CWCBLPM1.CN-MXMZ-T4-0-A00-R18
    AMSOSRAM(艾迈斯半导体)
    LEDCERAMOS
CWCBLPM1.CN-MXMZ-T4-0-A00-R18 数据手册
2015-09-28 CERAMOS Gen 3 Datasheet Version 1.0 CW CBLPM1.CN Highly efficient lightsource, slim package design Hocheffiziente Lichtquelle, niedrige Bauteilhöhe Features: • Package: SMD ceramic package with silicone resin • Technology: ThinGaN (UX:3) • Viewing angle at 50 % IV: 120° (Lambertian Emitter) • Color: Cx = 0.38, Cy = 0.38 acc. to CIE 1931 (white); CRI (typ.) = 90; CTR = 4000 K • ESD - withstand voltage: 2 kV acc. to ANSI/ESDA/JEDEC JS-001 (HBM, Class 2); 8 kV acc. to IEC 61000-4-2, level 4 (contact discharge) Besondere Merkmale: • Gehäusetyp: SMD Keramik Gehäuse mit Silikonverguss • Technologie: ThinGaN (UX:3) • Abstrahlwinkel bei 50 % IV: 120° (Lambertscher Strahler) • Farbe: Cx = 0.38, Cy = 0.38 nach CIE 1931 (weiß); CRI (typ.) = 90; CTR = 4000 K • ESD - Festigkeit: 2 kV nach ANSI/ESDA/JEDEC JS-001 (HBM, Klasse 2); 8 kV nach IEC 61000-4-2, level 4 (Kontaktentladung) Applications • Camera Flash and Video Light • Torch Light Anwendungen • Blitzlicht für Kameras/ Videoleuchte • Taschenlampe 2015-09-28 1 Version 1.0 CW CBLPM1.CN Ordering Information Bestellinformation Type: Luminous Flux 1) page 21 Ordering Code Typ: Lichtstrom 1) Seite 21 Bestellnummer IF = 1000 mA ΦV [lm] CW CBLPM1.CN-MXMZ-T4 Note: 180 ... 280 Q65111A8546 The above Type Numbers represent the order groups which include only a few brightness groups (see page 5). Only one group will be shipped on each packing unit (there will be no mixing of two groups on each packing unit). E. g. CW CBLPM1.CN-MXMZ-T4 means that only one group MX, MY, MZ will be shippable for any packing unit. In a similar manner for colors where color chromaticity coordinate groups are measured and binned, single groups will be shipped on any one packing unit. CW CBLPM1.CN-MXMZ-T4 means that the device will be shipped within the specified limits. Anm.: Die oben genannten Typbezeichnungen umfassen die bestellbaren Selektionen. Diese bestehen aus wenigen Helligkeitsgruppen (siehe Seite 5). Es wird nur eine einzige Helligkeitsgruppe pro Verpackungseinheit geliefert. Z. B. CW CBLPM1.CN-MXMZ-T4 bedeutet, dass in einer Verpackungseinheit nur eine der Helligkeitsgruppen MX, MY, MZ enhalten ist. Gleiches gilt für die Farben, bei denen Farbortgruppen gemessen und gruppiert werden. Pro Verpackungseinheit wird nur eine Farbortgruppe geliefert. Z.B. CW CBLPM1.CN-MXMZ-T4 bedeutet, dass in einer Verpackungseinheit nur eine der Farbortgruppen enthalten ist. CW CBLPM1.CN-MXMZ-T4 bedeutet, dass das Bauteil innerhalb der spezifizierten Grenzen geliefert wird. 2015-09-28 2 Version 1.0 CW CBLPM1.CN Maximum Ratings Grenzwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Operating temperature range Betriebstemperatur Top -40 ... 85 °C Storage temperature range Lagertemperatur Tstg -40 ... 85 °C Junction temperature 2) page 21 Sperrschichttemperatur 2) Seite 21 Tj 150 °C Junction temperature pulsed 3) page 21 Sperrschichttemperatur gepulst 3) Seite 21 Tj 175 °C Forward current 2) page 21 Durchlassstrom 2) Seite 21 IF 30 ... 500 mA Forward current pulsed 3) page 21 Durchlassstrom gepulst 3) Seite 21 IF pulse 30 ... 2000 mA Reverse voltage Sperrspannung (TS = 25 °C) VR 2015-09-28 3 not designed for reverse operation V Version 1.0 CW CBLPM1.CN Characteristics (TS = 25 °C; IF = 1000 mA) Kennwerte Parameter Symbol Values Unit Bezeichnung Symbol Werte Einheit Chromaticity coordinates acc. to CIE 1931 4) page 21 Farbkoordinaten nach CIE 1931 4) Seite 21 (typ.) (typ.) Cx Cy 0.38 0.38 - Viewing angle at 50 % IV Abstrahlwinkel bei 50 % IV (typ.) 2ϕ 120 ° Forward voltage 5) page 21 Durchlassspannung 5) Seite 21 (min.) (typ.) (max.) VF VF VF 2.70 3.05 3.70 V V V IR not designed for reverse operation Ra 90 - Rth JS el 8.0 K/W Reverse current Sperrstrom Color rendering index 6) page 21 Farbwiedergabe Index 6) Seite 21 (typ.) "Electrical" thermal resistance junction / solder point (typ.) 7) page 21 "Elektrischer" Wärmewiderstand Sperrschicht / Lötpad 7) Seite 21 (acc. to JEDEC 51-14 and 51-51, with efficiency ηe = 27 %) 2015-09-28 4 Version 1.0 CW CBLPM1.CN Brightness Groups Helligkeitsgruppen Group Luminous Flux 1) page 21 Luminous Flux 1) page 21 Luminous Intensity 8) page 22 Lichtstrom 1) Seite 21 Lichtstrom 1) Seite 21 Lichtstärke 8) Seite 22 (min.) ΦV [lm] (max.) ΦV [lm] (typ.) IV [cd] MX 180 210 58.5 MY 210 240 67.5 MZ 240 280 78 Gruppe 2015-09-28 5 Version 1.0 CW CBLPM1.CN Chromaticity Coordinate Groups 4) page 21 Farbortgruppen 4) Seite 21 0.41 0.90 0.85 Cy Cy 0.80 0.40 0.75 0.70 0.65 0.39 0.60 T4 0.55 0.38 4500 K 0.50 0.45 0.40 0.37 0.35 0.30 0.36 0.25 0.20 0.15 0.35 0.10 0.05 Color Chromaticity Groups 4) page 21 Farbortgruppen 4) Seite 21 T4 2015-09-28 Cx Cy 0.3670 0.3578 0.3736 0.3874 0.3898 0.3716 0.4006 0.4044 0.41 0.40 0.39 0.38 Cx Cx Group Gruppe 0.37 0.36 0.75 0.70 0.65 0.60 0.55 0.50 0.45 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0.34 0.00 0.00 6 Version 1.0 CW CBLPM1.CN Group Name on Label Gruppenbezeichnung auf Etikett Example: MX-T4 Beispiel: MX-T4 Brightness Helligkeit Chromaticity Coordinate Farbort MX T4 Note: No packing unit / tape ever contains more than one group for each selection. Anm.: In einer Verpackungseinheit / Gurt ist immer nur eine Gruppe für jede Selektion enthalten. 2015-09-28 7 Version 1.0 CW CBLPM1.CN Relative Spectral Emission - V(λ) = Standard eye response curve 8) page 22 Relative spektrale Emission - V(λ) = spektrale Augenempfindlichkeit 8) Seite 22 Φrel = f (λ); TJ = 25 °C; IF = 1000 mA Irel CW CBLPM1.CN 1.0 : Vλ 0.8 0.6 0.4 0.2 0.0 350 400 450 500 550 600 650 700 750 800 λ [nm] Radiation Characteristics 8) page 22 Abstrahlcharakteristik 8) Seite 22 Irel = f (ϕ); TJ = 25 °C 40˚ 30˚ 20˚ 10˚ 0˚ ϕ 50˚ OHL01660 1.0 0.8 0.6 60˚ 0.4 70˚ 0.2 80˚ 0 90˚ 100˚ 1.0 2015-09-28 0.8 0.6 0.4 0˚ 20˚ 8 40˚ 60˚ 80˚ 100˚ 120˚ Version 1.0 CW CBLPM1.CN Relative Luminous Flux 8) page 22 , 9) page 22 Relativer Lichtstrom 8) Seite 22 , 9) Seite 22 ΦV/ΦV(1000 mA) = f(IF); TJ = 25 °C Forward Current 8) page 22 , 9) page 22 Durchlassstrom 8) Seite 22 , 9) Seite 22 IF = f (VF); TJ = 25 °C IF [mA] ΦV CW CBLPM1.CN 2000 CW CBLPM1.CN 1.8 ΦV(1000mA) 1.6 1.4 1500 1.2 1.0 1000 0.8 0.6 0.4 500 0.2 0.0 0 0 2.5 2.6 2.8 3.0 3.2 3.4 VF [V] CW CBLPM1.CN 0.03 0.02 0.01 0.00 -0.01 -0.02 : ∆ Cx : ∆ Cy - -0.03 0 0 50 00 10 0 15 0 20 00 IF [mA] 2015-09-28 00 10 0 15 0 20 IF [mA] Chromaticity Coordinate Shift 8) page 22 Farbortverschiebung 8) Seite 22 ΔCx, ΔCy = f(IF); TJ = 25 °C ∆Cx ∆Cy 0 50 9 00 Version 1.0 CW CBLPM1.CN Max. Permissible Forward Current Max. zulässiger Durchlassstrom IF = f (T) IF [mA] CW CBLPM1.CN 550 500 Note: 450 Deratings strongly relate on the boundary conditions of each individual device: • The DC-derating on the left represents several thermal resistance values Rth JA (Junction/Ambient) as examples. • The shown pulse-deratings represent just one of alterative options for use. For further information please refer to application note „Thermal Management of Flash LEDs“. 400 350 : 160 K/W : 110 K/W : 60 K/W : 18 K/W 300 250 200 150 100 50 Do not use below 30 mA 0 0 20 40 60 80 T [°C] Permissible Pulse Handling Capability Zulässige Impulsbelastbarkeit IF = f(tp) Rth JA el = 160 K/W; TA = 25°C; still air; FR4 Permissible Pulse Handling Capability Zulässige Impulsbelastbarkeit IF = f(tp) Rth JA el = 160K/W; TA = 85°C; still air; FR4 CW CBLPM1.CN CW CBLPM1.CN IF [A] 2.5 IF [A] 2.5 2.0 2.0 1.5 1.5 1.0 1.0 0.5 0.0 10-5 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 10-4 10-3 0.5 0.01 0.1 1 0.0 10-5 10 Pulse time [s] 2015-09-28 : D = 0.2 : D = 0.1 : D = 0.05 : D = 0.02 : D = 0.01 : D = 0.005 10-4 10-3 0.01 0.1 1 10 Pulse time [s] 10 Version 1.0 CW CBLPM1.CN Package Outline 10) page 22 Maßzeichnung 10) Seite 22 Approximate Weight: 8.2 mg Gewicht: 8.2 mg Mark: Cathode Markierung: Kathode ESD information: LED is protected by ESD device which is connected in parallel to LED-Chip. ESD Information: Die LED enthält ein ESD-Bauteil, das parallel zum Chip geschaltet ist. 2015-09-28 11 Version 1.0 CW CBLPM1.CN Electrical Internal Circuit Internes Elektrisches Schaltbild 2015-09-28 12 Version 1.0 Recommended Solder Pad 10) page 22 Empfohlenes Lötpaddesign 10) Seite 22 CW CBLPM1.CN Reflow soldering Reflow-Löten Note: For superior solder joint connectivity results we recommend soldering under standard nitrogen atmosphere. Package not suitable for ultra sonic cleaning. Anm.: Um eine verbesserte Lötstellenkontaktierung zu erreichen, empfehlen wir, unter StandardStickstoffatmosphäre zu löten. Das Gehäuse ist für Ultraschallreinigung nicht geeignet. 2015-09-28 13 Version 1.0 CW CBLPM1.CN Reflow Soldering Profile Reflow-Lötprofil Product complies to MSL Level 2 acc. to JEDEC J-STD-020D.01 OHA04525 300 ˚C T 250 Tp 245 ˚C 240 ˚C tP 217 ˚C 200 tL 150 tS 100 50 25 ˚C 0 0 50 100 150 200 s 300 250 t OHA04612 Symbol Symbol Profile Feature Profil-Charakteristik Pb-Free (SnAgCu) Assembly Minimum ) Ramp-up rate to preheat* 25 °C to 150 °C Time tS TSmin to TSmax tS 60 Ramp-up rate to peak*) TSmax to TP Recommendation Maximum 2 3 100 120 2 3 Unit Einheit K/s s K/s Liquidus temperature TL 217 Time above liquidus temperature tL 80 100 s Peak temperature TP 245 260 °C Time within 5 °C of the specified peak temperature TP - 5 K tP 20 30 s 3 6 K/s 10 Ramp-down rate* TP to 100 °C 480 Time 25 °C to TP All temperatures refer to the center of the package, measured on the top of the component * slope calculation DT/Dt: Dt max. 5 s; fulfillment for the whole T-range 2015-09-28 °C 14 s Version 1.0 CW CBLPM1.CN Taping 10) page 22 Gurtung 10) Seite 22 2015-09-28 15 Version 1.0 CW CBLPM1.CN Tape and Reel Gurtverpackung 8 mm tape with 4000 pcs. on ∅ 180 mm reel W1 D0 P0 A N F W E 13.0 ±0.25 P2 Label P1 Direction of unreeling Direction of unreeling W2 Leader: min. 400 mm * Trailer: min. 160 mm * *) Dimensions acc. to IEC 60286-3; EIA 481-D OHAY0324 Tape dimensions [mm] Gurtmaße [mm] Tape dim ensions in m m W P0 P1 P2 D0 E F 8 + 0.3 / -0.1 4 ± 0.1 2 ± 0.05 or 4 ± 0.1 2 ± 0.05 1.5 ± 0.1 1.75 ± 0.1 3.5 ± 0.05 Reel dimensions [mm] Rollenmaße [mm] Reel dim ensions in m m A W Nmin W1 W2max 180 8 60 8.4 + 2 14.4 2015-09-28 16 Version 1.0 CW CBLPM1.CN Barcode-Product-Label (BPL) Barcode-Produkt-Etikett (BPL) OSRAM Opto EX A RoHS Compliant (6P) BATCH NO: 1234567890 (1T) LOT NO: 1234567890 BIN1: XX-XX-X-XXX-X LX XXXX Semiconductors MP ML Temp ST X XXX °C X (9D) D/C: 1234 Pack: RXX LE DEMY XXX X_X123_1234.1234 X (X) PROD NO: 123456789(Q)QTY: 9999 (G) GROUP: XX-XX-X-X OHA04563 Dry Packing Process and Materials Trockenverpackung und Materialien Moisture-sensitive label or print L VE el LE see . lab e H) nk, (R bla cod If y bar . dit RH mi % hu e /60 ve ed ag ˚C ati rar ck rel 30 s VE RS _ < inf pa % ainITI TO of to ak 90 urs d nt ). < ns (pe or urs d co NSUC Ho de , cte itio urs g SEND Ho an bje ing co ˚C 72 nd Ho urs 5 baRE CO te 48 ˚C su ss e Ho co ± ce is 24 6 da e y MI 40 be tim ˚C e ThISTU th < tor ll pro tim SE or ). 23 tim e at t wi nt˚C or l wi fac MO Flo tim s TO at or ca at re. Flo d tha ale el or nth OP nti Flo uiv du if: rea es l 4 5 Flo lab mo ide ce eq low g, l ve vic is be or de 24 tin en l 5a6 pro ve Le de , e te co , g: ve l un wh Le ke r se da ve % ure ba ed low ba Le mo ba e al d ure Le ist en ref e e 10 tim ure se for ist ale op se for > , Mo se 3 ist ure is or . , is ha se Mo nk be ist nk rd g -03 Mo in n Flo r-p RH g, bla Mo ba TD po If blathi % kin Ca life s (if ar t. wi 10 ba tor J-S thi, va p. elf Ye ar ks _ < e icat me , C 1 Ye ee urs Sh terlow tem ted at ed uir > 1 W Ho un Af Indno uir DE 1. d e 4 8 ref dy reqy is 2. JE bo e Mo ore tim 16 req : C/ e es dit2b a) St tim or mi IP ed or g is tim e vic b) or e Hu Flo en tim or De 2a kin nc te Flo a) op or 3. b) baere Flo da e l 1 2 Flo If al ref tim ve l 4. se d l 2a3 ve Le g an ve l Le Ba te ure Le ve ure Le ist Da ure ist Mo ist ure Mo ist Mo Mo Barcode label N TIO U A C M RA OS Humidity indicator Barcode label Please check the HIC immidiately after bag opening. Discard if circles overrun. Avoid metal contact. Do not eat. Comparator check dot WET If wet, examine units, if necessary bake units 15% If wet, examine units, if necessary bake units 10% 5% If wet, parts still adequately dry. change desiccant Humidity Indicator MIL-I-8835 AM OSR Desiccant OHA00539 Note: Moisture-sensitive product is packed in a dry bag containing desiccant and a humidity card. Regarding dry pack you will find further information in the internet and in the Short Form Catalog in chapter “Tape and Reel” under the topic “Dry Pack”. Here you will also find the normative references like JEDEC. Anm.: Feuchteempfindliche Produkte sind verpackt in einem Trockenbeutel zusammen mit einem Trockenmittel und einer Feuchteindikatorkarte. Bezüglich Trockenverpackung finden Sie weitere Hinweise im Internet und in unserem Short Form Catalog im Kapitel “Gurtung und Verpackung” unter dem Punkt “Trockenverpackung”. Hier sind Normenbezüge, unter anderem ein Auszug der JEDEC-Norm, enthalten. 2015-09-28 17 Version 1.0 CW CBLPM1.CN Transportation Packing and Materials Kartonverpackung und Materialien Barcode label 8 Y M DE R 18 -1 Q P -1 + P: C: 99 D/ 21 00 (9 D) 21 : 20 00 : 14 2 5 (Q )Q TY O H 12 34 S S em R ic AM on du O p ct to or H NO s TC 3G BA (6 P) NO : 12 11 00 LO T (1 T) NO : OD PR ) (X 44 (G ) G RO UP : P -1 + Q -1 R 18 DE M Y Bi n2 : Pn3 : Q 1: -1 20 M -2 2 L 0 Te 2a 22 m 3 24 0 p ST Ad 26 0 C R C R0 ditio 0 C R PA 77 na RT l TE CK VA XT R: M u L lt S iT Y O T P 67 L 6 E Bi D Bi n1 D) (9 : 20 00 D/ C: 01 Muster TY )Q : 34 : NO O PR (X ) Packing Sealing label Dimensions of transportation box in mm Width Length Height Breite Länge Höhe 200 ± 5 195 ± 5 30 ± 5 2015-09-28 M RA OS D 5 14 2 110 0 (Q O S TC (1 T) LO T NO (6 P) : 12 BA S 8 3G em R ic AM o n O d u p ct to o H rs NO 2199 H 12 2100 01 44 el A C OU L GR E V LE see . lab e H) nk, cod (R bla r If ty ba . idi RH m hu 0% e /6 ive d ˚C re ag lat ra ck re 30 _ < inf pa % k s of to 90 ea ur s d ). < ns (p or ur s d Ho de , cteg itio ur s Ho an bje co ˚C 72 sin nd Ho ur 5 te 48 ˚C su es e Ho IC co ± is UR 24 6 da e M 40 be oc ry tim ˚C e Th STSE r th < ll pr tim cto ). r OI oo 23 wi nt tim e at l wi fa r M TO Fl oo tim s at at ale ˚C at e. ica Fl th oo r th ur el OP nt Fl oo on es uiv if: read ed l 4 5 Fl , lab m ide eq low l oc ve vic is ingen be or de 24 l 5a6 pr ve Le de nt wh e te co , w, g: ve l Le ke r re ou se da ba ed flo Le ve tu re m % ba e ba al d Le r en re tu re e re 10 ois tim se fo tu re ale op se fo > , M r se ois 3 is , is ha se M ois tu nk be oo . 03 nk rd g M ois in r-p bla in Fl RH g, DM ba po If blath % kin Ca life is (if . ar ST p. wi 10 baator et Jelf r th va Ye ar ks s m _ < m ed 1 Ye ee ur d, C iredic t Sh te w, te at nt > 1 W Ho Af flody qu In no ire DE 1. e 4 8 ou re ed re ty is qu JE 2. bo e M or tim 16 re C/ : e es idi 2b r a) St tim mor is IP ed r oo tim e vic b) g e r Hu Fl en oo tim De 2a kin nc te Fl oo r a) op 3. b) ba re Fl oo da e fe l 1 2 Fl If al re tim ve l 4. se d l 2a3 ve Le g an ve l Le re Ba te Le ve tu re Le tu Da ois re tu re M ois M ois tu M ois M Nns IVEORS ai IT CT nt TIO co NS DU g SE U ba E ON (G ) M u L lt S iT Y O T67 P L 6 Muster E Bi D Bi n1 Bi n2 : Pn3 : Q- 1: 1- 20 M 20 2 L Te 2a 22 m 3 24 0 p ST Ad 26 0 C R 0 C R0 dit ion C R PA 77 al RT CK TE VA XT R: Barcode label 18 OHA02044 Version 1.0 CW CBLPM1.CN Notes Hinweise The evaluation of eye safety occurs according to the standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Within the risk grouping system of this CIE standard, the LED specified in this data sheet fall into the class Exempt group (exposure time 10000 s). Under real circumstances (for exposure time, eye pupils, observation distance), it is assumed that no endangerment to the eye exists from these devices. As a matter of principle, however, it should be mentioned that intense light sources have a high secondary exposure potential due to their blinding effect. As is also true when viewing other bright light sources (e.g. headlights), temporary reduction in visual acuity and afterimages can occur, leading to irritation, annoyance, visual impairment, and even accidents, depending on the situation. Die Bewertung der Augensicherheit erfolgt nach dem Standard IEC 62471:2008 ("photobiological safety of lamps and lamp systems"). Im Risikogruppensystem dieser CIE- Norm erfüllen die in diesem Datenblatt angegebenen LEDs folgende Gruppenanforderung - Exempt group (Expositionsdauer 10000 s). Unter realen Umständen (für Expositionsdauer, Augenpupille, Betrachtungsabstand) geht damit von diesen Bauelementen keinerlei Augengefährdung aus. Grundsätzlich sollte jedoch erwähnt werden, dass intensive Lichtquellen durch ihre Blendwirkung ein hohes sekundäres Gefahrenpotenzial besitzen. Nach einem Blick in eine helle Lichtquelle (z.B. Autoscheinwerfer), kann ein temporär eingeschränktes Sehvermögen oder auch Nachbilder zu Irritationen, Belästigungen, Beeinträchtigungen oder sogar Unfällen führen. For further application related informations please visit www.osram-os.com/appnotes Für weitere applikationsspezifische Informationen besuchen Sie bitte www.osram-os.com/appnotes 2015-09-28 19 Version 1.0 CW CBLPM1.CN Disclaimer Disclaimer Language english will prevail in case of any discrepancies or deviations between the two language wordings. Bei abweichenden Angaben im zweisprachigen Wortlaut haben die Angaben in englischer Sprache Vorrang. Attention please! The information describes the type of component and shall not be considered as assured characteristics. Terms of delivery and rights to change design reserved. Due to technical requirements components may contain dangerous substances. For information on the types in question please contact our Sales Organization. If printed or downloaded, please find the latest version in the Internet. Packing Please use the recycling operators known to you. We can also help you – get in touch with your nearest sales office. By agreement we will take packing material back, if it is sorted. You must bear the costs of transport. For packing material that is returned to us unsorted or which we are not obliged to accept, we shall have to invoice you for any costs incurred. Components used in life-support devices or systems must be expressly authorized for such purpose! Critical components* may only be used in life-support devices** or systems with the express written approval of OSRAM OS. Bitte beachten! Lieferbedingungen und Änderungen im Design vorbehalten. Aufgrund technischer Anforderungen können die Bauteile Gefahrstoffe enthalten. Für weitere Informationen zu gewünschten Bauteilen, wenden Sie sich bitte an unseren Vertrieb. Falls Sie dieses Datenblatt ausgedruckt oder heruntergeladen haben, finden Sie die aktuellste Version im Internet. Verpackung Benutzen Sie bitte die Ihnen bekannten Recyclingwege. Wenn diese nicht bekannt sein sollten, wenden Sie sich bitte an das nächstgelegene Vertriebsbüro. Wir nehmen das Verpackungsmaterial zurück, falls dies vereinbart wurde und das Material sortiert ist. Sie tragen die Transportkosten. Für Verpackungsmaterial, das unsortiert an uns zurückgeschickt wird oder das wir nicht annehmen müssen, stellen wir Ihnen die anfallenden Kosten in Rechnung. Bauteile, die in lebenserhaltenden Apparaten und Systemen eingesetzt werden, müssen für diese Zwecke ausdrücklich zugelassen sein! Kritische Bauteile* dürfen in lebenserhaltenden Apparaten und Systemen** nur dann eingesetzt werden, wenn ein schriftliches Einverständnis von OSRAM OS vorliegt. *) A critical component is a component used in a life-support device or system whose failure can reasonably be expected to cause the failure of that life-support device or system, or to affect its safety or the effectiveness of that device or system. **) Life support devices or systems are intended (a) to be implanted in the human body, or (b) to support and/or maintain and sustain human life. If they fail, it is reasonable to assume that the health and the life of the user may be endangered. 2015-09-28 *) Ein kritisches Bauteil ist ein Bauteil, das in lebenserhaltenden Apparaten oder Systemen eingesetzt wird und dessen Defekt voraussichtlich zu einer Fehlfunktion dieses lebenserhaltenden Apparates oder Systems führen wird oder die Sicherheit oder Effektivität dieses Apparates oder Systems beeinträchtigt. **) Lebenserhaltende Apparate oder Systeme sind für (a) die Implantierung in den menschlichen Körper oder (b) für die Lebenserhaltung bestimmt. Falls Sie versagen, kann davon ausgegangen werden, dass die Gesundheit und das Leben des Patienten in Gefahr ist. 20 Version 1.0 CW CBLPM1.CN Glossary Glossar 1) Brightness: Brightness values are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 8 % and an expanded uncertainty of ± 11 % (acc. to GUM with a coverage factor of k = 3). 1) Helligkeit: Helligkeitswerte werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 8 % und einer erweiterten Messunsicherheit von ± 11 % gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 2) Operating Conditions: Operating conditions according DC-derating (Max. Permissible Forward Current) 2) Nutzungsbedingungen: Nutzungsbedingungen gemäß DC-Derating (Maximal zulässiger Durchlassstrom) 3) Operating Conditions: Operating conditions according Pulse-derating (Permissible Pulse Handling Capability) 3) Nutzungsbedingungen: Nutzungsbedingungen gemäß Pulsderating (Zulässige Impulsbelastbarkeit) 4) Chromaticity coordinate groups: Chromaticity coordinates are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 0.005 and an expanded uncertainty of ± 0.01 (acc. to GUM with a coverage factor of k = 3). 4) Farbortgruppen: Farbkoordinaten werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 0,005 und einer erweiterten Messunsicherheit von ± 0,01 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 5) Forward Voltage: The forward voltage is measured during a current pulse of typically 8 ms, with an internal reproducibility of ± 0.05 V and an expanded uncertainty of ± 0.1 V (acc. to GUM with a coverage factor of k = 3). 5) Durchlassspannung: Vorwärtsspannungen werden während eines Strompulses einer typischen Dauer von 8 ms, mit einer internen Reproduzierbarkeit von ± 0,05 V und einer erweiterten Messunsicherheit von ± 0,1 V gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 6) Color reproduction index: Color reproduction index values (CRI-RA) are measured during a current pulse of typically 25 ms, with an internal reproducibility of ± 2 and an expanded uncertainty of ± 3 (acc. to GUM with a coverage factor of k = 3). 6) Farbwiedergabe Index: Werte des Farbwiedergabe Index (CRI-RA) werden während eines Strompulses einer typischen Dauer von 25 ms, mit einer internen Reproduzierbarkeit von ± 2 und einer erweiterten Messunsicherheit von ± 3 gemessen (gemäß GUM mit Erweiterungsfaktor k = 3). 7) Thermal Resistance: The typical Rth value is the average of a distribution. The value was determined on a sample basis and is not monitored. 7) Wärmewiderstand: Der typische Rth Wert ist der Mittelwert einer Verteilung. Der Wert wurde auf Musterbasis ermittelt und wird nicht ständig überwacht. 2015-09-28 21 Version 1.0 CW CBLPM1.CN Glossary Glossar 8) Typical Values: Due to the special conditions of the manufacturing processes of LED, the typical data or calculated correlations of technical parameters can only reflect statistical figures. These do not necessarily correspond to the actual parameters of each single product, which could differ from the typical data and calculated correlations or the typical characteristic line. If requested, e.g. because of technical improvements, these typ. data will be changed without any further notice. 8) Typische Werte: Wegen der besonderen Prozessbedingungen bei der Herstellung von LED können typische oder abgeleitete technische Parameter nur aufgrund statistischer Werte wiedergegeben werden. Diese stimmen nicht notwendigerweise mit den Werten jedes einzelnen Produktes überein, dessen Werte sich von typischen und abgeleiteten Werten oder typischen Kennlinien unterscheiden können. Falls erforderlich, z.B. aufgrund technischer Verbesserungen, werden diese typischen Werte ohne weitere Ankündigung geändert. 9) Characteristic curve: In the range where the line of the graph is broken, you must expect higher differences between single LEDs within one packing unit. 9) Kennlinien: Im gestrichelten Bereich der Kennlinien muss mit erhöhten Abweichungen zwischen Leuchtdioden innerhalb einer Verpackungseinheit gerechnet werden. 10) Tolerance of Measure: Unless otherwise noted in drawing, tolerances are specified with ±0.1 and dimensions are specified in mm. 10) Maßtoleranz: Wenn in der Zeichnung nicht anders angegeben, gilt eine Toleranz von ±0,1. Maße werden in mm angegeben. Published by OSRAM Opto Semiconductors GmbH Leibnizstraße 4, D-93055 Regensburg www.osram-os.com © All Rights Reserved. 2015-09-28 22
CWCBLPM1.CN-MXMZ-T4-0-A00-R18 价格&库存
很抱歉,暂时无法提供与“CWCBLPM1.CN-MXMZ-T4-0-A00-R18”相匹配的价格&库存,您可以联系我们找货
