C11980_LENA-W
C11980_LENA-W
    LEDIL(芬兰)
    REFLECTOR 111MM RND PC 85.6MM HT
C11980_LENA-W 数据手册
PRODUCT DATASHEET C11980_LENA-W LENA-W ~45° wide beam SPECIFICATION: Dimensions Ø 111.0 mm Height 80 mm Fastening socket ROHS compliant yes MATERIALS: Component Type Material Colour LENA-W Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C11980_LENA-W » Box size: 400 x 280 x 380 mm Qty in box 60 MOQ MPQ 60 60 Box weight (kg) 4.0 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/39 PRODUCT DATASHEET C11980_LENA-W See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED BXRA ES Rectangle FWHM / FWTM 46.0° / 64.0° Efficiency 74 % LEDs/each optic 1 Light colour/type White Required components: C12153_LENA-STD-BASE-BXRA C11996_LENA-LENS LED BXRA RS FWHM / FWTM 51.0° Efficiency 76 % LEDs/each optic 1 Light colour/type White Required components: C12229_LENA-STD-BASE-RS C11996_LENA-LENS LED BXRA RS FWHM / FWTM 51.0° Efficiency 81 % LEDs/each optic 1 Light colour/type White Required components: C12229_LENA-STD-BASE-RS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED V10 Gen6 FWHM / FWTM 39.0° / 64.0° Efficiency 74 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13186_LENA-STD-BASE-CXA15 C11996_LENA-LENS LED Vero SE 29 FWHM / FWTM 57.0° / 70.0° Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C15083_LENA-STD-BASE-VERO29 LED VERO13 FWHM / FWTM 48.0° / 71.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED VERO18 FWHM / FWTM 52.0° / 69.0° Efficiency 80 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS LED VERO29 FWHM / FWTM 57.0° / 75.0° Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS LED CL-L340 FWHM / FWTM 45.0° / 63.0° Efficiency 75 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11995_LENA-STD-BASE-CL340 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CLL02x/CLU02x (LES10) FWHM / FWTM 45.0° / 64.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 434 Typ L1 LED CLL03x/CLU03x FWHM / FWTM 47.0° / 65.0° Efficiency 80 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED CLL03x/CLU03x FWHM / FWTM 47.0° / 67.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM 45.0° / 66.0° Efficiency 79 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS A.A.G. STUCCHI: 8101-G2 + S-8000-11 LED CLL03x/CLU03x FWHM / FWTM 47.0° / 61.0° Efficiency 85 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED CLL04x/CLU04x FWHM / FWTM 52.0° / 66.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 50.0° / 65.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2204CT + 50-2100LN LED CLL04x/CLU04x FWHM / FWTM 49.0° / 72.0° Efficiency 77 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS IDEAL: 50-2204CT + 50-2100LN LED CLL04x/CLU04x FWHM / FWTM 46.0° / 64.0° Efficiency 76 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM 50.0° / 78.0° Efficiency 73 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED CLU700/701/702/703 FWHM / FWTM 39.0° / 61.0° Efficiency 81 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 434 Typ L1 LED CLU720/721/723 FWHM / FWTM 46.0° / 66.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CLU720/721/723 FWHM / FWTM 44.0° / 60.0° Efficiency 81 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED CMA1840 FWHM / FWTM 43.0° / 60.0° Efficiency 86 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14146_LENA-STD-BASE-CXA18 LED CMA2550 FWHM / FWTM 49.0° / 63.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CMT14xx FWHM / FWTM 44.0° / 60.0° Efficiency 85 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED CMT19xx FWHM / FWTM 47.0° / 61.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 477 Typ L1 LED CMT28xx FWHM / FWTM 51.0° / 64.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CMT28xx FWHM / FWTM 54.0° / 66.0° Efficiency 85 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 471 Typ L3 LED CXA/B 15xx FWHM / FWTM 44.0° / 61.0° Efficiency 81 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 441 Typ L1 LED CXA/B 15xx FWHM / FWTM 38.0° / 59.0° Efficiency 77 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13186_LENA-STD-BASE-CXA15 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CXA/B 1830 FWHM / FWTM 49.0° / 60.0° Efficiency 82 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C14169_LENA-CLEAR-LENS Bender Wirth: 437 Typ L1 LED CXA/B 1830 FWHM / FWTM 17.0° / 64.0° Efficiency 74 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C12231_LENA-FRESNEL Bender Wirth: 437 Typ L1 LED CXA/B 1830 FWHM / FWTM 48.0° / 61.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CXA/B 25xx FWHM / FWTM 44.0° / 60.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 LED CXA/B 25xx FWHM / FWTM 44.0° / 61.0° Efficiency 76 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 C11996_LENA-LENS LED CXA2011 FWHM / FWTM 42.0° Efficiency 75 % LEDs/each optic 1 Light colour/type White Required components: C12105_LENA-STD-BASE-CXA20 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CHI3030 19W FWHM / FWTM 50.0° / 70.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 468 Typ L3 LED CHI3030 29W FWHM / FWTM 53.0° / 76.0° Efficiency 78 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 468 Typ L3 LED LUXEON CoB 1204/1205 FWHM / FWTM 44.0° / 66.0° Efficiency 68 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1204HD FWHM / FWTM 40.0° / 58.0° Efficiency 86 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 LED LUXEON CoB 1205HD FWHM / FWTM 43.0° / 60.0° Efficiency 85 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 LED LUXEON CoB 1208 FWHM / FWTM 46.0° / 67.0° Efficiency 68 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1208 FWHM / FWTM 46.0° / 62.0° Efficiency 73 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 51.0° / 64.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 51.0° / 65.0° Efficiency 79 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8102-G2 + S-8000-12 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 50.0° / 69.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 50.0° / 79.0° Efficiency 75 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED LUXEON K12 FWHM / FWTM 45.0° / 61.0° Efficiency 74 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED LUXEON K16 FWHM / FWTM 46.0° / 62.0° Efficiency 72 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K C11996_LENA-LENS LED CDM-14 (Dim-To-Warm) FWHM / FWTM 47.0° / 67.0° Efficiency 82 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 491 Typ L2 LED CDM-14 (Dim-To-Warm) FWHM / FWTM 47.0° / 61.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CDM-18 (Dim-To-Warm) FWHM / FWTM 48.0° / 68.0° Efficiency 82 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 491 Typ L2 LED CDM-18 (Dim-To-Warm) FWHM / FWTM 50.0° / 63.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 LED CDM-9 (Dim-To-Warm) FWHM / FWTM 44.0° / 59.0° Efficiency 87 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 490 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CDM-9 (Dim-To-Warm) FWHM / FWTM 44.0° / 63.0° Efficiency 82 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 490 Typ L1 LED CTM-14 (Tunable White) FWHM / FWTM 46.0° / 65.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 442 Typ L3 LED CTM-14 (Tunable White) FWHM / FWTM 45.0° / 61.0° Efficiency 86 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CTM-18 (Tunable White) FWHM / FWTM 49.0° / 69.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 442 Typ L3 LED CTM-18 (Tunable White) FWHM / FWTM 49.0° / 63.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 LED CTM-22 (Tunable White) FWHM / FWTM 53.0° / 72.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 489 Typ L6 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED CTM-22 (Tunable White) FWHM / FWTM 55.0° / 68.0° Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 494 Typ L3 LED CxM-14 (19x19) FWHM / FWTM 48.0° / 68.0° Efficiency 78 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED COB J-Type FWHM / FWTM 49.0° / 69.0° Efficiency 79 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 463 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM 46.0° / 63.0° Efficiency 79 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM 45.0° / 66.0° Efficiency 79 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 45.0° / 60.0° Efficiency 86 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 498 Typ L2 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM 46.0° / 66.0° Efficiency 81 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 498 Typ L2 LED Soleriq S13 FWHM / FWTM 47.0° / 64.0° Efficiency 78 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 437 Typ L1 LED Soleriq S19 FWHM / FWTM 50.0° / 71.0° Efficiency 78 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 462 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED Fortimo SLM L13 CoB FWHM / FWTM 44.0° / 60.0° Efficiency 85 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED Fortimo SLM L13 CoB FWHM / FWTM 44.0° / 61.0° Efficiency 79 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS LED Fortimo SLM L15 CoB FWHM / FWTM 47.0° / 61.0° Efficiency 85 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED Fortimo SLM L15 CoB FWHM / FWTM 46.0° / 63.0° Efficiency 79 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS LED Fortimo SLM L19 CoB FWHM / FWTM 48.0° / 65.0° Efficiency 79 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS LED Fortimo SLM L19 CoB FWHM / FWTM 50.0° / 63.0° Efficiency 85 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED Fortimo SLM L23 CoB FWHM / FWTM 51.0° / 64.0° Efficiency 85 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED Fortimo SLM L23 CoB FWHM / FWTM 50.0° / 67.0° Efficiency 79 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM 49.0° / 66.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED LC040D / LC060D / LC080D FWHM / FWTM 51.0° / 71.0° Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS LED ZC12/18 FWHM / FWTM 48.0° / 66.0° Efficiency 77 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED Mega Zenigata (GW5DGC) FWHM / FWTM 44.0° / 64.0° Efficiency 75 % LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED Mega Zenigata (GW5DGC) FWHM / FWTM 44.0° / 60.0° Efficiency 80 % LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED SLE G7 LES15 FWHM / FWTM 48.0° / 62.0° Efficiency 88 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED SLE G7 LES17 H FWHM / FWTM 49.0° / 62.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14547_LENA-ADAPTER-B Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (MEASURED): LED SLE G7 LES21 H FWHM / FWTM 52.0° / 64.0° Efficiency 86 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14547_LENA-ADAPTER-B LED XOB 14.5 mm FWHM / FWTM 46.0° / 60.0° Efficiency 89 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (SIMULATED): LED V10 Gen7 FWHM / FWTM 44.0° / 60.0° Efficiency 81 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 486 Typ L1 LED V10 Gen7 FWHM / FWTM 46.0° / 59.0° Efficiency 88 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 486 Typ L1 LED V13 Gen7 FWHM / FWTM 47.0° / 63.0° Efficiency 82 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 477 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM 42.0° / 64.0° Efficiency 85 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS IDEAL: 50-2103CT + 50-2100LN LED V13 Gen7 FWHM / FWTM 44.0° / 62.0° Efficiency 87 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100LN LED V22 Gen7 FWHM / FWTM 51.0° / 67.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (SIMULATED): LED V22 Gen7 FWHM / FWTM 51.0° / 67.0° Efficiency 87 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 LED CXA/B 30xx FWHM / FWTM 42.0° / 62.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2234C + 50-2100LN LED CXA/B 30xx FWHM / FWTM 43.0° / 64.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS IDEAL: 50-2234C + 50-2100LN Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (SIMULATED): LED CxM-14 (19x19) FWHM / FWTM 47.0° / 67.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED CxM-14 (19x19) FWHM / FWTM 47.0° / 61.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 LED CxM-22 (28x28) FWHM / FWTM 48.0° / 62.0° Efficiency 83 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 35/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (SIMULATED): LED CxM-9 (13.5x13.5) FWHM / FWTM 45.0° / 64.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 434 Typ L1 LED CxM-9 (13.5x13.5) FWHM / FWTM 44.0° / 59.0° Efficiency 86 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED Soleriq S15 FWHM / FWTM 48.0° / 61.0° Efficiency 88 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 36/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (SIMULATED): LED ZC12/18 FWHM / FWTM 47.0° / 67.0° Efficiency 81 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED ZC12/18 FWHM / FWTM 47.0° / 61.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 LED ZC4/6 FWHM / FWTM 45.0° / 64.0° Efficiency 81 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 434 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 37/39 PRODUCT DATASHEET C11980_LENA-W OPTICAL RESULTS (SIMULATED): LED ZC4/6 FWHM / FWTM 44.0° / 59.0° Efficiency 86 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 38/39 PRODUCT DATASHEET C11980_LENA-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice Published: 30/05/2018 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 39/39
C11980_LENA-W 价格&库存
很抱歉,暂时无法提供与“C11980_LENA-W”相匹配的价格&库存,您可以联系我们找货
