GWPSLPS1.CC-KQKS-5R8T-1 数据手册
2014-05-23
DURIS® S 5
Datasheet
Version 1.0
GW PSLPS1.CC
Features:
Besondere Merkmale:
• Package: white SMT package, colored diffused
silicone resin
• Viewing angle at 50 % IV: 120°
• Color: 2700 K - 4000 K ( white )
• CRI: min. 90 ( typ. 97 )
• Luminous Flux: typ. 83 lm @ 3000 K
• Luminous efficacy: typ. 87 lm/W @ 3000 K
• Lumen Maintenance: Testing according to
IESNA LM-80 in progress
• Gehäusetyp: weißes SMT Gehäuse, farbiger
diffuser Silikon-Verguss
• Abstrahlwinkel bei 50 % IV: 120°
• Farbe: 2700 K - 4000 K ( weiß )
• Lichtstrom: typ. 83 lm @ 3000 K
• Lichtausbeute: typ. 87 lm/W @ 3000 K
• Lichtstromerhaltung: Tests nach IESNA LM-80
im Gange
Applications
Anwendungen
• Indoor General Lighting
• Professional downlights
• Retrofits and fixtures
• Innen-Allgemeinbeleuchtung
• Professionelle Downlights
• Retrofits
2014-05-23
1
Version 1.0
GW PSLPS1.CC
Ordering Information
Type:
Typ:
Color
Temperature
Luminous Flux
Farbtemperatur
Lichtstrom
Ordering Code
1) page 24
Bestellnummer
1) Seite 24
IF = 150 mA
[K]
ΦV [lm]
GW PSLPS1.CC-KSKU-5L7N-1
4000
89.2 ... 112
Q65111A5745
GW PSLPS1.CC-KRKT-5L7N-1
4000
82 ... 104.2
Q65111A5747
GW PSLPS1.CC-KRKT-5R8T-1
3000
82 ... 104.2
Q65111A5746
GW PSLPS1.CC-KQKS-5R8T-1
3000
76.3 ... 97
Q65111A5738
GW PSLPS1.CC-KQKS-5U8X-1
2700
76.3 ... 97
Q65111A5743
GW PSLPS1.CC-KPKR-5U8X-1
2700
71 ... 89.2
Q65111A5739
Note:
The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each
packing unit (there will be no mixing of two groups on each packing unit). E. g. GW PSLPS1.CC-KRKT-5R8T-1 means that only one group KR, KS, KT
will be shippable for any packing unit. In order to ensure availability, single brightness groups will not be orderable.
In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing
unit. GW PSLPS1.CC-KRKT-5R8T-1 means that the device will be shipped within the specified limits. In order to ensure availability, single color
chromaticity groups groups will not be orderable (see page 7).
In a similar manner for colors where forward voltage groups are measured and binned, single forward voltage groups will be shipped on any packing
unit. E. g. GW PSLPS1.CC-KRKT-5R8T-1 means that only one forward voltage group C,D,E,F,G will be shippable. In order to ensure availability, single
forward voltage groups will not be orderable (see page 5).
Anm.:
Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es
wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. GW PSLPS1.CC-KRKT-5R8T-1 bedeutet, dass in einer
Verpackungseinheit nur eine der Helligkeitsgruppen KR, KS, KT enhalten ist. Um die Liefersicherheit zu gewährleisten, können einzelne
Helligkeitsgruppen nicht bestellt werden.
Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert.
Z.B. GW PSLPS1.CC-KRKT-5R8T-1 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist (siehe Seite 7). GW
PSLPS1.CC-KRKT-5R8T-1 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. Um die Liefersicherheit zu gewährleisten,
können einzelne Farbortgruppen nicht bestellt werden.
Gleiches gilt für die LEDs, bei denen die Durchlassspannungsgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine
Durchlassspannungsgruppe geliefert. Z. B. GW PSLPS1.CC-KRKT-5R8T-1 bedeutet, dass nach Durchlassspannungsgruppen gruppiert wird. In einer
Verpackungseinheit ist nur eine der Durchlassspannungsgruppen C,D,E,F,G enthalten (siehe Seite 5). Um die Liefersicherheit zu gewährleisten,
können einzelne Durchlassspannungsgruppen nicht direkt bestellt werden.
2014-05-23
2
Version 1.0
GW PSLPS1.CC
Maximum Ratings
Parameter
Symbol
Values
Bezeichnung
Symbol
Operating temperature range
Betriebstemperatur
Top
-40 ... 110
°C
Storage temperature range
Lagertemperatur
Tstg
-40 ... 125
°C
Junction temperature
Sperrschichttemperatur
Tj
125
°C
Forward current
Durchlassstrom
(TS = 25 °C)
IF
10 ... 240
mA
Surge current
Stoßstrom
(t ≤ 10 µs; D = 0.005; TS = 25 °C)
IFM
400
mA
Reverse current 2) page 24
Sperrstrom 2) Seite 24
IR
mA
ESD withstand voltage
ESD Festigkeit
(acc. to ANSI/ESDA/JEDEC JS-001 - HBM)
VESD
up to 5
kV
2014-05-23
3
Werte
Unit
Einheit
Version 1.0
GW PSLPS1.CC
Characteristics (TS = 25 °C; IF = 150 mA)
Parameter
Bezeichnung
Symbol
Values
Symbol
Werte
Unit
Einheit
(typ.)
2ϕ
120
Forward voltage 3) page 24
Durchlassspannung 3) Seite 24
(min.)
(typ.)
(max.)
VF
VF
VF
5.80
6.35
6.80
V
V
V
Reverse voltage
Sperrspannung
(IR = 20 mA)
(max.)
VR
1.2
V
Color reproduction index 4) page 24
Farbwiedergabe Index 4) Seite 24
(typ.)
(min.)
Ra
Ra
97
90
Real thermal resistance junction / solder point
(typ.)
(max.)
Rth JS real
Rth JS real
17
22
K/W
K/W
(typ.)
(max.)
Rth JS el
Rth JS el
12
16
K/W
K/W
5) page 24
Realer Wärmewiderstand Sperrschicht / Lötpad
5) Seite 24
"Electrical" thermal resistance junction / solder
point 5) page 24
"Elektrischer" Wärmewiderstand Sperrschicht /
Lötpad 5) Seite 24
(with efficiency η e = 28 %)
Note:
Individual forward voltage groups see next page
Anm.:
Durchlassspannungsgruppen siehe nächste Seite
2014-05-23
4
Version 1.0
GW PSLPS1.CC
Brightness Groups
Group
Luminous Flux
Luminous Flux
Luminous Intensity
1) page 24
1) page 24
6) page 24
1) Seite 24
Lichtstrom
1) Seite 24
Lichtstärke 6) Seite 24
Gruppe
Lichtstrom
(min.) ΦV [lm]
(max.) ΦV [lm]
KP
71
76.3
24.9
KQ
76.3
82
26.8
KR
82
89.2
29
KS
89.2
97
31.5
KT
97
104.2
34.1
KU
104.2
112
36.6
(typ.) IV [cd]
Note:
The standard shipping format for serial types includes either a lower family group, an upper family group or
a grouping of all individual brightness groups of only a few brightness groups. Individual brightness groups
cannot be ordered.
Anm.:
Die Standardlieferform von Serientypen beinhaltet entweder eine untere Familiengruppe, eine obere
Familiengruppe oder eine Sammelgruppe, die aus nur wenigen Helligkeitsgruppen besteht. Einzelne
Helligkeitsgruppen sind nicht bestellbar.
Forward Voltage Groups 3) page 24
Group
Gruppe
(min.) VF [V]
(max.) VF [V]
C
5.80
6.00
D
6.00
6.20
E
6.20
6.40
F
6.40
6.60
G
6.60
6.80
2014-05-23
5
Version 1.0
GW PSLPS1.CC
Chromaticity Coordinate Groups 7) page 24
Farbortgruppen 7) Seite 24
Cy
520
525
515
530
0.800
540
510
0.700
550
505
560
0.600
570
500
0.500
580
590
495
0.400
600
610
0.300
490
0.200
630
700
485
480
0.100
0.000
0.000
475
470
460
450
0.100
0.200
0.300
0.400
0.500
0.600
Cx
0.700
Coordinates in reference to CIE 1931 (cx cy)
Cy 0.450
2500 K
3000 K
0.430
3500 K
8S
8R
0.410
8Q
4000 K
8O
7P
7N
0.390
6N
7L
0.370
0.350
45
0.330
0.330
00
00
00
40
5J
5I
5H
50
5K
6I
6H
5M
6K
5L
6J
5P
30
3 50
7U 7V
8W
7W
8X
7X
6X
6W
6U 6V
5X
5W
5U 5V
27 0 0
K
00 K
0K
warm white
K
K
K
0.350
0.370
0.390
0.410
0.430
2014-05-23
5S
5R
5Q
5T
8U 8V
5N 5O
6L
7I
7H
6M
7K
7J
6P
6O
6T
6S
6R
6Q
7O
7M
4500 K
5000 K
7Q
7T
7S
7R
8P
neutral white
8T
6
0.450
0.470
0.490
0.510
Cx
Version 1.0
GW PSLPS1.CC
Color Chromaticity Groups 7) page 24
Group
Gruppe
5L
6L
7L
5M
6M
7M
5N
2014-05-23
Cx
Cy
0.3670
0.3578
0.3692
0.3746
Group
Gruppe
Cx
Cy
0.4222
0.3840
0.3677
0.4263
0.3624
0.4298
0.3773
0.3726
0.4342
0.3692
0.3677
0.4263
0.3929
0.3714
0.3775
0.4305
0.4019
0.3773
0.3726
0.4342
0.3957
0.4386
0.4048
0.4305
0.4019
5S
6S
Cx
Cy
0.4477
0.3998
0.3929
0.4526
0.4090
0.3867
0.4534
0.4011
0.3957
0.4585
0.4104
0.4526
0.4090
0.4576
0.4183
0.4585
0.4104
0.4197
0.4183
0.4108
0.4625
0.4275
0.4048
0.4636
0.4197
0.4138
0.4688
0.4290
0.4483
0.3919
0.4534
0.4011
0.4538
0.3931
0.3736
0.3874
0.4346
0.3799
0.3828
0.4386
0.3826
0.3931
0.4430
0.3746
0.3624
0.4346
0.4108
0.3773
0.3726
0.4387
0.4197
0.3822
0.3670
0.4430
0.4138
0.4474
0.4228
0.4298
0.3867
0.3853
0.3776
0.3773
0.3726
0.3799
0.3828
0.4342
0.3853
0.3776
0.4373
0.3885
0.3882
0.4420
0.3799
0.3828
0.4342
0.3957
0.3826
0.3931
0.4386
0.4048
0.3885
0.3882
0.4420
0.3985
0.4468
0.4077
0.4386
0.4048
5T
6T
0.3916
0.3987
0.3822
0.3670
0.3853
0.3776
0.4430
0.3898
0.3716
0.4468
0.3934
0.3825
0.4515
7T
7
7V
0.4636
0.3828
0.3775
8S
6V
0.4576
0.3799
0.3714
7S
Group
Gruppe
8V
5W
0.4591
0.4025
0.4534
0.4011
0.3957
0.4585
0.4104
0.3893
0.4591
0.4025
0.3985
0.4644
0.4118
0.4585
0.4104
0.4636
0.4197
0.4644
0.4118
6W
7W
0.4697
0.4211
0.4636
0.4197
0.4138
0.4688
0.4290
0.4077
0.4697
0.4211
0.4168
0.4750
0.4304
8W
Version 1.0
Group
Gruppe
6N
7N
5R
6R
7R
8R
2014-05-23
GW PSLPS1.CC
Cx
Cy
Group
Gruppe
0.3853
0.3776
0.4430
0.4138
0.3885
0.3882
0.4474
0.4228
0.3934
0.3825
0.4515
0.4168
0.4562
0.4260
0.4373
0.3893
8T
Cx
Cy
0.3970
0.3935
0.3885
0.3882
0.3916
0.3987
0.4420
0.3970
0.3935
0.4428
0.4006
0.4044
0.4477
0.4147
0.3814
0.4420
0.3985
0.4185
0.3902
0.4468
0.4077
0.4222
0.3840
0.4477
0.3998
0.4526
0.4090
0.4468
0.4077
5U
6U
0.3931
0.4591
0.4025
0.4593
0.3944
0.4038
0.3985
0.4644
0.4118
0.3906
0.4648
0.4038
0.3998
0.4703
0.4132
0.4644
0.4118
0.4697
0.4211
0.4703
0.4132
0.3929
0.4223
0.3990
0.4515
0.4263
0.3929
0.4526
0.4305
0.4019
0.4576
0.4223
0.3990
0.4515
0.4168
0.4261
0.4077
0.4562
0.4260
0.4305
0.4019
0.4576
0.4183
0.4625
0.4275
0.4428
0.3906
6X
7X
0.4758
0.4225
0.4697
0.4211
0.4168
0.4750
0.4304
0.4090
0.4758
0.4225
0.4183
0.4813
0.4319
0.4346
0.4108
0.4261
0.4077
0.4299
0.4165
0.4477
0.3998
0.4346
0.4108
0.4483
0.3919
0.4387
0.4197
0.4534
0.4011
8
0.4538
0.4025
0.3902
5V
Cy
0.4648
0.4263
8U
5X
Cx
0.4591
0.4185
7U
Group
Gruppe
8X
Version 1.0
GW PSLPS1.CC
Group Name on Label
Example: KU-6S-D
Beispiel: KU-6S-D
Brightness
Helligkeit
Farbort
Forward Voltage
Durchlassspannung
KU
6S
D
Note:
No packing unit / tape ever contains more than one group for each selection.
Anm.:
In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten.
2014-05-23
9
Version 1.0
GW PSLPS1.CC
Relative Spectral Emission - V(λ) = Standard eye response curve 6) page 24
Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 6) Seite 24
Φrel = f (λ); TS = 25 °C; IF = 150 mA
Irel
GW PSLPS1.CC
1.0
: warm white
: Vλ
0.8
0.6
0.4
0.2
0.0
350
400
450
500
550
600
650
700
750
800
λ [nm]
Radiation Characteristics 6) page 24
Abstrahlcharakteristik 6) Seite 24
Irel = f (ϕ); TS = 25 °C
GW PSLPS1.CC
ϕ [°]
-10°
0°
10°
-20°
20°
30°
40°
50°
60°
70°
80°
90°
1.0
-30°
-40°
0.8
-50°
0.6
-60°
0.4
-70°
0.2
-80°
0.0
-90°
-100°
2014-05-23
10
Irel
Version 1.0
GW PSLPS1.CC
Forward Current 6) page 24
Durchlassstrom 6) Seite 24
IF = f (VF); TS = 25 °C
Relative Luminous Flux 6) page 24
Relativer Lichtstrom 6) Seite 24
ΦV/ΦV (150 mA) = f(IF); TS = 25 °C
GW PSLPS1.CC
ΦV
IF [mA]
GW PSLPS1.CC
1.6
ΦV(150mA)
1.4
200
1.2
1.0
150
0.8
0.6
100
0.4
50
0.2
0.0
10
5.2 5.4 5.6 5.8 6.0 6.2 6.4 6.6 6.8
∆Cx
∆Cy
6) page 24
GW PSLPS1.CC
0.03
: ∆Cx
: ∆Cy
0.02
0.01
0.00
-0.01
-0.02
-0.03
50
IF [mA]
2014-05-23
IF [mA]
VF [V]
Chromaticity Coordinate Shift
Farbortverschiebung 6) Seite 24
Cx, Cy = f(IF); TS = 25 °C
50
11
Version 1.0
GW PSLPS1.CC
Relative Forward Voltage 6) page 24
Relative Vorwärtsspannung 6) Seite 24
ΔVF = VF - VF(25 °C) = f(Tj); IF = 150 mA
∆VF [V]
ΦV/ΦV (25 °C) = f(Tj); IF = 150 mA
Φv
GW PSLPS1.CC
0.4
GW PSLPS1.CC
1.2
Φv(25°C)
0.3
1.0
0.2
0.8
0.1
0.6
0.0
0.4
-0.1
0.2
-0.2
-40
-20
60
80
0.0
-40
100 120
2014-05-23
-20
60
80
100 120
Tj [°C]
Tj [°C]
12
Version 1.0
GW PSLPS1.CC
Chromaticity Coordinate Shift 6) page 24
Cx, Cy = f(Tj); IF = 150 mA
3000 K / 3000 K
4000 K / 4000 K
GW PSLPS1.CC
GW PSLPS1.CC
Cx
Cy
Cx
Cy
0.44
0.390
0.43
0.385
0.42
0.380
0.41
0.375
0.40
0.370
: Cx
: Cy
0.39
-40
-20
: Cx
: Cy
0.365
60
80
100 120
-40
Tj [°C]
2014-05-23
6) page 24
-20
60
80
100 120
Tj [°C]
13
Version 1.0
GW PSLPS1.CC
Max. Permissible Forward Current
Max. zulässiger Durchlassstrom
IF = f (T)
IF [mA]
GW PSLPS1.EC
260
240
220
200
180
160
140
: TS
120
100
80
60
40
Do not use below 10 mA
60
80
100
120
TS [°C]
2014-05-23
14
Version 1.0
GW PSLPS1.CC
Package Outline 8) page 24
Maßzeichnung 8) Seite 24
Current Source / Current Source
Approximate Weight:
17.7 mg
Gewicht:
17.7 mg
Mark:
Cathode
Markierung:
Kathode
ESD information:
LED is protected by ESD device which is
connected in parallel to LED-Chip.
ESD Information:
Die LED enthält ein ESD-Bauteil, das parallel
zum Chip geschaltet ist.
2014-05-23
15
Version 1.0
GW PSLPS1.CC
Recommended Solder Pad 8) page 24
Empfohlenes Lötpaddesign 8) Seite 24
Reflow soldering
Reflow-Löten
Note:
Package not suitable for ultra sonic cleaning.
For superior solder joint connectivity results we
recommend soldering under standard nitrogen
atmosphere.
Anm.:
Das Gehäuse ist für Ultraschallreinigung nicht
geeignet.
Um eine verbesserte Lötstellenkontaktierung zu
erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten.
2014-05-23
16
Version 1.0
GW PSLPS1.CC
Reflow Soldering Profile
Reflow-Lötprofil
Preconditioning: JEDEC Level 3 acc. to JEDEC J-STD-020D.01
OHA04525
300
˚C
T 250
Tp 245 ˚C
240 ˚C
tP
217 ˚C
200
tL
150
tS
100
50
25 ˚C
100
150
200
250
s 300
t
OHA04612
Profile Feature
Profil-Charakteristik
Symbol
Symbol
Pb-Free (SnAgCu) Assembly
Minimum
Ramp-up rate to preheat*)
25 °C to 150 °C
Time tS
TSmin to TSmax
tS
60
Ramp-up rate to peak*)
TSmax to TP
Recommendation
Maximum
2
3
100
120
2
3
Unit
Einheit
K/s
s
K/s
Liquidus temperature
TL
217
Time above liquidus temperature
tL
80
100
s
Peak temperature
TP
245
260
°C
Time within 5 °C of the specified peak
temperature TP - 5 K
tP
s
3
6
K/s
10
Ramp-down rate*
TP to 100 °C
480
Time
25 °C to TP
All temperatures refer to the center of the package, measured on the top of the component
* slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range
2014-05-23
°C
17
s
Version 1.0
GW PSLPS1.CC
Taping 8) page 24
Gurtung 8) Seite 24
2014-05-23
18
Version 1.0
GW PSLPS1.CC
Tape and Reel
Gurtverpackung
12 mm tape with 2000 pcs. on ∅ 180 mm reel
W1
D0
P0
A
N
F
W
E
13.0 ±0.25
P2
Label
P1
Direction of unreeling
W2
Leader: min. 400 mm *
Trailer: min. 160 mm *
*) Dimensions acc. to IEC 60286-3; EIA 481-D
OHAY0324
Tape dimensions in mm (inch)
Tape dim ensions in m m ( inch)
W
P0
P1
P2
D0
E
F
12 +0.3/-0.1
4 ± 0.1
(0.157 ±
0.004)
4 ± 0.1
(0.157 ±
0.004)
or
8 ± 0.1
(0.315 ±
0.004)
2 ± 0.05
(0.079 ±
0.002)
1.5 ± 0.1
(0.059 +
0.004)
1.75 ± 0.1
(0.069 ±
0.004)
5.5 ± 0.05
(0.217 ±
0.002)
Reel dimensions in mm (inch)
Reel dim ensions in m m ( inch)
A
W
Nmin
W1
W2max
180 (7)
12 (0.472)
60 (2.362)
12.4 + 2 (0.488 +
0.079)
18.4 (0.724)
2014-05-23
19
Version 1.0
GW PSLPS1.CC
Barcode-Product-Label (BPL)
Barcode-Produkt-Etikett (BPL)
OSRAM Opto
EX
A
RoHS Compliant
(6P) BATCH NO: 1234567890
(1T) LOT NO: 1234567890
BIN1: XX-XX-X-XXX-X
LX XXXX
Semiconductors
MP
ML Temp ST
X XXX °C X
(9D) D/C: 1234
Pack: RXX
LE
DEMY
XXX
X_X123_1234.1234 X
(X) PROD NO: 123456789(Q)QTY:
9999
(G) GROUP:
XX-XX-X-X
OHA04563
Dry Packing Process and Materials
Trockenverpackung und Materialien
Moisture-sensitive label or print
Barcode label
L
VE
l
LE
k,
see
labe
code
blan
If
bar
(RH
idity
N s IVE RS
Otain
TO
SIT
UC
TIcon
SEN
U
RH
hum
0%
e
tive d
˚C/6
kag
rela are
30
_
infr pac
of
90% to ak
ns
ed (pe
or
rs
e).
ND
Hou
rs
rs
rs
Hou
and ject
ditio
cod
˚C,
72
sing
Hou
e
5
bag E
48
˚C sub
Hou
con
s UR ICO
ces
24 6
dat
40 be
time
˚C
ory
ThiISTSEM
pro
time
or
23
time
at t will ˚C).
or
l with
fact
ent
MO
Flo
time
s
TO
at
or
at
Flo
l
tica
d
tha
or
ival
ure
nth
OP
Flo
4
if: rea
w
Flo
labe
mo ices
iden
5
ced
equ
el
n
e
5a
is
el
ing,
belo
or
24
pro
6
Lev
e
dev
el
cod
e
unt whe
Lev
el
re
ow,
see
bag
Lev
l dat
re
mo
bak
bar
ned
Lev
refl
istu
10%
re
led
time
sea
for
istu
ore>
re
ope e
Mo
see
istu
k,
is
or .
sea is has k,
Mo
bef
istu
d
033
Mo
in
Flo
RH
blan
Mo
or-p blan in
bag
Car
ing,
r
TDlife
(if
If with
t.
r
lf
10%bak or
J-S
thisvapp.
Yea
_
eks rs
r
ed
icat med, C
1
Yea
tem
She
ow,
at
uire not
y
1
WeHou
unt
DE
Afte
Ind
4
uire
refl
is
red req
bod Mo
/JE
time
168
req
2b
a)
Sto ices idity
time
or
is IPC
or
time
b)
ned Flo
or
Hum ing ce
time
or
Dev 2a
e
Flo
a)
ope
or
3.
b) bakren
Flo
1
l dat
Flo
If
2
refe
time el
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
e
Lev
re
Lev
istu
Dat
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
A
C
1.
2.
M
RA
OS
Humidity indicator
Barcode label
Please check the HIC immidiately after
bag opening.
Discard if circles overrun.
Avoid metal contact.
Do not eat.
Comparator
check dot
WET
If wet,
examine units, if necessary
bake units
15%
If wet,
bake units
10%
5%
If wet,
parts still adequately dry.
change desiccant
Humidity Indicator
MIL-I-8835
AM
Desiccant
OSR
OHA00539
Note:
Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card.
Regarding dry pack you will find further information in the internet and in the Short Form Catalog in
chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references
like JEDEC.
Anm.:
Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem
Trockenmittel und einer Feuchteindikatorkarte.
Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form
Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind
Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten.
2014-05-23
Version 1.0
GW PSLPS1.CC
Transportation Packing and Materials
Kartonverpackung und Materialien
Barcode label
DE
MY
8
1
T6
PL 76
R1
Q-
lti LS
TO Y
1+
POU
GR
(G)
Mu
: 01
(9D
D/C
21
00
21
99
8
4
Y:
23
LO
(X)
PR
OD
NO
11
00
(1T
QT
(Q)
H
Se
3G
H1
BA
TC
: 12
(6P
5
NO
T
14
2
O
SR
mi AM
co
nd O
uc pt
to o
rs
NO
see
labe
44
l
k,
N
O
TI
U
A
C
00
L
VE
LE
code (RH
blan
If
y
bar
idit
RH
hum
60%
e
tive d
˚C/
kag
rela are
30
E S
s
_
infr pac
OR
of
tainITIV
90% to ak
urs
CT
e).
or
urs
ted (pe
ons
con NS
Ho
g
urs
SE DU
Ho
and jec
diti
cod
˚C,
72
sin
Ho urs
e
5
bag E ON
48
˚C sub
e
Ho
con
s UR
ces
24 6
dat
e
MIC
40 be
tim
˚C
e
ThiISTSE
pro
tory
tim
or
t
with
23
tim e
at t will ˚C)
or
fac
MO
Flo
al
len
tim
s
TO
at
or
at
Flo
d
or
iva
ure
el
nth s tha
OP
ntic
Flo
4
if: rea
Flo
lab
ow
mo ice equ
ide
5
ced
el
e
5a
is
el
ingen
bel
or
24
pro
6
Lev
e
dev,
el
cod
e
unt wh
Lev
el
re
ow
see
bag
Lev
l dat
re
mo
bak
e
bar
ned
Lev
refl
istu
10%
re
tim
sea
for
istu
ore>
re
ope e
Mo
see
3
istu
is
or .
sea is has
Mo
nk,
bef
istu
nk, Flo
rd
-03
Mo
in
RH
bla
Mo
or-p bla in
bag
ingCa
r
TD
life
(if
If with
t.
r
lf
vapp.
10%baktor
J-S
this
Yea
_
eks
r
ed
ica med, C
1
urs
Yea
tem
She
ow
at
uire not
y
1
WeHo
unt
DE
Afte
Ind
1.
e
4
uire
refl
red req
2.
bod Mo
e
ity is
/JE
tim
s
168
req
e
2b
a)
Sto
tim
or
mid
is IPC
tim e
vice or
b)
ned Flo
or
Hu
tim
ing ce
or
De
e
2a
Flo
a)
ope
or
3.
b) bakren
Flo
e
1
l dat
Flo
If
2
el
refe
tim
2a
4.
el
sea
3
Lev
el
and
Lev
el
re
Bag
te
Lev
re
Lev
istu
Da
re
istu
re
Mo
istu
Mo
istu
Mo
Mo
P:
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Tem
2a
220
3
240 p ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
Barcode label
DE
MY
1
T6
PL 76
R1
8
lti LS
TO Y
Mu
1+
Q-
P:
PGR
(G)
44
: 01
D/C
(9D
QT
Y:
LO
(1T
OD
NO
M
RA
OS
(X)
PR
5
14 2
110 0
(Q)
ico AM
nd O
uc pt
to o
rs
SR
NO
23
4
m
O
H
H1
Se
3G
TC
998
NO
: 12
BA
021
T
(6P
210
OU
Muster
ED Bin
Bin 1:
Bin 2: P-1
3: Q-1 -20
ML
-20
2
Te
2a
220 mp
3
240
ST
Ad 260 C R
C
R0 diti
R
ona C RT
PA 77
l TE
CK
VA
XT
R:
led
Packing
Sealing label
OHA02044
Width / Breite
Length / Länge
Height / Höhe
195 ± 5 (7.677 ± 0.1968)
30 ± 5 (1.181 ± 0.196)
2014-05-23
21
Version 1.0
GW PSLPS1.CC
Notes
Hinweise
The evaluation of eye safety occurs according to the
standard IEC 62471:2008 ("photobiological safety of
lamps and lamp systems"). Within the risk grouping
system of this CIE standard, the LED specified in this
data sheet fall into the class Low risk (exposure time
100 s). Under real circumstances (for exposure time,
eye pupils, observation distance), it is assumed that
no endangerment to the eye exists from these
devices. As a matter of principle, however, it should
be mentioned that intense light sources have a high
secondary exposure potential due to their blinding
effect. As is also true when viewing other bright light
sources (e.g. headlights), temporary reduction in
visual acuity and afterimages can occur, leading to
irritation, annoyance, visual impairment, and even
accidents, depending on the situation.
Die Bewertung der Augensicherheit erfolgt nach
dem Standard IEC 62471:2008 ("photobiological
safety of lamps and lamp systems"). Im
Risikogruppensystem dieser CIE- Norm erfüllen die
in diesem Datenblatt angegebenen LEDs folgende
Gruppenanforderung - Low risk (Expositionsdauer
100 s). Unter realen Umständen (für
Expositionsdauer, Augenpupille,
Betrachtungsabstand) geht damit von diesen
Bauelementen keinerlei Augengefährdung aus.
Grundsätzlich sollte jedoch erwähnt werden, dass
intensive Lichtquellen durch ihre Blendwirkung ein
hohes sekundäres Gefahrenpotenzial besitzen.
Nach einem Blick in eine helle Lichtquelle (z.B.
Autoscheinwerfer), kann ein temporär
eingeschränktes Sehvermögen oder auch
Nachbilder zu Irritationen, Belästigungen,
Beeinträchtigungen oder sogar Unfällen führen.
This LED contains metal materials. Corroded metal
may lead to a worsening of the optical performance
of the LED and can in the worst case lead to a failure
of the LED. Do not expose this LED to aggressive
atmospheres. Note, that corrosive gases may as
well be emitted from materials close to the LED in the
final product.
Diese LED enthält teilweise metallische
Bestandteile. Korrodiertes Metall kann zu einer
Verschlechterung der optischen Eigenschaften und
im schlimmsten Fall zum Ausfall der LED führen.
Diese LED darf aggressiven Bedingungen nicht
ausgesetzt werden. Es ist zu beachten, dass
korrosive Gase auch von Materialien emittiert
werden können, die sich im Endprodukt in
unmittelbarer Umgebung der LED befinden.
For further application related informations
please visit www.osram-os.com/appnotes
Für weitere applikationsspezifische
Informationen besuchen Sie bitte
Change management for this component is aligned
with the requirements of the lighting market.
Das Änderungsmanagement dieses Bauteils ist an
den Anforderungen des Lichtmarktes ausgerichtet.
2014-05-23
22
Version 1.0
GW PSLPS1.CC
Disclaimer
Disclaimer
Attention please!
The information describes the type of component and
shall not be considered as assured characteristics.
Terms of delivery and rights to change design reserved.
Due to technical requirements components may contain
dangerous substances.
For information on the types in question please contact
our Sales Organization.
If printed or downloaded, please find the latest version in
the Internet.
Packing
Please use the recycling operators known to you. We
can also help you – get in touch with your nearest sales
office.
By agreement we will take packing material back, if it is
sorted. You must bear the costs of transport. For
packing material that is returned to us unsorted or which
we are not obliged to accept, we shall have to invoice
you for any costs incurred.
Components used in life-support devices or
systems must be expressly authorized for such
purpose!
Critical components* may only be used in life-support
devices** or systems with the express written approval
of OSRAM OS.
Bitte beachten!
Lieferbedingungen und Änderungen im Design
vorbehalten. Aufgrund technischer Anforderungen
können die Bauteile Gefahrstoffe enthalten. Für weitere
Informationen zu gewünschten Bauteilen, wenden Sie
sich bitte an unseren Vertrieb. Falls Sie dieses
Datenblatt ausgedruckt oder heruntergeladen haben,
finden Sie die aktuellste Version im Internet.
Verpackung
Benutzen Sie bitte die Ihnen bekannten Recyclingwege.
Wenn diese nicht bekannt sein sollten, wenden Sie sich
bitte an das nächstgelegene Vertriebsbüro. Wir nehmen
das Verpackungsmaterial zurück, falls dies vereinbart
wurde und das Material sortiert ist. Sie tragen die
Transportkosten. Für Verpackungsmaterial, das
unsortiert an uns zurückgeschickt wird oder das wir nicht
annehmen müssen, stellen wir Ihnen die anfallenden
Kosten in Rechnung.
Bauteile, die in lebenserhaltenden Apparaten und
Systemen eingesetzt werden, müssen für diese
Zwecke ausdrücklich zugelassen sein!
Kritische Bauteile* dürfen in lebenserhaltenden
Apparaten und Systemen** nur dann eingesetzt
werden, wenn ein schriftliches Einverständnis von
OSRAM OS vorliegt.
*) A critical component is a component used in a
life-support device or system whose failure can
reasonably be expected to cause the failure of that
life-support device or system, or to affect its safety or the
effectiveness of that device or system.
**) Life support devices or systems are intended (a) to be
implanted in the human body, or (b) to support and/or
maintain and sustain human life. If they fail, it is
reasonable to assume that the health and the life of the
user may be endangered.
*) Ein kritisches Bauteil ist ein Bauteil, das in
lebenserhaltenden
Apparaten
oder
Systemen
eingesetzt wird und dessen Defekt voraussichtlich zu
einer Fehlfunktion dieses lebenserhaltenden Apparates
oder Systems führen wird oder die Sicherheit oder
Effektivität
dieses
Apparates
oder
Systems
beeinträchtigt.
**) Lebenserhaltende Apparate oder Systeme sind für
(a) die Implantierung in den menschlichen Körper oder
(b) für die Lebenserhaltung bestimmt. Falls Sie
versagen, kann davon ausgegangen werden, dass die
Gesundheit und das Leben des Patienten in Gefahr ist.
2014-05-23
23
Version 1.0
GW PSLPS1.CC
Glossary
Glossar
1)
Brightness: Brightness groups are tested at a
current pulse duration of 25 ms and a tolerance of
± 11%.
1)
Helligkeit: Helligkeitswerte werden mit
Stromeinprägedauer von 25 ms und
Genauigkeit von ± 11% ermittelt.
2)
Reverse Operation: A minimum of 10 hours of
reverse operation is permisable in total.
2)
Betrieb in Sperrrichtung: Eine Gesamtbetriebszeit
von wenigstens 10 Stunden in Sperrrichtung ist
gewährleistet.
3)
Forward Voltage: Forward voltages are tested at a
current pulse duration of 1 ms and a tolerance of ±
0.1 V.
3)
Durchlassspannung: Spannungswerte werden mit
einer Stromeinprägedauer von 1 ms und einer
Genauigkeit von ± 0,1 V ermittelt.
4)
Color reproduction index: Color
reproduction
index values (CRI-RA) are measured during a
current pulse of typically 25 ms and with a tolerance
of ± 3.
4)
Farbwiedergabe Index: Werte
des
Farbwiedergabe Index (CRI-RA) werden während
eines Strompulses einer typischen Dauer von 25 ms
und mit einer Genauigkeit ± 3 gemessen.
5)
Thermal Resistance: Rth max is based on statistic
values (6σ).
5)
Wärmewiderstand: Rth
statistischen Werten (6σ).
6)
Typical Values: Due to the special conditions of the
manufacturing processes of LED, the typical data or
calculated correlations of technical parameters can
only reflect statistical figures. These do not
necessarily correspond to the actual parameters of
each single product, which could differ from the
typical data and calculated correlations or the typical
characteristic line. If requested, e.g. because of
technical improvements, these typ. data will be
changed without any further notice.
6)
Typische Werte: Wegen
der
besonderen
Prozessbedingungen bei der Herstellung von LED
können typische oder abgeleitete technische
Parameter nur aufgrund statistischer Werte
wiedergegeben werden. Diese stimmen nicht
notwendigerweise mit den Werten jedes einzelnen
Produktes überein, dessen Werte sich von typischen
und abgeleiteten Werten oder typischen Kennlinien
unterscheiden können. Falls erforderlich, z.B.
aufgrund technischer Verbesserungen, werden
diese typischen Werte ohne weitere Ankündigung
geändert.
7)
Chromaticity coordinate groups: Chromaticity
coordinate groups are tested at a current pulse
duration of 25 ms and a tolerance of ±0.01.
7)
Farbortgruppen: Farbortgruppen werden mit einer
Stromeinprägedauer von 25 ms und einer
Genauigkeit von ±0,01 ermittelt.
8)
Tolerance of Measure: Unless otherwise noted in
drawing, tolerances are specified with ±0.1 and
dimensions are specified in mm.
8)
Maßtoleranz: Wenn in der Zeichnung nicht anders
angegeben, gilt eine Toleranz von ±0,1. Maße
werden in mm angegeben.
2014-05-23
24
max
basiert
einer
einer
auf
Version 1.0
GW PSLPS1.CC
Published by OSRAM Opto Semiconductors GmbH
Leibnizstraße 4, D-93055 Regensburg
www.osram-os.com © All Rights Reserved.
2014-05-23
25
