SST-10-B-B90-N450
SST-10-B-B90-N450
    LUMINUS(朗明纳斯)
    SMD3535_2P
    发光二极管/LED 蓝色 SMD3535_2P 450nm
SST-10-B-B90-N450 数据手册
SST-10-Blue Product Datasheet SST-10-B Blue LED Features: Table of Contents • High Power Blue LED with Peak Wavelength of 450nm • Wall-Plug Efficiency: typ. 57% @350mA SST-10 Binning Structure. . . 2 • 90 or 130° viewing angle at 50% Iv Product Shipping & Labeling Information. . . . . . . . . . . . . . . . 3 • Low Thermal Resistance Optical and Electrical Characteristics. . . . . . . . . . . . . 4 • Built-in ESD Protection • RoHS and REACh compliant B130 - Mech. Dimensions. . . 6 B130 - Tape and Reel . . . . . . . 7 B90 - Mech. Dimensions. . . . 8 B90 - Tape and Reel. . . . . . . . . 9 Soldering Profile. . . . . . . . . . 10 Applications • Horticulture / Growlights • Remote-phosphor fixtures Precautions for Use. . . . . . . . 11 • Accent and effect lighting • Stage lighting History of Changes. . . . . . . . 12 • Architectural lighting 1 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet SST-10 Binning Structure SST-10 Blue LEDs are tested for luminous flux and chromaticity at a drive current of 350mA - 20ms single pulse and placed into one of the following luminous flux (FF) and chromaticity (WW) bins: Flux Bins - Test condition=350mA, 250C, 20ms pulse Flux Bin (FF) Minimum Flux (mW) Maximum Flux (mW) N 510 550 P 550 590 Q 590 630 R 630 670 Wavelength Bins - Test condition=350mA, 250C, 20ms pulse *Note: Chromaticity Bin (WW) Minimum Wavelength (nm) Maximum Wavelength (nm) B2 440 445 B3 445 450 B4 450 455 B5 455 460 Luminus maintains a +/- 6% tolerance on flux measurements. Ordering Information Products Ordering Part Number Description SST-10-B-B90 SST-10-B-B90-xx123 High Power 1-mm2 Blue LED in a 3535 surface mount package and a 90-degree lens SST-10-B-B130 SST-10-B-B130-xx123 High Power 1-mm2 Blue LED in a 3535 surface mount package and a 130-degree lens 2 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet Part Number Nomenclature SST 10 Product Family LED Emission Area SST: Surface Mount Package 10: 1.0 mm2 Color : Color B = Blue Package Configuration Bin kit B90: 90-degree lens B130: 130-degree lens Flux and Chromaticity bin kit code - See available ordering codes below SST-10 Bin Kit Order Codes The following table describes the bin kit ordering codes available for the SST-10 Blue LEDs. Each bin kit specifies a minimum flux as well as specific chromaticity bins allowed. Please note that within each kit a maximum flux is not specified and as a result Luminus may ship any part meeting or exceeding the minimum flux specification. Shipments will always meet the listed chromaticity bins. For information on ordering bin kits not listed below, please contact Luminus. SST-10 Blue Bin Kit Order Codes Luminous Flux Color Bin Kit Flux Code Min. Flux Blue N 510 Chromaticity Bins Kit Number B2,B3,B4,B5 N450 Product Shipping & Labeling Information All SST-10 products are packaged and labeled with their respective bin as outlined in the tables on pages 2 & 3. Each reel will only contain one bin. SST-10 Blue SST 10 B BXXX FFWW Product Family LED Emission Area Color Package Configuration Bin kit SST: Surface Mount Package 10: 1.0 mm2 Color B90: 90-degree lens B130: 130-degree lens Flux and Chromaticity bin kit code as outlined above 3 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet (Part #) Product Datasheet Optical and Electrical Characteristics Optical and Electrical Characteristics at 350mA1 Parameter Symbol Minimum Typical Maximum Unit 1,500 mA Forward Current2 If 350 Output Power Φr 600 Forward Voltage Vf 2.7 3.0 mW 3.4 V Wall-Plug Efficiency WPE 57 % Viewing Angle 2 Ø1/2 90 or 130 degrees Peak Wavelength FWHM Thermal Resistance (Electrical) λP 440 450 460 nm Dλ1/2 20 22 24 nm RTH 5.3 °C/W Absolute Maximum Ratings2 Parameter Symbol Rating Unit Forward Current I 1.5 A Power Dissipation Pd 5.0 W Reverse Voltage Vr 5 V Tstg -40~100 °C Junction Temperature Tj 115 ºC °C Soldering Temperature Tsld JEDEC 020, 260 ºC ESD Sensitivity (HBM) Vb 6000 3,4 Storage Temperature 3,4 V Note 1: Ratings are based on operation at a constant junction temperature of Tj = 25ºC. Note 2: To prevent damage, please refer to operating conditions and derating curves for appropriate maximum operating conditions Note 3: Maximum operating case temperature combined with maximum drive current defines the total maximum operating condition for the device. To prevent damage, please follow derating curves for all operating conditions. Note 4: Luminus SST-10-Blue LEDs are designed for operation up to an absolute maximum forward drive current as specified above. Product lifetime data is specified at typical forward drive currents. Sustained operation at absolute maximum currents will result in a reduction of device lifetime compared to typical forward drive currents. Actual device lifetimes will also depend on junction temperature. Refer to the current vs. junction temperature derating curves for further information. In pulsed operation, rise time from 10-90% of forward current should be larger than 0.5 microseconds. Note 5: Caution must be taken not to stare at the light emitted from these LEDs. Under special circumstances, the high intensity could damage the eye. 4 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet (Part #) Product Datasheet Optical and Electrical Characteristics Relative Output Flux vs. Forward Current Forward Current vs. Forward Voltage Relative Output Flux vs. Junction Temperature Typical Spectra Typical Polar Radiation Plot - B130 5 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Typical Polar Radiation Plot - B90 Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet Mechanical Dimensions - B130 Package 6 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet Tape and Reel - B130 Package 2.00±0.10 .079±.004 4.00±0.10 .157±.004 +.004 .059 - .000 1.75±0.10 .069±.004 0.10 3.80+0.00 +0.10 1.50 0.00 B +.004 .150 - .000 A CATHODE SIDE 0.10 4.18+0.00 B +.004 .165 - .000 12.00±0.20 .472±.008 5.50±0.05 .217±.002 8.00±0.10 .315±.004 1.70±0.10 .067±.004 ANODE SIDE 0.25±0.05 A SECTION A-A +0.10 3.80 0.00 +.004 .150 - .000 0.10 4.18+0.00 +.004 .165 - .000 0.10 2.20+0.00 +.004 .087 - .000 UNREELING DIRECTION 5.0° 5.0° SECTION B-B NOTES: 1. FINAL TAPE AND REEL PACKAGING MUST MEET THE REQUIREMENTS OF JEDEC-STD-033, LEVEL 2A. 2. LEAVE 304.8mm [12.00 in] OF TAPE EMPTY FOR LEAD IN (38 EMPTY POCKETS). 3. LEAVE 457.2mm [18.00 in] OF TAPE EMPTY FOR TRAILER (57 EMPTY POCKETS). 4. MUST COMPLY TO EIA-481-C-2003 12.4 .488 178 7 21.3 .839 3X 2.00 .079 13 .512 16.0 .630 C 120° DETAIL C UNREELING DIRECTION TOP VIEW DETAIL D 7 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet Mechanical Dimensions - B90 Package 8 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet Tape and Reel - B90 Package 4.00±0.05 .157±.002 2.00±0.10 .079±.004 +0.10 1.50 0.00 +.004 .059 - .000 1.75±0.10 .069±.004 A CATHODE SIDE B 3.60±0.10 .142±.004 B 12.00±0.20 .472±.008 5.50±0.05 .217±.002 1.50±0.10 .059±.004 8.00±0.10 .315±.004 ANODE SIDE 2.48±0.10 .098±.004 96 3.8 SECTION A-A NOTES: 7.0° SECTION B-B 0.25±0.05 A 3.67±0.10 .144±.004 7.0° 1. FINAL TAPE AND REEL PACKAGING MUST MEET THE REQUIREMENTS OF JEDEC-STD-033, LEVEL 2A. 2. LEAVE 304.8mm [12.00 in] OF TAPE EMPTY FOR LEAD IN (38 EMPTY POCKETS). 3. LEAVE 457.2mm [18.00 in] OF TAPE EMPTY FOR TRAILER (57 EMPTY POCKETS). 4. MUST COMPLY TO EIA-481-C-2003 UNREELING DIRECTION 178 7 560 22.0 77 3.0 C UNREELING DIRECTION TOP VIEW DETAIL D 9 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet Soldering Profile Profile Feature Sn-Pb Eutectic Assembly Pb-Free Assembly Preheat & Soak Temperature min (Tsmin) Temperature max (Tsmax) Time (Tsmin to Tsmax) (ts) 100 °C 150 °C 60-120 seconds 150 °C 200 °C 60-120 seconds Average ramp-up rate (Tsmax to Tp) 3 °C/second max 3 °C/second max Liquidous temperature (TL) Time at liquidous (tL) 183 °C 60-150 seconds 217 °C 60-150 seconds Peak package body temperature (Tp)* 230 °C ~235 °C 255 °C ~260 °C Classification temperature (Tc) Time (tp) within 5 °C of the specified classification temperature (Tc) Average ramp-down rate (Tp to Tsmax) Time 25 °C to peak temperature 235 °C 260 °C 20 seconds 30 seconds 6 °C/second max 6 °C/second max 6 minutes max 8 minutes max * Tolerance for peak profile temperature(Tp) is defined as a supplier minimum and a user maximum. ** Tolerance for time at peak profile temperature(tp) is defined as asupplier minimum and a user maximum. 10 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet Precautions for Use Storage: 1. Before opening the package The LEDs should be kept at a temperature lower than 40° C and relative humidity lower than 90%. The LEDs should be used within a year. When storing the LEDs, moisture proof package with absorbent material (silica gel) is recommended. 2. After opening the package The LEDs should be kept at temperature lower than 30° C and relative humidity lower than 60%. The LEDs should be soldered within 168 hours (7days) after opening the moisture proof package. If unused LEDs remain, they should be stored in moisture proof packages, such as sealed containers with moisture proof package within absorbent material (silica gel). It is also recommended to return the unused LEDs to the original moisture proof package and to seal the moisture proof package again. If the moisture absorbent material (silica gel) vapors or expires the expiration date, baking treatment should be performed by using the following conditions : 60 °C for 20 hours. The LEDs electrode and leadframe comprise a silver plated copper alloy. The silver surface may be affected by environments. Please avoid conditions which may cause the LEDs to corrode or discolore. The corrosion or discoloration might lower solderability or affect optical characteristics. Please avoid rapid transition in ambient temperature, especially in high humidity environments where condensation can occur. Static Electricity: 1. The products are sensitive to static electricity, and care should be taken when handling them. 2. Static electricity or surge voltage will damage the LEDs. It is recommended to wear a anti-electrostatic wristband or anti-electrostatic gloves when handling the LEDs. 3. All devices, equipment and machinery must be properly grounded. It is recommended that measures be taken against surge voltage to the equipment that mounts the LEDs. 11 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 SST-10-Blue Product Datasheet History of Changes Rev Description of Change 01 09/14/2015 Initial Release - Preliminary Specifications 02 10/13/2015 Updated solder pad layout and added 80-degree lens option 03 04/15/2016 Updated binning and angular distribution data. Added 90-degree tape & reel 04 06/24/2016 Updated pictures on front page 05 04/03/2017 Updated title in “Relative Output Flux vs. Junction Temperature” graph and address. 12 PDS-002735 Rev 05 © 2017 Luminus Devices, Inc. - All Rights Reserved Luminus Devices, Inc. • T 408.708.7000 • www.luminus.com 1145 Sonora Court • Sunnyvale, CA 94086 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Luminus Devices: SST-10-B-B130-P450 SST-10-B-B130-N450 SST-10-B-B90-P450 SST-10-B-B90-N450 SST-10-B-B130-Q450 SST-10-B-B90-Q450
SST-10-B-B90-N450 价格&库存
很抱歉,暂时无法提供与“SST-10-B-B90-N450”相匹配的价格&库存,您可以联系我们找货
SST-10-B-B90-N450
  • 1+12.651771+1.62984
  • 10+8.9784110+1.15663
  • 100+6.73731100+0.86792
库存:1020
SST-10-B-B90-N450
    SST-10-B-B90-N450
    库存:1020
