CA15231_VERONICA-SQ-MINI-W
    LEDIL(芬兰)
    ASSEMBLYSQUARE1POS13.9+13.9M
CA15231_VERONICA-SQ-MINI-W 数据手册
PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W VERONICA-SQ-MINI-W ~55° wide beam SPECIFICATION: Dimensions Height Fastening ROHS compliant 13.9 x 13.9 mm 8.9 mm tape, pin yes MATERIALS: Component Type Material Colour VERONICA-SQ-MINI-W Single lens PMMA clear VERONICA-SQ-MINI-TAPE Tape Acrylic foam clear Finish ORDERING INFORMATION: Component CA15231_VERONICA-SQ-MINI-W » Box size: 480 x 280 x 300 mm Single lens Qty in box MOQ MPQ 5544 252 252 Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 8.6 1/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W See also our general installation guide: www.ledil.com/installation_guide Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W OPTICAL RESULTS (MEASURED): LED XP-G2 FWHM / FWTM 56.8° / 87.5° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-G3 FWHM / FWTM 49.0° / 89.0° Efficiency 94 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NCSxE17A FWHM / FWTM 28.0° / 65.0° Efficiency 91 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 50.0° / 85.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W OPTICAL RESULTS (MEASURED): LED Duris S5 (2 chip) FWHM / FWTM 34.0° / 69.0° Efficiency 82 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED SFH 4170S FWHM / FWTM 31.0° / 72.0° Efficiency % LEDs/each optic 1 Light colour IR Required components: LED SFH 4180S FWHM / FWTM 30.0° / 72.0° Efficiency % LEDs/each optic 1 Light colour IR Required components: LED LH181A FWHM / FWTM 32.0° / 68.0° Efficiency 89 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W OPTICAL RESULTS (MEASURED): LED LH181B FWHM / FWTM 37.0° / 71.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22P FWHM / FWTM 46.0° / 82.0° Efficiency 92 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W OPTICAL RESULTS (SIMULATED): LED J Series 3030 FWHM / FWTM 38.0° / 72.0° Efficiency 96 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour White Required components: LED XP-E2 FWHM / FWTM 66.0° / 84.0° Efficiency 96 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour White Required components: LED XQ-E HD FWHM / FWTM 48.0° / 76.0° Efficiency 96 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON 2835 Line FWHM / FWTM 41.0° / 74.0° Efficiency 96 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour PC Amber Required components: Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W OPTICAL RESULTS (SIMULATED): LED LUXEON HL1Z FWHM / FWTM 26.0° / 64.0° Efficiency 95 % Peak intensity 2.7 cd/lm LEDs/each optic 1 Light colour White Required components: LED LUXEON HL2X FWHM / FWTM 68.0° / 89.0° Efficiency 96 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED NVSxE21A FWHM / FWTM 34.0° / 68.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 57.0° / 80.0° Efficiency 97 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W OPTICAL RESULTS (SIMULATED): LED LH351B FWHM / FWTM 65.0° / 90.0° Efficiency 94 % Peak intensity 0.9 cd/lm LEDs/each optic 1 Light colour White Required components: LED Z8Y22T FWHM / FWTM 41.0° / 72.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour White Required components: Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/9 PRODUCT DATASHEET CA15231_VERONICA-SQ-MINI-W GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 24/11/2023 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/9
物料型号: CA15231_VERONICA-SQ-MINI-W
器件简介: - 产品名称:VERONICA-SQ-MINI-W - 光束角度:约55°宽光束 - 尺寸:13.9 x 13.9 mm - 高度:8.9 mm - 固定方式:胶带、引脚 - 符合ROHS标准
引脚分配: - 正面视图和等轴视图展示了引脚位置,但具体引脚分配未在文档中详细说明。
参数特性: - 使用了不同品牌的LED,包括CREE、NICHIA、OSRAM、SAMSUNG等,具有不同的发光角度、效率和峰值强度。
功能详解: - 提供了光学测试结果,包括实际测量和模拟的光束角度、效率和峰值强度。 - 涉及的LED型号有CREE XP-G2、XP-G3、NICHIA NCSxE17A、NVSxx19B/NVSxx19C、OSRAM Duris S5 (2 chip)、SFH 4170S、SFH 4180S、SAMSUNG LH181A、LH181B、E OCTO LED Z8Y22P等。
应用信息: - 适用于需要宽光束照明的应用。
封装信息: - 组件类型材料:VERONICA-SQ-MINI-W为单透镜PMMA材料,颜色为透明。 - 胶带材料:VERONICA-SQ-MINI-TAPE为丙烯酸泡沫胶带,颜色为透明。
订购信息: - 组件数量:每箱5544个 - 最小订购量:252 - 每箱重量:8.6公斤
其他信息: - LEDiL是LEDiL Oy在欧盟、美国和某些其他国家的注册商标。 - 文件最后更新日期为2023年11月24日,并且可能会在不提前通知的情况下进行更改。
CA15231_VERONICA-SQ-MINI-W 价格&库存
很抱歉,暂时无法提供与“CA15231_VERONICA-SQ-MINI-W”相匹配的价格&库存,您可以联系我们找货
