CA11929_LR2-RS
CA11929_LR2-RS
    LEDIL(芬兰)
    LENS ASSY 1POS 21.6MM RND 14.3MM
CA11929_LR2-RS 数据手册
PRODUCT DATASHEET CA11929_LR2-RS LR2-RS ~9.6° spot beam optimized for LUXEON Rebel ES. 14.8 mm high assembly with installation tape. SPECIFICATION: Dimensions Ø 21.6 mm Height 14.8 mm Fastening tape, pin ROHS compliant yes MATERIALS: Component Type Material Colour Finish Length LXP2-RS Single lens PMMA clear 21.6 LR2-ES-LH1-HLD Holder PC white 21.6 HEIDI-TAPE Tape Acrylic foam black ORDERING INFORMATION: Component CA11929_LR2-RS » Box size: 480 x 280 x 300 mm Qty in box MOQ MPQ 1680 336 112 Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. Box weight (kg) 9.3 1/13 PRODUCT DATASHEET CA11929_LR2-RS See also our general installation guide: www.ledil.com/installation_guide Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 2/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (MEASURED): LED XP-L HD FWHM / FWTM 16.0° / 31.0° Efficiency 91 % Peak intensity 8.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Rebel ES FWHM / FWTM 11.0° Efficiency 94 % LEDs/each optic 1 Light colour/type White Required components: LED LUXEON T FWHM / FWTM 12.0° / 23.0° Efficiency 91 % Peak intensity 12.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 3/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (MEASURED): LED LUXEON TX FWHM / FWTM 11.0° / 23.0° Efficiency 91 % Peak intensity 15.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON Z ES FWHM / FWTM 6.0° / 16.0° Efficiency 91 % Peak intensity 38.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NVSxx19B/NVSxx19C FWHM / FWTM 11.0° / 23.0° Efficiency 94 % Peak intensity 16 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 4/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (MEASURED): LED OSLON Square EC FWHM / FWTM 10.0° / 22.0° Efficiency 92 % Peak intensity 17.6 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED PLPVEC2 850A FWHM / FWTM 5.0° / 12.0° Efficiency % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 5/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (SIMULATED): LED J Series 5050 Round LES FWHM / FWTM 18.0° / 41.0° Efficiency 95 % Peak intensity 5.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XD16 FWHM / FWTM 8.0° / 18.0° Efficiency 91 % Peak intensity 22.8 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XP-G2 FWHM / FWTM 10.0° / 20.0° Efficiency 95 % Peak intensity 22.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 6/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (SIMULATED): LED XP-G3 FWHM / FWTM 12.0° / 24.0° Efficiency 94 % Peak intensity 15.2 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HD FWHM / FWTM 7.0° / 15.0° Efficiency 92 % Peak intensity 39 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED XQ-E HI FWHM / FWTM 6.0° / 14.0° Efficiency 93 % Peak intensity 47.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 7/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (SIMULATED): LED LUXEON 5050 Round LES FWHM / FWTM 18.0° / 41.0° Efficiency 96 % Peak intensity 5.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON 5050 Square LES FWHM / FWTM 18.0° / 40.0° Efficiency 97 % Peak intensity 5.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON CZ FWHM / FWTM 6.0° / 14.0° Efficiency 95 % Peak intensity 53 cd/lm LEDs/each optic 1 Light colour/type Red Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 8/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (SIMULATED): LED LUXEON H50-2 FWHM / FWTM 10.5° / 22.0° Efficiency 93 % Peak intensity 17.7 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON HL2X FWHM / FWTM 12.0° / 24.0° Efficiency 94 % Peak intensity 15.9 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON IR Domed 60 (L1I0-0xxx060000000) FWHM / FWTM 8.0° / 20.0° Efficiency 92 % LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 9/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (SIMULATED): LED LUXEON MZ FWHM / FWTM 16.0° / 34.0° Efficiency 95 % Peak intensity 7.4 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED LUXEON V2 FWHM / FWTM 11.0° / 24.0° Efficiency 94 % Peak intensity 16.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED NV4WB35AM FWHM / FWTM 16.0° / 34.0° Efficiency 96 % Peak intensity 8.3 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 10/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (SIMULATED): LED OSCONIQ C 2424 FWHM / FWTM 8.0° / 20.0° Efficiency 95 % Peak intensity 24 cd/lm LEDs/each optic 1 Light colour/type White Required components: LED OSCONIQ P 3030 FWHM / FWTM 8.0° / 18.0° Efficiency 94 % Peak intensity 27.8 cd/lm LEDs/each optic 1 Light colour/type Blue Required components: LED OSLON Square CSSRM2/CSSRM3 FWHM / FWTM 10.0° / 20.0° Efficiency 95 % Peak intensity 22.5 cd/lm LEDs/each optic 1 Light colour/type White Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 11/13 PRODUCT DATASHEET CA11929_LR2-RS OPTICAL RESULTS (SIMULATED): LED OSLON SSL 120 FWHM / FWTM 8.0° / 16.0° Efficiency 95 % Peak intensity 33 cd/lm LEDs/each optic 1 Light colour/type Amber Required components: LED SFH 4715AS FWHM / FWTM 6.0° / 19.0° Efficiency 94 % LEDs/each optic 1 Light colour/type IR Required components: LED SFH 4770S FWHM / FWTM 8.0° / 18.0° Efficiency 95 % Peak intensity 29.9 cd/lm LEDs/each optic 1 Light colour/type IR Required components: Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 12/13 PRODUCT DATASHEET CA11929_LR2-RS GENERAL INFORMATION: NOTE: The typical beam angle will be changed by different color, chip size and chip position tolerance. The typical total beam angle is the full angle measured where the luminous intensity is half of the peak value. MATERIALS: As part of our continuous research and improvement processes, and to ensure the best possible quality and availability of our products, LEDiL reserves the right to change material grades without notice. PRODUCT DATA USER AGREEMENT AND DISCLAIMER: The measured data in the provided downloadable LEDiL Product Datasheets and Mechanical 2D-Drawings is rounded and provided as reference for planning. LEDiL Oy's optical specifications have been verified by conducting performance testing of the products in accordance with the company's quality system. The reported data are averaged results of multiple measurements with typical variation. LEDiL Oy reserves the right to without prior notification make changes and improvements to its products. LEDiL Oy assumes neither warranty, nor guarantee nor any other liability of any kind for the contents and correctness of the provided data. The provided data has been generated with highest diligence but the provided data may in reality not represent the complete possible variation range of all intrinsic parameters. Therefore, in certain cases a deviation from the provided data could occur. LEDiL Oy Joensuunkatu 13 FI-24240 SALO Finland LEDiL Inc. 228 West Page Street Suite D Sycamore IL 60178 USA Ledil Optics Technology (Shenzhen) Co., Ltd. # 405 , Block B Casic Motor Building Shenzhen 518057 P.R.CHINA Local sales and technical support www.ledil.com/ where_to_buy Shipping locations Poznan, Poland Hong Kong, China Distribution Partners www.ledil.com/ where_to_buy LEDiL Oy reserves the right to undertake technical changes of its products without further notification which could lead to changes in the provided data. LEDiL Oy assumes no liability of any kind for the possible deviation from any provided data or any other damage resulting from the usage of the provided data. The user agrees to this disclaimer and user agreement with the download or usage of the provided files. Last update: 13/05/2024 Subject to change without prior notice LEDiL is a registered trademark of LEDiL Oy in the European Union, USA, and certain other countries. 13/13
CA11929_LR2-RS 价格&库存
很抱歉,暂时无法提供与“CA11929_LR2-RS”相匹配的价格&库存,您可以联系我们找货
CA11929_LR2-RS
  • 1+18.743471+2.35040
  • 112+15.04885112+1.88710
  • 336+14.14772336+1.77410
  • 560+13.24659560+1.66110
CA11929_LR2-RS
  • 10+13.3662110+1.67610
  • 25+13.1891725+1.65390
  • 50+13.1006650+1.64280
  • 150+12.92362150+1.62060
  • 300+12.56955300+1.57620
CA11929_LR2-RS
  • 112+9.20587112+1.15440
  • 336+9.02883336+1.13220
  • 448+8.94031448+1.12110
  • 1120+8.719021120+1.09335
  • 1680+8.541981680+1.07115
CA11929_LR2-RS
  • 10+10.6221510+1.33200
  • 40+10.4451240+1.30980
  • 150+10.26808150+1.28760
  • 400+10.17956400+1.27650
  • 1500+9.914011500+1.24320
