PRODUCT DATASHEET
Lena series
last update 19/9/2014
DETAILS
Product Number
C13101_LENA-X-WAS
Family
Lena
Type
Reflector
Color
white
Diameter
111 mm
Height
37 mm
Style
round
Optic Material
PC
Holder Material
Fastening
glue
Status
ready
ROHS Comliant
Yes
Date Updated
19/09/2014
OPTICAL PROPERTIES
LED
Viewing Angle
N/A degrees
Light Beam
Efficiency
cd/lm
connector
(simulated) 0.000
September 19th 2014 18:48 Copyright Ledil Oy - Subject to change without prior notice - Page 1/1
Ledil Oy
Salorankatu 10
24240 SALO
Finland
http://www.ledil.com
email: ledil@ledil.com
FAX: +358-2-733 8001
NOTE: The typical divergence will be changed by different color, chip size and chip position
tolerance. The typical total divergence is the full angle measured where the luminous intensity
is half of the peak value.
GENERAL INFORMATION
- Product series especially designed & optimized for series of LEDs.
- Special care taken to make light distribution as uniform as possible.
- Reflector is made of aluminium coated PC (120 degrees of Celcius / 248 degrees of Fahrenheit) with
protective lacquer (short term 100 degrees of Celcius / 212 degrees of Fahrenheit).
- Fastening to PCB with appropriate adhesive. By clicking link below you can find Ledil recommended glue
options.
http://www.ledil.com/datasheets/DataSheet_GLUES.pdf
NOTE 1: We advise customer to ensure the suitability and sufficiency of the bond in the end
product. For example, mechanical stress, vibration and holes on the surface of the circuit boar
weaken the strength of the glue.
NOTE 2: All surfaces where glue is applied must be clean, dry and free from grease and dirt. If
cleaning of PCB surfaces is needed, please follow strictly the cleaning instructions of your LED
manufacturer -this is important as cleaning shall under no circumstances damage LEDs or other
electronics components on the PCB.
Further note that optical components shall not be cleaned with any chemicals - only micro fiber
cloth may be used to remove fingerprints or other traces from handling.
很抱歉,暂时无法提供与“C13101_LENA-X-WAS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 60+55.47243
- 120+54.08531
- 240+53.25324
- 国内价格
- 1+90.34004
- 15+88.35100
- 30+86.47651
- 国内价格
- 1+74.69481
- 56+59.74626
- 168+56.00913
- 280+52.28397
- 国内价格 香港价格
- 1+76.256181+9.86490
- 56+60.9700056+7.88740
- 168+57.21397168+7.40150
- 280+53.37059280+6.90430
