LEUWU1A401-8Q6R-EBXD68-T10 数据手册
2015-08-04
OSRAM OSTAR Headlamp Pro
Datasheet
Version 2.3 - OS-PCN-2015-006-A
LE UW U1A4 01
OSRAM OSTAR Headlamp is designed for
applications where high brightness is required. Due to
a seamless white colour impression at a maximum
brightness level and its scalable brightness.
Die OSRAM OSTAR Headlamp ist durch ihren
übergangslosen weißen Farbeindruck und der
extremen Helligkeit speziell für Anwendungen mit
hohen Helligkeiten entwickelt worden.
Features:
Package: compact lightsource in multi chip on
board technology
Technology: ThinGaN (UX:3)
Viewing angle at 50 % IV: 120° (Lambertian
Emitter)
Color: Cx = 0.32, Cy = 0.33 acc. to CIE 1931
(ultra white)
ESD - withstand voltage: 8 kV acc. to
ANSI/ESDA/JEDEC JS-001 (HBM, Class 3B)
Corrosion Robustness: Improved corrosion
robustness
Besondere Merkmale:
Gehäusetyp: Kompakte Lichtquelle mit Multi Chip
Technologie
Technologie: ThinGaN (UX:3)
Abstrahlwinkel bei 50 % IV: 120° (Lambertscher
Strahler)
Farbe: Cx = 0.32, Cy = 0.33 nach CIE 1931
(ultra weiß)
ESD - Festigkeit: 8 kV nach ANSI/ESDA/JEDEC
JS-001 (HBM, Klasse 3B)
Korrosionsstabilität: Verbesserte
Applications
Exterior Automotive Lighting
Floodlight
Anwendungen
Automobilbeleuchtung außen
Flutlicht
2015-08-04
1
LE UW U1A4 01
Ordering Information
Bestellinformation
Type:
Luminous Flux 1) page 18
Ordering Code
Typ:
Lichtstrom 1) Seite 18
Bestellnummer
IF = 1000 mA
ΦV [lm]
LE UW U1A4
01-8Q8R-ebvF68ebzB68
Note:
1000 ... 1800
Q65111A7562
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will
be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. LE UW U1A4
01-8Q8R-ebvF68ebzB68 means that only one group 5R, 6R, 7R, 8Q, 8R will be shippable for any packing unit.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on
any one packing unit. LE UW U1A4 01-8Q8R-ebvF68ebzB68 means that the device will be shipped within the specified limits.
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen
(siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. LE UW U1A4
01-8Q8R-ebvF68ebzB68 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen 5R, 6R, 7R, 8Q, 8R enhalten
ist.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine
Farbortgruppe geliefert. Z.B. LE UW U1A4 01-8Q8R-ebvF68ebzB68 bedeutet, dass in einer Verpackungseinheit nur eine der
Farbortgruppen enthalten ist. LE UW U1A4 01-8Q8R-ebvF68ebzB68 bedeutet, dass das Bauteil innerhalb der spezifizierten
Grenzen geliefert wird.
2015-08-04
2
LE UW U1A4 01
Maximum Ratings
Grenzwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Operating temperature range
Betriebstemperatur
Top
-40 ... 135
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 135
°C
Junction temperature for short time applications *
Sperrschichttemperatur für Kurzzeitanwendung *
Tj
175
°C
Tj
150
°C
Forward current
Durchlassstrom
(TBoard = 25 °C)
IF
50 ... 1500
mA
Forward current pulsed
Durchlassstrom gepulst
(acc. pulse derating on page 11)
IF pulse
2000
mA
Reverse voltage
Sperrspannung
(TBoard = 25 °C)
VR
ESD withstand voltage
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM, Class
3B)
VESD
not designed for reverse
operation
V
8
kV
Note:
*The LED chip exhibits excellent performance but slight package discoloration occurs at highest temperatures. Exemplary
median lifetime for Tj = 175°C is 100h.
Anm:
*Auch bei höchsten Temperaturen zeigt der LED Chip sehr gute Leistungsmerkmale, aber es kann eine leichte Verfärbung
des Gehäuses auftreten. Die mittlere Lebensdauer bei Tj = 175°C beträgt 100h.
2015-08-04
3
LE UW U1A4 01
Characteristics (TBoard = 25 °C; IF = 1000 mA)
Kennwerte
Parameter
Symbol
Values
Unit
Bezeichnung
Symbol
Werte
Einheit
Chromaticity coordinates acc. to CIE 1931 2) page 18
Farbkoordinaten nach CIE 1931 2) Seite 18
(typ.)
(typ.)
Cx
Cy
0.322
0.334
(typ.)
2ϕ
120
Forward voltage 3) page 18
Durchlassspannung 3) Seite 18
(min.)
(typ.)
(max.)
VF
VF
VF
11.80
12.40
14.10
V
V
V
IR
not designed for
reverse operation
Reverse current
Sperrstrom
Radiating surface
Abstrahlende Fläche
(typ.)
Acolor
4.4
mm²
Thermal resistance junction / board 4) page 18
Wärmewiderstand Sperrschicht / Board 4) Seite 18
(typ.)
(max.)
Rth JB real
Rth JB real
1.8
2.2
K/W
K/W
(with efficiency ηe = 30 %)
(typ.)
(max.)
Rth JB el
Rth JB el
1.3
1.5
K/W
K/W
2015-08-04
4
LE UW U1A4 01
Brightness Groups
Helligkeitsgruppen
Group
Luminous Intensity
5) page 18
Lichtstärke 5) Seite 18
(min.) ΦV [lm]
(max.) ΦV [lm]
(typ.) IV [cd]
8Q
1000
1120
350
5R
1120
1250
390
6R
1250
1400
435
7R
1400
1590
495
8R
1590
1800
560
Gruppe
2015-08-04
5
LE UW U1A4 01
Chromaticity Coordinate Groups 2) page 18
Farbortgruppen 2) Seite 18
0,90
0,37
520
525
515
530
0,80
Cy
Cy
540
510
0,70
0,36
550
505
0,35
560
0,60
570
ebzB68
500
0,34
0,50
580
590
ebxD68
495
0,40
0,33
600
610
0,30
620
630
650
700
490
0,20
ebvF68
0,32
485
480
0,10
0,00
0,00
0,31
475
470
465
460
455
450
400
0,10
0,20
0,30
0,40
0,50
0,60
0,30
0,29
0,70
0,30
0,31
0,32
0,33
Cx
0,34
Cx
Color Chromaticity Groups 2) page 18
Group
Gruppe
Cx
Cy
Group
Gruppe
Cx
Cy
ebzB68
0.3186
0.3484
ebvF68
0.3096
0.3282
0.3203
0.3274
0.3127
0.3093
0.3349
0.3404
0.3246
0.3424
0.3355
0.3633
0.3255
0.3216
0.3138
0.3381
0.3163
0.3181
0.3298
0.3526
0.3300
0.3308
ebxD68
2015-08-04
6
LE UW U1A4 01
Group Name on Label
Gruppenbezeichnung auf Etikett
Example: 5R-ebvF68
Beispiel: 5R-ebvF68
Brightness
Helligkeit
Farbort
5R
ebvF68
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2015-08-04
7
LE UW U1A4 01
Relative Spectral Emission - V(λ) = Standard eye response curve 5) page 18
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 5) Seite 18
Φrel = f (λ); TBoard = 25 °C; IF = 1000 mA
Φrel
LE UW U1A4 01
1,0
: Vλ
: white
0,8
0,6
0,4
0,2
0,0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics 5) page 18
Abstrahlcharakteristik 5) Seite 18
Irel = f (ϕ); TBoard = 25 °C
LE UW U1A4 01
ϕ [°]
-10°
0°
10°
-20°
20°
30°
40°
50°
60°
70°
80°
90°
1,0
-30°
-40°
0,8
-50°
0,6
-60°
0,4
-70°
0,2
-80°
-90°
0,0
-100°
2015-08-04
8
Irel
LE UW U1A4 01
Relative Luminous Flux 5) page 18 , 6) page 18
Relativer Lichtstrom 5) Seite 18 , 6) Seite 18
ΦV/ΦV(1000 mA) = f(IF); TBoard = 25 °C
Forward Current 5) page 18 , 6) page 18
Durchlassstrom 5) Seite 18 , 6) Seite 18
IF = f (VF); TBoard = 25 °C
IF [mA]
ΦV
LE UW U1A4 01
1500
LE UW U1A4 01
ΦV(1000mA) 1,4
1400
: white
1,2
1200
1,0
1000
0,8
800
0,6
600
0,4
400
0,2
200
0,0
50
10,6
11,0
11,5
12,0
12,5
50 200
13,1
Chromaticity Coordinate Shift 5) page 18
Farbortverschiebung 5) Seite 18
Cx, Cy = f(IF); TBoard = 25 °C
LE UW U1A4 01
: Cx
: Cy
0,35
0,34
0,33
0,32
0,31
50 200
00 200
10
1
00
15
IF [mA]
2015-08-04
00 200
10
1
00
15
IF [mA]
VF [V]
Cx
Cy 0,36
9
LE UW U1A4 01
Relative Forward Voltage 5) page 18
Relative Vorwärtsspannung 5) Seite 18
ΔVF = VF - VF(25 °C) = f(Tj); IF = 1000 mA
ΦV/ΦV(25 °C) = f(Tj); IF = 1000 mA
LE UW U1A4 01
Φv
∆VF [V]
Φv(25°C)
0,6
LE UW U1A4 01
1,2
: white
1,0
0,4
0,8
0,2
0,6
0,0
-0,2
0,4
-0,4
0,2
-0,6
-40 -20
-40 -20
20 40 60 80 100 120 140
Cx, Cy = f(Tj); IF = 1000 mA
LE UW U1A4 01
: Cx
: Cy
0,35
0,34
0,33
0,32
0,31
0,30
-40 -20
Tj [°C]
2015-08-04
Tj [°C]
Tj [°C]
Cx
Cy
LE UW U1A4 01
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T); 0.7 * ΦV min. of bin 8Q; Rth real max.
I F [mA]
LE UW U1A4 01
1600
1500
1400
1300
1200
1100
1000
900
800
: T B oard
700
600
500
400
300
200
Do not us e below 50 mA
100
60
80
100
120
140
T B oard [°C ]
Permissible Pulse Handling Capability
Zulässige Impulsbelastbarkeit IF = f(tp)
D: Duty cycle
T Board = 0°C ... 112°C
I F [A]
D: Duty cycle
T Board = 135°C
LE UW U1A4 01
2,2
I F [A]
LE UW U1A4 01
2,2
2,0
2,0
1,8
1,8
D
D
D
D
D
D
D
D
= 1.0
= 0.5
= 0.2
= 0.1
= 0.05
= 0.02
= 0.01
= 0.005
1,6
1,4
1,2
1,6
D
D
D
D
D
D
D
D
= 1.0
= 0.5
= 0.2
= 0.1
= 0.05
= 0.02
= 0.01
= 0.005
1,0
0,8
1,4
10 -6
0,6
10 -5
10 -4
10 -3
0,01
0,1
1
10 -6
10
P ulse time [s ]
2015-08-04
10 -5
10 -4
10 -3
0,01
0,1
1
10
P ulse time [s ]
11
LE UW U1A4 01
Package Outline 7) page 18
Maßzeichnung 7) Seite 18
Approximate Weight:
1.8 g
Gewicht:
1.8 g
Note
Percentage of red: >5% acc. to ECE regulation
Percentage of UV: 5% gem. ECE-Richtlinie UV-Anteil:
