C15430_STRADELLA-16-HB-S
    LEDIL(芬兰)
C15430_STRADELLA-16-HB-S 数据手册
PRODUCT DATASHEET C15430_STRADELLA-16-HB-S STRADELLA-16-HB-S ~25° spot beam for industrial applications SPECIFICATION: Dimensions Height Fastening ROHS compliant 49.5 x 49.5 7.5 mm pin, screw yes MATERIALS: Component Type Material Colour STRADELLA-16-HB-S Multi-lens PMMA clear Finish Length 49.5 ORDERING INFORMATION: Component C15430_STRADELLA-16-HB-S » Box size: 480 x 280 x 300 mm Qty in box 800 MOQ MPQ 160 160 Box weight (kg) 6.1 Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 1/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S See also our general installation guide: www.ledil.com/installation_guide Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (MEASURED): LED J Series 3030 FWHM / FWTM 29.0° / 86.0° Efficiency 91 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED EHP-223.5x50-1604-xx-70-LS30-06-NTC FWHM / FWTM 30.0° / 95.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NFSx757D FWHM / FWTM 25.0° / 78.0° Efficiency 90 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (MEASURED): LED NFSx757G FWHM / FWTM 27.0° / 80.0° Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW219D FWHM / FWTM 32.0° / 83.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW319B FWHM / FWTM 37.0° / 97.0° Efficiency 93 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (MEASURED): LED PrevaLED Brick MP 4x16 FWHM / FWTM 30.0° / 92.0° Efficiency 92 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Duris S5 (2 chip) FWHM / FWTM 27.0° / 83.0° Efficiency 92 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type Purple Required components: LED Duris S5 (Single chip) FWHM / FWTM 23.0° / 72.0° Efficiency 90 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (MEASURED): LED OSCONIQ S 3030 (QSLR31) FWHM / FWTM 28.0° / 82.0° Efficiency 91 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Fortimo FastFlex LED 4x16 DHE G4 FWHM / FWTM 29.0° / 88.0° Efficiency 92 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED HiLOM RM64 (LM301B) FWHM / FWTM 30.0° / 92.0° Efficiency 93 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (MEASURED): LED LM231 A/B FWHM / FWTM 22.0° / 70.0° Efficiency 91 % Peak intensity 2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XLE-S44XTEHE (XT-E HE) FWHM / FWTM 29.0° / 89.0° Efficiency 92 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED SEOUL 3030 FWHM / FWTM 26.0° / 78.0° Efficiency 90 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (MEASURED): LED SEOUL DC 3030 FWHM / FWTM 24.0° / 75.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z5M3 FWHM / FWTM 33.0° / 100.0° Efficiency 94 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED RLE 4x16 4000lm MP ADV2 OTD FWHM / FWTM 29.0° / 89.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (MEASURED): LED RLE 4x8 2000lm MP ADV2 OTD FWHM / FWTM 29.0° / 89.0° Efficiency 93 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED Bridgelux SMD 2835 FWHM / FWTM 31.0° / 81.0° Efficiency 94 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CSP 2727 (BXCP) FWHM / FWTM 28.0° / 80.0 + 78.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED CSP 2727 (BXCP) FWHM / FWTM 28.0° / 80.0 + 78.0° Efficiency 84 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED J Series 2835 FWHM / FWTM 28.0° / 77.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED J Series 3030C FWHM / FWTM 30.0° / 80.0° Efficiency 94 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 HE FWHM / FWTM 46.0° / 90.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED XP-G3 FWHM / FWTM 37.0° / 95.0° Efficiency 91 % Peak intensity 1.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XT-E FWHM / FWTM 28.0° / 82.0° Efficiency 91 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 2835 Line FWHM / FWTM 30.0° / 78.0° Efficiency 85 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LUXEON 2835 Line FWHM / FWTM 28.0° / 78.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 3030 HE Plus FWHM / FWTM 32.0° / 82.0° Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 3535L HE PLUS FWHM / FWTM 30.0° / 80.0° Efficiency 86 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LUXEON C FWHM / FWTM 25.0° / 105.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type RGBW Required components: LED LUXEON C FWHM / FWTM 25.0° / 107.0° Efficiency 90 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type Green Required components: LED LUXEON C FWHM / FWTM 25.0° / 104.0° Efficiency 91 % Peak intensity 1.4 cd/lm LEDs/each optic 1 Light colour/type Blue Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 14/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LUXEON C FWHM / FWTM 25.0° / 96.0° Efficiency 91 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 23.0° / 70.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type RGBW Required components: LED LUXEON CZ FWHM / FWTM 22.0° / 67.0° Efficiency 94 % Peak intensity 2.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 15/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LUXEON HL1Z FWHM / FWTM 18.0° / 62.0° Efficiency 94 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NCSxE17A FWHM / FWTM 22.0° / 69.0° Efficiency 91 % Peak intensity 2.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NFSWE11A FWHM / FWTM 16.0° / 56.0° Efficiency 90 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 16/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED NVSW219D FWHM / FWTM 34.0° / 80.0° Efficiency 93 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSW519A FWHM / FWTM 43.0° / 95.0° Efficiency 90 % Peak intensity 1.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxE21A FWHM / FWTM 25.0° / 74.0° Efficiency 92 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 17/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED Duris E5 FWHM / FWTM 30.0° / 80.0° Efficiency 93 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 2424 FWHM / FWTM 26.0° / 73.0° Efficiency 93 % Peak intensity 2.1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ C 3030 FWHM / FWTM 28.0° / 78.0° Efficiency 86 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 18/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED OSCONIQ C 3030 FWHM / FWTM 28.0° / 78.0° Efficiency 94 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3030 FWHM / FWTM 22.0° / 60.0° Efficiency 94 % Peak intensity 2.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3737 (3W version) FWHM / FWTM 36.0 + 34.0° / 88.0 + 87.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 19/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED OSLON Pure 1414 FWHM / FWTM 18.0° / 58.0° Efficiency 95 % Peak intensity 3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 32.0° / 87.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type Red Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 25.0° / 74.0° Efficiency 94 % Peak intensity 2.2 cd/lm LEDs/each optic 1 Light colour/type Far Red Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 20/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LH231B FWHM / FWTM 31.0° / 80.0° Efficiency 83 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LH231B FWHM / FWTM 31.0° / 82.0° Efficiency 91 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351B FWHM / FWTM 33.0° / 83.0° Efficiency 94 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 21/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LH351C FWHM / FWTM 37.0° / 87.0° Efficiency 94 % Peak intensity 1.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LH351D FWHM / FWTM 44.0° / 93.0° Efficiency 93 % Peak intensity 1.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LM301B FWHM / FWTM 28.0° / 76.0° Efficiency 87 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 22/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LM301B FWHM / FWTM 27.0° / 78.0° Efficiency 93 % Peak intensity 1.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LM301B FWHM / FWTM 30.0° / 78.0° Efficiency 86 % Peak intensity 1.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED LM302D FWHM / FWTM 29.0° / 79.0° Efficiency 93 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 23/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED LM302Z plus FWHM / FWTM 30.0° / 80.0° Efficiency 93 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LM302Z plus FWHM / FWTM 30.0° / 82.0° Efficiency 87 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Protective plate, glass LED SEOUL DC 3030C FWHM / FWTM 30.0° / 80.0° Efficiency 93 % Peak intensity 1.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 24/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S OPTICAL RESULTS (SIMULATED): LED SEOUL DC 5050 6V FWHM / FWTM 45.0° / 100.0° Efficiency 91 % Peak intensity 1 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED Z8Y22T FWHM / FWTM 31.0° / 82.0° Efficiency 93 % Peak intensity 1.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 25/26 PRODUCT DATASHEET C15430_STRADELLA-16-HB-S GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Salo, Finland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 25/03/2024 Subject to change without prior notice Published: 07/03/2019 LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 26/26
C15430_STRADELLA-16-HB-S 价格&库存
很抱歉,暂时无法提供与“C15430_STRADELLA-16-HB-S”相匹配的价格&库存,您可以联系我们找货
  • 1+18.23052
  • 10+16.27810
  • 50+15.25997
  • 160+14.22986
库存:160
  • 1+19.620461+2.53120
  • 10+17.5182610+2.26000
  • 50+16.3795850+2.11310
  • 160+15.32848160+1.97750
库存:160
      • 1+34.793311+4.48863
      • 10+25.5415010+3.29507
      • 160+19.29631160+2.48939
      • 640+17.40805640+2.24578
      • 1120+16.806701120+2.16821
      • 2080+16.229472080+2.09374
      • 5120+15.530015120+2.00350
