CXA2011-0000-000P00G00E7
    WOLFSPEED
    Module
    LED Lighting COBs, Engines, Modules Chip On Board (COB) XLamp® CXA2011 White, Warm Square
CXA2011-0000-000P00G00E7 数据手册
® CLD-DS40 Rev 5A Product family data sheet ® Cree XLamp CXA2011 LED Product Description features Table of Contents The Cree XLamp CXA2011 LED • Available in ANSI white bins Characteristics............................... 2 brings lighting‑class reliability and performance to easy-to-use Flux Characteristics, Standard Order EasyWhite bins at 2700K, Codes and Bins.............................. 3 LED arrays. The XLamp CXA2011 3000K, 3500K, 4000K and Flux Characteristics, Standard Order expands 5000K CCT Codes and Bins, 90 CRI................... 4 Cree’s lighting-class leadership to multi‑die, high‑flux arrays. With XLamp lighting‑class reliability, a wide viewing angle, • 90 minimum CRI available in 2700K and 3000K CCT Relative Spectral Power Distribution.. 5 Relative Luminous Flux vs. Junction • Forward Voltage: 40 V Temperature.................................. 5 uniform light output, and industry- • 85 °C binning and Electrical Characteristics.................. 6 leading chromaticity binning in a characterization Relative Luminous Flux vs. Current... 6 16‑mm diameter optical source, the XLamp CXA2011 LED continues • NEMA SSL-3 2011 standard flux bins Relative Chromaticity vs. Current and Temperature............................ 7 Cree’s history of segment-focused • Max drive current: 1000 mA Typical Spatial Distribution............... 8 product innovation in LEDs for • 120° viewing angle, uniform Performance Groups - Brightness...... 8 lighting applications. chromaticity profile Performance Groups - Chromaticity... 9 • Top-side solder connections Cree EasyWhite Bins Plotted on the • Thermocouple attach point 1931 CIE Color Space....................10 brings high performance and a • Screw-down attachment Bin and Order Code Formats...........11 smooth look to a wide range of • Unlimited shelf life at Cree ANSI White Bins Plotted on The lighting www.cree.com/Xlamp as well as 4-step and 2-step XLamp CXA2011 applications, downlighting, recessed LED including fixtures, can lights and retrofit bulbs. ≤ 30°C/85% RH the 1931 CIE Color Space...............11 • RoHS- and REACh‑compliant Notes...........................................12 • UL‑recognized component Mechanical Dimensions..................13 (E349212) Packaging.....................................14 Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 XLamp CXA2011 LED Characteristics Characteristics Unit Effective thermal resistance, junction to case °C/W 0.4 degrees 120 Viewing angle (FWHM) ESD withstand voltage (HBM per Mil-Std-883D) Minimum Typical Maximum V 8000 DC forward current mA 1,000 Reverse current mA 0.1 Forward voltage (@ 270 mA, 85 °C) LED junction temperature Temperature coefficient of voltage V 40 °C mV/°C 48 150 -35 Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 2 XLamp CXA2011 LED Flux Characteristics, Standard Order Codes and Bins (If = 270 mA, TJ = 85 °C) The following tables provide order codes for XLamp CXA2011 LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 11). Color CCT Range 5000K 4000K EasyWhite 3500K 3000K 2700K Color CCT Range 5000K 4000K ANSI White 3500K 3000K 2700K Base Order Codes Min. Luminous Flux @ 270 mA Group Flux (lm) @ 85 ° C Flux (lm) @ 25 ° C* H0 900 1036 J0 1040 1197 G0 780 898 H0 900 1036 G0 780 898 H0 900 1036 G0 780 898 H0 900 1036 F0 680 783 G0 780 898 Base Order Codes Min. Luminous Flux @ 270 mA Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* H0 900 1036 J0 1040 1197 G0 780 898 H0 900 1036 G0 780 898 H0 900 1036 G0 780 898 H0 900 1036 F0 680 783 G0 780 898 2-Step Order Code 4-Step Order Code Chromaticity Region 50H 40H 35H 30H 27H Chromaticity Region CXA2011-0000-000P00H050H CXA2011-0000-000P00J050H CXA2011-0000-000P00G040H CXA2011-0000-000P00H040H CXA2011-0000-000P00G035H CXA2011-0000-000P00H035H CXA2011-0000-000P00G030H CXA2011-0000-000P00H030H CXA2011-0000-000P00F027H CXA2011-0000-000P00G027H Chromaticity Regions 3A0, 3B0, 3C0, 3D0 5A0, 5B0, 5C0, 5D0 6A0, 6B0, 6C0, 6D0 7A0, 7B0, 7C0, 7D0 8A0, 8B0, 8C0, 8D0 50F 40F 35F 30F 27F CXA2011-0000-000P00H050F CXA2011-0000-000P00J050F CXA2011-0000-000P00G040F CXA2011-0000-000P00H040F CXA2011-0000-000P00G035F CXA2011-0000-000P00H035F CXA2011-0000-000P00G030F CXA2011-0000-000P00H030F CXA2011-0000-000P00F027F CXA2011-0000-000P00G027F Order Code CXA2011-0000-000P00H00E3 CXA2011-0000-000P00J00E3 CXA2011-0000-000P00G00E5 CXA2011-0000-000P00H00E5 CXA2011-0000-000P00G00E6 CXA2011-0000-000P00H00E6 CXA2011-0000-000P00G00E7 CXA2011-0000-000P00H00E7 CXA2011-0000-000P00F00E8 CXA2011-0000-000P00G00E8 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. • Minimum CRI for chromaticity kits 27F, 27H, 30F, 30H, 0E8, 0E7 is 80. • Minimum CRI for chromaticity kit 35F, 35H, 0E6 is 77 and typical CRI is 80. • Minimum CRI for chromaticity kits 40F, 40H, 50F, 50H, 0E5, 0E3 is 70 and typical CRI is 75. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 3 XLamp CXA2011 LED Flux Characteristics, Standard Order Codes and Bins, 90 CRI (If= 270 mA, TJ= 85 °C) The following tables provide order codes for XLamp CXA2011 90 CRI minimum LEDs. For a complete description of the order code nomenclature, please reference Bin and Order Code Formats (page 11). Color EasyWhite CCT Range 3000K 2700K Color ANSI White CCT Range 3000K 2700K Base Order Codes Min Luminous Flux @ 270 mA Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* F0 680 783 G0 780 898 F0 680 783 Base Order Codes Min Luminous Flux @ 270 mA, 85 °C Group Flux (lm) @ 85 °C Flux (lm) @ 25 °C* F0 680 783 G0 780 898 F0 680 783 2-Step Order Code 4-Step Order Code Chromaticity Region 30H 27H Chromaticity Region CXA2011-0000-000P0UF030H CXA2011-0000-000P0UG030H CXA2011-0000-000P0UF027H Chromaticity Regions 7A0, 7B0, 7C0, 7D0 8A0, 8B0, 8C0, 8D0 30F 27F CXA2011-0000-000P0UF030F CXA2011-0000-000P0UG030F CXA2011-0000-000P0U0F027F Order Code CXA2011-0000-000P0UF00E7 CXA2011-0000-000P0UG00E7 CXA2011-0000-000P0UF00E8 Notes: • Cree maintains a tolerance of ±7% on flux and power measurements, ±0.005 on chromaticity (CCx, CCy) measurements and a tolerance of ±2 on CRI measurements. • Minimum CRI for chromaticity kits 30H, 30F, 27H, 27F, 0E7, 0E8 is 90. * Flux values @ 25 °C are calculated and for reference only. Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 4 XLamp CXA2011 LED Relative Spectral Power Distribution - White, Hot Binned, Baby Relative Spectral Power Distribution (If = 270 ma, Tj= 85 °C) This is native CXA Spectral Data @ 3000K The following graph represents typical spectral emission of standard CRI XLamp CXA2011 LEDs. Relative Spectral Power (%) 100% 90% 80% 70% 60% 3000K CCT 50% 4000K CCT 40% 5000K CCT 30% 20% 10% 0% 400 450 500 550 600 650 700 750 Wavelength (nm) lativeRelative Flux Output vs.Flux Junction Temperature (If(I= = 270 mA) 270 mA?) Luminous vs. Junction Temperature F The following graph represents typical performance of the XLamp CXA2011 LED. Relative Luminous Flux (%) 120% 100% 80% 60% 40% 20% 0% 0 25 50 75 100 125 150 Junction Temperature (ºC) Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 5 XLamp CXA2011 LED Electrical Characteristics (Tj = 85ºC) The following graph represents typical performance of each LED die in the XLamp MT-G Electrical Characteristics (TJ = 85 °C) The following graph represents typical electrical characteristics of the XLamp CXA2011 LED. 1000 Forward Current (mA) 900 800 700 600 500 400 300 200 100 0 36.0 38.0 40.0 42.0 44.0 46.0 48.0 Forward Voltage (V) Relative Intensity vs. Current (Tj = 85ºC) Relative Luminous Flux vs. Current (TJ = 85 °C) The following graph represents typical performance of the XLamp CXA2011 LED. Relative Luminous Flux (%) 300% 250% 200% 150% 100% 50% 0% 0 200 400 600 800 1000 Forward Current (mA) Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 6 -0.015 -0.020 -0.020 0 200 400 600 800 1000 25 50 75 100 125 150 Tj (°C) Current (mA) XLamp CXA2011 LED Relative Chromaticity vs. Current and Temperature The following graphs represent typical chromaticity vs current and temperature for the standard CRI version of the CXA2011, E7 XLamp CXA2011 at 3000K CCT. CXA2011, E7 0.020 0.020 0.015 0.015 0.010 0.010 0.005 0.005 0.000 0.000 ΔCCx -0.005 ΔCCy -0.010 -0.015 -0.020 -0.020 200 400 600 800 ΔCCy -0.010 -0.015 0 ΔCCx -0.005 1000 25 50 75 100 125 150 Tj (°C) Current (mA) CXA2011 graphs E3 The following represent typical chromaticity vs current andE3temperature for the XLamp CXA2011 at 5000K CCT. CXA2011 0.020 0.020 0.015 0.015 0.010 0.010 0.005 0.005 0.000 ΔCCx -0.005 ΔCCy 0.000 -0.010 -0.010 -0.015 -0.015 -0.020 -0.020 0 200 400 600 800 1000 ΔCCx -0.005 ΔCCy 25 50 75 100 125 150 Tj (°C) Current (mA) CXA2011, E7 CXA2011, E7 0.020 0.020 0.015 0.015 0.010 0.010 Copyright is subject to change without notice. Cree®, the Cree logo and XLamp® are registered 0.005 © 2011-2013 Cree, Inc. All rights reserved. The information in this document 0.005 trademarks of Cree, Inc. 0.000 0.000 -0.005 ΔCCx -0.005 7ΔCCx ΔCCy XLamp CXA2011 LED Field Typical Spatial Distribution The following graph represents the typical spatial distribution of the XLamp CXA2011 LED. Relative Luminous Intensity (%) 120 100 80 60 40 20 0 -90 -70 -50 -30 -10 10 30 50 70 90 Angle (º) Performance Groups - Brightness (If = 270 mA, Tj = 85 °C) XLamp CXA2011 LEDs are tested for luminous flux and placed into one of the following bins. Group Code Min. Luminous Flux @ 270 mA, Tj= 85 °C Max. Luminous Flux @ 270 mA, Tj= 85 °C E0 590 680 F0 680 780 G0 780 900 H0 900 1040 J0 1040 1200 K0 1200 1380 Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 8 XLamp CXA2011 LED Performance Groups - Chromaticity (Tj = 85 °C) XLamp CXA2011 LEDs are tested for chromaticity and placed into one of the regions defined by the following bounding coordinates. EasyWhite Color Temperatures – 4-Step EasyWhite Color Temperatures – 2-Step Code Code 50F 40F 35F 30F 27F CCT 5000K 4000K 3500K 3000K 2700K x y 0.3407 0.3459 0.3415 0.3586 0.3499 0.3654 0.3484 0.3521 0.3744 0.3685 0.3782 0.3837 0.3912 0.3917 0.3863 0.3981 x y 0.3429 0.3507 0.3434 0.3571 0.3475 0.3604 0.3469 0.3539 0.3784 0.3741 0.3804 0.3818 0.3867 0.3857 0.3758 0.3844 0.3778 0.3800 0.4030 0.3857 0.4040 0.3966 0.4061 0.3941 0.4186 0.4037 0.4132 0.3976 0.4116 0.3865 0.4099 0.3890 0.4242 0.3919 0.4291 0.3973 0.4322 0.4096 0.4333 0.4062 0.4449 0.4141 0.4395 0.4084 0.4359 0.3960 0.4351 0.3994 0.4475 0.3994 0.4528 0.4046 0.4573 0.4178 0.4578 0.4138 0.4695 0.4207 0.4638 0.4152 0.4589 0.4021 0.4586 0.4060 ANSI White Bins Code CCT Bin Code 3A0 3B0 0E3 5000K 3C0 3D0 CCT 50H 5000K 40H 4000K 35H 3500K 30H 3000K 27H 2700K ANSI White Bins x y .3371 .3490 .3451 .3554 .3440 .3427 .3366 Code CCT Bin Code ANSI White Bins x y .3670 .3578 .3702 .3722 .3825 .3798 .3369 .3783 .3376 .3616 .3463 .3687 .3451 .3554 .3371 .3490 .3463 .3687 .3551 .3760 .3533 .3620 .3451 Code CCT Bin Code x y .3889 .3690 .3941 .3848 .4080 .3916 .3646 .4017 .3751 .3702 .3722 .3941 .3848 .3736 .3874 .3996 .4015 .3869 .3958 .4146 .4089 .3825 .3798 .4080 .3916 .3825 .3798 .4080 .3916 .3869 .3958 .4146 .4089 .4006 .4044 .4299 .4165 .3554 .3950 .3875 .4221 .3984 .3451 .3554 .3783 .3646 .4017 .3751 .3533 .3620 .3825 .3798 .4080 .3916 .3515 .3487 .3950 .3875 .4221 .3984 .3440 .3427 .3898 .3716 .4147 .3814 5A0 5B0 0E5 4000K 5C0 5D0 6A0 6B0 0E6 3500K 6C0 6D0 Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 9 XLamp CXA2011 LED ANSI White Bins Code CCT Bin Code 7A0 7B0 0E7 3000K 7C0 7D0 ANSI White Bins x y .4147 .4221 .4342 .4028 .4259 .4221 .4299 .4165 .4430 .4212 .4342 .4028 .4342 .4028 .4430 .4212 .4562 .4260 .4465 .4259 .4342 .4028 .4465 .4071 .4373 Code CCT Bin Code x y .3814 .4373 .3893 .3984 .4465 .4071 .4582 .4099 .3853 .4483 .3919 .3984 .4465 .4071 .4562 .4260 .4687 .4289 .4582 .4099 .4582 .4099 .4687 .4289 .4813 .4319 .4071 .4700 .4126 .3853 .4483 .3919 .4582 .4099 .4700 .4126 .4593 .3944 8A0 8B0 0E8 2700K 8C0 8D0 .3893 Cree EasyWhite Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) 0.45 ANSI C78.377 Quadrangle EasyWhite 4-step EasyWhite 2-step 0.44 2700K 3000K 0.43 3500K 0.42 4000K 0.41 4500K 0.40 5000K CCy 0.39 5700K 0.38 0.37 0.36 0.35 0.34 0.33 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.32 CCx Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 10 XLamp CXA2011 LED Cree ANSI White Bins Plotted on the 1931 CIE Color Space (Tj = 85 °C) 0.45 0.44 2900K 2600K 3000K 0.43 3200K 0.42 3500K 7B0 4000K 0.40 6C0 4300K 0.39 7D0 8A0 6D0 5B0 6A0 5D0 0.37 ANSI C78.377A 5A0 3C0 0.36 8D0 7A0 5C0 4750K 5300K 0.38 6B0 4500K 5000K 8C0 8B0 7C0 3700K 0.41 CCy 2700K 3B0 3D0 0.35 3A0 0.34 0.33 0.49 0.48 0.47 0.46 0.45 0.44 0.43 0.42 0.41 0.40 0.39 0.38 0.37 0.36 0.35 0.34 0.33 0.32 0.32 CCx Bin and Order Code Formats Bin codes and order codes are configured as follows: Order Code Bin Code Series = CXA20 Series = CXA20 Internal code Chromaticity bin Vf class: P0 = 40-V class CRI Specification U = 90 minimum 0 = standard CRI SSSSSCC-HHHH-NNNGGNNNNNN Internal code SSSSSCC-WWW-FF-GGA-AAAAA Kit code Vf class: P0 = 40-V class Performance class CRI specification U = 90 CRI minimum H = 80 CRI minimum E = 77 CRI minimum B = 70 CRI minimum Flux bin Performance class Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 11 XLamp CXA2011 LED Notes Lumen Maintenance Projections Cree now uses standardized IES LM-80-08 and TM-21-11 methods for collecting long-term data and extrapolating LED lumen maintenance. For information on the specific LM-80 data sets available for this LED, refer to the public LM-80 results document at www.cree.com/xlamp_app_notes/LM80_results. Please read the XLamp Long-Term Lumen Maintenance application note at www.cree.com/xlamp_app_notes/lumen_ maintenance for more details on Cree’s lumen maintenance testing and forecasting. Please read the XLamp Thermal Management application note at www.cree.com/xlamp_app_notes/thermal_management for details on how thermal design, ambient temperature, and drive current affect the LED junction temperature. RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Ecology section of www.cree.com. REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notices of their intent to frequently revise the SVHC listing for the foreseeable future, please contact a Cree representative to insure you get the most up-to-date REACh Declaration. Historical REACh banned substance information (substances restricted or banned in the EU prior to 2010) is also available upon request. UL Recognized Component Level 4 enclosure consideration. The LED package or a portion thereof has been investigated as a fire and electrical enclosure per ANSI/UL 8750. Vision Advisory Claim Users should be cautioned not to stare at the light of this LED product. The bright light can damage the eye. See the LED Eye Safety aplication note at www.cree.com/xlamp_app_notes/led_eye_safety. Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 12 6 5 4 3 2 XLamp CXA20111 LED REVISONS NOTICE CREE CONFIDENTIAL. THIS PLOT AND THE INFORMATION CONTAINED WITHIN ARE THE PROPRIETARY AND CONFIDENTIAL INFORMATION OF CREE, INC. THIS PLOT MAY NOT BE COPIED, REPRODUCED OR DISCLOSED TO ANY UNAUTHORIZED PERSON WITHOUT THE WRITTEN CONSENT OF CREE INC. REV BY DESCRIPTION DATE APP'D Mechanical Dimensions D D 22.000 2.997 2.100 2.510 2.275 R.700 2.100 3.400 2.510 2.997 C C 22.000 16.200 R.700 2.997 2.510 2.510 2.100 B B 1.300 2.100 2.510 2.997 6.860 All measurements are ±.13 mm unless otherwise indicated. A THIRD ANGLE PROJECTION UNLESS OTHERWISE SPECIFIED DIMENSIONS ARE IN MILLIMETERS AND AFTER FINISH. TOLERANCE UNLESS SPECIFIED: .XX ± .25 .XXX ± .125 X° ± .5 ° FOR SHEET METAL PARTS ONLY .X ± 1.5 .XX ± .75 .XXX ± .25 X° ± .5 ° SURFACE FINISH: 6 5 4 3 DRAWN BY DATE CHECK DATE APPROVED DATE 4600 Silicon Drive Durham, N.C 27703 Phone (919) 313-5300 Fax (919) 313-5558 A TITLE HIGH POWER ARRAY OUTLINE MATERIAL SIZE FINAL PROTECTIVE FINISH SCALE 1.6 2 C 7.000 DRAWING NO. REV. FE2201 SHEET OF 2 /2 1 Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 13 XLamp CXA2011 LED Packaging Cree CXA2011 LEDs are packaged in tubes of 20, which are then combined in boxes of 5 tubes, or 100 LEDs. Boxes of 100 LEDs are of the same performance bin. PATENT LABEL IS LOCATED ON UNDERSIDE OF COVER LABEL WITH CREE BIN CODE, QTY, LOT # Copyright © 2011-2013 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree®, the Cree logo and XLamp® are registered trademarks of Cree, Inc. 14
CXA2011-0000-000P00G00E7 价格&库存
很抱歉,暂时无法提供与“CXA2011-0000-000P00G00E7”相匹配的价格&库存,您可以联系我们找货
