C12726_STRADA-SQ-T-DWC
    LEDIL(芬兰)
C12726_STRADA-SQ-T-DWC 数据手册
PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC STRADA-SQ-T-DWC Universal road lighting beam with excellent mixed illuminance and luminance uniformity. Typically IESNA Type III (medium). Version with location pins. SPECIFICATION: Dimensions Height Fastening ROHS compliant 25.0 x 25.0 mm 8 mm glue, pin, screw yes MATERIALS: Component Type Material Colour STRADA-SQ-T-DWC Single lens PMMA clear Finish Length 25.0 ORDERING INFORMATION: Component C12726_STRADA-SQ-T-DWC » Box size: Qty in box MOQ MPQ 294 98 Box weight (kg) 7.9 Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC See also our general installation guide: www.ledil.com/installation_guide Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC OPTICAL RESULTS (MEASURED): LED XHP50 FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XHP50.2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XM-L FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC OPTICAL RESULTS (MEASURED): LED XM-L2 FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-L HD FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC OPTICAL RESULTS (MEASURED): LED XP-L2 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON M/MX FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON MZ FWHM / FWTM Asymmetric Efficiency 90 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC OPTICAL RESULTS (MEASURED): LED NFMW48xA FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NS9x383 FWHM / FWTM Asymmetric Efficiency 91 % LEDs/each optic 1 Light colour/type White Required components: LED PLW7070 FWHM / FWTM Asymmetric Efficiency 94 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC OPTICAL RESULTS (SIMULATED): LED MHB-A/B FWHM / FWTM Asymmetric Efficiency % LEDs/each optic 1 Light colour/type White Required components: LED XHP50.3 HD FWHM / FWTM Asymmetric Efficiency 92 % Peak intensity 0.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON M/MX FWHM / FWTM Asymmetric Efficiency 81 % Peak intensity 0.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC OPTICAL RESULTS (SIMULATED): LED NVSW519A FWHM / FWTM Asymmetric Efficiency 91 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S8 FWHM / FWTM Asymmetric Efficiency 89 % Peak intensity 0.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM Asymmetric Efficiency 94 % LEDs/each optic 1 Light colour/type White Required components: Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC OPTICAL RESULTS (SIMULATED): LED LH181B FWHM / FWTM Asymmetric Efficiency 79 % Peak intensity 0.4 cd/lm LEDs/each optic 4 Light colour/type White Required components: Protective plate, glass LED LH351B FWHM / FWTM Asymmetric Efficiency 93 % Peak intensity 0.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/10 PRODUCT DATASHEET C12726_STRADA-SQ-T-DWC GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 26/04/2024 Subject to change without prior notice Published: 28/04/2020 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/10
C12726_STRADA-SQ-T-DWC 价格&库存
很抱歉,暂时无法提供与“C12726_STRADA-SQ-T-DWC”相匹配的价格&库存,您可以联系我们找货
    • 1+34.895151+4.50177
    • 98+20.2276198+2.60953
    • 196+19.07476196+2.46080
    • 588+17.59721588+2.27019
    • 1078+16.933801078+2.18460
    • 2058+16.325252058+2.10610
    • 5096+15.617415096+2.01478
