D-7X-SE 80 BXRC-30A2001-B-73-SE 93 BXRC-30A2001-C-73-SE 93 BXRC-30A2001-D-73-SE 93 BXRC-35E2000-B-7X-SE 80 BXRC-35E2000-C-7X-SE 80 BXRC-35E2000-D-7X-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 499 966 1832 2648 3378 693 1342 2565 3682 4699 492 955 1860 2629 3361 503 974 1848 2670 3406 699 1353 2587 3713 4739 497 963 1876 2651 3390 691 1337 2537 3666 4677 960 1858 3552 5098 6506 682 1322 2576 3640 4654 457 876 1649 2319 2901 655 1263 2309 3442 4378 470 909 1674 2490 3176 461 883 1663 2339 2926 661 1274 2328 3471 4416 474 917 1689 2512 3204 633 1213 2283 3211 4017 907 1749 3197 4766 6062 651 1259 2318 3448 4398 138 130 117 109 101 137 129 117 108 100 133 126 117 106 98 139 131 118 110 102 138 130 118 109 101 134 127 118 107 98 191 180 162 151 139 190 179 162 150 139 185 174 162 146 135 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 13 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-35G2000-B-7X-SE 90 BXRC-35G2000-C-7X-SE 90 BXRC-35G2000-D-7X-SE 90 BXRC-35A2001-B-73-SE 93 BXRC-35A2001-C-73-SE 93 BXRC-35A2001-D-73-SE 93 BXRC-40C2001-B-74-SE 70 BXRC-40C2001-C-74-SE 70 BXRC-40C2001-D-74-SE 70 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 576 1114 2114 3055 3897 800 1548 2960 4248 5422 568 1101 2147 3033 3879 542 1048 1989 2874 3666 752 1456 2784 3996 5101 535 1036 2019 2854 3649 755 1461 2772 4006 5110 1048 2030 3881 5570 7109 745 1444 2814 3977 5085 528 1011 1903 2676 3347 756 1458 2664 3971 5052 543 1049 1932 2874 3665 496 951 1790 2517 3149 711 1371 2506 3736 4753 511 987 1817 2703 3448 692 1325 2495 3508 4389 991 1911 3492 5207 6624 711 1375 2533 3768 4805 159 150 135 126 116 158 149 135 125 115 154 145 135 122 113 150 141 127 118 109 149 140 127 117 109 145 137 127 115 106 209 197 177 165 152 207 195 177 163 151 202 190 177 160 148 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 14 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40E2000-B-7X-SE 80 BXRC-40E2000-C-7X-SE 80 BXRC-40E2000-D-7X-SE 80 BXRC-40G2000-B-7X-SE 90 BXRC-40G2000-C-7X-SE 90 BXRC-40G2000-D-7X-SE 90 BXRC-40H2000-B-7X-SE 97 BXRC-40H2000-C-7X-SE 97 BXRC-40H2000-D-7X-SE 97 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 695 1346 2553 3689 4705 966 1869 3574 5129 6546 686 1330 2592 3662 4683 597 1156 2192 3168 4041 829 1605 3069 4405 5623 589 1142 2226 3146 4022 508 982 1864 2693 3435 705 1365 2609 3745 4779 501 971 1892 2674 3419 637 1220 2297 3231 4042 913 1760 3216 4795 6100 655 1267 2333 3470 4425 547 1048 1973 2775 3471 784 1512 2762 4118 5239 563 1088 2003 2980 3801 465 891 1677 2358 2951 666 1285 2348 3501 4453 478 925 1703 2533 3231 192 181 163 152 140 191 180 163 151 139 186 175 163 147 136 165 156 140 130 120 164 154 140 129 120 160 151 140 126 117 140 132 119 111 102 139 131 119 110 102 136 128 119 107 99 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 15 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-40A2001-B-73-SE 93 BXRC-40A2001-C-73-SE 93 BXRC-40A2001-D-73-SE 93 BXRC-50C2001-B-74-SE 70 BXRC-50C2001-C-74-SE 70 BXRC-50C2001-D-74-SE 70 BXRC-50E2001-B-74-SE 80 BXRC-50E2001-C-74-SE 80 BXRC-50E2001-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 580 1123 2130 3078 3926 806 1560 2982 4280 5462 572 1110 2162 3056 3907 763 1478 2803 4051 5167 1060 2053 3924 5633 7189 753 1460 2846 4022 5143 716 1387 2631 3802 4850 995 1927 3683 5287 6747 707 1371 2671 3775 4827 532 1018 1917 2695 3372 762 1469 2683 4001 5089 547 1057 1946 2895 3692 700 1340 2523 3548 4438 1002 1933 3532 5266 6698 720 1391 2561 3810 4860 657 1258 2368 3330 4166 941 1814 3315 4942 6287 675 1306 2404 3576 4561 160 151 136 126 117 159 150 136 126 116 155 146 136 123 113 211 199 179 166 154 210 197 179 165 153 204 193 179 162 149 198 187 168 156 145 197 185 168 155 144 191 181 168 152 140 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 16 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-50G2001-B-74-SE 90 BXRC-50G2001-C-74-SE 90 BXRC-50G2001-D-74-SE 90 BXRC-57C2001-B-74-SE 70 BXRC-57C2001-C-74-SE 70 BXRC-57C2001-D-74-SE 70 BXRC-57E2001-B-74-SE 80 BXRC-57E2001-C-74-SE 80 BXRC-57E2001-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 610 1180 2239 3236 4128 847 1640 3135 4500 5743 602 1167 2274 3213 4108 738 1428 2709 3915 4994 1025 1984 3793 5444 6948 728 1412 2751 3887 4970 708 1370 2600 3757 4792 983 1904 3639 5224 6667 699 1354 2639 3730 4769 559 1071 2015 2834 3546 801 1544 2822 4207 5351 575 1111 2046 3044 3882 676 1295 2438 3429 4290 969 1868 3414 5089 6474 695 1344 2476 3682 4697 649 1243 2340 3290 4116 930 1793 3275 4883 6212 667 1290 2375 3533 4507 169 159 143 133 123 167 158 143 132 122 163 154 143 129 119 204 192 173 161 149 202 191 173 160 148 197 186 173 156 144 196 184 166 154 143 194 183 166 153 142 189 179 166 150 139 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 17 Performance at Commonly Used Drive Currents Table 4: Product Performance at Commonly Used Drive Currents (Continued) Part Number CRI BXRC-65C2001-B-74-SE 70 BXRC-65C2001-C-74-SE 70 BXRC-65C2001-D-74-SE 70 BXRC-65E2001-B-74-SE 80 BXRC-65E2001-C-74-SE 80 BXRC-65E2001-D-74-SE 80 Drive Current1 (mA) Typical Vf Tc = 25ºC (V) Typical Power Tc = 25ºC (W) Typical Flux2 Tc = 25ºC (lm) Typical DC Flux3 Tc = 85ºC (lm) Typical Efficacy Tc = 25ºC (lm/W) 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 113 225 450 675 900 158 315 630 945 1260 125 250 500 750 1000 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 32.1 33.0 34.8 36.1 37.3 32.1 33.0 34.8 36.1 37.3 29.6 30.3 31.8 33.2 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 3.6 7.4 15.7 24.3 33.6 5.1 10.4 21.9 34.1 47.0 3.7 7.6 15.9 24.9 34.4 751 1453 2756 3983 5081 1043 2018 3859 5538 7069 741 1436 2798 3955 5056 721 1395 2647 3825 4879 1001 1938 3705 5318 6787 711 1379 2687 3797 4855 688 1318 2481 3488 4364 986 1901 3473 5177 6586 707 1368 2519 3746 4778 661 1265 2382 3349 4191 946 1825 3335 4972 6324 679 1313 2418 3597 4588 208 196 176 164 151 206 194 176 163 150 201 189 176 159 147 199 188 169 157 145 198 186 169 156 144 193 182 169 153 141 Notes for Table 4: 1. Alternate drive currents are provided for reference only and are not a guarantee of performance. 2. Bridgelux maintains a ± 7% tolerance on flux measurements. 3. Typical stabilized DC performance values are provided as reference only and are not a guarantee of performance. 18 Electrical Characteristics Table 5: Electrical Characteristics Forward Voltage Pulsed, Tc = 25ºC (V) 1, 2, 3, 8 Part Number BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Drive Current (mA) Typical Coefficient of Forward Voltage4 ∆Vf/∆Tc (mV/ºC) Typical Thermal Resistance Junction to Case5,6 Rj-c (ºC/W) Driver Selection Voltages7 (V) Vf Min. Hot Tc = 105ºC (V) Vf Max. Cold Tc = -40ºC (V) 0.28 31.0 38.3 -14.3 0.35 33.4 41.0 37.4 -14.3 0.20 31.0 38.3 37.3 40.1 -14.3 0.24 33.4 41.0 29.4 31.8 34.2 -13.3 0.34 28.4 35.0 31.8 34.4 37.0 -13.3 0.41 30.8 37.9 Minimum Typical Maximum 450 32.2 34.8 37.4 -14.3 900 34.5 37.3 40.1 630 32.2 34.8 1260 34.5 500 1000 Notes for Table 5: 1. Parts are tested in pulsed conditions, Tc = 25°C. Pulse width is 10ms. 2. Voltage minimum and maximum are provided for reference only and are not a guarantee of performance. 3. Bridgelux maintains a tester tolerance of ± 0.10V on forward voltage measurements. 4. Typical coefficient of forward voltage tolerance is ± 0.1mV for nominal current. 5. Thermal resistance values are based from test data of a 3000K 80 CRI product. 6. Thermal resistance value was calculated using total electrical input power; optical power was not subtracted from input power. The thermal interface material used during testing is not included in the thermal resistance value. 7. Vf min hot and max cold values are provided as reference only and are not guaranteed by test. These values are provided to aid in driver design and selection over the operating range of the product. 8. This product has been designed and manufactured per IEC 62031:2014. This product has passed dielectric withstand voltage testing at 1160 V. The working voltage designated for the insulation is 80V d.c. The maximum allowable voltage across the array must be determined in the end product application. 19 Eye Safety Table 6: Eye Safety Risk Group (RG) Classifications Part Number BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Drive Current 5 (mA) CCT1,5 2700K/3000K 4000K2 5000K3 6500K4 450 RG1 RG1 RG1 RG1 675 RG1 RG1 RG1 RG2 900 RG1 RG1 RG2 RG2 630 RG1 RG1 RG1 RG1 945 RG1 RG1 RG2 RG2 1260 RG1 RG2 RG2 RG2 500 RG1 RG1 RG1 RG1 750 RG1 RG1 RG1 RG2 1000 RG1 RG1 RG2 RG2 Notes for Table 6: 1. Eye safety classification for the use of Bridgelux Vero SE Series LED arrays is in accordance with specification IEC/TR 62778: Application of IEC 62471 for the assessment of blue light hazard to light sources and luminaires. 2. For products classified as RG2 at 4000K, Ethr= 1847.5 lx. 3. For products classified as RG2 at 5000K Ethr= 1315.8 lx. 4. For products classified as RG2 at 6500K, Ethr= 1124.5 lx. 5. Please contact your Bridgelux sales representative for Ethr values at specific drive currents and CCTs not listed. 20 Absolute Maximum Ratings Table 7: Maximum Ratings Parameter Maximum Rating LED Junction Temperature (Tj) 150°C Storage Temperature -40°C to +105°C Operating Case Temperature1 (Tc) 105°C BXRC-xxx200x-B-7x-SE BXRC-xxx200x-C-7x-SE BXRC-xxx200x-D-7x-SE Maximum Drive Current3 900mA 1260mA 1000mA Maximum Peak Pulsed Drive Current4 1290mA 1800mA 1430mA Maximum Reverse Voltage5 -60V -60V -55V Notes for Table 7: 1. For IEC 62717 requirement, please consult your Bridgelux sales representative. 2. Refer to Bridgelux Application Note AN120: Assembly Considerations for Bridgelux Vero SE LED Arrays. 3. Arrays may be driven at higher currents however lumen maintenance may be reduced. 4. Bridgelux recommends a maximum duty cycle of 10% and pulse width of 20 ms when operating LED Arrays at maximum peak pulsed current specified. Maximum peak pulsed currents indicate values where LED Arrays can be driven without catastrophic failures. 5. Light emitting diodes are not designed to be driven in reverse voltage and will not produce light under this condition. Maximum rating provided for reference only. 21 Performance Curves Figure 1: Vero SE 13B Drive Current vs. Voltage Figure 2: Vero SE 13C Drive Current vs. Voltage 1000 1400 900 1200 700 Forward Current (mA) Forward Current (mA) 800 600 500 400 300 1000 800 600 400 200 200 100 0 32 33 34 35 36 37 0 38 32 33 34 Forward Voltage (V) 35 36 37 38 Forward Voltage (V) Figure 3: Vero SE 13D Drive Current vs. Voltage Figure 4: Vero SE 13B Typical Relative Flux vs. Current 200% 1100 180% 1000 160% Relative Luminous Flux Forward Current (mA) 900 800 700 600 500 400 300 120% 100% 80% 60% 40% 200 20% 100 0 140% 0% 29 30 31 32 33 34 0 35 100 200 300 200% 200% 180% 180% 160% 160% 140% 140% 120% 100% 80% 60% 850 Forward Current (mA) 900 1000 60% 20% 0% 700 800 80% 40% 550 700 100% 20% 400 600 120% 40% 250 500 Figure 6 Vero SE 13D Typical Relative Flux vs. Current Relative Luminous Flux Relative Luminous Flux Figure 5: Vero SE 13C Typical Relative Flux vs. Current 100 400 Forward Current (mA) Forward Voltage (V) 1000 1150 1300 0% 0 100 200 300 400 500 600 700 800 900 1000 1100 Forward Current (mA) Notes for Figures 1-6: 1. Bridgelux does not recommend driving high power LEDs at low currents. Doing so may produce unpredictable results. Pulse width modulation (PWM) is recommended for dimming effects. 2. Products tested under pulsed condition (10ms pulse width) at nominal test current where Tj (junction temperature) = Tc (case temperature) = 25°C. 22 Performance Curves Figure 7: Typical DC Flux vs. Case Temperature 0 103% 25 50 75 100 125 0.003 Warm White Neutral White 100% Cool White 0.000 25°C Pulsed 97% -0.003 94% ccy Shift Relative Luminous Flux Figure 8: Typical DC ccy Shift vs. Case Temperature 91% -0.006 88% -0.009 85% -0.012 82% -0.015 Warm White 0 25 50 75 100 125 Case Temperature (°C) Neutral White Cool White 25°C Pulsed Case Temperature (°C) Figure 9: Typical DC ccx Shift vs. Case Temperature 0 25 50 75 100 125 0.000 -0.002 ccx Shift -0.004 -0.006 -0.008 Warm White -0.010 -0.012 Neutral White Cool White 25°C Pulsed Case Temperature (°C) Notes for Figures 7 - 9: 1. Characteristics shown for warm white based on 3000K and 80 CRI. 2. Characteristics shown for neutral white based on 4000K and 80 CRI. 3. Characteristics shown for cool white based on 5000K and 70 CRI. 4. For other color SKUs, the shift in color will vary. Please contact your Bridgelux Sales Representative for more information. 23 Performance Curves Figure 10: 2700K, 97 CRI Color Shift vs. Case Temperature1 Figure 11: 3000K, 97 CRI Color Shift vs. Case Temperature1 0.4110 0.4050 15°C Pulsed Center Point Tc = 25°C 0.4100 25°C 25°C 0.4090 45°C 0.4010 45°C ccy ccy 0.4080 Pulsed Center Point Tc = 25°C 15°C 0.4030 0.4070 65°C 70°C 0.3990 0.4060 85°C 85°C 0.4050 0.3970 105°C 0.4040 105°C 0.4030 0.457 0.3950 0.4323 0.4572 0.4574 0.4576 0.4578 0.4328 0.4333 0.458 0.4343 0.4348 0.4353 ccx ccx Figure 12: 3000K, 90 CRI Color Shift vs. Case Temperature1,3 0.4338 Figure 13: 3000K Class A Color Shift vs. Case Temperature1 0.403 15°C 0.402 0.369 Pulsed Center Point Tc=25°C 25°C 25°C 0.401 0.367 45°C 0.4 0.399 0.366 65°C ccy ccy 15°C 0.368 0.398 85°C 0.364 70°C 85°C 0.362 105°C 0.396 45°C 0.365 0.363 0.397 0.361 0.395 0.444 0.4445 0.445 0.4455 0.446 0.4465 Figure 14: 3500K Class A Color Shift vs. Case Temperature1 0.366 0.417 ccx 0.4175 0.418 0.4185 0.3760 15°C 25°C 0.4165 Figure 15: 4000K Class A Color Shift vs. Case Temperature1 0.37 0.368 105°C 0.36 0.416 0.447 ccx Pulsed Center Point Tc=25°C 15°C 0.3740 25°C 0.3720 45°C Pulsed Center Point Tc=25°C 45°C ccy 0.3700 ccy Pulsed Center Point Tc=25°C 0.364 0.3680 70°C 0.362 70°C 0.3660 85°C 0.36 85°C 0.3640 105°C 0.358 0.392 105°C 0.393 0.394 0.395 0.396 0.397 ccx Notes for Figures 10-15: 1. Measurements made under DC test conditions at the nominal drive current. 2. Typical color shift is shown with a tolerance of ±0.002. 3. Characteristics shown for Decor Series Showcase products, BXRC-30G400C-x-73-SE 0.3620 0.373 0.374 0.375 0.376 ccx 0.377 0.378 0.379 24 Typical Radiation Pattern Figure 16: Typical Spatial Radiation Pattern Note for Figure 16: 1. Typical viewing angle is 120⁰. 2. The viewing angle is defined as the off axis angle from the centerline where intensity is ½ of the peak value. Figure 17: Typical Polar Radiation Pattern 25 Typical Color Spectrum Figure 18: Typical Color Spectrum 110% 3000K 100% 4000K 5000K Relative Spectral Power Distribution 90% 6500K 80% 70% 60% 50% 40% 30% 20% 10% 0% 400 450 500 550 600 650 700 750 800 Wavelength (nm) Note for Figure 18: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 2. Color spectra shown is 3000K and 80 CRI. 3. Color spectra shown is 4000K and 80 CRI. 4. Color spectra shown is 5000K and 70 CRI. 4. Color spectra shown is 6500K and 70 CRI. Figure 19: Typical Color Spectrum for Vero SE 13 with Décor Series 1 27H 0.9 30H 30G (Décor Series Showcase) Relative Spectral Power Distribution 0.8 0.7 0.6 0.5 0.4 0.3 0.2 0.1 0 400 450 500 550 600 Wavelength (nm) 650 700 750 800 Note for Figure 19: 1. Color spectra measured at nominal current for Tj = Tc = 25°C. 26 Mechanical Dimensions Figure 20: Drawing for Vero SE 13 LED Array Notes for Figure 20: 1. Drawings are not to scale. 2. Drawing dimensions are in millimeters. 3. Unless otherwise specified, tolerances are ±0.1mm. 4. Mounting holes (2X) are for M3 screws. 5. Bridgelux recommends two tapped holes for mounting screws with 31.4 ± 0.10mm center-to-center spacing. 6. Screws with flat shoulders (pan, dome, button, round, truss, mushroom) provide optimal torque control. Do NOT use flat, countersink, or raised head screws. 7. The optical center of the LED Array is nominally defined by the mechanical center of the array to a tolerance of ± 0.2mm. 8. Bridgelux maintains a flatness of 0.10mm across the mounting surface of the array. 27 Color Binning Information Figure 21: Warm and Neutral White Test Bins in xy Color Figure 22: Cool White Test Bins in xy Color Space Space 0.39 4 SDCM 0.44 3 SDCM 0.38 3 SDCM 2 SDCM 0.37 2700K 0.42 3000K 5700K 3500K 0.35 Y 0.4 5000K 0.36 Y 4000K 0.34 0.38 6500K 0.33 0.32 0.36 0.31 0.3 0.34 0.36 0.39 0.42 X 0.45 0.3 0.48 0.31 0.32 0.33 0.34 0.35 0.36 X Note: Pulsed Test Conditions, Tc = 25°C Note: Pulsed Test Conditions, Tc = 25°C Table 8: Warm and Neutral White xy Bin Coordinates and Associated Typical CCT Bin Code 2700K 3000K1 3500K1 4000K1 ANSI Bin (for reference only) (2580K - 2870K) (2870K - 3220K) (3220K - 3710K) (3710K - 4260K) 73 (3 SDCM) (2651K - 2794K) (2968K - 3136K) (3369K - 3586K) (3851K - 4130K) 72 (2 SDCM) (2674K - 2769K) (2995K - 3107K) (3404K - 3548K) (3895K - 4081K) Center Point (x,y) (0.4578, 0.4101) (0.4338, 0.403) (0.4465, 0.4024)2 (0.4073, 0.3917) (0.3818, 0.3797) Note for Table 8: 1. Color Binning information excludes Decor Series Class A products. Please contact your Bridgelux Sales Representative for more information. 2. Center Point for Decor Series Showcase. Table 9: Cool White xy Bin Coordinates and Associated Typical CCT (product is hot targeted to Tc = 85°C) Bin Code 5000K 5700K 6500K ANSI Bin (for reference only) (4745K - 5311K) (5312K - 6022K) (6022K - 7042K) 74 (4 SDCM) (4801K - 5282K) (5829K - 5481K) (6270K - 6765K) 73 (3 SDCM) (4835K - 5215K) (5490K - 5820K) (6250K - 6745K) Center Point (x,y) (0.3447, 0.3553) (0.3287, 0.3417) (0.3123, 0.3282) 28 Packaging and Labeling Figure 23: Drawing for Vero SE 13 Packaging Tray Notes for Figure 23: 1. Dimensions are in millimeters. 2. Drawings are not to scale. 29 Packaging and Labeling Figure 24: Vero SE Series Packaging and Labeling Notes for Figure 24: 1. Each tray holds 100 COBs. 2. Each tray is vacuum sealed in an anti-static bag and placed in its own box. 3. Each tray, bag and box is to be labeled as shown above. Figure 25: Vero SE Product Labeling Bridgelux COB arrays have laser markings on the back side of the substrate to help with product identification. In addition to the product identification markings, Bridgelux COB arrays also contain markings for internal Bridgelux manufacturing use only. The image below shows which markings are for customer use and which ones are for Bridgelux internal use only. The Bridgelux internal manufacturing markings are subject to change without notice, however these will not impact the form, function or performance of the COB array. Customer Use- 2D Barcode Scannable barcode provides product part number and other Bridgelux internal production information. Customer Use- Product part number 30E2000C 73 2F Customer Use- Vf Bin Code included to enable greater luminaire design flexibility. Refer to AN92 for bin code definitions. 30 Design Resources Application Notes 3D CAD Models Bridgelux has developed a comprehensive set of application notes and design resources to assist customers in successfully designing with the Vero product family of LED array products. For all available application notes visit www.bridgelux.com. Three dimensional CAD models depicting the product outline of all Bridgelux Vero LED arrays are available in both IGS and STEP formats. Please contact your Bridgelux sales representative for assistance. Optical Source Models LM80 Optical source models and ray set files are available for all Bridgelux products. For a list of available formats, visit www.bridgelux.com. LM80 testing has been completed and the LM80 report is now available. Please contact your Bridgelux sales representative for LM-80 report. Precautions CAUTION: CHEMICAL EXPOSURE HAZARD Exposure to some chemicals commonly used in luminaire manufacturing and assembly can cause damage to the LED array. Please consult Bridgelux Application Note AN121 for additional information. CAUTION: RISK OF BURN Do not touch the Vero LED array during operation. Allow the array to cool for a sufficient period of time before handling. The Vero LED array may reach elevated temperatures such that could burn skin when touched. CAUTION CONTACT WITH LIGHT EMITTING SURFACE (LES) Avoid any contact with the LES. Do not touch the LES of the LED array or apply stress to the LES (yellow phosphor resin area). Contact may cause damage to the LED array. Optics and reflectors must not be mounted in contact with the LES (yellow phosphor resin area). Optical devices may be mounted on the top surface of the plastic housing of the Vero LED array. Use the mechanical features of the LED array housing, edges and/or mounting holes to locate and secure optical devices as needed. Disclaimers MINOR PRODUCT CHANGE POLICY STANDARD TEST CONDITIONS The rigorous qualification testing on products offered by Bridgelux provides performance assurance. Slight cosmetic changes that do not affect form, fit, or function may occur as Bridgelux continues product optimization. Unless otherwise stated, array testing is performed at the nominal drive current. 31 About Bridgelux: Bridging Light and Life™ At Bridgelux, we help companies, industries and people experience the power and possibility of light. Since 2002, we’ve designed LED solutions that are high performing, energy efficient, cost effective and easy to integrate. Our focus is on light’s impact on human behavior, delivering products that create better environments, experiences and returns—both experiential and financial. And our patented technology drives new platforms for commercial and industrial luminaires. For more information about the company, please visit bridgelux.com twitter.com/Bridgelux facebook.com/Bridgelux youtube.com/user/Bridgelux linkedin.com/company/bridgelux-inc-_2 WeChat ID: BridgeluxInChina 46430 Fremont Boulevard Fremont, CA 94538 U.S.A. Tel (925) 583-8400 www.bridgelux.com © 2016-2018 Bridgelux, Inc. All rights reserved 2018. Product specifications are subject to change without notice. Bridgelux, the Bridgelux stylized logo design, Vero, V Series and V Series HD are registered trademarks, and Decor Series is a trademark of Bridgelux, Inc. All other trademarks are the property of their respective owners. Bridgelux Vero SE 13 Array Series Product Data Sheet DS121 Rev. K (10/2018) 32
BXRC-27E2000-C-73-SE 价格&库存
很抱歉,暂时无法提供与“BXRC-27E2000-C-73-SE”相匹配的价格&库存,您可以联系我们找货
