C12948_LENA-WAS
C12948_LENA-WAS
    LEDIL(芬兰)
    REFLECTOR RND 1POS 111MM 37MM
C12948_LENA-WAS 数据手册
PRODUCT DATASHEET C12948_LENA-WAS LENA-WAS Asymmetric beam for wall-washing SPECIFICATION: Dimensions Ø 111.0 mm Height 37 mm Fastening glue ROHS compliant yes MATERIALS: Component Type Material Colour LENA-WAS Reflector PC metal Finish Coating lacquer ORDERING INFORMATION: Component C12948_LENA-WAS » Box size: 480 x 280 x 300 mm Qty in box 56 MOQ MPQ 56 56 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 3.1 1/53 PRODUCT DATASHEET C12948_LENA-WAS See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED BXRA ES Rectangle FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12153_LENA-STD-BASE-BXRA C11996_LENA-LENS LED BXRA ES Rectangle FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12153_LENA-STD-BASE-BXRA LED BXRA RS FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12229_LENA-STD-BASE-RS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED BXRA RS FWHM / FWTM Asymmetric Efficiency 75 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12229_LENA-STD-BASE-RS C11996_LENA-LENS LED V10 Gen6 FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13186_LENA-STD-BASE-CXA15 C11996_LENA-LENS LED V22 Gen7 FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED V22 Gen7 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C14169_LENA-CLEAR-LENS Bender Wirth: 431 Typ L3 LED Vero SE 29 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C15083_LENA-STD-BASE-VERO29 LED VERO13 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED VERO13 FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 LED VERO13 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS LED VERO18 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED VERO18 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS LED VERO18 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS LED VERO29 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED VERO29 FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS LED CL-L340 FWHM / FWTM Asymmetric Efficiency 73 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11995_LENA-STD-BASE-CL340 C11996_LENA-LENS LED CL-L340 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11995_LENA-STD-BASE-CL340 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 LED CLL03x/CLU03x FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8101-G2 + S-8000-11 LED CLL03x/CLU03x FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 433 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED CLL03x/CLU03x FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED CLL03x/CLU03x FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLL03x/CLU03x FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED CLL04x/CLU04x FWHM / FWTM Asymmetric Efficiency 78 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS LED CLL04x/CLU04x FWHM / FWTM Asymmetric Efficiency 74 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS A.A.G. STUCCHI: 8102-G2 + S-8000-12 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 LED CLL04x/CLU04x FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 431 Typ L3 LED CLL04x/CLU04x FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS IDEAL: 50-2204CT + 50-2100LN Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLL04x/CLU04x FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED CLL04x/CLU04x FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED CLU700/701/702/703 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLU700/701/702/703 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 434 Typ L1 LED CLU710/711 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED CLU710/711 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLU720/721/723 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED CLU720/721/723 FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED CLU720/721/723 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CLU720/721/723 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 433 Typ L1 LED CMA1840 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14146_LENA-STD-BASE-CXA18 LED CMA2550 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CMT14xx FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 434 Typ L1 LED CMT19xx FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED CMT19xx FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 477 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CMT28xx FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 471 Typ L3 LED CMT28xx FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED CXA/B 15xx FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 441 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 441 Typ L1 LED CXA/B 15xx FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13186_LENA-STD-BASE-CXA15 C11996_LENA-LENS LED CXA/B 15xx FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 441 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CXA/B 15xx FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13186_LENA-STD-BASE-CXA15 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14146_LENA-STD-BASE-CXA18 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 437 Typ L1 LED CXA/B 1816 & CXA/B 1820 & CXA 1850 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 437 Typ L1 LED CXA/B 25xx FWHM / FWTM Asymmetric Efficiency 75 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13324_LENA-STD-BASE-CXA25 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CXA2011 FWHM / FWTM Asymmetric Efficiency 79 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12105_LENA-STD-BASE-CXA20 LED CXA2011 FWHM / FWTM Asymmetric Efficiency 75 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12105_LENA-STD-BASE-CXA20 C11996_LENA-LENS LED LUXEON CoB 1202/1203 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 438 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1202/1203 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED LUXEON CoB 1202/1203 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED LUXEON CoB 1204HD FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1205HD FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11981_LENA-STD-BASE-COB-L110 LED LUXEON CoB 1211 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 431 Typ L3 LED LUXEON CoB 1211 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 431 Typ L3 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1213/1216/1812 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED LUXEON CoB 1213/1216/1812 FWHM / FWTM 60.0° / 95.0° Efficiency 81 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED LUXEON CoB 1213/1216/1812 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED LUXEON CoB 1213/1216/1812 FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS A.A.G. STUCCHI: 8102-G2 + S-8000-12 LED LUXEON K12 FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K LED LUXEON K12 FWHM / FWTM Asymmetric Efficiency 77 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED LUXEON K16 FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K LED LUXEON K16 FWHM / FWTM Asymmetric Efficiency 76 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12924_LENA-STD-BASE-LUXEON-K C11996_LENA-LENS LED CDM-14 (Dim-To-Warm) FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 491 Typ L2 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 27/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CDM-14 (Dim-To-Warm) FWHM / FWTM 59.0° / 90.0° Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 LED CDM-18 (Dim-To-Warm) FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 491 Typ L2 LED CDM-18 (Dim-To-Warm) FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 491 Typ L2 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 28/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CDM-9 (Dim-To-Warm) FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 490 Typ L1 LED CDM-9 (Dim-To-Warm) FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 490 Typ L1 LED CTM-14 (Tunable White) FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C12606_LENINA-DL Bender Wirth: 442 Typ L3 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 29/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CTM-14 (Tunable White) FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 LED CTM-18 (Tunable White) FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 442 Typ L3 LED CTM-18 (Tunable White) FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 442 Typ L3 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 30/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CTM-22 (Tunable White) FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 494 Typ L3 LED CTM-22 (Tunable White) FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 494 Typ L3 LED CxM-14 (19x19) FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 31/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED CxM-14 (19x19) FWHM / FWTM Asymmetric Efficiency 82 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED CxM-22 (28x28) FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED CxM-22 (28x28) FWHM / FWTM Asymmetric Efficiency 79 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 32/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED COB J-Type FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 463 Typ L2 LED COB J-Type FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 463 Typ L2 LED COB J-Type FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 463 Typ L2 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 33/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 11) FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED COB L-Type (LES 11) FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED COB L-Type (LES 11) FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 438 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 34/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED COB L-Type (LES 9) FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 438 Typ L1 LED COB L-Type (LES 9) FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 438 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 35/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM Asymmetric Efficiency 83 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 498 Typ L2 LED NVCWJ024Z-V1MT: COB J-Type Tunable White FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 498 Typ L2 LED Soleriq S13 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 437 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 36/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED Soleriq S13 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 437 Typ L1 LED Soleriq S13 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 437 Typ L1 LED Soleriq S19 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 C11996_LENA-LENS Bender Wirth: 462 Typ L3 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 37/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED Soleriq S19 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13867_LENA-STD-BASE-VERO29 Bender Wirth: 462 Typ L3 LED Fortimo SLM L13 CoB FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED Fortimo SLM L13 CoB FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 38/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED Fortimo SLM L15 CoB FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED Fortimo SLM L15 CoB FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS LED Fortimo SLM L19 CoB FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 39/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED Fortimo SLM L19 CoB FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED Fortimo SLM L23 CoB FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED Fortimo SLM L23 CoB FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 40/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED LC016D / LC019D / LC026D / LC033D FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED Mega Zenigata (GW6DME) FWHM / FWTM Asymmetric Efficiency 80 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 41/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED Mega Zenigata (GW6DME) FWHM / FWTM Asymmetric Efficiency 75 % Peak intensity 0.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS LED SLE G7 LES15 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 LED SLE G7 LES17 H FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14547_LENA-ADAPTER-B Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 42/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (MEASURED): LED SLE G7 LES21 H FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C14547_LENA-ADAPTER-B LED XOB 14.5 mm FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 43/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED V10 Gen7 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 486 Typ L1 LED V10 Gen7 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 486 Typ L1 LED V10 Gen7 FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 486 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 44/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 477 Typ L1 LED V13 Gen7 FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS LED V13 Gen7 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 477 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 45/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED V13 Gen7 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2103CT + 50-2100LN LED V13 Gen7 FWHM / FWTM Asymmetric Efficiency 84 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 477 Typ L1 LED CXA/B 30xx FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: IDEAL: 50-2234C + 50-2100LN Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 46/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED CXA/B 30xx FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C11996_LENA-LENS IDEAL: 50-2234C + 50-2100LN LED LUXEON CoB 1204/1205 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS LED LUXEON CoB 1204/1205 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 47/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED LUXEON CoB 1208 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED LUXEON CoB 1208 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS LED CxM-14 (19x19) FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 48/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED CxM-14 (19x19) FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED CxM-14 (19x19) FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED Soleriq S15 FWHM / FWTM Asymmetric Efficiency 88 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 49/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED LC040D / LC060D / LC080D FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12692_LENA-STD-BASE-CLL040 LED ZC12/18 FWHM / FWTM Asymmetric Efficiency % LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 C11996_LENA-LENS LED ZC12/18 FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 Bender Wirth: 433 Typ L1 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 50/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED ZC12/18 FWHM / FWTM Asymmetric Efficiency 85 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED ZC12/18 FWHM / FWTM Asymmetric Efficiency 87 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: C13868_LENA-STD-BASE-VERO13-18 C11996_LENA-LENS Bender Wirth: 433 Typ L1 LED ZC12/18 FWHM / FWTM Asymmetric Efficiency 86 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: C12691_LENA-STD-BASE-CLL030 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 51/53 PRODUCT DATASHEET C12948_LENA-WAS OPTICAL RESULTS (SIMULATED): LED Mega Zenigata (GW5DGC) FWHM / FWTM Asymmetric Efficiency % LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ LED Mega Zenigata (GW5DGC) FWHM / FWTM Asymmetric Efficiency % LEDs/each optic 1 Light colour/type White Required components: C12292_LENA-STD-BASE-MEZ C11996_LENA-LENS Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 52/53 PRODUCT DATASHEET C12948_LENA-WAS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. Due to use of high power COB's with this product, special attention to proper thermal design is highly recommended. LEDiL has no liability for direct, indirect or consecutive damages arising from the LEDiL products being used outside of the recommended temperature range. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 53/53
C12948_LENA-WAS 价格&库存
很抱歉,暂时无法提供与“C12948_LENA-WAS”相匹配的价格&库存,您可以联系我们找货
C12948_LENA-WAS
    C12948_LENA-WAS
    • 56+81.3549656+10.56120
    C12948_LENA-WAS
      • 1+74.10789
      • 6+65.92691
      • 60+59.74626
      库存:56
