KWDCLMS1.PC-BYCX-4A7D-1-20-R18
    AMSOSRAM(艾迈斯半导体)
    SMD2
    LEDTOPLEDCOOLWHITE8000K2SMD
KWDCLMS1.PC-BYCX-4A7D-1-20-R18 数据手册
2015-01-19 TOPLED E3014 Datasheet Version 1.1 KW DCLMS1.PC Features: Besondere Merkmale: • Package: white SMT package, colored silicone resin • Technology: InGaN on Sapphire • Viewing angle at 50 % IV: 110° • Color: white; CTR = 4500 K - 8000 K; CRI (min.) = 70 • ESD - withstand voltage: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2) • Gehäusetyp: weißes SMT Gehäuse, farbiger Silikon-Verguss • Technologie: InGaN on Sapphire • Abstrahlwinkel bei 50 % IV: 110° • Farbe: weiß; CTR = 4500 K - 8000 K; CRI (min.) = 70 • ESD - Festigkeit: 2 kV nach ANSI/ESDA/JEDEC JS-001 (HBM, Klasse 2) Applications Anwendungen • White Goods Lighting • Vending Machines • Transportation • Weiße Ware • Automaten • Verkehrsmittel 2015-01-19 1 Version 1.1 KW DCLMS1.PC Ordering Information Bestellinformation Type: Color Temperature Luminous Intensity 1) page 24 Ordering Code Typ: Farbtemperatur Lichtstärke Bestellnummer 1) Seite 24 IF = 20 mA KW DCLMS1.PC-BYCX-5J7K-1 [K] IV [mcd] 4500 2100 ... 3300 Q65111A4105 KW DCLMS1.PC-BYCX-5H7I-1 5000 2100 ... 3300 Q65111A4104 KW DCLMS1.PC-BYCX-4A7D-1 8000 2100 ... 3300 Q65111A4103 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. KW DCLMS1.PC-BYCX-4A7D-1 means that only one group BY, BZ, CX will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. KW DCLMS1.PC-BYCX-4A7D-1 means that the device will be shipped within the specified limits. In order to ensure availability, single color chromaticity groups groups will not be orderable. In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing unit. E. g. KW DCLMS1.PC-BYCX-4A7D-1 means that only one forward voltage group 24,64,A4 will be shippable. In order to ensure availability, single forward voltage groups will not be orderable (see page 5). Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. KW DCLMS1.PC-BYCX-4A7D-1 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen BY, BZ, CX enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne Helligkeitsgruppen nicht bestellt werden. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. KW DCLMS1.PC-BYCX-4A7D-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. KW DCLMS1.PC-BYCX-4A7D-1 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten, können einzelne Farbortgruppen nicht bestellt werden. Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Durchlassspannungsgruppe geliefert. Z. B. KW DCLMS1.PC-BYCX-4A7D-1 bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer Verpackungseinheit ist nur eine der Durchlassspannungsgruppen 24,64,A4 enthalten (siehe Seite 5). Um die Liefersicherheit zu gewährleisten, können einzelne Durchlassspannungsgruppen nicht direkt bestellt werden. 2015-01-19 2 Version 1.1 KW DCLMS1.PC Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 85 °C Storage temperature range Lagertemperatur Tstg -40 ... 100 °C Junction temperature Sperrschichttemperatur Tj 110 °C Forward current Durchlassstrom (TS = 25 °C) IF 30 mA Surge current Stoßstrom (t ≤ 10000 µs; D = 0.1; TS = 25 °C) IFM 100 mA Reverse voltage Sperrspannung (TS = 25 °C) VR not designed for reverse operation 2015-01-19 3 V Version 1.1 KW DCLMS1.PC Characteristics (TS = 25 °C; IF = 20 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 110 ° Forward voltage 2) page 24 , 3) page 24 Durchlassspannung 2) Seite 24 , 3) Seite 24 (min.) (typ.) (max.) VF VF VF 2.80 3.05 3.40 V V V IR not designed for reverse operation Reverse current Sperrstrom Real thermal resistance junction / ambient 4) page 24 , 5) page 24 (typ.) (max.) Rth JA real Rth JA real 330 430 K/W K/W (typ.) (max.) Rth JS real Rth JS real 125 162 K/W K/W Realer Wärmewiderstand Sperrschicht / Umgebung 4) Seite 24 , 5) Seite 24 Real thermal resistance junction / solder point 5) page 24 Realer Wärmewiderstand Sperrschicht / Lötpad 5) Seite 24 Note: Individual forward voltage groups see next page Anm.: Durchlassspannungsgruppen siehe nächste Seite 2015-01-19 4 Version 1.1 KW DCLMS1.PC Brightness Groups Helligkeitsgruppen Group Luminous Intensity Luminous Intensity 1) page 24 1) page 24 Lichtstärke 1) Seite 24 Lichtstrom 6) Seite 24 (min.) Iv [mcd] (max.) Iv [mcd] (typ.) ΦV [mlm] 2100 2400 6750 2400 2800 7800 2800 3300 9150 Gruppe Lichtstärke BY BZ CX 1) Seite 24 Luminous Flux 6) page 24 Note: The standard shipping format for serial types includes either a lower family group, an upper family group or a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups cannot be ordered. Anm.: Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne Helligkeitsgruppen sind nicht bestellbar. Forward Voltage Groups 2) page 24 , 3) page 24 Durchlassspannungsgruppen 2) Seite 24 , 3) Seite 24 Group Gruppe (min.) VF [V] (max.) VF [V] 24 2.80 3.00 64 3.00 3.20 A4 3.20 3.40 2015-01-19 5 Version 1.1 KW DCLMS1.PC Chromaticity Coordinate Groups 7) page 24 Farbortgruppen 7) Seite 24 0,90 0,41 520 Cy Cy 530 0,80 540 510 0,39 0,70 4500 K 550 7K 5000 K 560 0,37 0,60 7J 6K 7I 6J 7H 570 5500 K 500 0,50 2500 K 3000 K 580 4000 K 3500 K 495 0,30 490 5J 5I 5H 6500 K 590 4500 5000 KK 5500KK8J 6000 7K 8I 7J 8H 7I 6K 6500KK7H 6J 7000 6I 5K 5J 6H 5I 8000 K 5H 9000 8C K8D 7D 10000 7C K 6D 6C 5D 12000K7A K7B 6B 5C 4D 5B 4C 14000 6A 4B 5A 20000 K 4A 0,40 5K 6I 6H 6000 K 0,35 600 7D 7000 K 7C 6D 0,33 610 620 630 650 6C 5D 7B 5C 6B 4D 7A 5B 4C 6A 4B 5A 8000 K 0,31 9000 K 0,20 10000 K 4A 480 0,29 0,10 470 460 450 0,41 0,39 0,37 0,35 0,33 0,31 0,27 0,29 0,27 0,90 0,80 0,70 0,60 0,50 0,40 0,30 0,20 0,10 0,00 0,00 Cx Cx Color Chromaticity Groups 7) page 24 Farbortgruppen 7) Seite 24 Group Gruppe 4A 5A 6A 2015-01-19 Cx Cy Group Gruppe 0.2961 0.2952 0.3041 0.3240 0.2981 0.2892 0.3055 0.3177 0.3015 0.3033 0.3098 0.3032 0.2968 0.3108 0.2949 0.2993 0.3028 0.3304 0.2961 0.2952 0.3041 0.3002 0.3082 0.3087 0.3015 0.3033 0.3098 0.2936 0.3034 0.3119 0.3162 0.2949 0.2993 0.3130 0.3095 0.2990 0.3131 0.3170 0.3002 0.3082 0.3178 6C 7C 4D Cx 6 Cy Group Gruppe Cx Cy 0.3448 0.3515 0.3456 0.3601 0.3296 0.3527 0.3578 0.3229 0.3539 0.3669 0.3456 0.3601 0.3240 0.3464 0.3688 0.3363 0.3539 0.3669 0.3296 0.3551 0.3760 0.3512 0.3465 0.3524 0.3555 0.3212 0.3591 0.3522 0.3142 0.3608 0.3616 6I 7I 5J Version 1.1 Group Gruppe 7A 4B 5B 6B 7B 4C 5C 2015-01-19 KW DCLMS1.PC Cx Cy Group Gruppe 0.2924 0.3076 0.3108 0.3229 0.2936 0.3034 0.3119 0.3162 0.2978 0.3181 0.3162 0.3282 0.3170 0.3212 0.3098 0.3296 5D Cx Cy 0.2990 0.3131 0.3015 0.3033 0.3032 0.2968 0.3108 0.3068 0.3113 0.3154 0.3083 0.3044 0.3162 0.3002 0.3082 0.3087 0.3363 0.3015 0.3033 0.3098 0.3296 0.3056 0.3171 0.3146 0.3422 0.3154 0.3352 0.3366 0.3369 6D 7D 0.3555 0.3536 0.3646 0.3608 0.3616 0.3711 0.3229 0.3548 0.3736 0.3352 0.3625 0.3711 0.3282 0.3642 0.3805 0.3591 0.3522 0.3608 0.3616 0.3670 0.3578 0.3113 0.3002 0.3082 0.3369 0.3044 0.3228 0.3440 0.3056 0.3171 0.3448 0.2978 0.3181 0.3369 0.3451 0.2990 0.3131 0.3373 0.3534 0.3032 0.3286 0.3448 7J 5K 0.3692 0.3677 0.3608 0.3616 0.3451 0.3625 0.3711 0.3428 0.3692 0.3677 0.3515 0.3714 0.3775 0.3625 0.3711 0.3642 0.3805 0.3515 0.3714 0.3775 0.3456 0.3601 0.3736 0.3874 0.3373 0.3534 0.3044 0.3228 0.3068 0.3113 0.3081 0.3049 0.3376 0.3616 0.3119 0.3162 0.3456 0.3601 0.3130 0.3095 0.3464 0.3688 0.3055 0.3177 0.3440 0.3428 0.3068 0.3113 0.3448 0.3515 0.3108 0.3229 0.3515 0.3487 0.3119 0.3162 0.3527 0.3578 5I 0.3524 0.3646 0.3131 7H Cy 0.3625 0.3068 6H 6J Cx 0.3536 0.2990 5H Group Gruppe 7 6K 7K Version 1.1 KW DCLMS1.PC Group Name on Label Gruppenbezeichnung auf Etikett Example: BY-4A-24 Beispiel: BY-4A-24 Brightness Helligkeit Chromaticity Coordinate Farbort Forward Voltage Durchlassspannung BY 4A 24 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2015-01-19 8 Version 1.1 KW DCLMS1.PC Relative Spectral Emission - V(λ) = Standard eye response curve 6) page 24 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 6) Seite 24 Irel = f (λ); TS = 25 °C; IF = 20 mA Irel K W DC LMS 1.P C (4500K ) 1,0 4.500K : white : Vλ 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Relative Spectral Emission - V(λ) = Standard eye response curve 6) page 24 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 6) Seite 24 Irel = f (λ); TS = 25 °C; IF = 20 mA Irel K W DC LMS 1.P C (8000K ) 1,0 8.000K : white : Vλ 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] 2015-01-19 9 Version 1.1 KW DCLMS1.PC Radiation Characteristics 6) page 24 Abstrahlcharakteristik 6) Seite 24 Irel = f (ϕ); TS = 25 °C KW DCLMS1.PC (4500K) ϕ [°] -10° 0° 10° -20° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° -40° 0,8 -50° 0,6 -60° 0,4 -70° 0,2 -80° 0,0 -90° -100° 2015-01-19 10 Irel Version 1.1 KW DCLMS1.PC Forward Current 6) page 24 , 3) page 24 Durchlassstrom 6) Seite 24 , 3) Seite 24 IF = f (VF); TS = 25 °C IF [mA] Relative Luminous Intensity 6) page 24 , 3) page 24 Relative Lichtstärke 6) Seite 24 , 3) Seite 24 IV/IV(20 mA) = f(IF); TS = 25 °C KW DCLMS1.PC (4500K) 100 K W DC LMS 1.P C (4500K ) IV 4.500K 4 I V (20mA) 3 80 2 1 60 0,5 40 0,4 0,3 0,2 20 3,8 4,0 VF [V] I F [mA ] 6) page 24 , 3) page 24 Relative Luminous Intensity Relative Lichtstärke 6) Seite 24 , 3) Seite 24 IV/IV (20 mA) = f(IF); TS = 25 °C IV I V (20mA) K W DC LMS 1.P C (8000K ) 0 3,6 10 3,4 20 3,2 30 40 50 3,0 10 2,8 2 2,6 3 4 5 0,1 2,4 Chromaticity Coordinate Shift Farbortverschiebung 6) Seite 24 ΔCx, ΔCy = f(IF); TS = 25 °C 8.000K ∆C x ∆C y 4 3 6) page 24 K W DC LMS 1.P C (4500K ) 0,03 4.500K : ∆C x : ∆C y 0,02 2 0,01 1 0,00 0,5 0,4 -0,01 0,3 0,2 -0,02 0,1 0 10 80 60 I F [mA ] I F [mA ] 2015-01-19 40 20 0 10 20 30 40 50 10 3 4 5 2 -0,03 11 Version 1.1 KW DCLMS1.PC Chromaticity Coordinate Shift 6) page 24 Farbortverschiebung 6) Seite 24 ΔCx, ΔCy = f(IF); TS = 25 °C K W DC LMS 1.P C (8000K ) 0,03 ∆C x ∆C y 8.000K : ∆C x : ∆C y 0,02 0,01 0,00 -0,01 -0,02 0 10 80 60 40 20 -0,03 I F [mA ] 2015-01-19 12 Version 1.1 KW DCLMS1.PC Relative Forward Voltage 6) page 24 Relative Vorwärtsspannung 6) Seite 24 ΔVF = VF - VF(25 °C) = f(Tj); IF = 20 mA ∆VF [V] Relative Luminous Intensity 6) page 24 Relative Lichtstärke 6) Seite 24 IV/IV(25)°C = f(Tj); IF = 20 mA KW DCLMS1.PC (T-gang) 0,3 Iv 0,2 1,0 0,1 0,8 0,0 0,6 -0,1 0,4 -0,2 0,2 -0,3 -40 -20 0 20 40 60 80 0,0 -40 100 Tj [°C] KW DCLMS1.PC (T-gang) 0,03 : ∆ Cx : ∆ Cy 0,02 0,01 0,00 -0,01 -0,02 -0,03 -40 -20 0 20 40 60 80 100 Tj [°C] 2015-01-19 -20 0 20 40 60 80 100 Tj [°C] Chromaticity Coordinate Shift 6) page 24 Farbortverschiebung 6) Seite 24 ΔCx, ΔCy = f(Tj); IF = 20 mA ∆Cx ∆Cy KW DCLMS1.PC (T-gang) 1,2 Iv(25°C) 13 Version 1.1 KW DCLMS1.PC Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) KW DCLMS1.PC IF [mA] 30 25 20 : TA : TS 15 10 5 0 0 20 40 60 80 T [°C] Permissible Pulse Handling Capability Zulässige Impulsbelastbarkeit IF = f(tp) D: Duty cycle TS = 0°C ... 85°C KW DCLMS1.PC I F [ A] : D = 1.0 : D = 0.5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 0,10 0,08 0,06 0,04 10-5 10-4 10-3 0,01 0,1 1 10 Pulse time [s] 2015-01-19 14 Version 1.1 KW DCLMS1.PC Package Outline 8) page 24 Maßzeichnung 8) Seite 24 Approximate Weight: 10 mg Gewicht: 10 mg ESD information: LED is protected by ESD device which is connected in parallel to LED-Chip. ESD Information: Die LED enthält ein ESD-Bauteil, das parallel zum Chip geschaltet ist. 2015-01-19 15 Version 1.1 KW DCLMS1.PC Recommended Solder Pad 8) page 24 Empfohlenes Lötpaddesign 8) Seite 24 Reflow soldering Reflow-Löten Note: For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning. Anm.: Um eine verbesserte Lötstellenkontaktierung zu erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Das Gehäuse ist für Ultraschallreinigung nicht geeignet. 2015-01-19 16 Version 1.1 KW DCLMS1.PC Reflow Soldering Profile Reflow-Lötprofil Product complies to MSL Level 3 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 250 s 300 t OHA04612 Profile Feature Profil-Charakteristik Symbol Symbol Pb-Free (SnAgCu) Assembly Minimum Ramp-up rate to preheat*) 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2015-01-19 °C 17 s Version 1.1 KW DCLMS1.PC Taping 8) page 24 Gurtung 8) Seite 24 2015-01-19 18 Version 1.1 KW DCLMS1.PC Tape and Reel Gurtverpackung 8 mm tape with 2000 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Tape dimensions [mm] Gurtmaße [mm] Tape dim ensions in m m W P0 P1 P2 D0 E F 8 + 0.3 / -0.1 4 ± 0.1 2 ± 0.05 or 4 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 3.5 ± 0.05 Reel dimensions [mm] Rollenmaße [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 8 60 8.4 + 2 14.4 2015-01-19 19 Version 1.1 KW DCLMS1.PC Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Trockenverpackung und Materialien Moisture-sensitive label or print Barcode label L VE l LE k, see labe code blan If bar ). (RH . idity N s IVE RS Otain TO SIT UC TIcon SEN U < RH hum 0% e tive d ˚C/6 kag rela are 30 _ < infr pac of 90% to ak ns ed (pe or rs e). ND Hou rs rs rs Hou and ject ditio cod ˚C, 72 sing Hou e 5 bag E 48 ˚C sub Hou con ± s UR ICO ces 24 6 dat 40 be time ˚C ory ThiISTSEM pro < time or 23 time at t will ˚C). or l with fact ent MO . Flo time s TO at or at Flo l tica d tha or ival ure nth OP Flo 4 if: rea w Flo labe mo ices iden 5 ced equ el n e 5a is el ing, belo or 24 pro 6 Lev e dev : el cod e , unt whe Lev el re ow, see bag Lev l dat re mo bak bar ned Lev refl istu 10% re led time sea for istu ore> re ope e Mo see istu k, is or . sea is has k, Mo bef istu d 033 Mo in Flo RH blan Mo or-p blan in bag Car ing, r TDlife (if If with t. r lf 10%bak or J-S thisvapp. Yea _ eks rs < r ed icat med, C 1 Yea tem She ow, at uire not > y 1 WeHou unt DE Afte Ind 4 uire refl is red req bod Mo /JE time 168 req : 2b a) Sto ices idity time or is IPC or time b) ned Flo or Hum ing ce time or Dev 2a e Flo a) ope or 3. b) bakren Flo 1 l dat Flo If 2 refe time el 2a 4. el sea 3 Lev el and Lev el re Bag e Lev re Lev istu Dat re istu re Mo istu Mo istu Mo Mo A C 1. 2. M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM Desiccant OSR OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2015-01-19 20 Version 1.1 KW DCLMS1.PC Transportation Packing and Materials Kartonverpackung und Materialien Barcode label DE MY 8 1 T6 PL 76 R1 Q- lti LS TO Y 1+ POU GR (G) Mu : 01 (9D ) D/C 21 00 21 99 8 : 4 20 Y: 23 LO (X) PR OD NO ) 11 00 (1T QT (Q) H Se 3G H1 BA TC ) : 12 (6P 5 NO T 14 2 O SR mi AM co nd O uc pt to o rs NO ). : see labe 44 l k, N O TI U A C 00 L VE LE code (RH blan If y bar . idit RH hum 60% e tive d ˚C/ kag rela are 30 E S s _ < infr pac OR of tainITIV 90% to ak urs CT < e). or urs ted (pe ons con NS Ho g urs SE DU Ho and jec diti cod ˚C, 72 sin Ho urs e 5 bag E ON 48 ˚C sub e Ho con ± s UR ces 24 6 dat e MIC 40 be tim ˚C e ThiISTSE pro < tory tim . or t with 23 tim e at t will ˚C) or fac MO . Flo al len tim s TO at or at Flo d or iva ure el nth s tha OP ntic Flo 4 if: rea Flo , lab ow mo ice equ ide 5 ced el e 5a is el ingen bel or 24 pro 6 Lev e dev, : el cod e , unt wh Lev el re ow see bag Lev l dat re mo bak e bar ned Lev refl istu 10% re tim sea for istu ore> re ope e Mo see 3 istu is or . sea is has Mo nk, bef istu , nk, Flo rd -03 Mo in RH bla Mo or-p bla in bag ingCa r TD life (if If with t. r lf vapp. 10%baktor J-S this Yea , _ eks < r ed ica med, C 1 urs Yea tem She ow at uire not > y 1 WeHo unt DE Afte Ind 1. e 4 uire refl red req 2. bod Mo e ity is /JE tim s 168 req : e 2b a) Sto tim or mid is IPC tim e vice or b) ned Flo or Hu tim ing ce or De e 2a Flo a) ope or 3. b) bakren Flo e 1 l dat Flo If 2 el refe tim 2a 4. el sea 3 Lev el and Lev el re Bag te Lev re Lev istu Da re istu re Mo istu Mo istu Mo Mo P: Muster ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Tem 2a 220 3 240 p ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: Barcode label DE MY 1 T6 PL 76 R1 8 lti LS TO Y Mu 1+ Q- P: PGR (G) 44 : 01 D/C ) (9D 20 00 QT Y: : LO (1T ) : NO OD Packing Sealing label Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 200 ± 5 195 ± 5 30 ± 5 2015-01-19 M RA OS (X) PR 5 14 2 110 0 (Q) ico AM nd O uc pt to o rs SR NO 23 4 m O H H1 Se 3G TC 998 NO ) : 12 BA 021 T (6P 210 OU Muster ED Bin Bin 1: Bin 2: P-1 3: Q-1 -20 ML -20 2 Te 2a 220 mp 3 240 ST Ad 260 C R C R0 diti R ona C RT PA 77 l TE CK VA XT R: led 21 OHA02044 Version 1.1 KW DCLMS1.PC Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Exempt group (exposure time 10000 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Exempt group (Expositionsdauer 10000 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Autoscheinwerfer), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. Subcomponents of this LED are silverplated. Silver is discoloring when being exposed to environments containing high concentrations of aggressive substances. Corroded silver may lead to a worsening of the optical performance of the LED and can in the worst case lead to a failure of the LED. Do not expose this LED to aggressive atmospheres. Note, that corrosive gases may as well be emitted from materials close to the LED in the final product. Einzelkomponenten dieser LED sind silberbeschichtet. Silberoberflächen werden durch korrosive Substanzen verändert. Korrodiertes Silber kann zu einer Verschlechterung der optischen Eigenschaften und im schlimmsten Fall zum Ausfall der LED führen. Diese LED darf aggressiven Bedingungen nicht ausgesetzt werden. Es ist zu beachten, dass korrosive Gase auch von Materialien emittiert werden können, die sich im Endprodukt in unmittelbarer Umgebung der LED befinden. For further application related informations please visit www.osram-os.com/appnotes Für weitere applikationsspezifische Informationen besuchen Sie bitte www.osram-os.com/appnotes 2015-01-19 22 Version 1.1 KW DCLMS1.PC Disclaimer Disclaimer Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 2015-01-19 23 Version 1.1 KW DCLMS1.PC Glossary Glossar 1) Brightness: Brightness groups are tested at a current pulse duration of 25 ms and a tolerance of ± 11%. 1) Helligkeit: Helligkeitswerte werden mit Stromeinprägedauer von 25 ms und Genauigkeit von ± 11% ermittelt. 2) Forward Voltage: Forward voltages are tested at a current pulse duration of 1 ms and a tolerance of ± 0.1 V. 2) Durchlassspannung: Spannungswerte werden mit einer Stromeinprägedauer von 1 ms und einer Genauigkeit von ± 0,1 V ermittelt. 3) Specification Curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 3) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 4) Thermal Resistance: RthJA results from mounting on PC board FR 4 (pad size 16mm² per pad) 4) Wärmewiderstand: RthJA ergibt sich bei Montage auf PC-Board FR 4 (Padgröße 16mm² je pad) 5) Thermal Resistance: Rth max is based on statistic values (6σ). 5) Wärmewiderstand: Rth statistischen Werten (6σ). 6) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 6) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 7) Chromaticity coordinate groups: Chromaticity coordinate groups are tested at a current pulse duration of 25 ms and a tolerance of ±0.01. 7) Farbortgruppen: Farbortgruppen werden mit einer Stromeinprägedauer von 25 ms und einer Genauigkeit von ±0,01 ermittelt. 8) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 8) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. 2015-01-19 24 max basiert einer einer auf Version 1.1 KW DCLMS1.PC Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-01-19 25
KWDCLMS1.PC-BYCX-4A7D-1-20-R18 价格&库存
很抱歉,暂时无法提供与“KWDCLMS1.PC-BYCX-4A7D-1-20-R18”相匹配的价格&库存,您可以联系我们找货
