ITEM
Q'TY
PART NUMBER
REV.
PART DESCRIPTION
Surface Mount Right Angle Light Pipe, 2.8mm, 2 Station.
1
1
LPR2-XXX-XXX
2
1
RLPH2-XXX
DESCRIPTION
A Engineering Release
B Added Overall Height "K" Dim
C Added Overall Snap Height Dimension
D Added Color Options, Sheet #3
See Table on 2nd Page
DATE
APPROVED
11/06/09
03/04/11
08/15/12
02/02/16
T. Y.
T. Y.
T. Y.
J. C.
LPR Housing, 2 Station, White. See Table on 2nd Page
0.538 [13.7mm]
0.366 [9.3mm]
L
0.110 [2.8mm]
SQ. TYP.
(0.310 [7.9mm])
0.138 [3.5mm]
0.426 [10.8mm]
LED MOUNTING AREA, 2X
0.482 [12.2mm]
0.200 [5.1mm]
0.141 [3.6mm]
0.079 [2.0mm] TYP.
0.200 [5.1mm]
2X Ø.110 [Ø2.8mm]
LENS OUTPUT
K
H
0.118 [3.0mm]
0.110 [2.8mm]
0.138 [3.5mm]
0.114 [2.9mm]
0.228 [5.8mm]
0.148 [3.8mm]
0.050 [1.3mm]
0.120 [3.0mm] TYP.
2X THRU-HOLE
0.069 [1.8mm]
0.071 [1.8mm]
0.106 [2.7mm]
MAX. LED HEIGHT
0.059 [1.5mm]
LIGHT PIPE FACE
0.142 [3.6mm]
TYP.
RECOMMENDED MOUNTING
0.062" PCB THICKNESS
0.020 [0.5mm]
STANDARD TOLERANCE
( UNLESS OTHERWISE SPECIFIED )
DECIMALS
(0.577 [14.7mm])
.X
.XX
.XXX
± .1
± .01
± .010
DESIGNED:
Raffy Paje
CHECKED:
T. Yin
ANGULAR
X°
± 1°
4 THOMAS, IRVINE, CA. 92618
TEL: (949) 951-8808
TITLE:
DATE:
11/06/09
DATE:
11/06/09
FAX: (949) 951-3974
RIGHT ANGLE LIGHT PIPE,
2.8MM, 2 STATION
REVISION:
PART NO:
RLP2-XXX-XXX
CAGE CODE : 32559
D
SHEET # 1 OF 3
CAD GENERATED DOCUMENT, DO NOT MEASURE DRAWING.
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
RLP2-XXX-XXX
ASSY P/N
H
K
0.551 [14.0mm]
RLP2-200-500
RLP2-200-650
L
0.197 [5.0mm]
0.669 [17.0mm]
0.287 [7.3mm]
LPR2-XXX-XXX
RLPH2-XXX
LPR2-200-500
RLPH2-200
LPR2-200-650
RLPH2-200
RLP2-200-800
0.787 [20.0mm]
LPR2-200-800
RLPH2-200
RLP2-400-500
0.551 [14.0mm]
LPR2-400-500
RLPH2-400
LPR2-400-650
RLPH2-400
RLP2-400-650
0.394 [10.0mm]
0.669 [17.0mm]
0.484 [12.3mm]
RLP2-400-800
0.787 [20.0mm]
LPR2-400-800
RPH2-400
RLP2-600-500
0.551 [14.0mm]
LPR2-600-500
RLPH2-600
LPR2-600-650
RLPH2-600
LPR2-600-800
RLPH2-600
RLP2-600-650
RLP2-600-800
0.591 [15.0mm]
0.669 [17.0mm]
0.787 [20.0mm]
0.681 [17.3mm]
FIGURE
STANDARD TOLERANCE
DECIMALS
.X
.XX
.XXX
± .1
± .01
± .010
DESIGNED:
Raffy Paje
CHECKED:
T. Yin
ANGULAR
X°
± 1°
TEL: (949) 951-8808
TITLE:
DATE:
11/06/09
DATE:
11/06/09
FAX: (949) 951-3974
2.8MM, 2 STATION
REVISION:
PART NO:
RLP2-XXX-XXX
CAGE CODE : 32559
D
SHEET # 2 OF 3
REV.
DATE
DESCRIPTION
APPROVED
SEE SHEET #1
OTHER AVAILABLE COLORS
* SEE TABLE FOR ORDERING INFORMATION
RIGID LIGHT PIPE
SERIES
HEIGHT
LENGTH
COLOR
Order Code
BLUE
BE
BLACK
BK
GREEN
GN
GRAY
GY
RED
RD
YELLOW
YW
NOTE: LEAVE ORDER CODE BLANK
IF NO COLOR IS DESIRED.
STANDARD TOLERANCE
DECIMALS
ANGULAR
TEL: (949) 951-8808
TITLE:
2. ONLY LIGHT PIPES OF ASSEMBLIES WILL BE DYED.
1. PARTS ARE DYED TO COLOR UPON REQUEST.
DESIGNED:
K. Aukshunas
CHECKED:
J. Chiang
DATE:
01/22/16
DATE:
01/22/16
FAX: (949) 951-3974
2.8MM, 2 STATION
REVISION:
PART NO:
RLP2-XXX-XXX
CAGE CODE : 32559
D
SHEET # 3 OF 3
很抱歉,暂时无法提供与“RLP2-400-800”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10+10.3831710+1.18770
- 30+10.0920630+1.15440
- 75+9.8009475+1.12110
- 200+9.55834200+1.09335
- 400+9.12167400+1.04340
- 国内价格 香港价格
- 1+25.047651+2.86513
- 10+18.0919010+2.06948
- 100+13.94284100+1.59488
- 500+12.11503500+1.38581
- 1000+11.519341000+1.31767
- 2000+11.014992000+1.25998
- 5000+10.465185000+1.19708
- 10000+10.1231810000+1.15796
- 国内价格 香港价格
- 10+11.2565210+1.28760
- 30+11.0624530+1.26540
- 100+10.96541100+1.25430
- 300+10.77133300+1.23210
- 1000+10.480211000+1.19880
