GWCS8PM1.PM-LRLT-A434-1
    AMSOSRAM(艾迈斯半导体)
    LEDOSLONNEUWHITE4500K
GWCS8PM1.PM-LRLT-A434-1 数据手册
2016-08-25 OSLON® SSL 80 Datasheet Version 1.3 GW CS8PM1.PM Higher performance. Lower thermal resistance. Extended range of driving conditions. This OSLON SSL family new generation LED offers a prefocused radiation pattern making it the ideal choice for spot lighting applications. Higher performance. Lower thermal resistance. Extended range of driving conditions. This OSLON SSL family new generation LED offers a prefocused radiation pattern making it the ideal choice for spot lighting applications. Features: • Package: SMT ceramic package with silicone resin and silicone lens • Viewing angle at 50 % IV: 80° • Color: 3000 K - 6500 K (warm, neutral and cool white) • CRI: min. 70 • Luminous Flux: typ. 144 lm @ 5000 K, 85 °C • Luminous efficacy: typ. 144 lm/W @ 5000 K, 85 °C • Corrosion Robustness: Superior Corrosion Robustness • Lumen Maintenance: Test results according to IESNA LM-80 available Besondere Merkmale: • Gehäusetyp: SMT-Keramikgehäuse mit Silikonverguss und -linse • Abstrahlwinkel bei 50 % IV: 80° • Farbe: 3000 K - 6500 K (warm, neutral and cool white) • CRI: min. 70 • Lichtstrom: typ. 144 lm @ 5000 K, 85 °C • Lichtausbeute: typ. 144 lm/W @ 5000 K, 85 °C Applications Accent and effect lighting • • Architectural lighting • Industrial lighting • Outdoor lighting Anwendungen • Akzent- und Effektbeleuchtung • Architekturbeleuchtung • Industriebeleuchtung • Außenbeleuchtung 2016-08-25 • • 1 Korrosionsstabilität: Höchste Korrosionsbeständigkeit Lichtstromerhaltung: Testergebnisse nach IESNA LM-80 verfügbar Version 1.3 GW CS8PM1.PM Ordering Information Bestellinformation Type: Color Temperature Typ: Farbtemperatur Luminous Flux Ordering Code Lichtstrom Bestellnummer 1) page 24 1) Seite 24 IF = 350 mA, TS = 85 °C [K] ΦV [lm] GW CS8PM1.PM-LRLT-A737-1 3000 130 ... 164 Q65112A1037 GW CS8PM1.PM-LRLT-XX57-1 3000 130 ... 164 Q65112A1036 GW CS8PM1.PM-LRLT-A636-1 3500 130 ... 164 Q65112A1035 GW CS8PM1.PM-LRLT-XX56-1 3500 130 ... 164 Q65112A1034 GW CS8PM1.PM-LRLT-A535-1 4000 130 ... 164 Q65111A7343 GW CS8PM1.PM-LRLT-XX55-1 4000 130 ... 164 Q65111A8245 GW CS8PM1.PM-LRLT-A434-1 4500 130 ... 164 Q65111A7335 GW CS8PM1.PM-LRLT-XX54-1 4500 130 ... 164 Q65111A8246 GW CS8PM1.PM-LRLT-A333-1 5000 130 ... 164 Q65111A7333 GW CS8PM1.PM-LRLT-XX53-1 5000 130 ... 164 Q65111A8247 GW CS8PM1.PM-LRLT-A232-1 5700 130 ... 164 Q65111A7327 GW CS8PM1.PM-LRLT-XX52-1 5700 130 ... 164 Q65111A8248 GW CS8PM1.PM-LRLT-A131-1 6500 130 ... 164 Q65111A7324 GW CS8PM1.PM-LRLT-XX51-1 6500 130 ... 164 Q65111A8249 Note: The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. GW CS8PM1.PM-LRLT-XX57-1 means that only one group LR, LS, LT will be shippable for any packing unit. In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing unit. E. g. GW CS8PM1.PM-LRLT-XX57-1 means that only one forward voltage group K2,L1,L2,M1,M2 will be shippable. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW CS8PM1.PM-LRLT-XX57-1 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen LR, LS, LT enhalten ist. Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Durchlassspannungsgruppe geliefert. Z. B. GW CS8PM1.PM-LRLT-XX57-1 bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer Verpackungseinheit ist nur eine der Durchlassspannungsgruppen K2,L1,L2,M1,M2 enthalten (siehe Seite 5). 2016-08-25 2 Version 1.3 GW CS8PM1.PM Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 125 °C Storage temperature range Lagertemperatur Tstg -40 ... 125 °C Junction temperature absolute * Sperrschichttemperatur absolut * Tj, abs 160 °C Junction temperature Sperrschichttemperatur Tj 135 °C Forward current Durchlassstrom (TS = 85 °C) IF 100 ... 1300 mA Surge current Stoßstrom IFM 2000 mA Reverse current 2) page 24 Sperrstrom 2) Seite 24 IR 200 mA ESD withstand voltage ESD Festigkeit (acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class 3B) VESD 8 kV Note: * This is verified by testing 30 pieces. Pass criteria: No catastrophic failures allowed, luminous flux must be better than L70B50 after 1000 h. Anm: * Dieser Wert wird durch den Test von 30 Bauteilen abgesichert. Dabei dürfen keine Totalausfälle auftreten und der Lichtstrom muß nach 1000 h über L70B50 liegen. 2016-08-25 3 Version 1.3 GW CS8PM1.PM Characteristics (TS = 85 °C; IF = 350 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 80 ° Forward voltage Durchlassspannung (min.) (typ.) (max.) VF VF VF 2.70 2.85 3.20 V V V Reverse voltage Sperrspannung (IR = 20 mA) (max.) VR 1.2 V Color rendering index Farbwiedergabe Index (3000 K - 6500 K) (min.) Ra 70 - Real thermal resistance junction / solder point (typ.) (max.) Rth JS real Rth JS real 5.25 6.52 K/W K/W Rth JS el Rth JS el 3.7 4.6 K/W K/W 3) page 24 Realer Wärmewiderstand Sperrschicht / Lötpad 3) Seite 24 "Electrical" thermal resistance junction / solder point (typ.) (max.) "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 3) Seite 24 (with efficiency ηe = 30 %) 3) page 24 Note: Individual forward voltage groups see next page Anm.: Durchlassspannungsgruppen siehe nächste Seite 2016-08-25 4 Version 1.3 GW CS8PM1.PM Brightness Groups Helligkeitsgruppen Group Luminous Flux 1) page 24 Luminous Flux 1) page 24 Luminous Intensity Gruppe Lichtstrom 1) Seite 24 Lichtstrom 1) Seite 24 Lichtstärke 4) Seite 24 (min.) ΦV [lm] (max.) ΦV [lm] (typ.) IV [cd] LQ 121 130 85 LR 130 140 92 LS 140 150 99 LT 150 164 107 LU 164 180 117 Forward Voltage Groups Durchlassspannungsgruppen Group Gruppe (min.) VF [V] (max.) VF [V] K2 2.70 2.80 L1 2.80 2.90 L2 2.90 3.00 M1 3.00 3.10 M2 3.10 3.20 2016-08-25 5 4) page 24 Version 1.3 GW CS8PM1.PM Chromaticity Coordinate Groups 5) page 24 Farbortgruppen 5) Seite 24 2016-08-25 6 Version 1.3 GW CS8PM1.PM Color Chromaticity Groups 7) page 24 Farbortgruppen 7) Seite 24 2016-08-25 7 Version 1.3 2016-08-25 GW CS8PM1.PM 8 Version 1.3 GW CS8PM1.PM Group Name on Label Gruppenbezeichnung auf Etikett Example: LR-39-K2 Beispiel: LR-39-K2 Brightness Helligkeit Chromaticity Coordinate Farbort Forward Voltage Durchlassspannung LR 39 K2 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2016-08-25 9 Version 1.3 GW CS8PM1.PM Relative Spectral Emission - V(λ) = Standard eye response curve 4) page 24 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 4) Seite 24 Φrel = f (λ); TS = 85 °C; IF = 350 mA Erel GW CS8PM1.PM 1,0 : Vλ : white 0,8 0,6 0,4 0,2 0,0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 4) page 24 Abstrahlcharakteristik 4) Seite 24 Irel = f (ϕ); TS = 85 °C GW CS8PM1.PM ϕ [°] -10° 0° 10° -20° 20° 30° 40° 50° 60° 70° 80° 90° 1,0 -30° -40° 0,8 -50° 0,6 -60° 0,4 -70° 0,2 -80° -90° 0,0 -100° 2016-08-25 10 Irel Version 1.3 GW CS8PM1.PM Relative Luminous Flux 4) page 24 , 6) page 24 Relativer Lichtstrom 4) Seite 24 , 6) Seite 24 ΦV/ΦV(350 mA) = f(IF); TS = 85 °C Forward Current 4) page 24 , 6) page 24 Durchlassstrom 4) Seite 24 , 6) Seite 24 IF = f (VF); TS = 85 °C ΦV GW CS8PM1.PM IF [mA] 1300 GW CS8PM1.PM ΦV(350 ) mA 1200 1000 2,5 2,0 800 1,5 600 1,0 400 0,5 200 100 2,65 2,8 2,9 3,0 3,1 3,2 0 10 3,31 VF [V] : ∆ Cx - white : ∆ Cy - white 0,02 0,01 0,00 -0,01 -0,02 -0,03 0 10 0 40 0 60 0 80 00 10 00 13 F I 2016-08-25 0 80 00 10 00 13 F GW CS8PM1.PM 0,03 0 60 I Chromaticity Coordinate Shift 4) page 24 Farbortverschiebung 4) Seite 24 ΔCx, ΔCy = f(IF); TS = 85 °C ∆Cx ∆Cy 0 40 [mA] 11 [mA] Version 1.3 GW CS8PM1.PM Relative Forward Voltage 4) page 24 Relative Vorwärtsspannung 4) Seite 24 ΔVF = VF - VF(85 °C) = f(Tj); IF = 350 mA ∆VF [V] Relative Luminous Flux 4) page 24 Relativer Lichtstrom 4) Seite 24 ΦV/ΦV(85 °C) = f(Tj); IF = 350 mA Φv GW CS8PM1.PM 0,3 Φv(85°C) 0,2 1,0 0,1 0,8 0,0 0,6 -0,1 0,4 -0,2 0,2 -0,3 -40 -20 0 20 40 60 80 0,0 -40 -20 100 120 Chromaticity Coordinate Shift 4) page 24 Farbortverschiebung 4) Seite 24 ΔCx, ΔCy = f(Tj); IF = 350 mA GW CS8PM1.PM 0,03 : Cx - white : Cy - white 0,02 0,01 0,00 -0,01 -0,02 -0,03 -40 -20 0 20 40 60 80 100 120 Tj [°C] 2016-08-25 0 20 40 60 80 100 120 Tj [°C] Tj [°C] ∆Cx ∆Cy GW CS8PM1.PM 1,2 12 Version 1.3 GW CS8PM1.PM Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) IF [mA] GW CS8PM1.PM 1400 1300 1200 1100 1000 900 800 700 600 500 400 300 200 100 Do not use below 100 mA 0 0 20 40 60 80 100 120 Ts [°C] 2016-08-25 13 Version 1.3 GW CS8PM1.PM Package Outline 7) page 24 Maßzeichnung 7) Seite 24 Approximate Weight: 25 mg Gewicht: 25 mg ESD information: LED is protected by ESD device which is connected in parallel to LED-Chip. ESD Information: Die LED enthält ein ESD-Bauteil, das parallel zum Chip geschaltet ist. Corrosion robustness: Test conditions: 40 °C / 90 % rh / 15 ppm H2S / 336 h = Stricter than IEC 60068-2-43 (H2S) [25°C / 75 % rh / 10 ppm H2S / 21 days] = Regarding relevant gas (H2S) stricter than EN 60068-2-60 (method 4) [25 °C / 75 % rh / 200 ppb SO2, 200 ppb NO2,10 ppb Cl2 / 21 days] Korrosionsfestigkeit: Test Kondition: 40°C / 90 % rh / 15 ppm H2S / 336 h = Besser als IEC 60068-2-43 (H2S) [25°C / 75 % rh / 10 ppm H2S / 21 Tage] = Bezogen auf das Gas (H2S) besser als EN 60068-2-60 (method 4) [25°C / 75 % rh / 200ppb SO2, 200ppb NO2,10ppb Cl2 / 21 Tage] 2016-08-25 14 Version 1.3 GW CS8PM1.PM Recommended Solder Pad 7) page 24 Empfohlenes Lötpaddesign 7) Seite 24 foot print 2016-08-25 Cu area Reflow soldering Reflow-Löten solder resist 15 solder stencil Version 1.3 GW CS8PM1.PM Note: For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. For further information please refer to our Application Note “Handling and Processing Details for Ceramic LEDs“. Anm.: Um eine verbesserte Lötstellenkontaktierung zu erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Weitere Informationen finden Sie in der Applikationsschrift „Handling and Processing Details for Ceramic LEDs“. 2016-08-25 16 Version 1.3 GW CS8PM1.PM Reflow Soldering Profile Reflow-Lötprofil Product complies to MSL Level 2 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Symbol Symbol Profile Feature Profil-Charakteristik Pb-Free (SnAgCu) Assembly Minimum ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2016-08-25 °C 17 s Version 1.3 GW CS8PM1.PM Taping 9) page 24 Gurtung 9) Seite 24 2016-08-25 18 Version 1.3 GW CS8PM1.PM Tape and Reel Gurtverpackung 12 mm tape with 600 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Tape dimensions [mm] Gurtmaße [mm] Tape dim ensions in m m W P0 12 + 0.3 / - 0.1 4 ± 0.1 P1 P2 D0 E F 4 ± 0.1 or 8 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 5.5 ± 0.05 Reel dimensions [mm] Rollenmaße [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 12 60 12.4 + 2 18.4 2016-08-25 19 Version 1.3 GW CS8PM1.PM Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX A BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors RoHS Compliant (6P) BATCH NO: 1234567890 MP ML Temp ST X XXX °C X (9D) D/C: 1234 (1T) LOT NO: 1234567890 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Trockenverpackung und Materialien Moisture-sensitive label or print L VE LE el see . lab e H) nk, (R bla cod If y bar . dit RH mi % hu e /60 ve ed ag ˚C ati rar ck rel 30 s VE RS _ < inf pa % ainITI TO of to ak 90 urs d nt ). < ns (pe or urs d co NSUC Ho de , cte itio urs g SEND Ho an bje ing co ˚C 72 nd Ho urs 5 baRE CO te 48 ˚C su ss e Ho co ± ce is 24 6 da e y MI 40 be tim ˚C e ThISTU th < tor ll pro tim SE or ). 23 tim e at t wi nt˚C or l wi fac MO Flo tim s TO at or ca at re. Flo d tha ale el or nth OP nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ve % ure ba ed low ba Le mo ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk rd g -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo A U TIO Barcode label N C M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 A OSR Desiccant M OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2016-08-25 20 Version 1.3 GW CS8PM1.PM Transportation Packing and Materials Kartonverpackung und Materialien Barcode label 8 Y DE M R 18 Q -1 P -1 + P: OU C: 99 D/ 21 00 (9 D) 21 : 20 00 : O TY (Q )Q 14 2 5 S S em R ic AM on du O p ct to or NO s 3G H 12 34 BA TC H P) 11 00 C: D/ D) (9 00 : 20 TY )Q : NO PR O ) (X Packing Sealing label Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 195 ± 5 195 ± 5 30 ± 5 2016-08-25 : 12 (6 NO T LO T) (1 NO : OD PR (X ) DE M 18 01 44 (G ) G RO UP : P -1 + Q R -1 u L lt S iT Y O T P 67 L 6 M Y E Bi D Bi n1 Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: Muster : 34 12 AM R OS D 5 14 2 110 0 (Q S (1 T) LO T NO (6 P) : 12 BA 3G TC H O S 21 2100 H em R ic AM o n O d u p ct to o rs NO 998 01 44 el A C GR L E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho IC co ± is UR 24 6 da e M 40 be oc ry tim ˚C e Th STSE r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed re ty is qu JE 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT CT nt TIO co NS DU g SE U ba E ON (G ) M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 21 OHA02044 Version 1.3 GW CS8PM1.PM Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Exempt group (exposure time 10000 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. spotlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Exempt group (Expositionsdauer 10000 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Spotlights), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. Subcomponents of this LED contain, among other substances, goldplated and Ag-filled materials. In spite of the improved corrosion stability of this LED, it can be affected by environments that contain very high concentrations of aggressive substances. Therefore, we recommend avoiding aggressive atmospheres during storage, production and use. Einzelkomponenten dieser LED enthalten u.a. goldbeschichtete und Ag-gefüllte Materialien. Trotz der verbesserten Korrosionsstabilität dieser LED können Einzelkomponenten durch sehr hohe Konzentration aggressiver Substanzen angegriffen werden. Aus diesem Grund wird empfohlen, aggressive Umgebungen während der Lagerung, Produktion und im Betrieb zu vermeiden. This LED is designed for specific/recommended applications only. Please consult OSRAM Opto Semiconductors Sales Staff in advance for detailed information on other non-recommended applications (e.g. automotive) OR Please visit www.osram-os.com/appnotes. Change management for this component is aligned with the requirements of the lighting market. Die LED ist ausschließlich für spezifisch empfohlene Anwendungen konzipiert. Bitte kontaktieren Sie das OSRAM Opto Semiconductors Vertriebspersonal für detailierte Informationen über nicht empfohlene Anwendungsbereiche (z.B. Automobilbereich). oder besuchen Sie www.osram-os.com/appnotes Das Änderungsmanagement dieses Bauteils ist an den Anforderungen des Lichtmarktes ausgerichtet. 2016-08-25 22 Version 1.3 GW CS8PM1.PM Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Bei abweichenden Angaben im zweisprachigen Wortlaut haben die Angaben in englischer Sprache Vorrang. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2016-08-25 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 23 Version 1.3 GW CS8PM1.PM Glossary Glossar 1) Brightness: Brightness values are measured during a current pulse of typically 10 ms, with a tolerance of +/- 7%. 1) Helligkeit: Helligkeitswerte werden während eines Strompulses mit einer typischen Dauer von 10 ms, mit einer Genauigkeit von ± 7% ermittelt. 2) Reverse Operation: A minimum of 10 hours of reverse operation is permisable in total. 2) Betrieb in Sperrrichtung: Eine Gesamtbetriebszeit von wenigstens 10 Stunden in Sperrrichtung ist gewährleistet. 3) Thermal Resistance: Rth max is based on statistic values (6σ). 3) Wärmewiderstand: Rth statistischen Werten (6σ). 4) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 4) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 5) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 0.005 and an expanded uncertainty of ± 0.01 (acc. to GUM with a coverage factor of k = 3). 5) Farbortgruppen: Farbkoordinaten werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 0,005 und einer erweiterten Messunsicherheit von ± 0,01 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 6) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 6) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 7) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 7) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. 2016-08-25 24 max basiert auf Version 1.3 GW CS8PM1.PM Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2016-08-25 25
GWCS8PM1.PM-LRLT-A434-1 价格&库存
很抱歉,暂时无法提供与“GWCS8PM1.PM-LRLT-A434-1”相匹配的价格&库存,您可以联系我们找货
