C12598_LENINA-M
C12598_LENINA-M
    LEDIL(芬兰)
    REFLECTOR RND 1POS
C12598_LENINA-M 数据手册
PRODUCT DATASHEET C12598_LENINA-M LENINA-M ~30° medium beam SPECIFICATION: Dimensions Ø 74.0 mm Height 40 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour LENINA-M Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C12598_LENINA-M » Box size: 476 x 273 x 197 mm Qty in box 60 MOQ MPQ 120 60 Box weight (kg) 2.0 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/43 PRODUCT DATASHEET C12598_LENINA-M See also our general installation guide: www.ledil.com/installation_guide Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED BXRA ES Rectangle FWHM / FWTM 29.0° / 75.0° Efficiency 86 % LEDs/each optic 1 Light colour White Required components: C12153_LENA-STD-BASE-BXRA LED BXRA ES Rectangle FWHM / FWTM 36.0° / 76.0° Efficiency 78 % LEDs/each optic 1 Light colour White Required components: C12153_LENA-STD-BASE-BXRA C12606_LENINA-DL LED BXRA RS FWHM / FWTM 47.0° / 89.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12229_LENA-STD-BASE-RS C12606_LENINA-DL LED BXRA RS FWHM / FWTM 44.0° / 82.0° Efficiency 88 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12229_LENA-STD-BASE-RS Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED V10 Gen6 FWHM / FWTM 21.0° / 68.0° Efficiency 84 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13186_LENA-STD-BASE-CXA15 C12606_LENINA-DL LED Vero SE 29 FWHM / FWTM 51.0° / 84.0° Efficiency 92 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C15083_LENA-STD-BASE-VERO29 LED VERO13 FWHM / FWTM 28.0° / 74.0° Efficiency 91 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 LED VERO13 FWHM / FWTM 31.0° / 74.0° Efficiency 87 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED VERO18 FWHM / FWTM 37.0° / 77.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL LED VERO18 FWHM / FWTM 35.0° / 76.0° Efficiency 90 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 LED VERO29 FWHM / FWTM 52.0° / 84.0° Efficiency 89 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 LED VERO29 FWHM / FWTM 52.0° / 85.0° Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CL-L340 FWHM / FWTM 26.0° / 71.0° Efficiency 92 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C11995_LENA-STD-BASE-CL340 LED CL-L340 FWHM / FWTM 30.0° / 74.0° Efficiency 86 % LEDs/each optic 1 Light colour White Required components: C11995_LENA-STD-BASE-CL340 LED CL-L340 FWHM / FWTM 35.0° / 76.0° Efficiency 78 % LEDs/each optic 1 Light colour White Required components: C11995_LENA-STD-BASE-CL340 C12606_LENINA-DL LED CLL02x/CLU02x (LES10) FWHM / FWTM 26.0° / 71.0° Efficiency 87 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 23.0° / 71.0° Efficiency 91 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED CLL03x/CLU03x FWHM / FWTM 28.0° / 73.0° Efficiency 91 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 LED CLL03x/CLU03x FWHM / FWTM 31.0° / 73.0° Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 433 Typ L1 LED CLL03x/CLU03x FWHM / FWTM 30.0° / 73.0° Efficiency 87 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 29.0° / 73.0° Efficiency 91 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 LED CLL04x/CLU04x FWHM / FWTM 40.0° / 78.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 431 Typ L3 LED CLL04x/CLU04x FWHM / FWTM 40.0° / 77.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED CLL04x/CLU04x FWHM / FWTM 37.0° / 76.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C12606_LENINA-DL IDEAL: 50-2204CT + 50-2100LN Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 39.0° / 78.0° Efficiency 92 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 LED CLL04x/CLU04x FWHM / FWTM 35.0° / 75.0° Efficiency 90 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2204CT + 50-2100LN LED CLL04x/CLU04x FWHM / FWTM 38.0° / 77.0° Efficiency 76 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12606_LENINA-DL A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED CLL04x/CLU04x FWHM / FWTM 36.0° / 76.0° Efficiency 83 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8102-G2 + S-8000-12 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 43.0° / 80.0° Efficiency 78 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED CLU700/701/702/703 FWHM / FWTM 17.0° / 60.0° Efficiency 91 % Peak intensity 3.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED CLU700/701/702/703 FWHM / FWTM 23.0° / 70.0° Efficiency 87 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 434 Typ L1 LED CLU710/711 FWHM / FWTM 24.0° / 71.0° Efficiency 89 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CLU710/711 FWHM / FWTM 19.0° / 68.0° Efficiency 93 % Peak intensity 3.3 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 LED CLU720/721/723 FWHM / FWTM 23.0° / 71.0° Efficiency 88 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 LED CLU720/721/723 FWHM / FWTM 26.0° / 72.0° Efficiency 84 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED CLU730/731/733 FWHM / FWTM 26.0° / 71.0° Efficiency 84 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CLU730/731/733 FWHM / FWTM 24.0° / 70.0° Efficiency 94 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED CMA1840 FWHM / FWTM 25.0° / 70.0° Efficiency 92 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C14146_LENA-STD-BASE-CXA18 LED CMA1840 FWHM / FWTM 25.0° / 70.0° Efficiency 92 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C14146_LENA-STD-BASE-CXA18 LED CMA2550 FWHM / FWTM 32.0° / 73.0° Efficiency 92 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13324_LENA-STD-BASE-CXA25 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CMT14xx FWHM / FWTM 25.0° / 73.0° Efficiency 92 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED CMT19xx FWHM / FWTM 30.0° / 74.0° Efficiency 92 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 477 Typ L1 LED CMT19xx FWHM / FWTM 29.0° / 73.0° Efficiency 92 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 LED CMT28xx FWHM / FWTM 39.0° / 77.0° Efficiency 92 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 471 Typ L3 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CMT28xx FWHM / FWTM 37.0° / 76.0° Efficiency 92 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED CXA/B 15xx FWHM / FWTM 26.0° / 71.0° Efficiency 87 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 441 Typ L1 LED CXA/B 15xx FWHM / FWTM 17.0° / 56.0° Efficiency 91 % Peak intensity 4.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13186_LENA-STD-BASE-CXA15 LED CXA/B 15xx FWHM / FWTM 22.0° Efficiency % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 441 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM 22.0° / 66.0° Efficiency 86 % Peak intensity 3.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13186_LENA-STD-BASE-CXA15 C12606_LENINA-DL LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 21.0° / 72.0° Efficiency 92 % Peak intensity 3.9 cd/lm LEDs/each optic 1 Light colour White Required components: C14146_LENA-STD-BASE-CXA18 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 29.0° / 73.0° Efficiency 88 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 437 Typ L1 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM 26.0° / 73.0° Efficiency 92 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CXA/B 1830 FWHM / FWTM 30.0° / 74.0° Efficiency 93 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 LED CXA/B 1830 FWHM / FWTM 33.0° / 74.0° Efficiency 88 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 437 Typ L1 LED CXA/B 25xx FWHM / FWTM 33.0° / 74.0° Efficiency 86 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13324_LENA-STD-BASE-CXA25 LED CXA/B 25xx FWHM / FWTM 35.0° / 74.0° Efficiency 78 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13324_LENA-STD-BASE-CXA25 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CXA2011 FWHM / FWTM 33.0° / 76.0° Efficiency 77 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12105_LENA-STD-BASE-CXA20 C12606_LENINA-DL LED CXA2011 FWHM / FWTM 28.0° / 73.0° Efficiency 85 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12105_LENA-STD-BASE-CXA20 LED CHI3030 19W FWHM / FWTM 39.0° / 80.0° Efficiency 91 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 468 Typ L3 LED CHI3030 29W FWHM / FWTM 47.0° / 84.0° Efficiency 87 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 468 Typ L3 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1202/1203 FWHM / FWTM 26.0° / 71.0° Efficiency 88 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 438 Typ L1 LED LUXEON CoB 1202/1203 FWHM / FWTM 22.0° / 71.0° Efficiency 92 % Peak intensity 3.1 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 438 Typ L1 LED LUXEON CoB 1204/1205 FWHM / FWTM 30.0° / 74.0° Efficiency 82 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED LUXEON CoB 1204/1205 FWHM / FWTM 28.0° / 74.0° Efficiency 87 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1204HD FWHM / FWTM 20.0° / 65.0° Efficiency 92 % Peak intensity 3.5 cd/lm LEDs/each optic 1 Light colour White Required components: C11981_LENA-STD-BASE-COB-L110 LED LUXEON CoB 1205HD FWHM / FWTM 23.0° / 70.0° Efficiency 92 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: C11981_LENA-STD-BASE-COB-L110 LED LUXEON CoB 1208 FWHM / FWTM 31.0° / 75.0° Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ LED LUXEON CoB 1208 FWHM / FWTM 33.0° / 75.0° Efficiency 83 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1211 FWHM / FWTM 37.0° / 77.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 431 Typ L3 LED LUXEON CoB 1211 FWHM / FWTM 35.0° / 76.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 39.0° / 76.0° Efficiency 92 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 39.0° / 77.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12606_LENINA-DL A.A.G. STUCCHI: 8102-G2 + S-8000-12 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 40.0° / 77.0° Efficiency 88 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 38.0° / 77.0° Efficiency 85 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED LUXEON K12 FWHM / FWTM 28.0° / 74.0° Efficiency 89 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C12924_LENA-STD-BASE-LUXEON-K LED LUXEON K12 FWHM / FWTM 30.0° / 73.0° Efficiency 83 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C12924_LENA-STD-BASE-LUXEON-K C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED LUXEON K16 FWHM / FWTM 34.0° / 75.0° Efficiency 79 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C12924_LENA-STD-BASE-LUXEON-K C12606_LENINA-DL LED LUXEON K16 FWHM / FWTM 30.0° / 74.0° Efficiency 85 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C12924_LENA-STD-BASE-LUXEON-K LED CDM-14 (Dim-To-Warm) FWHM / FWTM 31.0° / 74.0° Efficiency 88 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 491 Typ L2 LED CDM-14 (Dim-To-Warm) FWHM / FWTM 29.0° / 74.0° Efficiency 92 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CDM-18 (Dim-To-Warm) FWHM / FWTM 34.0° / 75.0° Efficiency 92 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 LED CDM-18 (Dim-To-Warm) FWHM / FWTM 36.0° / 76.0° Efficiency 88 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 491 Typ L2 LED CDM-9 (Dim-To-Warm) FWHM / FWTM 24.0° / 72.0° Efficiency 92 % Peak intensity 2.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 490 Typ L1 LED CDM-9 (Dim-To-Warm) FWHM / FWTM 27.0° / 72.0° Efficiency 87 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 490 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CTM-14 (Tunable White) FWHM / FWTM 28.0° / 74.0° Efficiency 92 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 LED CTM-14 (Tunable White) FWHM / FWTM 31.0° / 74.0° Efficiency 87 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 442 Typ L3 LED CTM-18 (Tunable White) FWHM / FWTM 32.0° / 76.0° Efficiency 92 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 LED CTM-18 (Tunable White) FWHM / FWTM 34.0° / 76.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 442 Typ L3 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CTM-22 (Tunable White) FWHM / FWTM 39.0° / 79.0° Efficiency 92 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 494 Typ L3 LED CTM-22 (Tunable White) FWHM / FWTM 40.0° / 79.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 494 Typ L3 LED CxM-14 (19x19) FWHM / FWTM 31.0° / 73.0° Efficiency 89 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED CxM-14 (19x19) FWHM / FWTM 28.0° / 72.0° Efficiency 93 % Peak intensity 2.5 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED CxM-22 (28x28) FWHM / FWTM 40.0° / 80.0° Efficiency 89 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED CxM-22 (28x28) FWHM / FWTM 39.0° / 80.0° Efficiency 92 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED COB J-Type FWHM / FWTM 33.0° / 75.0° Efficiency 81 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED COB J-Type FWHM / FWTM 32.0° / 74.0° Efficiency 89 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED COB J-Type FWHM / FWTM 31.0° / 75.0° Efficiency 86 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ LED COB J-Type FWHM / FWTM 29.0° / 74.0° Efficiency 93 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 463 Typ L2 LED COB L-Type (LES 11) FWHM / FWTM 25.0° / 72.0° Efficiency 91 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 438 Typ L1 LED COB L-Type (LES 11) FWHM / FWTM 27.0° / 74.0° Efficiency 84 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C11981_LENA-STD-BASE-COB-L110 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 29.0° / 73.0° Efficiency 79 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C11981_LENA-STD-BASE-COB-L110 C12606_LENINA-DL LED COB L-Type (LES 11) FWHM / FWTM 28.0° / 72.0° Efficiency 87 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 26.0° / 71.0° Efficiency 89 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 438 Typ L1 LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 26.0° / 73.0° Efficiency 92 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 498 Typ L2 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 29.0° / 73.0° Efficiency 87 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 498 Typ L2 LED Soleriq S13 FWHM / FWTM 27.0° / 73.0° Efficiency 91 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 LED Soleriq S13 FWHM / FWTM 30.0° / 73.0° Efficiency 87 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 437 Typ L1 LED Soleriq S19 FWHM / FWTM 32.0° / 76.0° Efficiency 93 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 462 Typ L3 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED Soleriq S19 FWHM / FWTM 34.0° / 76.0° Efficiency 89 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 462 Typ L3 LED Fortimo SLM L13 CoB FWHM / FWTM 27.0° / 72.0° Efficiency 93 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ LED Fortimo SLM L13 CoB FWHM / FWTM 30.0° / 72.0° Efficiency 86 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED Fortimo SLM L15 CoB FWHM / FWTM 29.0° / 73.0° Efficiency % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED Fortimo SLM L15 CoB FWHM / FWTM 32.0° / 74.0° Efficiency 86 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED Fortimo SLM L19 CoB FWHM / FWTM 33.0° / 74.0° Efficiency 92 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED Fortimo SLM L19 CoB FWHM / FWTM 35.0° / 75.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED Fortimo SLM L23 CoB FWHM / FWTM 40.0° / 77.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED Fortimo SLM L23 CoB FWHM / FWTM 39.0° / 76.0° Efficiency 92 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 30.0° / 74.0° Efficiency 92 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 33.0° / 75.0° Efficiency 87 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED LC026B / 033B / 040B FWHM / FWTM 35.0° / 76.0° Efficiency 88 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 450 Typ L2 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED LC026B / 033B / 040B FWHM / FWTM 33.0° / 75.0° Efficiency 92 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 450 Typ L2 LED LC040D / LC060D / LC080D FWHM / FWTM 41.0° / 78.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL LED LC040D / LC060D / LC080D FWHM / FWTM 40.0° / 77.0° Efficiency 91 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED ZC25/40/60 FWHM / FWTM 44.0° / 79.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 C12606_LENINA-DL Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED ZC25/40/60 FWHM / FWTM 42.0° / 79.0° Efficiency 85 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED Mega Zenigata (GW5DGC) FWHM / FWTM 21.0° / 72.0° Efficiency 86 % LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ LED Mega Zenigata (GW5DGC) FWHM / FWTM 22.0° / 73.0° Efficiency 78 % LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED Mega Zenigata (GW6DME) FWHM / FWTM 30.0° / 75.0° Efficiency 87 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED Mega Zenigata (GW6DME) FWHM / FWTM 32.0° / 74.0° Efficiency 82 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C12292_LENA-STD-BASE-MEZ C12606_LENINA-DL LED SLE G7 LES15 FWHM / FWTM 30.0° / 74.0° Efficiency 93 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 LED SLE G7 LES17 H FWHM / FWTM 31.0° / 74.0° Efficiency 91 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: C14547_LENA-ADAPTER-B LED SLE G7 LES21 H FWHM / FWTM 37.0° / 76.0° Efficiency 91 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: C14547_LENA-ADAPTER-B Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 35/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (MEASURED): LED XOB 14.5 mm FWHM / FWTM 29.0° / 74.0° Efficiency 93 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 36/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (SIMULATED): LED V10 Gen7 FWHM / FWTM 28.0° / 70.0° Efficiency 86 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 486 Typ L1 LED V10 Gen7 FWHM / FWTM 26.0° / 71.0° Efficiency 91 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 486 Typ L1 LED V13 Gen7 FWHM / FWTM 31.0° / 73.0° Efficiency 90 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 477 Typ L1 LED V13 Gen7 FWHM / FWTM 26.0° / 70.0° Efficiency 90 % Peak intensity 2.6 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2103CT + 50-2100AN Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 37/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM 26.0° / 70.0° Efficiency 87 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: C12606_LENINA-DL IDEAL: 50-2103CT + 50-2100AN LED V13 Gen7 FWHM / FWTM 32.0° / 72.0° Efficiency 86 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 477 Typ L1 LED V22 Gen7 FWHM / FWTM 42.0° / 80.0° Efficiency 90 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 LED V22 Gen7 FWHM / FWTM 42.0° / 80.0° Efficiency 87 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 431 Typ L3 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 38/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (SIMULATED): LED CXA/B 1830 FWHM / FWTM 30.0° / 72.0° Efficiency 89 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 637b Lena LED CXA/B 30xx FWHM / FWTM 30.0° / 72.0° Efficiency 84 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C12606_LENINA-DL IDEAL: 50-2234C + 50-2100LN LED CXA/B 30xx FWHM / FWTM 28.0° / 70.0° Efficiency 89 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: IDEAL: 50-2234C + 50-2100LN LED CxM-14 (19x19) FWHM / FWTM 31.0° / 73.0° Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 433 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 39/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (SIMULATED): LED CxM-14 (19x19) FWHM / FWTM 29.0° / 73.0° Efficiency 91 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 LED CxM-9 (13.5x13.5) FWHM / FWTM 23.0° / 71.0° Efficiency 91 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED CxM-9 (13.5x13.5) FWHM / FWTM 26.0° / 71.0° Efficiency 87 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 434 Typ L1 LED Soleriq S15 FWHM / FWTM 30.0° / 71.0° Efficiency 90 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 40/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (SIMULATED): LED LC003D / LC006D / LC009D / LC013D FWHM / FWTM 18.0° / 53.0° Efficiency 88 % Peak intensity 4 cd/lm LEDs/each optic 1 Light colour White Required components: C12692_LENA-STD-BASE-CLL040 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 32.0° / 72.0° Efficiency 87 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour White Required components: Bender Wirth: 633c Lena LED ZC12/18 FWHM / FWTM 32.0° / 72.0° Efficiency 84 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 C12606_LENINA-DL LED ZC12/18 FWHM / FWTM 29.0° / 73.0° Efficiency 91 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 41/43 PRODUCT DATASHEET C12598_LENINA-M OPTICAL RESULTS (SIMULATED): LED ZC12/18 FWHM / FWTM 26.0° / 70.0° Efficiency 89 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: C12691_LENA-STD-BASE-CLL030 LED ZC12/18 FWHM / FWTM 31.0° / 73.0° Efficiency 88 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 433 Typ L1 LED ZC4/6 FWHM / FWTM 26.0° / 71.0° Efficiency 87 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 C12606_LENINA-DL Bender Wirth: 434 Typ L1 LED ZC4/6 FWHM / FWTM 23.0° / 71.0° Efficiency 91 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 42/43 PRODUCT DATASHEET C12598_LENINA-M GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 08/11/2023 Subject to change without prior notice Published: 04/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 43/43
C12598_LENINA-M
物料型号: - 产品型号为C12598_LENINA-M。
器件简介: - LENINA-M是一款LED照明产品,具有30°的中等光束角度。
引脚分配: - 该产品采用插座式固定方式。
参数特性: - 产品尺寸为直径74.0毫米,高度40毫米。 - 遵守ROHS标准。
功能详解: - 提供了详细的光学测试结果,包括不同LED型号的半功率角(FWHM)、全功率角(FWTM)、效率、峰值强度以及所需的组件。
应用信息: - 文档提供了关于产品使用的注意事项,例如色温变化、芯片尺寸和位置容差对光束角度的影响,以及对适当的热设计的高度推荐。
封装信息: - 材料包括反射器(PC材料,金属色,涂有漆面)。
订购信息: - 包括每箱数量、最小起订量(MOQ)、最大包装量(MPQ)以及箱重和尺寸。
最后更新日期为2023年8月11日,发布日期为2018年4月5日。LEDiL是LEDiL Oy在欧盟、美国和某些其他国家的注册商标。
C12598_LENINA-M 价格&库存
很抱歉,暂时无法提供与“C12598_LENINA-M”相匹配的价格&库存,您可以联系我们找货
C12598_LENINA-M
C12598_LENINA-M
