High Luminous Efficacy Green LED Emitter
LZ1-00G102
Key Features
High Luminous Efficacy Green LED emitter
Ultra-small foot print – 4.4mm x 4.4mm
Up to 1.5A drive current
Surface mount ceramic package with integrated glass lens
Low Thermal Resistance (6.0°C/W)
Electrically neutral thermal path
JEDEC Level 1 for Moisture Sensitivity Level
Lead (Pb) free and RoHS compliant
Reflow solderable
Available on tape and reel or with MCPCB
Typical Applications
Indoor and outdoor Architectural Lighting
Display Backlighting
Full Color Displays
Projectors
Horticulture
Description
The LZ1-00G102 Green LED emitter generates 215 lumen at 3.7W power dissipation in an extremely small package.
With a 4.4mm x 4.4mm footprint, this package provides exceptional luminous flux density. The patent-pending
design has unparalleled thermal and optical performance and excellent UV resistance. The high quality materials
used in the package are chosen to optimize light output and minimize stresses which results in monumental
reliability and lumen maintenance. The robust product design thrives in outdoor applications with high ambient
temperatures and high humidity.
COPYRIGHT © 2018 LED ENGIN. ALL RIGHTS RESERVED.
LZ1-00G102 (1.3 – 11/20/2018)
LED Engin | 651 River Oaks Parkway | San Jose, CA 95134 USA | ph +1 408 922 7200 | em LEDE-Sales@osram.com | www.osram.us/ledengin
Part number options
Base part number
Part number
Description
LZ1-00G102-xxxx
LZ1 emitter
LZ1-10G102-xxxx
LZ1 emitter on Standard Star MCPCB
Bin kit option codes
G1, Green (525nm)
Kit number
suffix
Min
flux
Bin
Color Bin Range
0000
N
G2 – G4
0G23
N
G2 – G3
Description
Flux bin N and above; full distribution
wavelength
Flux bin N and above; wavelength G2 and
G3 bins
Notes:
1.
Default bin kit option is -0000
2
Luminous Flux Bins
Table 1:
Bin Code
Minimum
Luminous Flux (ΦV)
@ IF = 1000mA [1]
(lm)
Maximum
Luminous Flux (ΦV)
@ IF = 1000mA [1]
(lm)
N
145
182
P
182
228
Q
228
285
Notes for Table 1:
o
1.
Luminous flux performance is measured at 10ms pulse, Tc = 25 C. LED Engin maintains a tolerance of ± 10% on flux measurements.
Dominant Wavelength Bins
Table 2:
Bin Code
Minimum
Dominant Wavelength (λD)
@ IF = 1000mA [1]
(nm)
Maximum
@ IF = 1000mA [1]
(nm)
G2
520
525
G3
525
530
G4
530
535
Notes for Table 2:
o
1.
Dominant wavelength is measured at 10ms pulse, Tc = 25 C. LED Engin maintains a tolerance of ± 1.0nm on dominant wavelength measurements.
Forward Voltage Bins
Table 3:
Bin Code
Minimum
Forward Voltage (VF)
@ IF = 1000mA [1]
(V)
Maximum
@ IF = 1000mA [1]
(V)
J
3.2
4.2
Notes for Table 3:
o
1.
Forward voltage is measured at 10ms pulse, Tc = 25 C. LED Engin maintains a tolerance of ± 0.04V for forward voltage measurements.
3
Absolute Maximum Ratings
Table 4:
Parameter
DC Forward Current at TJ(MAX)=90°C
Symbol
Value
Unit
[1]
IF
1500
[1]
IF
1200
mA
mA
DC Forward Current at TJ(MAX)=150°C [1]
IF
1000
mA
IFP
2000
mA
Reverse Voltage
VR
See Note 3
V
Storage Temperature
Tstg
-40 ~ +150
°C
Junction Temperature
TJ
150
°C
Soldering Temperature [4]
Tsol
260
°C
DC Forward Current at TJ(MAX)=135°C
Peak Pulsed Forward Current
[2]
Notes for Table 4:
1.
Maximum DC forward current is determined by the overall thermal resistance and ambient temperature. Follow the curves in Figure 11 for current derating.
2:
Pulse forward current conditions: Pulse Width ≤ 10msec and Duty cycle ≤ 10%.
3.
LEDs are not designed to be reverse biased.
4.
Solder conditions per JEDEC J-STD-020. See Reflow Soldering Profile Figure 3.
5.
LED Engin recommends taking reasonable precautions towards possible ESD damages and handling the LZ1-00G102 in an electrostatic protected area (EPA).
An EPA may be adequately protected by ESD controls as outlined in ANSI/ESD S6.1.
Optical Characteristics @ TC = 25°C
Table 5:
Parameter
Symbol
Typical
Unit
Luminous Flux (@ IF = 1000mA/ 1200mA/ 1500mA)
ΦV
215/ 235/ 270
lm
Radiant Flux (@ IF = 1000mA/ 1200mA/ 1500mA)
Φ
450/ 490/ 560
mW
2.0/ 2.1/ 2.4
umol/s
λD
523
nm
Peak Wavelength (@ IF = 700mA)
λP
517
nm
Viewing Angle [2]
2Θ1/2
100
Degrees
Total Included Angle [3]
Θ0.9
120
Degrees
PPF[1] 400-700nm (@ IF = 1000mA/ 1200mA/ 1500mA)
Dominant Wavelength (@ IF = 700mA)
Notes for Table 5:
1.
PPF is Photosynthetic Photon Flux.
2.
Viewing Angle is the off axis angle from emitter centerline where the luminous intensity is ½ of the peak value.
3.
Total Included Angle is the total angle that includes 90% of the total luminous flux.
Electrical Characteristics @ TC = 25°C
Table 6:
Parameter
Symbol
Typical
Unit
Forward Voltage (@ IF = 1000mA)
VF
3.75
V
Forward Voltage (@ IF = 1200mA)
VF
3.85
V
Forward Voltage (@ IF = 1500mA)
VF
3.95
V
Temperature Coefficient
of Forward Voltage
ΔVF/ΔTJ
-4.0
mV/°C
Thermal Resistance
(Junction to Case)
RΘJ-C
6.0
°C/W
4
IPC/JEDEC Moisture Sensitivity Level
Table 7 - IPC/JEDEC J-STD-020 MSL Classification:
Soak Requirements
Floor Life
Standard
Accelerated
Level
Time
Conditions
Time (hrs)
Conditions
Time (hrs)
Conditions
1
Unlimited
≤ 30°C/
85% RH
168
+5/-0
85°C/
85% RH
n/a
n/a
Notes for Table 7:
1.
The standard soak time includes a default value of 24 hours for semiconductor manufacturer’s exposure time (MET) between bake and bag and
includes the maximum time allowed out of the bag at the distributor’s facility.
Average Lumen Maintenance Projections
Lumen maintenance generally describes the ability of a lamp to retain its output over time. The useful lifetime for
solid state lighting devices (Power LEDs) is also defined as Lumen Maintenance, with the percentage of the original
light output remaining at a defined time period.
Based on long-term WHTOL testing, LED Engin projects that the LZ Series will deliver, on average, above 70%
Lumen Maintenance at 50,000 hours of operation at a forward current of 1000 mA. This projection is based on
constant current operation with junction temperature maintained at or below 125°C.
5
Mechanical Dimensions (mm)
Pin Out (Type 2)
Pad
[2]
Function
1
Anode
2
Cathode
3
Cathode
4
5
[3]
Anode
Thermal
1
2
5
4
3
Figure 1: Package outline drawing.
Notes for Figure 1:
1.
Unless otherwise noted, the tolerance = ± 0.20 mm.
2.
This emitter pin-out is reversed to that of LZ1-00xx00 and LZ1-00Rx02.
3.
Thermal contact, Pad 5, is electrically neutral.
Recommended Solder Pad Layout (mm)
Non-pedestal MCPCB Design
Pedestal MCPCB Design
Figure 2a: Recommended solder pad layout for anode, cathode, and thermal pad for non-pedestal and pedestal design.
Note for Figure 2a:
1. Unless otherwise noted, the tolerance = ± 0.20 mm.
2. Pedestal MCPCB allows the emitter thermal slug to be soldered directly to the metal core of the MCPCB. Such MCPCB eliminate t he high thermal resistance
dielectric layer that standard MCPCB technologies use in between the emitter thermal slug and the metal core of the MCPCB, thus lowering the overall system
thermal resistance.
3. LED Engin recommends x-ray sample monitoring for solder voids underneath the emitter solder pins, especially the thermal pad. The total area covered by
solder voids should be less than 20% of the total emitter thermal pad area. Excessive solder voids will increase the emitter to MCPCB thermal resist ance and
may lead to higher failure rates due to thermal over stress.
4. This emitter is compatible with all LZ1 MCPCBs provided that the MCPCB design follows the recommended solder mask layout (Figure 2b).
6
Recommended Solder Mask Layout (mm)
Figure 2b: Recommended solder mask opening for anode, cathode, and thermal pad for non-pedestal and pedestal design
Note for Figure 2b:
1.
Recommended 8mil Stencil Apertures Layout (mm)
Figure 2c: Recommended 8mil stencil apertures layout for anode, cathode, and thermal pad.
Note for Figure 2c:
1.
7
Figure 3: Reflow soldering profile for lead free soldering.
Typical Radiation Pattern
100%
90%
80%
Relatiive Intensity
70%
60%
50%
40%
30%
20%
10%
0%
-90 -80 -70 -60 -50 -40 -30 -20 -10
40
50
60
70
80
90
Angular Displacement (Degrees)
Figure 4: Typical representative spatial radiation pattern @ TC = 25°C.
8
Typical Relative Spectral Power Distribution
1.0
0.9
0.8
0.7
0.6
0.5
0.4
0.3
0.2
0.1
0.0
400
450
500
550
600
650
700
Wavelength (nm)
Figure 5: Relative spectral power vs. wavelength @ TC = 25°C.
Typical Forward Current Characteristics
1,600
IF - Forward Current (mA)
1,400
1,200
1,000
800
600
400
200
3.1
3.2
3.3
3.4
3.5
3.6
3.7
3.8
3.9
4.0
VF - Forward Voltage (V)
Figure 6: Typical forward current vs. forward voltage @ T C = 25°C.
9
Typical Relative Light Output over Current
120
Relative Light Output (%)
100
80
60
40
400
600
800
1000
1200
1400
1600
Figure 7: Typical relative light output vs. forward current @ T C = 25°C.
Typical Relative Light Output over Temperature
120
100
80
60
40
60
TC - Case
80
100
120
Temperature (oC)
Figure 8: Typical relative light output vs. case temperature.
10
Typical Dominant Wavelength Shift over Current
12.0
Dominant Wavelength Shift (nm)
9.0
6.0
3.0
0.0
-3.0
-6.0
-9.0
-12.0
400
600
800
1000
1200
1400
1600
Figure 9: Typical dominant wavelength shift vs. forward current @ T C = 25°C.
Typical Relative Dominant Wavelength Shift over Temperature
6.0
4.0
2.0
0.0
-2.0
-4.0
-6.0
60
Case
80
100
120
Temperature (oC)
Figure 10: Typical dominant wavelength shift vs. case temperature.
11
Current Derating
1400
1200
1000
800
600
RΘ JA = 9°C/W
RΘ JA = 12°C/W
400
RΘ JA = 15°C/W
200
50
75
100
TA - Ambient Temperature (°C)
125
150
(TJ(MAX) = 135)
Figure 11: Maximum forward current vs. ambient temperature
Notes for Figure 11:
1.
RΘJ-C [Junction to Case Thermal Resistance] for the LZ1-00G102 is typically 6°C/W.
2.
RΘJ-A [Junction to Ambient Thermal Resistance] = RΘJ-C + RΘC-A [Case to Ambient Thermal Resistance].
12
Emitter Tape and Reel Specifications (mm)
Figure 12: Emitter carrier tape specifications (mm).
Ø 178mm (SMALL REEL)
Ø 330mm (LARGE REEL)
Figure 13: Emitter reel specifications (mm).
Notes:
1.
Small reel quantity: up to 500 emitters
2.
Large reel quantity: 501-2500 emitters.
3.
Single flux bin and single wavelength bin per reel.
13
LZ1 MCPCB Family
Part number
Type of MCPCB
Diameter
(mm)
LZ1-1xxxxx
1-channel Star
19.9
Emitter + MCPCB
Typical VF
Thermal Resistance
(V)
(oC/W)
6.0 + 1.5 = 7.5
3.75
Typical IF
(mA)
1000
Mechanical Mounting of MCPCB
MCPCB bending should be avoided as it will cause mechanical stress on the emitter, which could lead to
substrate cracking and subsequently LED dies cracking.
To avoid MCPCB bending:
o Special attention needs to be paid to the flatness of the heat sink surface and the torque on the screws.
o Care must be taken when securing the board to the heat sink. This can be done by tightening three M3
screws (or #4-40) in steps and not all the way through at once. Using fewer than three screws will
increase the likelihood of board bending.
o It is recommended to always use plastics washers in combinations with the three screws.
o If non-taped holes are used with self-tapping screws, it is advised to back out the screws slightly after
tightening (with controlled torque) and then re-tighten the screws again.
Thermal interface material
To properly transfer heat from LED emitter to heat sink, a thermally conductive material is required when
mounting the MCPCB on to the heat sink.
There are several varieties of such material: thermal paste, thermal pads, phase change materials and thermal
epoxies. An example of such material is Electrolube EHTC.
It is critical to verify the material’s thermal resistance to be sufficient for the selected emitter and its operating
conditions.
It is recommended to verify thermal design by measuring case temperature (Tc) during design phase.
Wire soldering
To ease soldering wire to MCPCB process, it is advised to preheat the MCPCB on a hot plate of 125-150oC.
Subsequently, apply the solder and additional heat from the solder iron will initiate a good solder reflow. It is
recommended to use a solder iron of more than 60W.
It is advised to use lead-free, no-clean solder. For example: SN-96.5 AG-3.0 CU 0.5 #58/275 from Kester (pn:
24-7068-7601)
14
LZ1-1xxxxx
1 channel, Standard Star MCPCB (1x1) Dimensions (mm)
Notes:
Unless otherwise noted, the tolerance = ± 0.2 mm.
Slots in MCPCB are for M3 or #4-40 mounting screws.
LED Engin recommends plastic washers to electrically insulate screws from solder pads and electrical traces.
LED Engin recommends using thermal interface material when attaching the MCPCB to a heat sink.
The thermal resistance of the MCPCB is: RΘC-B 1.5°C/W
Components used
MCPCB:
HT04503
ESD/TVS diode: BZT52C5V1LP-7
VBUS05L1-DD1
(Bergquist)
(Diodes, Inc., for 1 LED die)
(Vishay Semiconductors, for 1 LED die)
Pad layout
Ch.
1
MCPCB
Pad
1,2,3
4,5,6
String/die
Function
1/A
Cathode Anode +
15
About LED Engin
LED Engin, an OSRAM business based in California’s Silicon Valley, develops, manufactures, and sells advanced LED
emitters, optics and light engines to create uncompromised lighting experiences for a wide range of
TM
entertainment, architectural, general lighting and specialty applications. LuxiGen multi-die emitter and
secondary lens combinations reliably deliver industry-leading flux density, upwards of 5000 quality lumens to a
target, in a wide spectrum of colors including whites, tunable whites, multi-color and UV LEDs in a unique patented
TM
compact ceramic package. Our LuxiTune series of tunable white lighting modules leverage our LuxiGen emitters
and lenses to deliver quality, control, freedom and high density tunable white light solutions for a broad range of
new recessed and downlighting applications. The small size, yet remarkably powerful beam output and superior insource color mixing, allows for a previously unobtainable freedom of design wherever high-flux density, directional
light is required. LED Engin is committed to providing products that conserve natural resources and reduce
greenhouse emissions; and reserves the right to make changes to improve performance without notice.
For more information, please contact LEDE-Sales@osram.com or +1 408 922-7200.
16
