C12479_MIRELLA-DL
C12479_MIRELLA-DL
    LEDIL(芬兰)
C12479_MIRELLA-DL 数据手册
PRODUCT DATASHEET Mirella series last update 19/9/2014 DETAILS Product Number C12479_MIRELLA-DL Family Mirella Type Lens Color clear Diameter 41 mm Height 3.4 mm Style round Optic Material PC Holder Material Fastening Status ready ROHS Comliant Yes Date Updated 19/09/2014 OPTICAL PROPERTIES LED Viewing Angle N/A degrees Light Beam Efficiency cd/lm connector - (simulated) 0.000 - September 22nd 2014 9:41 Copyright Ledil Oy - Subject to change without prior notice - Page 1/1 Ledil Oy Salorankatu 10 24240 SALO Finland http://www.ledil.com email: ledil@ledil.com FAX: +358-2-733 8001 C D E F G H 1.16 3.4 4 5.37 3 Front view 4 3 0. 4 8 7 1. 6 2 Isometric view Bottom view INDEX P 1 C Tolerances if not otherwise shown According to DIN ISO 2768-1 Linear measures: class M According to DIN ISO 2768-2 Form and position: class L THIRD ANGLE PROJECTION: 1 This drawing is the property of LEDiL Oy. It may not be reproduced, copied or communicated without a written agreement with LEDiL Oy. DRAWI SIZE A3 SCALE H G NOTE: The typical divergence will be changed by different color, chip size and chip position tolerance. The typical total divergence is the full angle measured where the luminous intensity is half of the peak value.
C12479_MIRELLA-DL 价格&库存
很抱歉,暂时无法提供与“C12479_MIRELLA-DL”相匹配的价格&库存,您可以联系我们找货
C12479_MIRELLA-DL
  • 28+10.9827528+1.42265
C12479_MIRELLA-DL
